fhempy: Tuya Cloud
Begonnen von dominik, 30 Juli 2021, 21:36:48
maddhin
hm, eigentlich immer noch der gleiche Fehler. 180MB von dem:
2022-09-11 20:40:13,878 - ERROR    - fhempy.lib.fhem_pythonbinding: Failed to handle message: b'{"defargs":null,"FHEMPYTYPE":null,"args":["volume_alarm: 30"],"function":"event","id":91011323,"argsh":{},"defargsh":null,"msgtype":"event","NAME":"ECHO_G091AA081132005B","PYTHONTYPE":null}'
  File "/opt/fhem/.local/lib/python3.9/site-packages/fhempy/lib/fhem_pythonbinding.py", line 129, in onMessage
    await self._onMessage(payload)
  File "/opt/fhem/.local/lib/python3.9/site-packages/fhempy/lib/fhem_pythonbinding.py", line 137, in _onMessage
    logger.debug(">>> WS: " + msg)
TypeError: can only concatenate str (not "bytes") to str
2022-09-11 20:40:13,893 - ERROR    - fhempy.lib.fhem_pythonbinding: Failed to handle message: b'{"function":"event","id":86815192,"FHEMPYTYPE":null,"args":["volume_alarm: 0"],"defargs":null,"PYTHONTYPE":null,"msgtype":"event","NAME":"ECHO_G090XG121505114X","defargsh":null,"argsh":{}}'
dominik
Was kommt bei fhempy Start für eine Versionsnummer? Also im Log
fhempy -  https://github.com/fhempy/fhempy: GoogleCast, Tuya, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
maddhin
im Log kann ich keine Version finden - in Fhem steht 0.1.242
dominik
Das ist viel zu alt. Wir hast du das installiert? Wie sieht dein Dockerfile aus?
maddhin
ich habe fhempy über docker-compose installiert:
fhem:
        #image: fhem/fhem:latest
        #image: ghcr.io/fhem/fhem-experimental:dev
        image: ghcr.io/fhem/fhem/fhem-docker:bullseye
        container_name: fhem
        privileged: true
        restart: always
        ports:
            - "8083:8083"
            - "7072:7072"
            - "3002:3002"
        volumes:
            - ./fhem/core/:/opt/fhem/
        networks:
            - fhem-network
        #devices:
        #    - "/dev/ttyUSB0:/dev/ttyUSB0"
        environment:
            FHEM_UID: 1000
            FHEM_GID: 1000
            TIMEOUT: 10
            RESTART: 1
            TELNETPORT: 7072
            TZ: Europe/Berlin
            APT_PKGS: "python3 python3-pip python3-dev libffi-dev libssl-dev libjpeg-dev zlib1g-dev autoconf build-essential libglib2.0-dev libdbus-1-dev bluez libbluetooth-dev git"
            NPM_PKGS: "alexa-fhem alexa-cookie2"
            CPAN_PKGS: "Protocol::WebSocket"
        depends_on:
            - "mysql"
            - "mqtt"
Ich war der Meinung, dass dann aktuelle Versionen installiert werden.
Ich lasse gerade pip3 install --upgrade fhempy  laufen - das installiert die aktuelle Version 1.461. Kennt jemand eine Möglichkeit das beim Start/Build des Containers laufen zu lassen?
Sollte das Update nicht auch über die FHEM Oberfläche anstoßbar sein? Aktuell passiert da bei mir gar nichts:(
dominik
Bei der alten Version geht das Update über fhem leider nicht.
maddhin
ok, nun eine dumme Frage: wo habe ich denn die stein-alte Version von fhempy her? Lag das an dem alten Docker-Image oder wurde da eine alte Version runtergeladen? Meiner Meinung nach wurde fhempy über FHEM beim Anlegen des devices installiert, oder?
Hintergrund meiner Frage ist einfach, wie ich in Zukunft dann automatisch eine aktuelle Version bekommen. Das Update jetzt hält ja (wohl) nur bis zum nächsten Start des Containers. Das ist ja nicht nachhaltig:(
dominik
Warum nur bis zum Restart? Der Container hält ja seine Daten und baut sich ja nicht dauernd neu, oder?
maddhin
Soweit ich weiß, ist das so. Beim Neustart lädt wieder das ursprüngliche Image - nur die Daten im Volume bleiben erhalten. Ich kenne mich da aber auch nicht aus. Meine Linux-Kenntnisse sind weitestgehend c&p ;)
Die manuelle Installation / Update von fhempy scheitert an cryptography bzw. fehlendem rust. Komisch, das hatte alles monatelang gut funktioniert. Irgendwas hat mir das letzte FHEM-Update da zerschossen.
dominik
Poste die Fehler von der Installation.
Bei Docker kann ich leider nicht viel helfen.
maddhin
das ist der Teil, wo die Fehler anfangen
Building wheels for collected packages: aiohttp, cryptography, dbus-python, websockets, frozenlist, multidict, yarl, pycares, Brotli, cchardet
  Building wheel for aiohttp (PEP 517) ... done
  Created wheel for aiohttp: filename=aiohttp-3.8.1-cp39-cp39-linux_armv7l.whl size=1123292 sha256=3c733a97da4b908873d8d6b0093a27a7df5a31e2a9018ecf225762395e4c8757
  Stored in directory: /root/.cache/pip/wheels/18/3d/16/11bf4b984ebad9a308297e1dd7ece9703314c8a4361f770e4f
  Building wheel for cryptography (PEP 517) ... error
  ERROR: Command errored out with exit status 1:
   command: /usr/bin/python3 /tmp/tmpdx_c70sz_in_process.py build_wheel /tmp/tmp9o0lauww
       cwd: /tmp/pip-install-khzjojv5/cryptography_63bdf7e594694206afd129c5250bb489
  Complete output (192 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-armv7l-cpython-39
  creating build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-39/cryptography
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  creating build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
  copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  running egg_info
  writing src/cryptography.egg-info/PKG-INFO
  writing dependency_links to src/cryptography.egg-info/dependency_links.txt
  writing requirements to src/cryptography.egg-info/requires.txt
  writing top-level names to src/cryptography.egg-info/top_level.txt
  reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  no previously-included directories found matching 'docs/_build'
  warning: no previously-included files found matching 'vectors'
  warning: no previously-included files matching '*' found under directory 'vectors'
  warning: no previously-included files matching '*' found under directory '.github'
  warning: no previously-included files found matching 'release.py'
  warning: no previously-included files found matching '.coveragerc'
  warning: no previously-included files found matching 'codecov.yml'
  warning: no previously-included files found matching '.readthedocs.yml'
  warning: no previously-included files found matching 'dev-requirements.txt'
  warning: no previously-included files found matching 'tox.ini'
  warning: no previously-included files found matching 'mypy.ini'
  warning: no previously-included files matching '*' found under directory '.circleci'
  adding license file 'LICENSE'
  adding license file 'LICENSE.APACHE'
  adding license file 'LICENSE.BSD'
  adding license file 'LICENSE.PSF'
  writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
  /tmp/pip-build-env-esr8i7h2/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning:     Installing 'cryptography.hazmat.bindings._rust' as data is deprecated, please list it in `packages`.
      # Package would be ignored #
      Python recognizes 'cryptography.hazmat.bindings._rust' as an importable package,
      but it is not listed in the `packages` configuration of setuptools.
      'cryptography.hazmat.bindings._rust' has been automatically added to the distribution only
      because it may contain data files, but this behavior is likely to change
      in future versions of setuptools (and therefore is considered deprecated).
      Please make sure that 'cryptography.hazmat.bindings._rust' is included as a package by using
      the `packages` configuration field or the proper discovery methods
      (for example by using `find_namespace_packages(...)`/`find_namespace:`
      instead of `find_packages(...)`/`find:`).
      You can read more about "package discovery" and "data files" on setuptools
      documentation page.
    check.warn(importable)
  copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-39/cryptography
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  running build_ext
  running build_rust
      =============================DEBUG ASSISTANCE=============================
      If you are seeing a compilation error please try the following steps to
      successfully install cryptography:
      1) Upgrade to the latest pip and try again. This will fix errors for most
         users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
      2) Read https://cryptography.io/en/latest/installation/ for specific
         instructions for your platform.
      3) Check our frequently asked questions for more information:
         https://cryptography.io/en/latest/faq/
      4) Ensure you have a recent Rust toolchain installed:
         https://cryptography.io/en/latest/installation/#rust
      Python: 3.9.2
      platform: Linux-5.10.103-v7+-armv7l-with-glibc2.31
      pip: n/a
      setuptools: 65.3.0
      setuptools_rust: 1.5.1
  error: can't find Rust compiler
  If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
  To update pip, run:
      pip install --upgrade pip
  and then retry package installation.
  If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
  This package requires Rust >=1.41.0.
  ERROR: Failed building wheel for cryptography
  Building wheel for dbus-python (setup.py) ... done
  Created wheel for dbus-python: filename=dbus_python-1.2.18-cp39-cp39-linux_armv7l.whl size=374188 sha256=4b93a7f16109fd7b9734a1041b9a5fcf680f0e1fd166613dca297ddc708375ef
  Stored in directory: /root/.cache/pip/wheels/48/d1/96/05b72337093d7d112f03ec7d121fb5426ae2353bd6a50ba97c
  Building wheel for websockets (setup.py) ... done
  Created wheel for websockets: filename=websockets-10.3-cp39-cp39-linux_armv7l.whl size=104260 sha256=b1d28b6f65c3733fba2cf722bd899e3e6a3517ef182daabca3d92342f0f24fa7
  Stored in directory: /root/.cache/pip/wheels/2f/1e/77/097069d35580f93f02355c49a0e7a8f78b7661566239e34bae
  Building wheel for frozenlist (PEP 517) ... done
  Created wheel for frozenlist: filename=frozenlist-1.3.1-cp39-cp39-linux_armv7l.whl size=135212 sha256=0ea514ca99dcadfa59eb47e9dad98934f99dae0970fcd0d33decc2f1df6c1914
  Stored in directory: /root/.cache/pip/wheels/09/e2/6d/51973d3dad5063063920221ce5379c1fd7e65cd5fca17b4f35
  Building wheel for multidict (PEP 517) ... done
  Created wheel for multidict: filename=multidict-6.0.2-cp39-cp39-linux_armv7l.whl size=109421 sha256=1124e32715af978ecdb67a3515f5d55ed77d416638d101f7cde2ad71b9848972
  Stored in directory: /root/.cache/pip/wheels/09/2e/af/35665f2dc3fdfa03603e3164d8d900effca39bd1ca5598f8d2
  Building wheel for yarl (PEP 517) ... done
  Created wheel for yarl: filename=yarl-1.8.1-cp39-cp39-linux_armv7l.whl size=204432 sha256=3ca4ca1958442c82c93e998e60d7cde0279da03f412168b9a47102d8f9a984d8
  Stored in directory: /root/.cache/pip/wheels/5f/b3/e8/8e9829e063b11e43799fbe97f90dc6b123275822e2553ecbc2
  Building wheel for pycares (PEP 517) ... done
  Created wheel for pycares: filename=pycares-4.2.2-cp39-cp39-linux_armv7l.whl size=243215 sha256=2045603a4c8187fdfc4b21d5e89eecb95cce6a403b1e8ed3deeee0669d1faad8
  Stored in directory: /root/.cache/pip/wheels/71/9e/4b/354d231631ca0eb996e5999f82ff15959d6219671e83d06e54
  Building wheel for Brotli (setup.py) ... done
  Created wheel for Brotli: filename=Brotli-1.0.9-cp39-cp39-linux_armv7l.whl size=2521773 sha256=f354c252ed584dadd0bf7b9e2d5af630b7a4638907174ddbebfe4cd9d89088ff
  Stored in directory: /root/.cache/pip/wheels/fc/64/ad/723809ab7a5b321a3e5997a75e00f388547f49f73b3192a32a
  Building wheel for cchardet (setup.py) ... done
  Created wheel for cchardet: filename=cchardet-2.1.7-cp39-cp39-linux_armv7l.whl size=244233 sha256=26e741e20b1d79911e519af0e9f128d8d99aafe14b5fea974d0eb5e01dc6bc06
  Stored in directory: /root/.cache/pip/wheels/53/72/df/32cb431a786ba2674993d3ea636aa0712c7f65495a9a3dbec9
Successfully built aiohttp dbus-python websockets frozenlist multidict yarl pycares Brotli cchardet
Failed to build cryptography
ERROR: Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
dominik
Schon das probiert was im Log steht
maddhin
pip Update installiert:
root@864b2806dcc1:/opt/fhem# pip install --upgrade pip
Requirement already satisfied: pip in /usr/lib/python3/dist-packages (20.3.4)
Collecting pip
  Downloading pip-22.2.2-py3-none-any.whl (2.0 MB)
     |████████████████████████████████| 2.0 MB 47 kB/s
Installing collected packages: pip
  Attempting uninstall: pip
    Found existing installation: pip 20.3.4
    Not uninstalling pip at /usr/lib/python3/dist-packages, outside environment /usr
    Can't uninstall 'pip'. No files were found to uninstall.
Successfully installed pip-22.2.2
Dann wieder der fhempy Update Versuch:
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests==2.26.0->fhempy) (2020.6.20)
Requirement already satisfied: idna<4,>=2.5 in /usr/lib/python3/dist-packages (from requests==2.26.0->fhempy) (2.10)
Requirement already satisfied: ifaddr>=0.1.7 in /usr/lib/python3/dist-packages (from zeroconf==0.36.12->fhempy) (0.1.7)
Collecting pycparser
  Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Collecting pycares>=4.0.0
  Using cached pycares-4.2.2-cp39-cp39-linux_armv7l.whl
Building wheels for collected packages: cryptography
  Building wheel for cryptography (pyproject.toml) ... error
  error: subprocess-exited-with-error
  × Building wheel for cryptography (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [192 lines of output]
      running bdist_wheel
      running build
      running build_py
      creating build
      running egg_info
      /tmp/pip-build-env-ko_nf87n/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning:     Installing 'cryptography.hazmat.bindings._rust' as data is deprecated, please list it in `packages`.
          documentation page.
      running build_ext
      running build_rust
          Python: 3.9.2
          pip: 22.2.2
          setuptools: 65.3.0
      To update pip, run:
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
Danach dachte ich, ich versuche pip nochmal zu installieren:
Collecting pip
  Using cached pip-22.2.2-py3-none-any.whl (2.0 MB)
    Uninstalling pip-20.3.4:
      Successfully uninstalled pip-20.3.4
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
root@864b2806dcc1:/opt/fhem# pip3 install --upgrade fhempy
bash: /usr/bin/pip3: No such file or directory
root@864b2806dcc1:/opt/fhem# pip install --upgrade fhempy
bash: /usr/bin/pip: No such file or directory
dominik
Achtung, warum machst du das als root?
Bitte den User fhem verwenden und nicht root.
maddhin
hab das Ganze jetzt nochmal als fhem user gemacht, hat aber die Fehlermeldung nicht geändert:(
