EMS-ESP error with boiler mqtt template
Begonnen von kroonen, 15 Oktober 2021, 19:26:11
kroonen
I got the the ems-esp implementation, and the thermostat works fine.
hem> l  Woonkamer_Thermostaat
   DEVICETOPIC Woonkamer_Thermostaat
   FUUID      5eab0d68-f33f-d772-98a6-b3131bbc9855ff51
   IODev      mqtt2
   LASTInputDev mqtt2
   MSGCNT     3301
   NAME       Woonkamer_Thermostaat
   NR         103
   STATE      auto
20 °C
/ 20.1 °C
   TYPE       MQTT2_DEVICE
   mqtt2_MSGCNT 3301
   mqtt2_TIME 2021-10-15 18:48:13
   JSONMAP:
     hc1_currtemp currtemp
     hc1_daytemp daytemp
     hc1_holidayttemp holidaytemp
     hc1_mode   mode
     hc1_nighttemp nighttemp
     hc1_seltemp desired-temp
     2021-07-31 15:28:35   0
     2021-10-15 09:36:22   IODev           mqtt2
     2021-02-18 20:31:16   attrTemplateVersion 20201110
     2021-10-15 18:48:13   building        medium
     2021-10-15 18:48:13   currtemp        20.1
     2021-10-15 18:48:13   dampedoutdoortemp -10
     2021-03-29 21:04:43   dampedtemp      -10
     2021-10-15 18:48:13   dateTime        18:46:29 15/10/2021
     2021-10-15 18:48:13   desired-temp    20
     2021-10-15 18:48:13   errorcode       (0)
     2021-10-15 18:48:13   floordry        off
     2021-10-15 18:48:13   hc1_comforttemp 21
     2021-10-15 18:48:13   hc1_controlmode room
     2021-10-15 18:48:13   hc1_designtemp  75
     2021-10-15 18:48:13   hc1_ecotemp     15
     2021-10-15 18:48:13   hc1_hatemp      20.1
     2021-10-15 18:48:13   hc1_heatingtype radiator
     2021-10-15 18:48:13   hc1_manualtemp  17
     2021-10-15 18:48:13   hc1_maxflowtemp 75
     2021-10-15 18:48:13   hc1_minflowtemp 25
     2021-10-15 18:48:13   hc1_modetype    comfort
     2021-10-15 18:48:13   hc1_nofrosttemp 5
     2021-10-15 18:48:13   hc1_offsettemp  0
     2021-10-15 18:48:13   hc1_program     1
     2021-10-15 18:48:13   hc1_roominfluence 3
     2021-10-15 18:48:13   hc1_summermode  auto
     2021-10-15 18:48:13   hc1_summertemp  17
     2021-10-15 18:48:13   hc1_targetflowtemp 0
     2021-10-15 18:48:13   minexttemp      -10
     2021-10-15 18:48:13   mode            auto
     2021-03-29 21:04:43   time            21:03:51 29/03/2021
     2021-10-15 18:48:13   wwcircmode      own_prog
     2021-10-15 18:48:13   wwextra1        0
     2021-10-15 18:48:13   wwmode          own_prog
     2021-10-15 18:48:13   wwsettemp       60
     2021-10-15 18:48:13   wwsettemplow    45
     2021-03-29 21:04:43   wwtemp          60
     2021-03-29 21:04:43   wwtemplow       45
   IODev      mqtt2
   devStateIcon set.auto:edit_settings:mode+manual set.manual:edit_settings:mode+auto auto:time_automatic:mode+manual manual:time_manual_mode:mode+auto  set.*°C:edit_settings
   group      Klimaat
   icon       temp_control
   jsonMap    hc1_mode:mode hc1_seltemp:desired-temp hc1_daytemp:daytemp hc1_nighttemp:nighttemp hc1_holidayttemp:holidaytemp hc1_currtemp:currtemp
   model      ems-esp_thermostat_simple
   readingList ems-esp/thermostat_data:.* { json2nameValue($EVENT, '', $JSONMAP) }
   room       Woonkamer
   setList    mode:uzsuSelectRadio,auto,manual thermostat_data/thermostat_cmd_mode1 $EVTPART1
  desired-temp:slider,15.0,0.5,30.0,1 thermostat_data/thermostat_cmd_temp1 $EVTPART1
   setStateList on off
   stateFormat mode
desired-temp °C
/ currtemp °C
   webCmd     mode:desired-temp
Only the boiler gives an error, and doesn't get any data
fhem> l Woonkamer_Boiler
   CID        ems-esp
   DEF        ems-esp
   DEVICETOPIC Woonkamer_Boiler
   FUUID      5eab1dc0-f33f-d772-98fc-6cc0645a33fea8f2
   IODev      mqtt2
   NAME       Woonkamer_Boiler
   NR         105
   STATE      heating
   TYPE       MQTT2_DEVICE
     2021-10-15 19:04:33   BoilerStatus    Error evaluating Woonkamer_Boiler userReading BoilerStatus: Undefined subroutine &main::BoilerStatus called at (eval 1712) line 1.
     2021-10-15 18:51:22   IODev           mqtt2
     2021-10-15 19:04:33   attrTemplateVersion 20201110
   IODev      mqtt2
   devStateIcon idle:sani_heating heating:sani_heating@red tapwater:sani_water_hot@red
   eventMap   hot:Hot intelligent:Eco
   group      Klimaat
   icon       sani_boiler_temp
   model      ems-esp_boiler
   readingList ems-esp/boiler_data { json2nameValue($EVENT,'',$JSONMAP) }
   room       Woonkamer
   setList    wWComfort:select,hot,intelligent ems-esp/boiler_cmd { "cmd":"comfort", "data": "$EVTPART1" }
   stateFormat { my $h=ReadingsNum($name,"heating_active",1); my $t=ReadingsNum($name,"tapwater_active",0); !$h && !$t ? "idle" : ($h && !$t ? "heating" : "tapwater")}
   userReadings BoilerStatus {BoilerStatus("serviceCode","serviceCodeNumber")}
   webCmd     wWComfort
in the console on the fhem server i get values
mosquitto_sub -h 192.168.180.5 -t ems-esp/boiler_data
{"heatingActive":"off","tapwaterActive":"off","selFlowTemp":5,"selBurnPow":0,"curBurnPow":0,"heatingPumpMod":0,"curFlowTemp":60.4,"retTemp":57.8,"sysPress":1.9,"boilTemp":63.4,"burnGas":"off","flameCurr":0,"heatingPump":"off","fanWork":"off","ignWork":"off","heatingActivated":"on","heatingTemp":75,"pumpModMax":70,"pumpModMin":30,"pumpDelay":1,"burnMinPeriod":10,"burnMinPower":0,"burnMaxPower":75,"boilHystOn":-6,"boilHystOff":6,"burnStarts":85885,"burnWorkMin":429333,"heatWorkMin":331881,"UBAuptime":3957817,"serviceCode":"0H","serviceCodeNumber":203,"lastCode":"6L(229) 29.09.2021 21:52","maintenanceMessage":"-","maintenance":"off"}
kroonen
Found 1 issue
should be
ems-esp/boiler_data:.* { json2nameValue($EVENT,'',$JSONMAP) }
Only  what is not working yet is stateformat/ I get the heating icon, and shouw expect "idle"
l Woonkamer_Boiler
   CID        ems-esp
   DEF        ems-esp
   IODev      mqtt2
   LASTInputDev mqtt2
   MSGCNT     63
   NR         105
   STATE      heating
   TYPE       MQTT2_DEVICE
   mqtt2_MSGCNT 63
   mqtt2_TIME 2021-10-15 20:22:53
     2021-10-15 20:22:53   BoilerStatus    Error evaluating Woonkamer_Boiler userReading BoilerStatus: Undefined subroutine &main::BoilerStatus called at (eval 9701) line 1.
     2021-10-15 20:22:53   UBAuptime       3957877
     2021-10-15 20:22:53   boilHystOff     6
     2021-10-15 20:22:53   boilHystOn      -6
     2021-10-15 20:22:53   boilTemp        55.2
     2021-10-15 20:22:53   burnGas         off
     2021-10-15 20:22:53   burnMaxPower    75
     2021-10-15 20:22:53   burnMinPeriod   10
     2021-10-15 20:22:53   burnMinPower    0
     2021-10-15 20:22:53   burnStarts      85885
     2021-10-15 20:22:53   burnWorkMin     429333
     2021-10-15 20:22:53   curBurnPow      0
     2021-10-15 20:22:53   curFlowTemp     51.4
     2021-10-15 20:22:53   fanWork         off
     2021-10-15 20:22:53   flameCurr       0
     2021-10-15 20:22:53   heatWorkMin     331881
     2021-10-15 20:22:53   heatingActivated on
     2021-10-15 20:22:53   heatingActive   off
     2021-10-15 20:22:53   heatingPump     off
     2021-10-15 20:22:53   heatingPumpMod  0
     2021-10-15 20:22:53   heatingTemp     75
     2021-10-15 20:22:53   ignWork         off
     2021-10-15 20:22:53   lastCode        6L(229) 29.09.2021 21:52
     2021-10-15 20:22:53   maintenance     off
     2021-10-15 20:22:53   maintenanceMessage -
     2021-10-15 20:22:53   pumpDelay       1
     2021-10-15 20:22:53   pumpModMax      70
     2021-10-15 20:22:53   pumpModMin      30
     2021-10-15 20:22:53   retTemp         44.3
     2021-10-15 20:22:53   selBurnPow      0
     2021-10-15 20:22:53   selFlowTemp     5
     2021-10-15 20:22:53   serviceCode     0H
     2021-10-15 20:22:53   serviceCodeNumber 203
     2021-10-15 20:22:53   sysPress        1.9
     2021-10-15 20:22:53   tapwaterActive  off
   IODev      mqtt2
   group      Klimaat
   readingList ems-esp/boiler_data:.* { json2nameValue($EVENT,'',$JSONMAP) }
   room       Woonkamer
   stateFormat { my $h=ReadingsNum($name,"heatingActive",1); my $t=ReadingsNum($name,"tapwaterActive",0); !$h && !$t ? "idle" : ($h && !$t ? "heating" : "tapwater")}
   webCmd     wWComfort
kroonen
I think , I now the error but don't know how to fix
the values are now off and on for heating an tapwater. The stateformat template said 0 en 1 I think
anyone idea how to fix this?
Thanks for the hint with missing :.*, will update svn these days.
Wrt. to state format, you may try:
stateFormat { my $h=ReadingsNum($name,"heatingActive",1) eq 'on'; my $t=ReadingsNum($name,"tapwaterActive",0) eq 'on'; !$h && !$t ? "idle" : ($h && !$t ? "heating" : "tapwater")}
kroonen
No the state format is not working. When heating is active on I shoould expect an red icon. (dedvstateicon), I get only the normal icon
Woonkamer_Boiler
   CID        ems-esp
   DEF        ems-esp
   IODev      mqtt2
   LASTInputDev mqtt2
   MSGCNT     3956
   NR         105
   STATE      idle
   TYPE       MQTT2_DEVICE
   mqtt2_MSGCNT 3956
   mqtt2_TIME 2021-10-16 09:55:53
     2021-10-16 09:55:53   BoilerStatus    Error evaluating Woonkamer_Boiler userReading BoilerStatus: Undefined subroutine &main::BoilerStatus called at (eval 78025) line 1.
     2021-10-15 22:56:40   IODev           mqtt2
     2021-10-16 09:55:53   UBAuptime       3958693
     2021-10-16 09:55:53   boilHystOff     6
     2021-10-16 09:55:53   boilHystOn      -6
     2021-10-16 09:55:53   boilTemp        35.5
     2021-10-16 09:55:53   burnGas         on
     2021-10-16 09:55:53   burnMaxPower    75
     2021-10-16 09:55:53   burnMinPeriod   10
     2021-10-16 09:55:53   burnMinPower    0
     2021-10-16 09:55:53   burnStarts      85898
     2021-10-16 09:55:53   burnWorkMin     429370
     2021-10-16 09:55:53   curBurnPow      29
     2021-10-16 09:55:53   curFlowTemp     34.8
     2021-10-16 09:55:53   fanWork         on
     2021-10-16 09:55:53   flameCurr       27.4
     2021-10-16 09:55:53   heatWorkMin     331911
     2021-10-16 09:55:53   heatingActivated on
     2021-10-16 09:55:53   heatingActive   on
     2021-10-16 09:55:53   heatingPump     on
     2021-10-16 09:55:53   heatingPumpMod  31
     2021-10-16 09:55:53   heatingTemp     75
     2021-10-16 09:55:53   ignWork         off
     2021-10-16 09:55:53   lastCode        6L(229) 29.09.2021 21:52
     2021-10-16 09:55:53   maintenance     off
     2021-10-16 09:55:53   maintenanceMessage -
     2021-10-16 09:55:53   pumpDelay       1
     2021-10-16 09:55:53   pumpModMax      70
     2021-10-16 09:55:53   pumpModMin      30
     2021-10-16 09:55:53   retTemp         27.1
     2021-10-16 09:55:53   selBurnPow      29
     2021-10-16 09:55:53   selFlowTemp     75
     2021-10-16 09:55:53   serviceCode     -H
     2021-10-16 09:55:53   serviceCodeNumber 200
     2021-10-16 09:55:53   sysPress        2.1
     2021-10-16 09:55:53   tapwaterActive  off
   IODev      mqtt2
   group      Klimaat
   room       Woonkamer
kroonen
Wrt to:
Zitat2021-10-16 09:55:53   BoilerStatus    Error evaluating Woonkamer_Boiler userReading BoilerStatus: Undefined subroutine &main::BoilerStatus called at (eval 78025) line 1.
Tried to fix it in https://forum.fhem.de/index.php/topic,104968.msg1180136.html#msg1180136
Unfortunately all the service codes provided in the original file had been in german, but you may find it usefull nevertheless....
