Hallo!
So ein Posting hier gab es schon mal, aber das verlief im Sande.
ich habe wohl erfolgreich den HM-SEN-DB-PCB gepairt, aber das mit dem Knopf drücken und ?Short geht irgendwie nicht.
List:
.triggerUsed 1
CFGFN
DEF 72C5C2
FUUID 613b62a2-f33f-9562-e37e-26980a801210d8e2
HMGW1_MSGCNT 10
HMGW1_RAWMSG 040300302CA01072C5C2AFFECC02020105000AAF0BFE0CCC140618000000
HMGW1_RSSI -48
HMGW1_TIME 2021-09-10 15:51:23
IODev HMGW1
LASTInputDev HMGW1
MSGCNT 10
NAME HM_72C5C2
NOTIFYDEV global
NR 3037
STATE RESPONSE TIMEOUT:RegisterRead
TYPE CUL_HM
chanNo 01
lastMsg No:2C - t:10 s:72C5C2 d:AFFECC 02020105000AAF0BFE0CCC140618000000
protCmdDel 9
protLastRcv 2021-09-10 15:51:23
protRcv 11 last_at:2021-09-10 15:51:23
protResndFail 2 last_at:2021-09-10 15:51:28
protSnd 7 last_at:2021-09-10 15:51:23
protState CMDs_done_Errors:1
rssi_at_HMGW1 cnt:11 min:-51 max:-44 avg:-47.36 lst:-48
.attraggr:
.attrminint:
2021-09-10 15:51:22 .D-devInfo 010101
2021-09-10 15:51:22 .D-stc 40
2021-09-10 15:50:26 .R-pairCentral set_0xAFFECC
2021-09-10 15:51:27 .associatedWith HM_72C5C2,HM_72C5C2
2021-09-10 15:51:23 .protLastRcv 20210910155123
2021-09-10 15:51:05 CommandAccepted yes
2021-09-10 15:51:22 D-firmware 1.0
2021-09-10 15:51:22 D-serialNr REQ1032033
2021-09-10 15:51:26 cfgState PeerIncom,RegMiss
2021-09-10 15:51:28 commState CMDs_done_Errors:1
2021-09-10 15:51:28 state RESPONSE TIMEOUT:RegisterRead
RegL_00.:
VAL
helper:
HM_CMDNR 44
PONtest 1
cSnd 01AFFECC72C5C200040000000000,01AFFECC72C5C200040000000000
getCfgList all
getCfgListNo ,4
mId 00DC
peerFriend peerAct,peerVirt
peerOpt 4:pushButton
regLst 0,1,4p
rxType 4
supp_Pair_Rep 0
cfgChk:
idPz00 fail
idRc01 RegL_00.,RegL_01.
cmds:
TmplKey :no:1631281887.43621
TmplTs 1631281887.43621
cmdKey 1:1:0::HM_72C5C2:00DC:01:
cmdLst:
assignHmKey noArg
clear [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
deviceRename -newName-
fwUpdate -filename- [-bootTime-]
getConfig noArg
getDevInfo noArg
getRegRaw (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
peerBulk -peer1,peer2,...- [({set}|unset)]
peerChan -btnNumber- -actChn- [({single}|dual|reverse)] [({set}|unset)] [(actor|remote|{both})]
peerSmart -peerOpt-
raw -data- [...]
regBulk -list-.-peerChn- -addr1:data1- -addr2:data2-...
regSet [(prep|{exec})] -regName- -value- [-peerChn-]
reset noArg
sign [(on|{off})]
tplDel -tplDel-
tplSet_0 -tplChan-
trgEventL -peer- -condition-
trgEventS -peer- -condition-
trgPressL [(-peer-|{all})]
trgPressS [(-peer-|{all})]
unpair noArg
lst:
condition slider,0,1,255
peer
peerOpt HM_653B50_Sw,HM_6A974D_Sideboard_Deko,HM_6A9B69_window,HM_6BAD9C_KITCHEN_LIGHT,HM_72910A_WindowRec,HM_72910A_remote,HM_7291D8_WindowRec,HM_7291D8_remote,HM_729217_WindowRec,HM_729217_remote,VCCU_Btn1,VCCU_Btn2,Vact_2Taster,Vact_Taster,light_sofa
tplChan
tplDel
tplPeer
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
param -param-
reg -addr- -list- [-peerChn-]
regList noArg
regTable noArg
regVal -addr- -list- [-peerChn-]
saveConfig [-filename-]
tplInfo noArg
expert:
def 0
det 0
raw 1
tpl 0
io:
flgs 0
newChn +72C5C2,00,00,00
nextSend 1631281883.69451
rxt 0
vccu VCCU
p:
72C5C2
00
00
00
prefIO:
HMGW1
mRssi:
mNo 2C
io:
HMGW1:
-40
-40
peerIDsH:
prt:
bErr 0
sProc 0
q:
qReqConf 00
qReqStat
role:
chn 1
dev 1
rpt:
IO HMGW1
flg A
ts 1631281883.39903
ack:
HASH(0x560f8535b018)
2C8002AFFECC72C5C200
rssi:
at_HMGW1:
avg -47.3636363636364
cnt 11
lst -48
max -44
min -51
shadowReg:
RegL_00. 02:01 0A:AF 0B:FE 0C:CC
tmpl:
.mId 00DC
IODev HMGW1
IOgrp VCCU:HMGW1
autoReadReg 4_reqStatus
expert rawReg
firmware 1.0
model HM-SEN-DB-PCB
serialNr REQ1032033
subType pushButton
Wenn ich nun den Knopf drücke, dann passiert das:
2021-09-10 15:57:29 CUL_HM HM_72C5C2 D-firmware: 1.0
2021-09-10 15:57:29 CUL_HM HM_72C5C2 D-serialNr: REQ1032033
2021-09-10 15:57:29 CUL_HM HM_72C5C2 cfgState: updating
2021-09-10 15:57:29 CUL_HM HM_72C5C2 commState: CMDs_pending
2021-09-10 15:57:29 CUL_HM HM_72C5C2 commState: CMDs_processing...
2021-09-10 15:57:34 CUL_HM HM_72C5C2 ResndFail
2021-09-10 15:57:34 CUL_HM HM_72C5C2 commState: CMDs_done_Errors:1
2021-09-10 15:57:34 CUL_HM HM_72C5C2 RESPONSE TIMEOUT:RegisterRead
Das ganze zurücksetzen und pairing habe ich 2-3 mal probiert, aber es läuft immer auf dasselbe heraus.
Hat noch jemand eine Idee?
Viele Grüße, Frood
