Autor Thema: show temperature / measuredTemperature at devices list, not desiredTemperature  (Gelesen 1737 mal)
Offline novalis
  • New Member
I am missing measuredTemperature value at HeatingThermostat (HT) details web page (was shown as "temperature" in old version, now it seems that it is only shown at HT which is not paired with Wall Thermosat (WT) ) and I would also like to see this temperature (and WT temperature) in MAX room devices list, I don't want to see desiredTemperature as "state", I want to see actual "temperature" of Heating and Wall thermostats.  It was possible with old MAX file version, but since I am using SVN version, I am having those new files ...
I did this:
--- FHEM/10_MAX.pm      (revision 24678)
+++ FHEM/10_MAX.pm      (working copy)
@@ -1602,6 +1602,7 @@
     #Sometime we get an MAX_Parse MAX,1,ThermostatState,01090d,180000000000, where desiredTemperature is 0 - ignore it
     readingsBulkUpdate($shash, "temperature", MAX_SerializeTemperature($measuredTemperature)) if ($measuredTemperature ne "");
+    $shash->{'.temperature'}=$measuredTemperature if ($measuredTemperature ne "");
     if (!AttrVal($shash->{NAME},'externalSensor',''))
     {readingsBulkUpdate($shash, "deviation", sprintf("%.1f",($measuredTemperature-$shash->{'.desiredTemperature'}))) if ($shash->{'.desiredTemperature'} && $measuredTemperature);}
     else
@@ -1692,6 +1693,7 @@
     if(defined($temperature))
       $temperature = ((($desiredTemperatureRaw &0x80)<<1) + $temperature)/10;  # auch Temperaturen über 25.5 °C werden angezeigt !
+      $shash->{'.temperature'}=$temperature;
       Log3 $hash, 5, $shash->{NAME}.", desiredTemperature : $shash->{'.desiredTemperature'}, temperature : $temperature";
       readingsBulkUpdate($shash, "temperature", sprintf("%.1f",$temperature));
       readingsBulkUpdate($shash, "deviation",   sprintf("%.1f", ($temperature-$shash->{'.desiredTemperature'})));
@@ -1938,6 +1940,7 @@
   #$state = $shash->{'.desiredTemperature'}.$c if (exists($shash->{'.desiredTemperature'}));
   $state = $shash->{'.desiredTemperature'} if (exists($shash->{'.desiredTemperature'}));
+  $state = $shash->{'.temperature'} if (exists($shash->{'.temperature'}));
   $state = ($shash->{'.isopen'}) ? 'opened' : 'closed' if (exists($shash->{'.isopen'}));
   if ($shash->{devtype} > 5)
To show at least the temperature at MAX room  devices list where the temperature is known,but I am still missing the measuredTemperature of HT, which is paired with WT
Thanks.
Offline novalis
  • New Member
Some update to shown temperatures - looks like after some time HeatingThersmostat (HT) is showing temperature, but it's not HT's measuredTemperature, but temperature of WallThermostat (in last post I wrote, that only HTs which are not paired with WT have "temperature")
Offline Wzut
  • Moderator
THX4Info, I will check this
Offline jangofritz
  • New Member
edit stateFormat to:
State                     : state °C<br/>
Temperature         : temperature °C<br/>
If you do not need the state just erase it.
JFritz
nanoCUL und 9 MAX! Thermostate. TabletUI und MAX!Scanner - ESP8266 als Aktor für die Zirkulationspumpe und zur Feuchte und Temperaturmessung - Sonoff TH16 als Aktor für Espressomaschine - Conbee + diverse THPs in Feuchträumen, sowie BWMs und Drucktaster
Offline Turnschuh
  • New Member
I do have the same issue.
After updating FHEM I cannot see in the list the actual temperature rather I can see the desired temperature.
Is there anything I can change to have the measure temperature back to my FHEM overview?
Offline novalis
  • New Member
I think we should return to old module versions, I am not seeing any progress in this :(
Offline novalis
  • New Member
Also setting "boost" to WallThermostat  doesn't work correctly - see  https://forum.fhem.de/index.php/topic,123302
so what I did was:
$cd FHEM
$svn up -r 21381 MaxCommon.pm
$svn up -r 21446 10_MAX.pm
and I have good old working MAX, which shows actual HT temperatures and correctly sets boost not only to WT, but also all paired HTs  (I have to do those commands again after new svn update, but I don't do that so often)
