Undefined subroutine &main::HMinfo_init called at fhem.pl line 3427 [gelöst]
Begonnen von bommel-bs, 17 Oktober 2021, 18:03:32
bommel-bs
ich habe eben ein Update in fhem durchgeführt. Fhem startet und bricht nach eine Weile mit der Fehlermeldung ab.
2021.10.17 17:52:42 3: Device Kueche_Fenster added to ActionDetector with 002:50 time
2021.10.17 17:52:44 3: Device Kueche_Wandthermostat added to ActionDetector with 000:10 time
2021.10.17 17:52:47 3: Device PM1 added to ActionDetector with 000:10 time
2021.10.17 17:52:47 3: Device SZ_Fenster_rechts added to ActionDetector with 028:00 time
2021.10.17 17:52:51 3: Device SZ_Heizung added to ActionDetector with 000:10 time
2021.10.17 17:52:51 3: Device Schlafzimmer_Balkontuer added to ActionDetector with 028:00 time
2021.10.17 17:52:53 3: Device Schlafzimmer_Heizung_links added to ActionDetector with 000:10 time
2021.10.17 17:52:53 3: Device Schlafzimmer_Rauchmelder added to ActionDetector with 099:00 time
2021.10.17 17:52:55 3: Device SonnenDetectorOst added to ActionDetector with 012:00 time
2021.10.17 17:52:58 3: Device Temp_outside added to ActionDetector with 000:10 time
2021.10.17 17:52:59 3: Device WK_Maschmaschine added to ActionDetector with 000:10 time
2021.10.17 17:53:02 3: Device WZ_Temp01 added to ActionDetector with 000:10 time
2021.10.17 17:53:04 3: Device Wintergarten_Heizung added to ActionDetector with 000:10 time
2021.10.17 17:53:05 3: Device Wohnzimmer_Fenster_rechts added to ActionDetector with 028:00 time
2021.10.17 17:53:17 1: CUL_HM finished initial cleanup
2021.10.17 17:53:18 1: usb create starting
2021.10.17 17:53:20 3: Probing CUL device /dev/ttyAMA0
2021.10.17 17:53:21 1: CUL: Can't open /dev/ttyAMA0: Permission denied
2021.10.17 17:53:21 1: usb create end
2021.10.17 17:53:21 0: Featurelevel: 6
2021.10.17 17:53:21 0: Server started with 534 defined entities (fhem.pl:25039/2021-10-01 perl:5.014002 os:linux user:fhem pid:31152)
2021.10.17 17:53:24 3: CUL_HM set AnkleideZimmer_Rolladen statusRequest noArg
2021.10.17 17:53:24 1: fhem.fritz.box:8883 reappeared (mqtt2Cloud)
2021.10.17 17:53:25 3: CUL_HM set WZ_Temp01 getConfig noArg
2021.10.17 17:53:25 1: HMLAN_Parse: HMLAN1 new condition ok
Undefined subroutine &main::HMinfo_init called at fhem.pl line 3427.
Was kamm hier schief gelaufen sein?
Zweite Frage:
Wie kann ich das am Anfang des Updates erstellte Backup wieder aktivieren?
Stefan
bommel-bs
Danke Beta-user,
nach der definition von HM-info startete mein fhem wieder.
viele grüße
Stefan
 :) Schön, wenn's geholfen hat, aber [gelöst] ist das damit eigentlich noch nicht ;) .
(Wobei HMinfo und VCCU eigentlich sowieso "Pflicht" sind, wenn man CUL_HM nutzt, aber das ist ein anderes Thema).
bommel-bs
VCCU steht schon auf der ToDo-Liste. Aber von HM-Info hatte ich noch nichts mitbekommen. Mein FHEM läuft seit März 2014 und wurde seit dem um Homatic-Komponenten und einiges an Logik erweitert.
Ich werde mir HM-Info mal genau ansehen, was ich damit machen kann.
Viele Grüße und danke noch einmal für die schnelle Hilfe
Stefan
frank
FHEM: 6.0(SVN) => Pi3(buster)
Bei vccu gehe ich ja noch mit.
Aber HMInfo ist für mich genau so entbehrlich wie der unsägliche ActionDetector.
Zumindest habe ich in all den Jahren, die ich inzwischen FHEM und Homematic nutze, beide devices noch nie für irgendwas benötigt.
turo
ZitatAber HMInfo ist für mich genau so entbehrlich wie der unsägliche ActionDetector.
Du Glücklicher! Meine FHEM/Homematic Installation entwickelt über die Monate immer wieder ein paar "Auffälligkeiten", die dann HMInfo meldet. Gerade letztes Wochenende habe ich wieder ein Stündchen mit unpeer/peer verbracht.
Besonders anfällig sind da bei mir die Fenstergriffsensoren. Die verlieren regelmäßig Teile ihrer oder gleich die ganze Konfiguration...
Turo
3xRaspberry PI, Homematic, SELVE Rollos, 1-wire, Logitech Harmony, Alexa, Fussbodenheizung (ESP8266), Netatmo
