FLOORPLAN startet nicht sofort...
Begonnen von Markus Hermann, 14 April 2013, 20:08:06
Markus Hermann
Hallo Forum.
nach einem shutdown restart bricht FLOORPLAN mit dieser Meldung ab:
2013.04.14 09:18:22.026 1: reload: Error:Modul 95_FLOORPLAN deactivated:
 Global symbol "$FW_RET" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 185, <$fh> line 21.
Global symbol "$FW_wname" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 186, <$fh> line 21.
Global symbol "$FW_wname" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 188, <$fh> line 21.
Global symbol "$FW_wname" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 189, <$fh> line 21.
Global symbol "$FW_ss" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 189, <$fh> line 21.
Global symbol "$FW_tp" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 190, <$fh> line 21.
Global symbol "$FW_subdir" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 191, <$fh> line 21.
Global symbol "$FW_RET" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 214, <$fh> line 21.
Global symbol "$FW_RET" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 215, <$fh> line 21.
Global symbol "$FW_subdir" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 217, <$fh> line 21.
Global symbol "$FW_subdir" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 219, <$fh> line 21.
Global symbol "$FW_subdir" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 226, <$fh> line 21.
Global symbol "$FW_cname" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 236, <$fh> line 21.
Global symbol "$FW_wname" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 237, <$fh> line 21.
Global symbol "$FW_ME" requires explicit package name at ./FHEM/95_FLOORPLAN.pm line 238, <$fh> line 21.
./FHEM/95_FLOORPLAN.pm has too many errors.
Wenn ich dann die fhem.cfg speichere, wird Floorplan ohne Fehler gestartet.
Was kann das sein?
MArkus
CUL/CUL-RFR/HM-LAN an Cubietruck
FS20/FHT/TFK/UTS/KS300/HM-SEC-SC/HMS100/HM-OU-CFM-PL/HM-RC-SEC3/
FLOORPLAN auf Android-Tablet und VDR
UliM
In fhem.cfg muss die Definition von fhemweb VOR der Definition von floorplan stehen.
Gruß Uli
Markus Hermann
Tja, so einfach kann das sein :-)
Vielen Dank Uli.
Gruß Markus
