fhempy: Fehler bei Installation
Begonnen von MarkusRobertAllen, 07 November 2021, 23:43:44
MarkusRobertAllen
mein Setup:
RPi "Stretch"
Python 3.10.0
pi@raspberrypi:/opt/fhem/log $ python --version
Python 3.10.0
pi@raspberrypi:/opt/fhem/log $ python3 --version
Python 3.10.0
list fhempy-Server:
   DEF        0
   FD         168
   FUUID      6188470f-f33f-9382-75a5-11de59070d3ae53c
   LAST_START 2021-11-07 23:34:09
   LAST_STOP  2021-11-07 23:34:09
   NAME       fhempyserver_15733
   NR         2461
   NTFY_ORDER 50-fhempyserver_15733
   PID        7034
   STARTS     22
   STATE      ???
   TYPE       fhempyServer
   currentlogfile ./log/fhempy-2021-11-07.log
   logfile    ./log/fhempy-%Y-%m-%d.log
   CoProcess:
     cmdFn      fhempyServer_getCmd
     name       fhempy
     state      running FHEM/bindings/python/bin/fhempy
     2021-11-07 23:34:09   fhempy          running FHEM/bindings/python/bin/fhempy
   devStateIcon {      my $status_img = "10px-kreis-gruen";;      my $status_txt = "running";;      if (substr(ReadingsVal($name, "fhempy", "running"),0,7) ne "running") {        $status_img = "10px-kreis-rot";;        $status_txt = "stopped";;      }      "<div><a>".FW_makeImage($status_img, $status_txt)."</a><a  href=\"/fhem?cmd.dummy=set $name restart&XHR=1\" title=\"Restart\">".FW_makeImage("audio_repeat")."</a></div>"      }
   group      fhempy
   icon       python
   nrarchive  10
   room       fhempy
local_pybinding zeigt den fhempy Server als offline an:
   BindingType fhempy
   DEF        fhempy
   DeviceName ws:127.0.0.1:15733
   FUUID      6188470f-f33f-9382-a5a1-d1d10b952221e26c
   IP         127.0.0.1
   NAME       local_pybinding
   NEXT_OPEN  1636323200.2308
   NR         2460
   NTFY_ORDER 50-local_pybinding
   PARTIAL
   PORT       15733
   STATE      fhempy server offline
   TYPE       BindingsIo
   localBinding 1
   nextOpenDelay 10
     2021-11-07 23:13:12   state           fhempy server offline
   args:
     local_pybinding
     BindingsIo
     fhempy
   argsh:
   devStateIcon {      my $status_img = "10px-kreis-gruen";;      my $status_txt = "connected";;      if (ReadingsVal($name, "state", "disconnected") eq "disconnected") {        $status_img = "10px-kreis-rot";;        $status_txt = "disconnected";;      }      my $ver = ReadingsVal($name, "version", "-");;      "<div><a>".FW_makeImage($status_img, $status_txt)."</a><a> ".$ver." </a><a  href=\"/fhem?cmd.dummy=set $name update&XHR=1\" title=\"Start update\">".FW_makeImage("refresh")."</a></div>"    }
   group      fhempy
   icon       file_json-ld2
   room       fhempy
Sowohl der Server als auch local_pybinding werden als "grün" angezeigt. local_pybinding allerdings erst, als ich set <...> update durchgeführt habe.
Das fhempy Log File zeigt mir folgende Fehler:
2021-11-07 23:38:44,879 - WARNING  - __main__: Failed to load fhempy: No module named 'fhempy'
2021-11-07 23:38:44,880 - INFO     - __main__: Attempting install of fhempy>=0.1.12
2021-11-07 23:38:50,279 - ERROR    - __main__: Unable to install package fhempy>=0.1.12: ERROR: Exception:
  File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/base_command.py", line 173, in _main
    status = self.run(options, args)
  File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/req_command.py", line 203, in wrapper
    return func(self, options, args)
  File "/usr/local/lib/python3.10/site-packages/pip/_internal/commands/install.py", line 266, in run
    session = self.get_default_session(options)
  File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/req_command.py", line 74, in get_default_session
    self._session = self.enter_context(self._build_session(options))
  File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/req_command.py", line 88, in _build_session
    session = PipSession(
  File "/usr/local/lib/python3.10/site-packages/pip/_internal/network/session.py", line 289, in __init__
    self.headers["User-Agent"] = user_agent()
  File "/usr/local/lib/python3.10/site-packages/pip/_internal/network/session.py", line 132, in user_agent
    linux_distribution = distro.linux_distribution()  # type: ignore
  File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 125, in linux_distribution
    return _distro.linux_distribution(full_distribution_name)
  File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 681, in linux_distribution
    self.version(),
  File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 741, in version
    self.lsb_release_attr('release'),
  File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 903, in lsb_release_attr
    return self._lsb_release_info.get(attribute, '')
  File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 556, in __get__
    ret = obj.__dict__[self._fname] = self._f(obj)
  File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 1014, in _lsb_release_info
    stdout = subprocess.check_output(cmd, stderr=devnull)
  File "/usr/local/lib/python3.10/subprocess.py", line 420, in check_output
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  File "/usr/local/lib/python3.10/subprocess.py", line 524, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '('lsb_release', '-a')' returned non-zero exit status 1.
  File "/usr/local/lib/python3.10/runpy.py", line 196, in _run_module_as_main
Nach etlichen Versionen und Löschen/erneutes Anlegen fehlt mir eine kreative Idee. Danke.
MarkusRobertAllen
Zwischenstand:
Nach Prüfung der fhempy-Log Datei:
habe ich festgestellt, dass auf meinem RPi auch manuell der Befehl lsb_release fehlschlägt.
Nach Recherche habe ich folgende Datei angepasst:
pi@raspberrypi:/usr/bin $ sudo vi lsb_release
Die erste Zeile habe ich wie folgt geändert:
# !/usr/bin/python3.5 -Es
Der Fehler war gelöst, bist der nächste auftauchte:
WARNING: pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
2021-11-08 18:03:39,896 - ERROR    - __main__: Failed to install fhempy, exit now...
Nach Recherche war dieser Fehler bekannt und man musste nur einige Libraries nachinstallieren und Python 3.10.0 neu kompilieren.
sudo apt install libssl-dev
sudo apt install libncurses5-dev
sudo apt install libsqlite3-dev
sudo apt install libreadline-dev
sudo apt install libtk8.6
sudo apt install libgdm-dev
sudo apt install libdb4o-cil-dev
sudo apt install libpcap-dev
Das erneute make führte allerdings zu Fehlern. Eine erneute Recherche brachte mich darauf, dass 3.10.0 auf Stretch grundsätzlich zu Problemen führt. Das hat mich zur Entscheidung geführt, entweder 3.9.5 (bestätigt OK) oder auf Bullseye zu wechseln.
Nach Abwägung aller Abhängigkeiten gehe ich jetzt auf Python 3.9.5.
More to come...
dominik
Warum aktualisierst du nicht einfach auf bullseye? Mit den manuellen Installationen verbiegst du dir sonst das ganze System.
fhempy -  https://github.com/fhempy/fhempy: GoogleCast, Tuya, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
MarkusRobertAllen
In der Tat scheint die Kombi mit Stretch problematisch zu sein. Hintergrund sind vermutlich Themen mit den Python Versionen.
Nachdem ich nun folgende Upgrade durchgeführt habe:
Stretch -> Buster und
Buster -> Bullseye
bekame ich angezeigt, dass die Datei /opt/fhem/.local vorhanden ist (und leer ist) und nicht überschrieben werden kann.
pi@raspberrypi:/opt/fhem $ ls .local
.local
pi@raspberrypi:/opt/fhem $ vi .local
pi@raspberrypi:/opt/fhem $ rm .local
Und siehe da, es geht weiter:
pi@raspberrypi:/opt/fhem/log $ vi  fhempy-2021-11-10.log
2021-11-10 13:37:55,444 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-11-10 13:37:55,481 - INFO     - fhempy.lib.pkg_installer: Attempting install of async-upnp-client==0.20.0
2021-11-10 13:38:09,760 - INFO     - fhempy.lib.pkg_installer: Successfully installed async-upnp-client==0.20.0 update!
2021-11-10 13:38:09,768 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-11-10 13:38:09,914 - WARNING  - asyncio: Executing <Task pending name='Task-1' coro=<async_main() running at /opt/fhem/.local/lib/python3.9/site-packages/fhempy/lib/fhem_pythonbinding.py:530> wait_for=<_GatheringFuture pending cb=[<TaskWakeupMethWrapper object at 0x7463cdd8>()] created at /usr/local/lib/python3.9/asyncio/tasks.py:704> cb=[_run_until_complete_cb() at /usr/local/lib/python3.9/asyncio/base_events.py:184] created at /usr/local/lib/python3.9/asyncio/base_events.py:621> took 0.145 seconds
2021-11-10 13:38:09,922 - INFO     - websockets.server: server listening on 0.0.0.0:15733
Trotzdem wird noch kein laufender fhempy Server gemeldet:
   BindingType fhempy
   CFGFN
   DEF        fhempy
   FUUID      618bad14-f33f-9382-f8ce-66a69739911a653c
   IP         127.0.0.1
   NEXT_OPEN  1636543953.20931
   NR         2903
   PARTIAL
   PORT       15733
   TYPE       BindingsIo
   localBinding 1
   nextOpenDelay 10
     2021-11-10 13:46:57   state           fhempy server offline
   args:
     local_pybinding
     BindingsIo
     fhempy
   argsh:
   group      fhempy
   icon       file_json-ld2
   room       fhempy
   verbose    5
MarkusRobertAllen
Nach einem Neustart des kompletten Systems, funktioniert es nun.
Für alle, die ähnliche Probleme haben:
a) Bullseye ist eine gute Basis, um mit fhempy zu starten
b) Einzelne Probleme sind gut zu lösen, wenn verbose=5 und durch lesen der fhempy Log Files
Danke für die Anregungen und das sehr gute Modul...
