httpmod XML vs. JSON
Begonnen von Wolfgang Hochweller, 27 April 2021, 10:32:54
Wolfgang Hochweller
httpmod unterstuetzt XPath um  XML-Dateien zu interpretieren.
Gibt es das vergleichbare auch fuer JSON-Dateien ?
Ich weiss, dass es z. B. jsonpath gibt, aber im WIKI von httpmod finde ich wenig ueber eine moegliche Syntax fuer komplexere Abfragen bzw. Zuweisung eines Readings bei json.
Kann ich mich irgendwo informieren ?
Ein Beispiel :
"type": "Feature",
"geometry": {
"type": "Point",
"coordinates": [
5.6206,
58.9987,
29
"properties": {
"meta": {
"updated_at": "2021-04-27T07:55:35Z",
"units": {
"air_pressure_at_sea_level": "hPa",
"air_temperature": "celsius",
"air_temperature_max": "celsius",
"air_temperature_min": "celsius",
"cloud_area_fraction": "%",
"cloud_area_fraction_high": "%",
"cloud_area_fraction_low": "%",
"cloud_area_fraction_medium": "%",
"dew_point_temperature": "celsius",
"fog_area_fraction": "%",
"precipitation_amount": "mm",
"precipitation_amount_max": "mm",
"precipitation_amount_min": "mm",
"probability_of_precipitation": "%",
"probability_of_thunder": "%",
"relative_humidity": "%",
"ultraviolet_index_clear_sky": "1",
"wind_from_direction": "degrees",
"wind_speed": "m/s",
"wind_speed_of_gust": "m/s"
"timeseries": [
"time": "2021-04-27T08:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1018,
"air_temperature": 6.9,
"cloud_area_fraction": 8.8,
"cloud_area_fraction_high": 7.8,
"cloud_area_fraction_low": 0,
"cloud_area_fraction_medium": 1.1,
"dew_point_temperature": 0.7,
"fog_area_fraction": 0,
"relative_humidity": 65.5,
"ultraviolet_index_clear_sky": 1.6,
"wind_from_direction": 327,
"wind_speed": 0.9,
"wind_speed_of_gust": 3.2
"next_12_hours": {
"summary": {
"symbol_code": "partlycloudy_day",
"symbol_confidence": "certain"
"details": {
"probability_of_precipitation": 0
"next_1_hours": {
"summary": {
"symbol_code": "fair_day"
"details": {
"precipitation_amount": 0,
"precipitation_amount_max": 0,
"precipitation_amount_min": 0,
"probability_of_precipitation": 0.6,
"probability_of_thunder": 0
"next_6_hours": {
"summary": {
"details": {
"air_temperature_max": 9.5,
"air_temperature_min": 7.8,
"time": "2021-04-27T09:00:00Z",
"data": {
"instant": {
"details": {
"air_temperature": 7.8,
"cloud_area_fraction": 25.2,
"cloud_area_fraction_high": 25,
"cloud_area_fraction_low": 0.2,
"cloud_area_fraction_medium": 0,
"dew_point_temperature": 1.6,
"relative_humidity": 65.7,
"ultraviolet_index_clear_sky": 2.3,
"wind_from_direction": 312.4,
"wind_speed": 2.1,
"wind_speed_of_gust": 4.7
"next_12_hours": {
"summary": {
"details": {
"next_1_hours": {
"summary": {
"details": {
"probability_of_precipitation": 0,
"next_6_hours": {
"summary": {
"details": {
"air_temperature_min": 8.6,
Die einzelnen Bloecke, etwa
"time": "2021-04-27T11:00:00Z",
"data": {
"instant": {
"details": {
unterscheiden sich nur im Datum.
Wie kann ich jetzt das erste, zweite oder auch 10. Auftreten eines Elements heraussuchen, unabhaengig vom Datum ?
Mit XML und XPath weiss ich das, aber mit JSON komme ich so nicht weiter.
Das Beispiel in der Dokumentation :
reading[0-9]+JSON
defines a path to the JSON object wanted by concatenating the object names with an underscore as delimiter (see the example below)
verstehe ich, die Frage ist, welche komplexeren Operation kann ich da reinlegen ( wenn ueberhaupt ) ?
Etwa, wie finde ich Bloecke, die zu 12 Uhr mittags gehoeren und nur die ?
Es gibt ein JsonMod, das in Automation behandelt wird.
Leider ist sie nicht in MAINTAINER.txt eingetragen :(
Wolfgang Hochweller
Danke, muss ich probieren.
Der Wetterbericht, der mir diese Daten liefert, hat schon angekuendigt, die XML-Version irgendwann einzustellen.
Wolfgang Hochweller
Das gibt eine Menge 'try and error '......
Bei obigem Beispiel gibt das hier ein Ergebnis :
single(jsonPath('$..time'), 'time0', 'default value');
das hier aber nicht :
single(jsonPath('$..time[1]'), 'time0', 'default value');
Ersteres liefert mir den Wert des erste 'time'-Eintrags,
letzteres sollte nach meinem Verstaendnis den Wert des 2. 'time'-Eintrags liefern.
Tut es aber nicht, was sicher an mir liegt.
yersinia
#4
Zitat von: Wolfgang Hochweller am 27 April 2021, 12:36:44das hier aber nicht :
Nope, das ist schlicht (noch) nicht implementiert.
ZitatHerausfiltern von spezifischen Array-Elementen (Thread & Thread)
[98_JsonMod.pm] Wunschliste von neuen Funktionen
Edit: ich sehe gerade, dass es bei dir anders gelagert sein könnte; versuche mal:
single(jsonPath('$.timeseries.[1]'), 'time0', 'default value');
viele Grüße, yersinia
FHEM 6.5 (SVN) on RPi 4B with RasPi OS Trixie (perl 5.40.1) | FTUI
Wolfgang Hochweller
Danke, geht aber auch nicht.
Denke, alles, was
  • benutzt, geht noch nicht.
    Das Problem liegt eher an meiner Annahme bzgl. JSONPath.
    Ich habe natuerlich versucht, herauszufinden, was es mit JSONPath auf sich hat, dann stoesst man schnell auf eine
    Bibliothek :  jasonpath.js
    Und habe die Beispiele dazu versucht, anzuwenden.
herrmannj
am besten dort lernen: https://goessner.net/articles/JsonPath/
Im Netz gibt es diverse tools bei denen Du Dein JSON reinkopierst und die query online und direkt testen kannst (google: jsonpath tester)
Array literal ".[1]" wird von JsonMod unterstützt, Array indirekt ".[-1]" etc nicht
Wolfgang Hochweller
#7
Danke, mache ich gerade.
Gibt es die umgekehrte Richtung auch irgendwo ?
Ich markiere ein Element und bekomme die Pfadbeschreibung ?
Gefunden !
yersinia
Aus reiner Neugier, was hat denn jetzt eigentlich zum Erfolg geführt?
single(jsonPath('$.timeseries[1]'), 'time0', 'default value');
single(jsonPath('$..times.[1]'), 'time0', 'default value');
single(jsonPath('$..times[1]'), 'time0', 'default value');
Wolfgang Hochweller
Das hier geht :
single(jsonPath('$.properties.timeseries[0].time'), 'time', 'time0');
egal ob
  • oder eine andere Zahl.
    Grenzen gehen aber nicht, jedenfalls nicht so :
    single(jsonPath('$.properties.timeseries[0:2].time'), 'time', 'time0');
    Ich habe jetzt bei meinen Versuchen sowohl einen Pathfinder als auch Pathchecker verwendet, funktioniert prinzipiell prima.
    Im Vergleich zu XML sind die Ergebnisse aber noch ernuechternd :
    Es passiert eigentlich alles, was passieren koennte :
    Pathfinder geht nicht, dann geht auch jsonmod nicht :    war zu erwarten
    Pathfinder geht, aber nicht jsonmod   :     Nicht vewunderlich, daran wird ja noch gearbeitet.
    Pathfinder geht nicht, obwohl ich meine, dass es funktionieren muesste :
    Beispiel :
    Das geht in Pathfinder, generiert aber einen Fehler in jsonmod:
    $.properties.timeseries[?(@.time == '2021-04-27T15:00:00Z')].time
    das geht weder in Pathfinder noch in jsonmod :
    $.properties.timeseries[?( '15:00:00' in @.time )].time
    oder
    $.properties.timeseries[?( @.time contains '15:00:00' )].time
    Dafuer geht das hier in Pathfinder, aber man muss FHEM neu starten, wenn man das in jsonmod versucht:
    $.properties.timeseries[?(/15:00:00/ .test (@.time ))].time
herrmannj
poste (oder schicke) doch bitte einmal ein komplettes JSON.
ZitatGrenzen gehen aber nicht
Das ist ok ((noch) nicht implementiert).
Das soll auch nicht gehen. Allerdings werte ich es als BUG wenn da ein Neustart fällig wird. Das muss ich mir mit Deinem JSON mal nachstellen und anschauen.
Als ich JsonMod geschrieben habe, gab es keine JSONPath lib für perl und ich habe (musste) das komplett implementieren. Referenz für mich ist Goessner, aber es gibt diverse Varianten "in the wild". Der Syntax ist nicht komplett implementiert sondern die 80% die für 98% der Anwendungen ausreichen. Arrays vervollständige ich noch (bei Gelegenheit) - Script Filter und logische Operatoren werden beliebig komplex, dafür müsste man lexer und parser implementieren (da fehlt mir Kosten/Nutzen)
Schick mal das JSON (gern nochmal mit der Erklärung was genau in die Readings soll) dann schau ich mir das an.
vg, joerg
Wolfgang Hochweller
#11
Klar, hier ist ein Beispiel :
"type": "Feature",
"geometry": {
"type": "Point",
"coordinates": [
5.6206,
58.9987,
29
"properties": {
"meta": {
"updated_at": "2021-04-27T13:57:45Z",
"units": {
"wind_speed": "m/s"
"timeseries": [
"time": "2021-04-27T14:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1017.5,
"air_temperature": 10.3,
"cloud_area_fraction": 20.1,
"relative_humidity": 58.2,
"wind_from_direction": 293.6,
"wind_speed": 4.9
"next_12_hours": {
"summary": {
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
"time": "2021-04-27T15:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1017.1,
"cloud_area_fraction": 63.5,
"relative_humidity": 57.9,
"wind_from_direction": 299.2,
"wind_speed": 5.4
"next_12_hours": {
"summary": {
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
"time": "2021-04-27T16:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1016.7,
"air_temperature": 9.8,
"cloud_area_fraction": 91.3,
"relative_humidity": 61.1,
"wind_from_direction": 305.5,
"wind_speed": 5.5
"next_12_hours": {
"summary": {
"symbol_code": "clearsky_day"
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
"time": "2021-04-27T17:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1016.3,
"air_temperature": 9.3,
"cloud_area_fraction": 80.7,
"relative_humidity": 59.8,
"wind_from_direction": 310.2,
"wind_speed": 5
"next_12_hours": {
"summary": {
"symbol_code": "clearsky_night"
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
"time": "2021-04-27T18:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1016.1,
"air_temperature": 8.7,
"cloud_area_fraction": 36.1,
"relative_humidity": 60.9,
"wind_from_direction": 316.9,
"wind_speed": 4.7
"next_12_hours": {
"summary": {
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
"time": "2021-04-27T19:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1016,
"air_temperature": 7.9,
"cloud_area_fraction": 10.5,
"relative_humidity": 69.4,
"wind_from_direction": 320.1,
"wind_speed": 3.6
"next_12_hours": {
"summary": {
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
"time": "2021-04-27T20:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1015.9,
"air_temperature": 7,
"cloud_area_fraction": 4.4,
"relative_humidity": 76.4,
"wind_from_direction": 326,
"wind_speed": 3.4
"next_12_hours": {
"summary": {
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
"time": "2021-04-27T21:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1015.8,
"air_temperature": 6.1,
"cloud_area_fraction": 2,
"relative_humidity": 88.1,
"wind_from_direction": 331.8,
"wind_speed": 2.7
"next_12_hours": {
"summary": {
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
"time": "2021-04-27T22:00:00Z",
"data": {
"instant": {
"details": {
"air_pressure_at_sea_level": 1015.7,
"air_temperature": 4.9,
"cloud_area_fraction": 3.9,
"relative_humidity": 92.3,
"wind_from_direction": 327.6,
"wind_speed": 2.2
"next_12_hours": {
"summary": {
"next_1_hours": {
"summary": {
"details": {
"next_6_hours": {
"summary": {
"details": {
https://jsonpath.herokuapp.com/
ist eine interessante Seite zum Checken.
Vier verschiedene Patchchecker, die Resultate sind schon verblueffend.
In dem Beispiel taucht jeder Zeitstempel genau einmal auf, kann man ja mal aendern.
Die Logik fuer die Readings , z. B.
ein Reading fuer jedes  'data.instant.details.air_temperature', wenn der Zeitstempel 12:00:00 enthaelt.
Das entspricht  dann jeweils der Mittagstemperatur fuer die kommenden Tage.
Also , erstes Auftreten waere die Temperatur heute ( oder morgen , je nachdem, wann man fragt ), das naechste der Tag danach, usw.
herrmannj
Welche readings sollen erzeugt werden?
Wolfgang Hochweller
#13
Ich war noch am aendern .....
Reicht die Erklaerung oben ?
Einen kompletten Datensatz bekommt man unter :
https://api.met.no/weatherapi/locationforecast/2.0/compact?lat=58.9987&lon=5.62055
herrmannj
#14
JsonMod kann sehr viel - aber nicht alles und das ist auch ok:). Das hier ist ein Grenzfall.
Der Reihe nach:
Die Daten die Du suchst sind innerhalb der JSON Source als Array/Liste organisiert. Daher ist die readingList ein multi()
Der JsonPath '$.properties.timeseries.[*]' löst auf das gesuchte Array auf.
Testweise die Zeit als Reading Name: property('time') und die Temperatur als Value: property('data.instant.details.air_temperature').
Die readingList
multi(jsonPath('$.properties.timeseries.[*]'), property('time'), property('data.instant.details.air_temperature'));
ergibt:
Readings
2021-04-28T200000Z   7.1
2021-04-28T210000Z   5.8
2021-04-28T220000Z   5.1
Jetzt zum Problem: Du möchtest _nur_ die Werte wo der Zeitstempel 12:00:00Z _enthält_. Das braucht einen Filter, allerdings passt keiner der zur Verfügung stehenden Filter (>,=,<, 'in' ...). Du bräuchtest ein 'enthält' oder 'endet auf' etc. Da gibt es nichts passendes. Da ich nicht ausschließen möchte, dass es innerhalb der kommenden 25 Jahre einen weiteren Anwendungsfall dafür geben könnte, habe ich einen regex operator (=~) eingebaut.
Der JsonPath mit Filter sieht dann so aus (Jetzt in doppelten Hochkomma weil man die einfachen für den Filter benötigt. Daher müssen $ und @ escaped werden!): jsonPath("\$.properties.timeseries.[?(\@.time =~ '12:00:00Z')]")
ergibt:
Readings
2021-04-29T120000Z   13.3
2021-04-30T120000Z   11
Jetzt noch hübsch machen:
multi(jsonPath("\$.properties.timeseries.[?(\@.time =~ '12:00:00Z')]"), substr(property('time'), 0, 10), sprintf('%.1f°', property('data.instant.details.air_temperature')));
ergibt:
Readings
2021-04-29   13.3°
2021-04-30   11.0°
2021-05-01   7.9°
Das braucht den JsonMod im Anhang, bitte testen und wenn es keine Nebenwirkungen gibt, dann checke ich das in den kommenden Tagen ein.
@Yersinia: falls Du mitliest, Du hattest einige Male einen ungeklärten Bug auf OS oder perl Ebene. JSON::XS wäre eine mögliche Ursache. In dieser Version habe ich JSON::XS durch Cpanel::JSON::XS ersetzt. Das müsste installiert sein, ansonsten wird das pure perl fallback verwendet.
Mit der Bitte um Feedback, Danke
Joerg
Nachtrag:
Hier wäre noch eine leicht modifizierte readingsList, plus Summary:
multi(jsonPath("\$.properties.timeseries.[?(\@.time =~ '12:00:00Z')]"), substr(property('time'), 0, 10), sprintf('%.1f° (%s)', property('data.instant.details.air_temperature'), property('data.next_12_hours.summary.symbol_code')));
2021-04-29 7.6° (rain)
2021-04-30 10.7° (cloudy)
2021-05-01 11.3° (cloudy)
