HM-OU-CFM-PL, was hast Du gesagt?
Begonnen von Markus Hermann, 21 April 2013, 21:59:53
hoert
Hallo Martin,
Danke für die Anweisungen zum
Auslesen. Diese bringen nun folgendes Ergebnis:
>list Gong< bringt:
   CHANGED
   DEF        20771D
   EVENTS     40
   HMLan1_MSGCNT 49
   HMLan1_RAWMSG E20771D,0000,15833F5F,FF,FFBA,C5A01020771D090601030000
   HMLan1_RSSI -70
   HMLan1_TIME 2013-05-10 22:51:08
   IODev      HMLan1
   LASTInputDev HMLan1
   MSGCNT     49
   NAME       Gong
   NR         221
   NTFY_TRIGGERTIME 2013-05-10 22:51:08
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 Gong_LED
   channel_02 Gong_Ton
   lastMsg    No:C5 - t:10 s:20771D d:090601 030000
   protLastRcv 2013-05-10 22:51:08
   protSnd    15 last_at:2013-05-10 22:51:06
   protState  CMDs_done
   rssi_at_HMLan1 avg:-70.69 min:-75 max:-69 lst:-70 cnt:49
   Readings:
     2013-05-10 22:50:30   CommandAccepted yes
     2013-05-10 22:50:57   PairedTo        0x90601
     2013-05-10 22:50:57   R-intKeyVisib   visib
     2013-05-10 22:50:57   R-pairCentral   0x90601
     2013-05-10 22:50:57   RegL_00:          02:81 A4:B9 0A:09 0B:06 0C:01  00:00
     2013-05-10 22:51:08   state           CMDs_done
   Helper:
     mId        0075
     rxType     1
     Respwait:
     Role:
       dev        1
     Rssi:
       At_hmlan1:
         avg        -70.6938775510204
         cnt        49
         lst        -70
         max        -69
         min        -75
     Shadowreg:
   expert     2
   firmware   2.0
   model      HM-OU-CFM-PL
   peerIDs
   room       XXX
   serialNr   JEQ0720788
   subType    outputUnit
   webCmd     getConfig
>list Gong_LED< bringt:
   DEF        20771D01
   NAME       Gong_LED
   NR         223
   STATE      off
   TYPE       CUL_HM
   chanNo     01
   device     Gong
   CHANGED:
     R-self01-lgActionType: jmpToTarget
     R-self01-lgMultiExec: on
     R-self01-shActionType: jmpToTarget
   Readings:
     2013-05-10 09:32:37   CommandAccepted yes
     2013-05-10 22:51:00   R-HS1_Btn_03-lgActNum 6
     2013-05-10 22:51:00   R-HS1_Btn_03-lgActTypeLed red_long
     2013-05-10 22:51:00   R-HS1_Btn_03-lgActionType jmpToTarget
     2013-05-10 22:51:00   R-HS1_Btn_03-lgCtDlyOff geLo
     2013-05-10 22:51:00   R-HS1_Btn_03-lgCtDlyOn geLo
     2013-05-10 22:51:00   R-HS1_Btn_03-lgCtOff geLo
     2013-05-10 22:51:00   R-HS1_Btn_03-lgCtOn geLo
     2013-05-10 22:51:00   R-HS1_Btn_03-lgCtValHi 100
     2013-05-10 22:51:00   R-HS1_Btn_03-lgCtValLo 50
     2013-05-10 22:51:00   R-HS1_Btn_03-lgMultiExec on
     2013-05-10 22:51:00   R-HS1_Btn_03-lgOffDly 0 s
     2013-05-10 22:51:00   R-HS1_Btn_03-lgOffTime 111600 s
     2013-05-10 22:51:00   R-HS1_Btn_03-lgOffTimeMode absolut
     2013-05-10 22:51:00   R-HS1_Btn_03-lgOnDly 0 s
     2013-05-10 22:51:00   R-HS1_Btn_03-lgOnTime 6 s
     2013-05-10 22:51:00   R-HS1_Btn_03-lgOnTimeMode absolut
     2013-05-10 22:51:00   R-HS1_Btn_03-lgSwJtDlyOff dlyOff
     2013-05-10 22:51:00   R-HS1_Btn_03-lgSwJtDlyOn dlyOff
     2013-05-10 22:51:00   R-HS1_Btn_03-lgSwJtOff dlyOff
     2013-05-10 22:51:00   R-HS1_Btn_03-lgSwJtOn dlyOff
     2013-05-10 22:51:00   R-HS1_Btn_03-shActNum 6
     2013-05-10 22:51:00   R-HS1_Btn_03-shActTypeLed red_long
     2013-05-10 22:51:00   R-HS1_Btn_03-shActionType jmpToTarget
     2013-05-10 22:51:00   R-HS1_Btn_03-shCtDlyOff geLo
     2013-05-10 22:51:00   R-HS1_Btn_03-shCtDlyOn geLo
     2013-05-10 22:51:00   R-HS1_Btn_03-shCtOff geLo
     2013-05-10 22:51:00   R-HS1_Btn_03-shCtOn geLo
     2013-05-10 22:51:00   R-HS1_Btn_03-shCtValHi 100
     2013-05-10 22:51:00   R-HS1_Btn_03-shCtValLo 50
     2013-05-10 22:51:00   R-HS1_Btn_03-shOffDly 0 s
     2013-05-10 22:51:00   R-HS1_Btn_03-shOffTime 111600 s
     2013-05-10 22:51:00   R-HS1_Btn_03-shOffTimeMode absolut
     2013-05-10 22:51:00   R-HS1_Btn_03-shOnDly 0 s
     2013-05-10 22:51:00   R-HS1_Btn_03-shOnTime 6 s
     2013-05-10 22:51:00   R-HS1_Btn_03-shOnTimeMode absolut
     2013-05-10 22:51:00   R-HS1_Btn_03-shSwJtDlyOff dlyOff
     2013-05-10 22:51:00   R-HS1_Btn_03-shSwJtDlyOn dlyOff
     2013-05-10 22:51:00   R-HS1_Btn_03-shSwJtOff dlyOff
     2013-05-10 22:51:00   R-HS1_Btn_03-shSwJtOn dlyOff
     2013-05-10 22:51:01   R-HS1_Btn_04-lgActNum 255
     2013-05-10 22:51:01   R-HS1_Btn_04-lgActTypeLed red_long
     2013-05-10 22:51:01   R-HS1_Btn_04-lgActionType jmpToTarget
     2013-05-10 22:51:01   R-HS1_Btn_04-lgCtDlyOff geLo
     2013-05-10 22:51:01   R-HS1_Btn_04-lgCtDlyOn geLo
     2013-05-10 22:51:01   R-HS1_Btn_04-lgCtOff geLo
     2013-05-10 22:51:01   R-HS1_Btn_04-lgCtOn geLo
     2013-05-10 22:51:01   R-HS1_Btn_04-lgCtValHi 100
     2013-05-10 22:51:01   R-HS1_Btn_04-lgCtValLo 50
     2013-05-10 22:51:01   R-HS1_Btn_04-lgMultiExec on
     2013-05-10 22:51:01   R-HS1_Btn_04-lgOffDly 0 s
     2013-05-10 22:51:01   R-HS1_Btn_04-lgOffTime 111600 s
     2013-05-10 22:51:01   R-HS1_Btn_04-lgOffTimeMode absolut
     2013-05-10 22:51:01   R-HS1_Btn_04-lgOnDly 0 s
     2013-05-10 22:51:01   R-HS1_Btn_04-lgOnTime 111600 s
     2013-05-10 22:51:01   R-HS1_Btn_04-lgOnTimeMode absolut
     2013-05-10 22:51:01   R-HS1_Btn_04-lgSwJtDlyOff no
     2013-05-10 22:51:01   R-HS1_Btn_04-lgSwJtDlyOn no
     2013-05-10 22:51:01   R-HS1_Btn_04-lgSwJtOff dlyOn
     2013-05-10 22:51:01   R-HS1_Btn_04-lgSwJtOn no
     2013-05-10 22:51:01   R-HS1_Btn_04-shActNum 255
     2013-05-10 22:51:01   R-HS1_Btn_04-shActTypeLed red_long
     2013-05-10 22:51:01   R-HS1_Btn_04-shActionType jmpToTarget
     2013-05-10 22:51:01   R-HS1_Btn_04-shCtDlyOff geLo
     2013-05-10 22:51:01   R-HS1_Btn_04-shCtDlyOn geLo
     2013-05-10 22:51:01   R-HS1_Btn_04-shCtOff geLo
     2013-05-10 22:51:01   R-HS1_Btn_04-shCtOn geLo
     2013-05-10 22:51:01   R-HS1_Btn_04-shCtValHi 100
     2013-05-10 22:51:01   R-HS1_Btn_04-shCtValLo 50
     2013-05-10 22:51:01   R-HS1_Btn_04-shOffDly 0 s
     2013-05-10 22:51:01   R-HS1_Btn_04-shOffTime 111600 s
     2013-05-10 22:51:01   R-HS1_Btn_04-shOffTimeMode absolut
     2013-05-10 22:51:01   R-HS1_Btn_04-shOnDly 0 s
     2013-05-10 22:51:01   R-HS1_Btn_04-shOnTime 111600 s
     2013-05-10 22:51:01   R-HS1_Btn_04-shOnTimeMode absolut
     2013-05-10 22:51:01   R-HS1_Btn_04-shSwJtDlyOff no
     2013-05-10 22:51:01   R-HS1_Btn_04-shSwJtDlyOn no
     2013-05-10 22:51:01   R-HS1_Btn_04-shSwJtOff dlyOn
     2013-05-10 22:51:01   R-HS1_Btn_04-shSwJtOn no
     2013-05-10 22:51:03   R-self01-lgActNum 7
     2013-05-10 22:51:03   R-self01-lgActTypeLed orange_long
     2013-05-10 22:51:03   R-self01-lgActionType jmpToTarget
     2013-05-10 22:51:03   R-self01-lgCtDlyOff geLo
     2013-05-10 22:51:03   R-self01-lgCtDlyOn geLo
     2013-05-10 22:51:03   R-self01-lgCtOff geLo
     2013-05-10 22:51:03   R-self01-lgCtOn geLo
     2013-05-10 22:51:03   R-self01-lgCtValHi 100
     2013-05-10 22:51:03   R-self01-lgCtValLo 50
     2013-05-10 22:51:03   R-self01-lgMultiExec on
     2013-05-10 22:51:03   R-self01-lgOffDly 0 s
     2013-05-10 22:51:03   R-self01-lgOffTime 111600 s
     2013-05-10 22:51:03   R-self01-lgOffTimeMode absolut
     2013-05-10 22:51:03   R-self01-lgOnDly 0 s
     2013-05-10 22:51:03   R-self01-lgOnTime 6 s
     2013-05-10 22:51:03   R-self01-lgOnTimeMode absolut
     2013-05-10 22:51:03   R-self01-lgSwJtDlyOff no
     2013-05-10 22:51:03   R-self01-lgSwJtDlyOn no
     2013-05-10 22:51:03   R-self01-lgSwJtOff dlyOn
     2013-05-10 22:51:03   R-self01-lgSwJtOn no
     2013-05-10 22:51:03   R-self01-shActNum 7
     2013-05-10 22:51:03   R-self01-shActTypeLed orange_long
     2013-05-10 22:51:03   R-self01-shActionType jmpToTarget
     2013-05-10 22:51:03   R-self01-shCtDlyOff geLo
     2013-05-10 22:51:03   R-self01-shCtDlyOn geLo
     2013-05-10 22:51:03   R-self01-shCtOff geLo
     2013-05-10 22:51:03   R-self01-shCtOn geLo
     2013-05-10 22:51:03   R-self01-shCtValHi 100
     2013-05-10 22:51:03   R-self01-shCtValLo 50
     2013-05-10 22:51:03   R-self01-shOffDly 0 s
     2013-05-10 22:51:03   R-self01-shOffTime 111600 s
     2013-05-10 22:51:03   R-self01-shOffTimeMode absolut
     2013-05-10 22:51:03   R-self01-shOnDly 0 s
     2013-05-10 22:51:03   R-self01-shOnTime 6 s
     2013-05-10 22:51:03   R-self01-shOnTimeMode absolut
     2013-05-10 22:51:03   R-self01-shSwJtDlyOff off
     2013-05-10 22:51:03   R-self01-shSwJtDlyOn on
     2013-05-10 22:51:03   R-self01-shSwJtOff dlyOn
     2013-05-10 22:51:03   R-self01-shSwJtOn dlyOff
     2013-05-10 22:51:00   RegL_03:HS1_Btn_03  02:00 03:00 04:32 05:64 06:00 07:26 08:00 09:FF 0A:01 0B:44 0C:44 24:12 25:06 26:00 27:00 28:00 29:00 2A:00 2B:FF 82:00 83:00 84:32 85:64 86:00 87:26 88:00 89:FF 8A:21 8B:44 8C:44 8D:12 8E:06 A4:12 A5:06 A6:00 A7:00 A8:00 A9:00 AA:00 AB:FF 00:00
     2013-05-10 22:51:01   RegL_03:HS1_Btn_04  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:10 0C:00 24:12 25:FF 26:00 27:00 28:00 29:00 2A:00 2B:FF 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:10 8C:00 8D:12 8E:FF A4:12 A5:FF A6:00 A7:00 A8:00 A9:00 AA:00 AB:FF 00:00
     2013-05-10 22:51:03   RegL_03:self01   02:00 03:00 04:32 05:64 06:00 07:26 08:00 09:FF 0A:01 0B:14 0C:63 24:32 25:07 26:00 27:00 28:00 29:00 2A:00 2B:FF 82:00 83:00 84:32 85:64 86:00 87:26 88:00 89:FF 8A:21 8B:10 8C:00 8D:32 8E:07 A4:32 A5:07 A6:00 A7:00 A8:00 A9:00 AA:00 AB:FF 00:00
     2013-05-10 22:50:58   peerList        HS1_Btn_03,HS1_Btn_04,self01,
     2013-05-10 09:32:45   state           off
   Helper:
     peerIDsRaw ,20771D01,16508F04,16508F03,00000000
     Role:
       chn        1
     Shadowreg:
       RegL_00:    02:81
   model      HM-OU-CFM-PL
   peerIDs    00000000,16508F03,16508F04,20771D01,
   room       XXX
   webCmd     press short:press long
>list Gong_Ton< bringt:
   DEF        20771D02
   NAME       Gong_Ton
   NR         225
   STATE      off
   TYPE       CUL_HM
   chanNo     02
   device     Gong
   CHANGED:
     R-self02-lgActionType: jmpToTarget
     R-self02-lgMultiExec: on
     R-self02-shActionType: jmpToTarget
   Readings:
     2013-05-08 21:49:55   CommandAccepted yes
     2013-05-10 22:51:05   R-HS1_Btn_03-lgActNum 1
     2013-05-10 22:51:05   R-HS1_Btn_03-lgActTypeMp3 16
     2013-05-10 22:51:05   R-HS1_Btn_03-lgActionType jmpToTarget
     2013-05-10 22:51:05   R-HS1_Btn_03-lgCtDlyOff geLo
     2013-05-10 22:51:05   R-HS1_Btn_03-lgCtDlyOn geLo
     2013-05-10 22:51:05   R-HS1_Btn_03-lgCtOff geLo
     2013-05-10 22:51:05   R-HS1_Btn_03-lgCtOn geLo
     2013-05-10 22:51:05   R-HS1_Btn_03-lgCtValHi 100
     2013-05-10 22:51:05   R-HS1_Btn_03-lgCtValLo 50
     2013-05-10 22:51:05   R-HS1_Btn_03-lgIntense vol_100
     2013-05-10 22:51:05   R-HS1_Btn_03-lgMultiExec on
     2013-05-10 22:51:05   R-HS1_Btn_03-lgOffDly 0 s
     2013-05-10 22:51:05   R-HS1_Btn_03-lgOffTime 111600 s
     2013-05-10 22:51:05   R-HS1_Btn_03-lgOffTimeMode absolut
     2013-05-10 22:51:05   R-HS1_Btn_03-lgOnDly 0 s
     2013-05-10 22:51:05   R-HS1_Btn_03-lgOnTime 111600 s
     2013-05-10 22:51:05   R-HS1_Btn_03-lgOnTimeMode absolut
     2013-05-10 22:51:05   R-HS1_Btn_03-lgSwJtDlyOff dlyOff
     2013-05-10 22:51:05   R-HS1_Btn_03-lgSwJtDlyOn dlyOff
     2013-05-10 22:51:05   R-HS1_Btn_03-lgSwJtOff dlyOff
     2013-05-10 22:51:05   R-HS1_Btn_03-lgSwJtOn dlyOff
     2013-05-10 22:51:05   R-HS1_Btn_03-shActNum 1
     2013-05-10 22:51:05   R-HS1_Btn_03-shActTypeMp3 16
     2013-05-10 22:51:05   R-HS1_Btn_03-shActionType jmpToTarget
     2013-05-10 22:51:05   R-HS1_Btn_03-shCtDlyOff geLo
     2013-05-10 22:51:05   R-HS1_Btn_03-shCtDlyOn geLo
     2013-05-10 22:51:05   R-HS1_Btn_03-shCtOff geLo
     2013-05-10 22:51:05   R-HS1_Btn_03-shCtOn geLo
     2013-05-10 22:51:05   R-HS1_Btn_03-shCtValHi 100
     2013-05-10 22:51:05   R-HS1_Btn_03-shCtValLo 50
     2013-05-10 22:51:05   R-HS1_Btn_03-shIntense vol_100
     2013-05-10 22:51:05   R-HS1_Btn_03-shOffDly 0 s
     2013-05-10 22:51:05   R-HS1_Btn_03-shOffTime 111600 s
     2013-05-10 22:51:05   R-HS1_Btn_03-shOffTimeMode absolut
     2013-05-10 22:51:05   R-HS1_Btn_03-shOnDly 0 s
     2013-05-10 22:51:05   R-HS1_Btn_03-shOnTime 111600 s
     2013-05-10 22:51:05   R-HS1_Btn_03-shOnTimeMode absolut
     2013-05-10 22:51:05   R-HS1_Btn_03-shSwJtDlyOff dlyOff
     2013-05-10 22:51:05   R-HS1_Btn_03-shSwJtDlyOn dlyOff
     2013-05-10 22:51:05   R-HS1_Btn_03-shSwJtOff dlyOff
     2013-05-10 22:51:05   R-HS1_Btn_03-shSwJtOn dlyOff
     2013-05-10 22:51:06   R-HS1_Btn_04-lgActNum 1
     2013-05-10 22:51:06   R-HS1_Btn_04-lgActTypeMp3 1
     2013-05-10 22:51:06   R-HS1_Btn_04-lgActionType jmpToTarget
     2013-05-10 22:51:06   R-HS1_Btn_04-lgCtDlyOff geLo
     2013-05-10 22:51:06   R-HS1_Btn_04-lgCtDlyOn geLo
     2013-05-10 22:51:06   R-HS1_Btn_04-lgCtOff geLo
     2013-05-10 22:51:06   R-HS1_Btn_04-lgCtOn geLo
     2013-05-10 22:51:06   R-HS1_Btn_04-lgCtValHi 100
     2013-05-10 22:51:06   R-HS1_Btn_04-lgCtValLo 50
     2013-05-10 22:51:06   R-HS1_Btn_04-lgIntense vol_100
     2013-05-10 22:51:06   R-HS1_Btn_04-lgMultiExec on
     2013-05-10 22:51:06   R-HS1_Btn_04-lgOffDly 0 s
     2013-05-10 22:51:06   R-HS1_Btn_04-lgOffTime 111600 s
     2013-05-10 22:51:06   R-HS1_Btn_04-lgOffTimeMode absolut
     2013-05-10 22:51:06   R-HS1_Btn_04-lgOnDly 0 s
     2013-05-10 22:51:06   R-HS1_Btn_04-lgOnTime 111600 s
     2013-05-10 22:51:06   R-HS1_Btn_04-lgOnTimeMode absolut
     2013-05-10 22:51:06   R-HS1_Btn_04-lgSwJtDlyOff no
     2013-05-10 22:51:06   R-HS1_Btn_04-lgSwJtDlyOn no
     2013-05-10 22:51:06   R-HS1_Btn_04-lgSwJtOff dlyOn
     2013-05-10 22:51:06   R-HS1_Btn_04-lgSwJtOn no
     2013-05-10 22:51:06   R-HS1_Btn_04-shActNum 1
     2013-05-10 22:51:06   R-HS1_Btn_04-shActTypeMp3 1
     2013-05-10 22:51:06   R-HS1_Btn_04-shActionType jmpToTarget
     2013-05-10 22:51:06   R-HS1_Btn_04-shCtDlyOff geLo
     2013-05-10 22:51:06   R-HS1_Btn_04-shCtDlyOn geLo
     2013-05-10 22:51:06   R-HS1_Btn_04-shCtOff geLo
     2013-05-10 22:51:06   R-HS1_Btn_04-shCtOn geLo
     2013-05-10 22:51:06   R-HS1_Btn_04-shCtValHi 100
     2013-05-10 22:51:06   R-HS1_Btn_04-shCtValLo 50
     2013-05-10 22:51:06   R-HS1_Btn_04-shIntense vol_100
     2013-05-10 22:51:06   R-HS1_Btn_04-shOffDly 0 s
     2013-05-10 22:51:06   R-HS1_Btn_04-shOffTime 111600 s
     2013-05-10 22:51:06   R-HS1_Btn_04-shOffTimeMode absolut
     2013-05-10 22:51:06   R-HS1_Btn_04-shOnDly 0 s
     2013-05-10 22:51:06   R-HS1_Btn_04-shOnTime 111600 s
     2013-05-10 22:51:06   R-HS1_Btn_04-shOnTimeMode absolut
     2013-05-10 22:51:06   R-HS1_Btn_04-shSwJtDlyOff no
     2013-05-10 22:51:06   R-HS1_Btn_04-shSwJtDlyOn no
     2013-05-10 22:51:06   R-HS1_Btn_04-shSwJtOff dlyOn
     2013-05-10 22:51:06   R-HS1_Btn_04-shSwJtOn no
     2013-05-10 22:51:08   R-self02-lgActNum 1
     2013-05-10 22:51:08   R-self02-lgActTypeMp3 0
     2013-05-10 22:51:08   R-self02-lgActionType jmpToTarget
     2013-05-10 22:51:08   R-self02-lgCtDlyOff geLo
     2013-05-10 22:51:08   R-self02-lgCtDlyOn geLo
     2013-05-10 22:51:08   R-self02-lgCtOff geLo
     2013-05-10 22:51:08   R-self02-lgCtOn geLo
     2013-05-10 22:51:08   R-self02-lgCtValHi 100
     2013-05-10 22:51:08   R-self02-lgCtValLo 50
     2013-05-10 22:51:08   R-self02-lgIntense vol_100
     2013-05-10 22:51:08   R-self02-lgMultiExec on
     2013-05-10 22:51:08   R-self02-lgOffDly 0 s
     2013-05-10 22:51:08   R-self02-lgOffTime 111600 s
     2013-05-10 22:51:08   R-self02-lgOffTimeMode absolut
     2013-05-10 22:51:08   R-self02-lgOnDly 0 s
     2013-05-10 22:51:08   R-self02-lgOnTime 111600 s
     2013-05-10 22:51:08   R-self02-lgOnTimeMode absolut
     2013-05-10 22:51:08   R-self02-lgSwJtDlyOff no
     2013-05-10 22:51:08   R-self02-lgSwJtDlyOn no
     2013-05-10 22:51:08   R-self02-lgSwJtOff dlyOn
     2013-05-10 22:51:08   R-self02-lgSwJtOn no
     2013-05-10 22:51:08   R-self02-shActNum 1
     2013-05-10 22:51:08   R-self02-shActTypeMp3 0
     2013-05-10 22:51:08   R-self02-shActionType jmpToTarget
     2013-05-10 22:51:08   R-self02-shCtDlyOff geLo
     2013-05-10 22:51:08   R-self02-shCtDlyOn geLo
     2013-05-10 22:51:08   R-self02-shCtOff geLo
     2013-05-10 22:51:08   R-self02-shCtOn geLo
     2013-05-10 22:51:08   R-self02-shCtValHi 100
     2013-05-10 22:51:08   R-self02-shCtValLo 50
     2013-05-10 22:51:08   R-self02-shIntense vol_100
     2013-05-10 22:51:08   R-self02-shOffDly 0 s
     2013-05-10 22:51:08   R-self02-shOffTime 111600 s
     2013-05-10 22:51:08   R-self02-shOffTimeMode absolut
     2013-05-10 22:51:08   R-self02-shOnDly 0 s
     2013-05-10 22:51:08   R-self02-shOnTime 111600 s
     2013-05-10 22:51:08   R-self02-shOnTimeMode absolut
     2013-05-10 22:51:08   R-self02-shSwJtDlyOff off
     2013-05-10 22:51:08   R-self02-shSwJtDlyOn on
     2013-05-10 22:51:08   R-self02-shSwJtOff dlyOn
     2013-05-10 22:51:08   R-self02-shSwJtOn dlyOff
     2013-05-10 22:51:05   RegL_03:HS1_Btn_03  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:44 0C:44 24:10 25:01 26:00 27:00 28:00 29:00 2A:00 2B:FF 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:44 8C:44 8D:10 8E:01 A4:10 A5:01 A6:00 A7:00 A8:00 A9:00 AA:00 AB:FF 00:00
     2013-05-10 22:51:06   RegL_03:HS1_Btn_04  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:10 0C:00 24:01 25:01 26:00 27:00 28:00 29:00 2A:00 2B:FF 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:10 8C:00 8D:01 8E:01 A4:01 A5:01 A6:00 A7:00 A8:00 A9:00 AA:00 AB:FF 00:00
     2013-05-10 22:51:08   RegL_03:self02   02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:14 0C:63 24:00 25:01 26:00 27:00 28:00 29:00 2A:00 2B:FF 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:10 8C:00 8D:00 8E:01 A4:00 A5:01 A6:00 A7:00 A8:00 A9:00 AA:00 AB:FF 00:00
     2013-05-10 22:50:58   peerList        HS1_Btn_03,HS1_Btn_04,self02,
     2013-05-08 21:50:10   state           off
   Helper:
     peerIDsRaw ,20771D02,16508F04,16508F03,00000000
     Role:
       chn        1
     Shadowreg:
       RegL_00:    02:81
   model      HM-OU-CFM-PL
   peerIDs    00000000,16508F03,16508F04,20771D02,
   room       XXX
   webCmd     press short:press long:playTone replay
>set Gong raw ++A01109060120771D8002020212< bewirkt:
... die LED leuchtet einmal mit redS (rot kurz) auf ...
Kannst Du daraus etwas ableiten?
Es sei noch gesagt, dass mit dem Gong eine Verknüpfung zu einem Button vordefiniert ist:
HS1_Btn_04 spielt am Gong_Ton das 001-MP3 ab und lässt die LED unendlich mal rotL blinken.
HS1_Btn_03 stoppt ggf. das MP3-Stück und erlischt die blinkende LED.
Diese Funktionen wurde mittels der HM-Lan-Konfigurator-Software unter Windows erstellt und funktioniert
wie gewünscht.
Ein PRESS-Befehl über FHEM bewirkt bei mir immer ein 8-maliges yellowL-Blinken.
Und die restlichen Erfahrungen mit dem Befehl ... led <Farbe>,...
habe ich bereits zuvor beschrieben.
Mein Wunsch bzw. Ziel wär folgender:
Eine Türglocke an-/abschaltbar zu machen. Mit kurzem Tastendruck an einem eigenen speziellen Taster soll der aktuelle Scharf-/Unscharf-Status der Türglocke
an der Gong_LED angezeigt werden (scharf =on =greenL, unscharf =off =redL). Mittels langem Tastendruck soll der Zustand getoggelt werden können und der neu eingestellte (=aktuelle) Status soll auch wieder entsprechend an der LED dargestellt werden.
Ist die Türglocke aktiviert, soll beim Betätigen des Klingel-Tasters die 001-MP3 abgespielt werden; die LED-Leuchte kann aus bleiben.
Bei deaktivierter Türglocke soll hingegen nur die LED eine gewisse Anzahl mal blinken.
Solch ein Konstrukt ist sicherlich nicht ganz einfach zu lösen, sollte jedoch mittels FHEM durchaus möglich sein.
LG Leo
