Umknown device on aetec zwave Z-stick
Begonnen von HarryT, 24 Juni 2021, 20:01:05
HarryT
Hi
I have an aetec zwave Z-stick which as a device named  UNKNOWN-4 . I have no idea what this could be. Most likely a try to add something to the nodlist which went wrong. Normally I can remove this again, but for this device I found nothing to remove it.
Can anybody give me a hint?
Thanks
FHEM 6.4 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz) and Raspberry Pi4 for testing
German reading skills are good.
Not sure that I understand your problem.
If this is a FHEM device, then you can delete it with the delete command.
If this ia a device seen in the output of the "get ZWDongle nodeList" command, then it can be deleted via removeFailedNode (see https://wiki.fhem.de/wiki/Z-Wave#Wie_kann_man_ohne_Exklusion_Nodes_des_Controllers_l.C3.B6schen.3F for details). Make sure you understand the implications.
HarryT
Thanks for you answer.
This is indeed a device listed in the output of  "get ZWDongle nodeList". In the list it is in black characters.  If I do  a "get ZWDongle isFailedNoode" I get the answer "no".  I don't see the device in fhem.cfg and I have no idea what this device could be.
The "remove FailedNode" does not remove it. Obviously because it is not marked as a failed node.
Other suggestions?
Thanks
