FHEM Connector für Amazon Alexa - alexaFHEM.ProxyConnection
Begonnen von aHome77, 24 Dezember 2021, 09:39:46
aHome77
Hallo Zusammen,
ich bin nach der Anleitung https://wiki.fhem.de/wiki/FHEM_Connector_f%C3%BCr_Amazon_Alexa  vorgegangen, insbesondere auch der Punkt "Permission denied",
wie hier beschrieben https://wiki.fhem.de/wiki/FHEM_Connector_f%C3%BCr_Amazon_Alexa#Permission_denied
Leider habe ich immer noch den Fehler,
sshautoconf: aborted with user homedir writable by group/other ('chmod 755 /opt/fhem' required)
siehe Log.
[23.12.2021, 21:44:43] *** SSH: checking proxy configuration
[23.12.2021, 21:44:43] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[23.12.2021, 21:44:43] Passed config: {
  connections: [
      server: '127.0.0.1',
      filter: 'alexaName=..*',
      uid: 999,
      port: '8083',
      webname: 'fhem'
  sshproxy: {
    description: 'FHEM Connector',
    ssh: '/usr/bin/ssh',
    options: [ '-i', '/opt/fhem/.ssh/id_rsa', '-p', 58824, 'fhem-va.fhem.de' ],
    'bind-ip': '127.0.0.1',
    server: Server {
      maxHeaderSize: undefined,
      insecureHTTPParser: undefined,
      _events: [Object: null prototype],
      _eventsCount: 3,
      _maxListeners: undefined,
      _connections: 0,
      _handle: [TCP],
      _usingWorkers: false,
      _workers: [],
      _unref: false,
      allowHalfOpen: true,
      pauseOnConnect: false,
      httpAllowHalfOpen: false,
      timeout: 0,
      keepAliveTimeout: 5000,
      maxHeadersCount: null,
      maxRequestsPerSocket: 0,
      headersTimeout: 60000,
      requestTimeout: 0,
      _connectionKey: '4:127.0.0.1:0',
      [Symbol(IncomingMessage)]: [Function: IncomingMessage],
      [Symbol(ServerResponse)]: [Function: ServerResponse],
      [Symbol(kCapture)]: false,
      [Symbol(async_id_symbol)]: 177
[23.12.2021, 21:44:43] sshautoconf: *** Error: Your Homedirectory is writable by group/other. This will not work with SSH
[23.12.2021, 21:44:43] sshautoconf: aborted with user homedir writable by group/other ('chmod 755 /opt/fhem' required)
[23.12.2021, 21:44:43] *** SSH: proxy configuration failed: user homedir writable by group/other ('chmod 755 /opt/fhem' required)
[23.12.2021, 21:44:43] No reading "alexaFHEM.bearerToken" found in "alexa" - incoming Cloud requests cannot be validated.
[23.12.2021, 21:44:44] Reading alexaFHEM.ProxyConnection set to error;; user homedir writable by group/other ('chmod 755 /opt/fhem' required)
Die Rechte in /opt/fhem passen, fhem:dialout 755.
Woran kann es noch liegen?
Was mir aufgefallen ist, das der Ordner /opt/fhem/.ssh nicht existierte. Muss ssh anderweitig, also VOR alexa-fhem installiert werden?
Andreas
Himi
als mir hat weitergeholfen..
(im Raspi LX Terminal)
Sudo chmod 755 /opt/fhem
gegebenen Falls danach noch folgendes eingeben...
Sudo chmod /opt/fhem/.ssh/id_rsa
im Reading von Alexa  muss dann unter alexaFHEM.ProxyConnecton folgendes stehen... running;SSH connection
aHome77
Danke für die Info, habe jetzt folgendes eingegeben:
sudo chmod 755 /opt/fhem
sudo chmod 600 /opt/fhem/.ssh/id_rsa
Bin jetzt einen Schritt weiter, mein Fehler war wohl die Berechtigungen mit "sudo chmod fhem:dialout 755 /opt/fhem" anzugeben.
Jetzt kommt noch folgender Fehler:
[24.12.2021, 11:38:23] sshautoconf: SSH key seems to exist
[24.12.2021, 11:38:23] sshautoconf: aborted with Reverse Proxy replied with neither registered nor unregistered status: out:  err:Warning: Permanently added '[fhem-va.fhem.de]:58824,[88.xx.xx.xx]:58824' (RSA) to the list of known hosts.
fhem@fhem-va.fhem.de: Permission denied (keyboard-interactive,publickey).
aHome77
okay, jetzt funktoniert es  :D
Habe die Files in /opt/fhem/.ssh nochmal gelöscht und "set alexa restart" gestartet.
Danke  :D
Mazz78
Ich muss/möchte mich hier mal einklinken...
Vorgeschichte:
Meine FHEM-Installation hat aus welchem Grund auch immer den Geist aufgegeben, deswegen habe ich mich entschlossen das letzte Backup wieder einzuspielen.
Soweit funktioniert wieder alles außer...
Problem:
Das Alexa Reading alexaFHEM.ProxyConnection zeigt mir
error; Reverse Proxy replied with neither registered nor unregistered status: out:  err:Unable to negotiate with 2a01:4f8:221:1b5a::f2 port 58824: no matching host key type found. Their offer: ssh-rsa
Was soll mir diese Fehlermeldung sagen ?
Kann damit jemand etwas anfangen und mir sagen was ich machen kann ?  ???
Im Log sehe ich
this is alexa-fhem 0.5.64
sshautoconf: aborted with Reverse Proxy replied with neither registered nor unregistered status: out:  err:Unable to negotiate with 2a01:4f8:221:xxxx::f2 port 58824: no matching host key type found. Their offer: ssh-rsa
*** SSH: proxy configuration failed: Reverse Proxy replied with neither registered nor unregistered status: out:  err:Unable to negotiate with 2a01:4f8:221:xxxx::f2 port 58824: no matching host key type found. Their offer: ssh-rsa
List Alexa sagt...
   FD         4
   FUUID      60291c83-f33f-f943-e160-678b04b844f6cf2b
   FVERSION   39_alexa.pm:0.238200/2021-02-24
   LAST_START 2024-03-28 18:01:41
   NAME       Alexa
   NOTIFYDEV  global,global:npmjs.*alexa-fhem.*
   NR         53
   NTFY_ORDER 50-Alexa
   PARTIAL
   PID        12215
   STARTS     1
   STATE      running /usr/local/bin/alexa-fhem
   TYPE       alexa
   active     0
   alexa-fhem version 0.5.64
   currentlogfile ./log/alexa-2024.log
   eventCount 2
   logfile    ./log/alexa-%Y.log
   CoProcess:
     cmdFn      alexa_getCMD
     name       alexaFHEM
     state      running /usr/local/bin/alexa-fhem
     2024-03-28 18:01:41   alexaFHEM       running /usr/local/bin/alexa-fhem
     2024-03-28 18:01:45   alexaFHEM.ProxyConnection error; Reverse Proxy replied with neither registered nor unregistered status: out:  err:Unable to negotiate with 2a01:4f8:221:1b5a::f2 port 58824: no matching host key type found. Their offer: ssh-rsa
     2021-02-14 13:50:54   alexaFHEM.bearerToken crypt:0600..<gekürzt>..c50
     2021-02-14 13:50:54   alexaFHEM.skillRegKey crypt:0406..<gekürzt>..60b
   helper:
   alexaFHEM-config ./alexa-fhem.cfg
   alexaFHEM-log ./log/alexa-%Y.log
   alexaMapping #Characteristic=<name>=<value>,...
On=verb=schalte,valueOn=an;ein,valueOff=aus,valueToggle=um
Brightness=verb=stelle,property=helligkeit,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
Hue=verb=stelle,valuePrefix=auf,values=rot:0;grün:128;blau:200
Hue=verb=färbe,values=rot:0;grün:120;blau:220
Saturation=verb=stelle,property=sättigung,valuePrefix=auf,values=AMAZON.NUMBER
Saturation=verb=sättige,values=AMAZON.NUMBER
TargetPosition=verb=mach,articles=den;die,values=auf:100;zu:0
TargetPosition=verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
TargetTemperature=verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=grad
Volume:verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
#Weckzeit=verb=stelle,valuePrefix=auf;für,values=AMAZON.TIME,valueSuffix=uhr
   alexaTypes #Type=<alias>[,<alias2>[,...]]
light=licht,lampen
blind=rolladen,rolläden,jalousie,jalousien,rollo,rollos
   devStateIcon stopped:control_home@red:start stopping:control_on_off@orange running.*:control_on_off@green:stop
   echoRooms  #<deviceId>=<room>
   fhemIntents #IntentName=<sample utterance>
gutenMorgen=guten morgen
guteNacht=gute nacht
   group      IO_Devices
   icon       alexa2
   persons    #<personId>=<name>
   room       System
   stateFormat alexaFHEM
RaPi 4 / Buster / FHEM 6
CUL868 / JeeLink868
Banana M1 (Bananian) + ser2net + Stiebel Eltron LWZ403
FIRMATA -> Gartenbewässerung /-licht
ALEXA
Ralli
Eigentlich ganz einfach. Steht doch da, was die Ursache ist:
Der einfachste und schnellste Weg dürfte sein, eine Neu-Registrierung am Proxy herbeizuführen wie im Wiki beschrieben.
Ralli
Proxmox 9 Cluster mit HP ED800G2i7, Intel NUC11TNHi7+NUC7i5BNH, virtualisiertes fhem 6.4 dev, virtualisierte OpenCCU (3.89.11.20260919) mit HB-RF-ETH 1.3.0 / RPI-RF-MOD, HM-LAN-GW (1.4.1) und HMW-GW, FRITZBOX 7490 (07.62), FBDECT, Siri und Alexa
juemuc
Eventuell muss die ssh_config ergänzt werden.
sudo nano /etc/ssh/ssh_config
Host fhem-va.fhem.de
  HostkeyAlgorithms +ssh-rsa
  PubkeyAcceptedAlgorithms +ssh-rsa
Jürgen
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
Mazz78
Das hab ich in diesem Beitrag auch schon gesehen, hat allerdings nicht zum Erfolg geführt
ZitatEventuell muss die ssh_config ergänzt werden.
CodeAuswählen
ZitatDer einfachste und schnellste Weg dürfte sein, eine Neu-Registrierung am Proxy herbeizuführen wie im Wiki beschrieben.
...leider war es dann auch so.
Jetzt funktionierts wieder
CUL868 / JeeLink868
ALEXA
FlyingPenguin
Nach einem Wechsel von einem Raspi auf einen anderen mittels FHEM Backup funktioniert alexa-fhem bei mir nicht mehr. Ich erhalte immer einen Fehler bei der Verbindung zum Proxy:
Reading alexaFHEM.ProxyConnection set to error;; Reverse Proxy replied with neither registered nor unregistered status: out:  err:fhem@fhem-va.fhem.de: Permission denied (keyboard-interactive,publickey).
Die Berechtigungen von /opt/fhem/.ssh und den Dateien darin passen. Ich habe das Verzeichnis schon gelöscht, die alexa-fhem Instanz in FHEM gelöscht und neu angelegt, die
+rsa-ssh in /etc/ssh/ssh_conf.d/ eingefügt, versucht mich über die Kommandozeile neu am Proxy zu registrieren, immer gibt es diese Fehlermeldung.
Hat irgendwer noch eine Idee?
Chuco
Schau mal post #6 weiter oben. Hat mir vor 5 Minuten auch zu Erfolg verholfen.
FlyingPenguin
Zitat von: Chuco am 02 März 2025, 22:40:19Schau mal post #6 weiter oben. Hat mir vor 5 Minuten auch zu Erfolg verholfen.
Vielleicht habe ich mich da missverständlich ausgedrückt: Das habe ich schon getan, nur eben nicht in der ssh_config, sondern in einer neuen Datei in ssh_conf.d. Das sollte exakt das Gleiche tun, aber sauberer sein. In ssh_config gehören nur globale Einstellungen. In das Verzeichnis alles was spezifisch für einen Host ist.
MadMax-FHEM
Du schreibst, dass die Berectigungen i.O. sind, zeigst sie aber nicht...
Das OS ist bzgl. /opt/fhem/.ssh sehr "empfindlich", nicht nur Gruppe und User müssen passen auch die jeweiligen User-/Gruppen-Rechte...
Hast du neue ssh-Schlüssel angelegt oder vom Altsystem übernommen?
Wenn übernommen: wie?
Sind ja normalerweise nicht im Backup enthalten...
Wenn neu, dann stimmen sie nicht mit den hinterlegten überein...
Entweder übertragen (Rechte usw. beachten) oder neu Registrieren, siehe Wiki...
Gruß, Joachim
FHEM PI3 Buster (Test)
Ralli
Wenn deine "eigentlich sauberere" Lösung nicht funktioniert, wie wär's, wenn du den Lösungsweg einschlägst, der bei zig anderen geholfen hat?! Und wenn das dann funktioniert hat, kannst du ja gerne an einer eleganteren Lösung weiter arbeiten und sie dann hier posten, wenn sie funktioniert.
Ralli
FlyingPenguin
Hallo Joachim,
Danke für die Hinweise. Fehler gefunden. Es war ein Tippfehler im Dateinamen der Datei in /etc/ssh/ssh.config.d, der dazu geführt hat, dass diese nicht geladen wurde.
Jetzt sieht alles OK aus (mit den pee SCP übertragenen alten Keys).
mfeske
ich über mich gerade am restoren meiner FHEM Installation und dokumentiere dabei aber irgendwas muss ich verkehrt gemacht haben.
Ich hatte mehrfach FHEM neu aufgesetzt und auch dann ein Backup eingespielt.
Die Alexa Keys hatte ich mir per scp zurück geholt.
Ich habe eine Testinstallation zu laufen und eine produktive mit der ich das Restore durchführe, ich bin auch der Meinung es hätte bei den ersten Versuchen funktioniert.
Jetzt hatte ich erst kein ssh zu laufen, bis ich dann
ausgeführt habe und
ergänzt habe.
Warum auch immer das auf dem ursprünglichen System nicht drin steht, beides läuft unter bookworm. Können die Zeilen auch nach /etc/ssh/ssh_conf.d/  ausgelagert werden ? Das habe ich im ursprünglichen System aber auch nichts gefunden.
Was ich auch nicht bedacht hatte war das get <alexa> proxyKey den Wert ändert. Ich bin jetzt verbunden, hätte aber gerne das mysterium um /etc/ssh/ssh_config noch gelöst
Micha
Hardware:
1 x Raspberry Pi Mod. B 512 MB
eq-3 2 x MAX! eTRV Heizungssteller, 1 x MAX! Fensterkontakt, 1 x MAX! Cube - LAN Gateway (ausser Betrieb)
Intertechno 1x ITZ-500, 3x ITT-1500, 9x ITR-1500, 3 x ITDL-1000, 2 x ITL-500
1 x CC1101-USB-Lite 433MHz (CUL433)  V3 1 x CC1101-USB-Lite 868MHz (CUL868)
