alexa connector: Rolladensteuerung Module ROLLO
Begonnen von eisman, 15 August 2021, 19:43:22
eisman
Alexa steuert 4 Rollos nur halbherzig, es gehen alle Funktionen ausser:
    open und closed (öffnen und schließen)
bis auf Level sind sie = meiner HM-Rollos und die gehen klasse.
Rollo:
   FUUID      60d0b27c-f33f-9137-1e4a-646ac5ffe6a92f2c
   NAME       RO_0102
   NR         502
   STATE      open
   TYPE       ROLLO
   stoptime   1629041600
     2021-08-15 19:08:12   command         pct-0
     2021-08-15 19:08:12   desired_pct     0
     2021-08-15 17:33:12   drive-type      modul
     2021-08-15 17:33:12   last_drive      drive-up
     2021-08-15 17:33:20   pct             100
     2021-08-15 17:33:20   state           open
   alexaName  Arbeitszimmerrollo
   alexaRoom  Arbeitszimmer
   alias      Arbeitszimmer
   cmdIcon    open:fts_shutter_up closed:fts_shutter_down stop:fts_shutter_manual half:fts_shutter_50
   devStateIcon open:fts_shutter_10@#808080:closed
closed:fts_shutter_100@#00FF00:open
half:fts_shutter_50@#0000FF:closed
drive-up:fts_shutter_up@#FF0000:stop
drive-down:fts_shutter_down@#FF0000:stop
pct-100:fts_shutter_10@#808080:open
pct-90:fts_shutter_10@#00FF00:closed
pct-80:fts_shutter_20@#0000FF:closed
pct-70:fts_shutter_30@#0000FF:closed
pct-60:fts_shutter_40@#0000FF:closed
pct-50:fts_shutter_50@#0000FF:closed
pct-40:fts_shutter_60@#0000FF:open
pct-30:fts_shutter_70@#0000FF:open
pct-20:fts_shutter_80@#0000FF:open
pct-10:fts_shutter_90@#00FF00:open
pct-0:fts_shutter_100@#00FF00:closed
   genericDeviceType blind
   group      Rollo
   icon       fts_shutter_50@FAB6B6
   rl_autoStop 0
   rl_commandDown set RO_0101 on
   rl_commandStopDown set RO_0101 on
   rl_commandStopUp set RO_0101 off
   rl_commandUp set RO_0101 off
   rl_excessBottom 0
   rl_excessTop 0
   rl_secondsDown 15
   rl_secondsUp 16
   rl_switchTime 1
   rl_type    HomeKit
   room       Arbeitszimmer,rollladen
   sortby     RO_0102
   stateFormat state
   webCmd     open:closed:half:stop:pct
RO_0102.version => 1.403 (Rollo-Module)
HM-Rollo:
   DEF        xxxxxx
   FUUID      5f69aff9-f33f-793a-84b9-e676fe70d7e2b2b4
   HMLAN0_MSGCNT 10
   HMLAN0_RAWMSG
   HMLAN0_RSSI -62
   HMLAN0_TIME 2021-08-15 17:56:38
   HMLAN1_MSGCNT 9
   HMLAN1_RAWMSG
   HMLAN1_RSSI -42
   HMLAN1_TIME 2021-08-15 17:56:38
   IODev      HMLAN0
   LASTInputDev HMLAN0
   MSGCNT     19
   NAME       RO_0101
   NR         92
   NTFY_ORDER 50-RO_0101
   STATE      20
   TYPE       CUL_HM
   chanNo     01
   disableNotifyFn 1
   lastMsg
   protLastRcv 2021-08-15 17:56:38
   protRcv    9 last_at:2021-08-15 17:56:38
   protSnd    10 last_at:2021-08-15 17:56:38
   protState  CMDs_done
     2021-08-15 17:56:27   CommandAccepted yes
     2020-09-22 10:08:04   D-firmware      2.11
     2020-09-22 10:08:04   D-serialNr      XXXXXXXXX
     2021-08-15 17:56:38   IODev           HMLAN0
     2021-03-17 08:30:23   PairedTo        XXXXXXXXX
     2020-09-22 10:05:55   R-confBtnTime   permanent
     2021-03-17 08:30:24   R-driveDown     14 s
     2020-09-22 10:13:56   R-driveTurn     1 s
     2020-09-22 10:13:07   R-driveUp       14 s
     2020-09-22 10:08:09   R-intKeyVisib   invisib
     2020-09-22 10:05:55   R-localResDis   off
     2020-09-22 10:08:09   R-pairCentral   XXXXXXXX
     2020-09-22 10:08:10   R-refRunCounter 0
     2020-09-22 10:08:10   R-sign          off
     2020-09-22 10:08:10   R-statusInfoMinDly 2 s
     2020-09-22 10:08:10   R-statusInfoRandom 1 s
     2020-09-22 10:08:10   R-transmitTryMax 6
     2021-08-09 19:24:25   cfgState        ok
     2021-08-15 17:56:38   commState       CMDs_done
     2021-08-15 17:56:38   deviceMsg       20 (to VCCU)
     2021-08-15 17:56:38   level           20
     2021-08-15 17:56:38   motor           stop:20
     2021-08-15 17:56:38   pct             20
     2020-09-22 10:06:57   powerOn         2020-09-22 10:06:57
     2021-08-15 17:56:38   recentStateType info
     2021-08-15 17:56:38   state           20
     2021-08-15 17:56:38   timedOn         off
     2021-08-15 17:56:27   trigLast        fhem:02
     peerIDsState complete
     peerOpt    3:blindActuator
   homebridgeMapping clear CurrentPosition=pct,minValue=0,maxValue=100,minStep=25
                                 TargetPosition=pct,minValue=0,maxValue=100,minStep=25,cmd=pct
                                 OpenClose=state,cmdOpen=pct 100,cmdClose=pct 0
   model      HM-LC-BL1PBU-FM
auch mit homebridgeMapping hat es nicht funktioniert,
vieleicht hat jemand eine Idee...
mfg
1x FHEM Debian, Homematic,ZigBee,FS20 / 1X Raspberry, ConBee / 7x ESP
1x FHEM Debian, Homematic,Z2M             / 1X Raspberry, ConBee / 6x ESP
1x FHEM Debian,MQTT2                             / 1X Raspberry, i2c,onewire,gpio
1x auf Windows 2012 Hyper-V-S
eisman
Cool jetzt gehen meine HM-Rollo's auch nicht mehr,
Sie hatten noch auf öffnen und schließen reagiert,
jetzt gehen sie bei Beiden befehlen auf.
"Das ist kein Fehler, Sondern eine neue sicherheit's Funktion :)"
justme1968
öffnen und schließen haben bei alexa schon immer etwas weiter öffnen bzw. schließen bedeutet. 'ganz auf' bzw 'ganz zu' öffnen ganz bzw. schließen ganz.
ansonsten:
- die beiden devices sind nicht identisch. eines hat kein homebridgeMapping und beim anderen erzeugst du komplett selber eins.
- den mapping ist falsch.  es enthält leerzeichen. das ist nicht erlaubt
- du verwendest cmdOpen und cmdClose. das gibt es nicht. wo ist das her?
wenn es wirklich mal so funktioniert hat wie du es dir vorstellst war das definitiv zufall.
weder am modul noch am connector hat sich in letzter zeit etwas geändert. vermutlich hat amazon diese zufälle jetzt geändert.
