Probleme beim pairen von HM-CC-RT-DN
Begonnen von mikawood, 18 Dezember 2021, 21:16:11
frank
Zitatich habe heute mal versucht das Pairing wie beschrieben durchzugeführt, leider ohne Erfolg.
auf spekulationen habe ich keine lust.  ;)
also zeige ein aktuelles list.
sniffe das pairing.
FHEM: 6.0(SVN) => Pi3(buster)
mikawood
Hallo Frank,
hier das aktuelle Liste des Thermostat
   CUL_868_MSGCNT 5
   CUL_868_RAWMSG A1A01840050187F0000001400954E4551313430383530355900FFFF::-77:CUL_868
   CUL_868_RSSI -77
   CUL_868_TIME 2021-12-28 00:58:37
   DEF        50187F
   FUUID      61afc572-f33f-9495-c41d-39db96da002f593b
   FVERSION   10_CUL_HM.pm:0.252980/2021-12-05
   IODev      CUL_868
   LASTInputDev CUL_868
   MSGCNT     5
   NAME       NN_WZ2_HZ2
   NR         226
   NTFY_ORDER 48-NN_WZ2_HZ2
   STATE      CMDs_pending
   TYPE       CUL_HM
   channel_01 NN_WZ2_HZ2_Weather
   channel_02 NN_WZ2_HZ2_Climate
   channel_03 NN_WZ2_HZ2_WindowRec
   channel_04 NN_WZ2_HZ2_Clima
   channel_05 NN_WZ2_HZ2_ClimaTeam
   channel_06 NN_WZ2_HZ2_remote
   disableNotifyFn 1
   lastMsg    No:01 - t:00 s:50187F d:000000 1400954E4551313430383530355900FFFF
   protCmdPend 42 CMDs_pending
   protLastRcv 2021-12-28 00:58:37
   protRcv    5 last_at:2021-12-28 00:58:37
   protResnd  3 last_at:2021-12-28 00:58:43
   protSnd    3 last_at:2021-12-28 00:58:37
   protState  CMDs_pending
   rssi_at_CUL_868 cnt:5 min:-77.5 max:-70.5 avg:-75.4 lst:-77
     2021-12-26 17:08:39   CommandAccepted yes
     2021-12-28 00:58:37   D-firmware      1.4
     2021-12-28 00:58:37   D-serialNr      NEQ1408505
     2021-12-28 00:58:37   IODev           CUL_868
     2021-12-28 01:02:14   cfgState        updating
     2021-12-28 01:02:16   commState       CMDs_pending
     2021-12-28 01:02:16   state           CMDs_pending
   cmdStack:
     ++A00162626250187F00040000000000
     ##A00162626250187F0103
     ##A00162626250187F01040000000001
     ##A00162626250187F0203
     ##A00162626250187F02040000000001
     ##A00162626250187F0303
     ##A00162626250187F03040000000001
     ##A00162626250187F0403
     ##A00162626250187F04040000000001
     ##A00162626250187F00040000000007
     ##A00162626250187F0503
     ##A00162626250187F05040000000001
     ##A00162626250187F0603
     ##A00162626250187F06040000000001
   helper:
     HM_CMDNR   41
     PONtest    1
     cSnd       0162626250187F00040000000000,0162626250187F00040000000000
     lastMsgTm  1640649517.22985
     mId        0095
     peerFriend -
     peerOpt    -:thermostat
     regLst     0
     rxType     140
     supp_Pair_Rep 1
     cmds:
       TmplKey    :no:1640556741.6941
       TmplTs     1640556741.6941
       cmdKey     0:1:0::NN_WZ2_HZ2:0095:01:
       cmdLst:
         assignHmKey noArg
         burstXmit  noArg
         clear      [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         inhibit    [(on|{off})]
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sysTime    noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         condition  slider,0,1,255
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       2
       newChn     +50187F,02,00,00
       nextSend   1640649517.37517
       rxt        2
       sendWu     1
       vccu
       p:
         50187F
         00
         00
         00
       prefIO:
     mRssi:
       mNo        01
       io:
         CUL_868:
           -75
           -75
     peerIDsH:
     prt:
       bErr       0
       sProc      2
       wuReSent   4
     q:
       qReqConf
       qReqStat
     role:
       dev        1
       prs        1
     rssi:
       at_CUL_868:
         avg        -75.4
         cnt        5
         lst        -77
         max        -70.5
         min        -77.5
     shRegW:
       07         04
     shadowReg:
     tmpl:
   IODev      CUL_868
   autoReadReg 4_reqStatus
   commStInCh off
   expert     rawReg
   firmware   1.4
   model      HM-CC-RT-DN
   room       26_Wohnzimmer2,41_Thermostate,CUL_HM
   serialNr   NEQ1408505
   subType    thermostat
   webCmd     getConfig:clear msgEvents:burstXmit
Meinst du mit sniffen das was Otto im Blog unter https://heinz-otto.blogspot.com/2017/10/homematic-nachrichten-sniffen.html?m=1 beschreibt?
Micha
raspberry 3  B Plus Rev 1.2  -(bookworm) - USB CUL 1.67 von Busware
15 * HM-CC-RT-DN - 1 * HM-SWI-3-FM - 4 * HM-Sen-DB-PCB - 2 * HM-PB-2-WM55 - 1 * HM-PB-6-WM55 - Vailant Atmo Tec clasic -
MDietrich
m.E. sieht das List gut aus. Die HMs brauchen manchmal ziemlich lange um zu reagieren, da hilft nur viel Geduld. Ich habe an den Thermostaten noch nie etwas tun müssen. Nur die SCOs arbeiten Settings nur auf "Knopfdruck" ab.
Hast du schon einmal ein set <device> clear all probiert?
Was zeigt der Event Monitor für das Gerät?
Habe eine CUL mit der Firmware V 1.67 CUL868, das funktioniert bisher ohne Probleme.
MDietrich
FB 6591 Cable / Raspberry 3b+ (Bookworm) / 4xECHO DOT 4/ Homematic Thermostate, Fenster- und Fenster-Sensoren / Philips HUE / CUL-HM /  Zigbee Schalter und Lampen / Shelly 1
frank
genau.
beim cul aber verbose 5 setzen, da er kein attr logIDs hat.
vor einem neuen pairen natürlich zuerst alle pending cmds löschen => clear msgevents.
definiere dir mal eine vccu. vielleicht funktioniert es ja damit besser. siehe wiki vccu.
ausserdem alle probleme beseitigen, die "get hminfo configCheck" zeigt.
mikawood
Hallo Frank
ich habe mir das mit Hminfo angeschaut - leider bekomme ich noch Fehlermeldungen.
Bei
get hm configcheck erhalte ich -> init not complete. configCheck won't be executed
bei
get hm peercheck
peerCheck done:
peer list incomplete. Use getConfig to read it.
    NN_AZ1_SD1:
    NN_FL1_DB:
    NN_FL1_TK1:
    NN_HZ1_SD1:
    NN_KU2_SW_1_Btn_01:
    NN_KU2_SW_1_Btn_02:
    NN_KU2_SW_1_Btn_03:
    NN_KU2_SW_1_Btn_04:
    NN_KU2_SW_1_Btn_05:
    NN_KU2_SW_1_Btn_06:
    NN_SZ2_SD1:
    NN_SZ2_TK1:
    NN_SZA_HZ1_Clima:
    NN_SZA_HZ1_ClimaTeam:
    NN_SZA_HZ1_Climate:
    NN_SZA_HZ1_Weather:
    NN_SZA_HZ1_WindowRec:
    NN_SZA_HZ1_remote:
    NN_WZ1_SD1:
    NN_WZ2_HZ2_Clima:
    NN_WZ2_HZ2_ClimaTeam:
    NN_WZ2_HZ2_Climate:
    NN_WZ2_HZ2_Weather:
    NN_WZ2_HZ2_WindowRec:
    NN_WZ2_HZ2_remote:
    NN_WZ2_TK1:
    NN_WZ2_TK2:
    NN_WZ2_TK3:
peering strange - likely not suitable
    NN_FL1_SD1: not peered!! add SD to any team !!
    NN_WZ2_SD1: not peered!! add SD to any team !!
trigger sent to undefined device
    NN_FL1_DB: 626262
    NN_FL1_SW_1_Btn_01: 626262
    NN_FL1_SW_1_Btn_02: 626262
    NN_KU2_SW_1_Btn_01: 636363
    NN_KU2_SW_1_Btn_02: 636363
    NN_KU2_SW_1_Btn_03: 636363
    NN_KU2_SW_1_Btn_04: 636363
    NN_KU2_SW_1_Btn_05: 636363
    NN_KU2_SW_1_Btn_06: 636363
    NN_KU2_SW_2_Btn_01: 626262
    NN_KU2_SW_2_Btn_02: 626262
    NN_KU2_SW_2_Btn_03: 626262
    NN_KU2_SW_2_Btn_04: 626262
    NN_KU2_SW_2_Btn_05: 626262
    NN_KU2_SW_2_Btn_06: 626262
    NN_SZ2_SW_1_Btn_01: 626262
    NN_SZ2_SW_1_Btn_02: 626262
Ich denke ich muss erst mal die Konflikte lösen bevor ich mir das Protokoll weiter ansehen kann. Was könnte hier die Ursache sein?
Michael
frank
Zitatinit not complete. configCheck won't be executed
das hört sich nicht gut an. also zunächst hminfo zum laufen bringen.
0. hast du nach der installation von hminfo einen echten fhem restart gemacht?
1. ist dein fhem aktuell (über den update cmd von fhem)?
alle dateien, oder sind welche vom update ausgeschlossen?
2. gibt es speicherprobleme?
gibt es in fhem.log zb diese meldungen: "Cannot fork: Cannot allocate memory"?
andere meldungen im log?
3. ist deine hardware zu schwach?
wo läuft fhem? (raspberry 2a - raspberry 3)
4. was sind das für devices, vermutlich homebrew? zeige je ein list von 626262 und 636363.
5. hast du die vccu richtig definiert?
zeige je ein list von vccu und cul.
6. gibt es freezes in fhem?
die module apptime und freezemon helfen dabei.
mikawood
Hallo Frank,
sorry das es etwas gedauert hat. Ich habe mir ein zweites system mit einem Raspberry 4 aufgeboot, Installiert habe ich Raspbian "Bullseye", die neueste Version von Fhem mit den scripts von Otto.
- neu
Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
/dev/root        32G    5,2G   25G   18% /
devtmpfs        813M       0  813M    0% /dev
tmpfs           982M       0  982M    0% /dev/shm
tmpfs           393M    2,0M  391M    1% /run
tmpfs           5,3M    4,1k  5,3M    1% /run/lock
/dev/mmcblk0p1  265M     51M  214M   20% /boot
tmpfs           197M     21k  197M    1% /run/user/1000
raspberry 4
   AssignedPeerCnt 1
   CFGFN
   CNT        155
   Clients    :CUL_HM:
   DEF        /dev/ttyAMA0
   DEVCNT     6
   DevState   99
   DevType    UART
   DeviceName /dev/ttyAMA0@115200
   FD         13
   FUUID      61ec36f9-f33f-d9b9-7d67-a644ae593ee40a7d
   LastOpen   1642870521.75621
   NAME       myHmUART
   NOTIFYDEV  global
   NR         24
   NTFY_ORDER 47-myHmUART
   PARTIAL
   RAWMSG     0500003C0486105017CC0000000A50AE0B0000
   RSSI       -60
   STATE      opened
   TYPE       HMUARTLGW
   XmitOpen   1
   model      HM-MOD-UART
   msgLoadCurrent 0
   msgLoadHistory 0/0/0/0/0/0/-1/0/0/0/0/0
   msgLoadHistoryAbs 0/0/0/0/0/0/0/1/1/1/1/1/1
   owner      626262
   Helper:
     CreditTimer 381
     FW         66561
     Initialized 1
     AckPending:
     LastSendLen:
       3
       3
     Log:
       IDs:
     RoundTrip:
       Delay      0.00285983085632324
     loadLvl:
       lastHistory 1642876224.24252
   MatchList:
     1:CUL_HM   ^A......................
   Peers:
     4CEFBA     +4CEFBA,02,00,00
     2022-01-22 17:55:24   D-HMIdAssigned  626262
     2022-01-22 17:55:24   D-HMIdOriginal  4702F0
     2022-01-22 17:55:24   D-firmware      1.4.1
     2022-01-22 17:55:24   D-serialNr      NEQ0231350
     2022-01-22 17:55:21   D-type          HM-MOD-UART
     2022-01-22 17:55:24   cond            ok
     2022-01-22 19:00:13   load            0
     2022-01-22 17:55:24   loadLvl         low
     2022-01-22 17:55:21   state           opened
   helper:
     bm:
       HMUARTLGW_Read:
         cnt        220
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.01. 19:30:32
         max        0.00379490852355957
         tot        0.239468574523926
         mAr:
           HASH(0x1ef8010)
       HMUARTLGW_Set:
         cnt        2
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.01. 19:30:24
         max        0.000149965286254883
         tot        0.0002288818359375
         mAr:
           HASH(0x1ef8010)
           myHmUART
   icon       cul
   room       00_CUL
active-timers: 5; max-active timers: 5; max-timer-load: 1  min-tmrHandlingTm: 0.0ms; max-tmrHandlingTm: 2.1ms; totAvgDly: 1.0ms
name                                     function                               max    count      total  average   maxDly   avgDly TS Max call     param Max call
WEB_192.168.10.99_58984                  FW_Read                                  8        7      14.42     2.06     0.00     0.00 22.01. 19:15:53 HASH(WEB_192.168.10.99_58984)
myHmUART                                 HMUARTLGW_Read                           2       14      17.13     1.22     0.00     0.00 22.01. 19:15:42 HASH(myHmUART)
tmr-HMUARTLGW_CheckCredits               HMUARTLGW_CheckCredits                   1        2       3.50     1.75     1.97     1.20 22.01. 19:15:43 HMUARTLGW_CheckCredits:myHmUART
WEB_192.168.10.99_58996                  FW_Read                                  1        1       1.46     1.46     0.00     0.00 22.01. 19:15:53 HASH(WEB_192.168.10.99_58996)
WEB_192.168.10.99_58985                  FW_Read                                  1        2       2.16     1.08     0.00     0.00 22.01. 19:15:53 HASH(WEB_192.168.10.99_58985)
WEB_192.168.10.99_58980                  FW_Read                                  1        4       4.14     1.04     0.00     0.00 22.01. 19:15:53 HASH(WEB_192.168.10.99_58980)
WEB_192.168.10.99_58986                  FW_Read                                  1        7       7.05     1.01     0.00     0.00 22.01. 19:15:53 HASH(WEB_192.168.10.99_58986)
WEB_192.168.10.99_58983                  FW_Read                                  1        2       2.04     1.02     0.00     0.00 22.01. 19:15:53 HASH(WEB_192.168.10.99_58983)
WEB                                      FW_Read                                  0        2       1.75     0.88     0.00     0.00 22.01. 19:15:31 HASH(WEB)
tmr-CUL_HM_cfgStateUpdate                cfgStateUpdate                           0        1       0.16     0.16     0.61     0.61 22.01. 19:15:54 cfgStateUpdate:HM_4CEFBA
WEB_192.168.10.99_58996                  FW_Notify                                0        4       0.16     0.04     0.00     0.00 22.01. 19:15:58 HASH(WEB_192.168.10.99_58996); HASH(myHmUART)
eventTypes                               eventTypes_Notify                        0        6       0.27     0.04     0.00     0.00 22.01. 19:15:42 HASH(eventTypes); HASH(myHmUART)
WEB                                      FW_Notify                                0        6       0.12     0.02     0.00     0.00 22.01. 19:15:42 HASH(WEB); HASH(myHmUART)
An dem eingentlichen Problem hat sich leider nichts geändert.
Der Fehler ist mit dem System gewandert, also anderer Raspberry, andere CUL - HM-MOD-RPI-PCB, das Thermostat habe ich reseted (Batterien raus alle 3 Tasten drücken).
Hier das Ergebis:
   CFGFN
   DEF        4CEFBA
   FUUID      61ec41a5-f33f-d9b9-0ce0-09a97a2561c058ca
   IODev      myHmUART
   NAME       HM_4CEFBA
   NOTIFYDEV  global
   NR         72
   NTFY_ORDER 48-HM_4CEFBA
   STATE      CMDs_pending
   TYPE       CUL_HM
   channel_01 HM_4CEFBA_Weather
   channel_02 HM_4CEFBA_Climate
   channel_03 HM_4CEFBA_WindowRec
   channel_04 HM_4CEFBA_Clima
   channel_05 HM_4CEFBA_ClimaTeam
   channel_06 HM_4CEFBA_remote
   protCmdPend 17 CMDs_pending
   protLastRcv 2022-01-22 18:40:53
   protRcv    1 last_at:2022-01-22 18:40:53
   rssi_at_myHmUART cnt:1 min:-60 max:-60 avg:-60 lst:-60
     2022-01-22 18:40:59   D-firmware      1.4
     2022-01-22 18:40:59   D-serialNr      NEQ0875664
     2022-01-22 18:40:54   IODev           myHmUART
     2022-01-22 19:05:55   cfgState        PairMiss,RegMiss,RegPend
     2022-01-22 18:44:55   commState       CMDs_pending
     2022-01-22 18:44:55   state           CMDs_pending
   cmdStack:
     ++A001F100004CEFBA00050000000000
     ++A001F100004CEFBA000802010AF10B000C00
     ++A001F100004CEFBA0006
     ++A001F100004CEFBA00040000000000
     ##A001F100004CEFBA0103
     ##A001F100004CEFBA01040000000001
     ##A001F100004CEFBA0203
     ##A001F100004CEFBA02040000000001
     ##A001F100004CEFBA0303
     ##A001F100004CEFBA03040000000001
     ##A001F100004CEFBA0403
     ##A001F100004CEFBA04040000000001
     ##A001F100004CEFBA00040000000007
     ##A001F100004CEFBA0503
     ##A001F100004CEFBA05040000000001
     ##A001F100004CEFBA0603
     ##A001F100004CEFBA06040000000001
   helper:
     HM_CMDNR   40
     PONtest    1
     cfgStateUpdt 1
     mId        0095
     peerFriend peerSensT
     peerOpt    p:thermostat
     regLst     0,1
     rxType     140
     supp_Pair_Rep 1
     bm:
       CUL_HM_Set:
         cnt        1
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.01. 19:37:52
         max        0.000769853591918945
         tot        0.000769853591918945
         mAr:
           HASH(0x2902eb0)
           HM_4CEFBA
     cfgChk:
       idPc01     fail
       idRc01     RegL_00.
       idRc03     fail
     cmds:
       TmplKey    :no:1642873259.02351
       TmplTs     1642873259.02351
       cmdKey     0:1:0::HM_4CEFBA:0095:01:
       cmdLst:
         assignHmKey noArg
         burstXmit  noArg
         getConfig  noArg
         getDevInfo noArg
         raw        -data- [...]
         reset      noArg
         sign       [(on|{off})]
         sysTime    noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       2
       newChn     +4CEFBA,02,00,00
       nextSend   1642873254.06873
       rxt        2
       vccu
       p:
         4CEFBA
         00
         00
         00
       prefIO:
     mRssi:
       mNo        01
       io:
         myHmUART:
           -56
           -56
     peerIDsH:
     prt:
       bErr       0
       sProc      2
     q:
       qReqConf
       qReqStat
     role:
       dev        1
     rssi:
       at_myHmUART:
         avg        -60
         cnt        1
         lst        -60
         max        -60
         min        -60
     shRegW:
       07         04
     shadowReg:
       RegL_00.    02:01 0A:F1 0B:00 0C:00
     tmpl:
   IODev      myHmUART
   expert     rawReg
   firmware   1.4
   model      HM-CC-RT-DN
   room       00_test,CUL_HM
   serialNr   NEQ0875664
   subType    thermostat
mfg
Micha
LuckyDay
du sendest mit hmId F10000
dein HMuart hat hmId 626262
entweder hat du noch einen Cul irgendwo oder eine kaputte vccu usw.
irgenwas ist noch faul bei dir
frank
Zitatdein HMuart hat hmId 626262
das attr hmid fehlt aber im hmuart list.
eine vollständige beantwortung aller meiner fragen kann ich nicht erkennen.
