Perl Warning seit heutigem Update von 31_HUEDevice.pm
Begonnen von punker, 10 Januar 2022, 08:32:17
punker
habe seit dem heutigen Update folgende Perl Wanung im Log:
2022.01.10 08:20:43.383 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/31_HUEDevice.pm line 1495.
2022.01.10 08:20:43.384 1: stacktrace:
2022.01.10 08:20:43.384 1:     main::__ANON__                      called by ./FHEM/31_HUEDevice.pm (1495)
2022.01.10 08:20:43.385 1:     main::HUEDevice_Parse               called by ./FHEM/30_HUEBridge.pm (1947)
2022.01.10 08:20:43.385 1:     main::HUEBridge_dispatch            called by FHEM/HttpUtils.pm (647)
2022.01.10 08:20:43.385 1:     main::__ANON__                      called by fhem.pl (771)
Dieter
The truth is out there!
justme1968
Jamo
Ich habe mit dem heutigen update folgende Warnungen im Logile:
   DEF        ME.IN.E.IP
   FUUID      5c42ff42-9101-5678-1234-3d2hh75368ssc5c7
   FVERSION   30_HUEBridge.pm:0.242960/2021-04-21
   INTERVAL   60
   NAME       PhilipsHue
   NOTIFYDEV  global
   NR         2146
   NTFY_ORDER 50-PhilipsHue
   STATE      connected
   TYPE       HUEBridge
   apiversion 1.48.0
   bridgeid   001788FFFE253FFA
   host       ME.IN.E.IP
   mac        00:17:88:gh:ef:cd
   manufacturer Signify
   modelName  Philips hue bridge 2015
   modelid    BSB002
   name       Philips Hue
   swversion  1948086000
   updatestate 0
   zigbeechannel 15
     2021-06-09 15:48:24   alert           none
     2022-01-11 01:13:25   lastError       parameter, xy, is not modifiable. Device is set to off.
     2021-06-09 15:51:50   onoff           0
     2021-06-09 15:51:50   pct             0
     2021-06-09 15:48:24   reachable       1
     2022-01-12 21:53:36   state           connected
     2021-09-18 21:37:25   swupdate        ZGB_100B_010F - LedStrips-SAMR21 - 16.0
   helper:
     apiversion 77824
     count      0
     last_config_timestamp 1642020813
     offsetUTC  3600
     updatestate 0
     groups:
       1:
         class      Living room
022.01.12 21:53:36.249 1: PERL WARNING: Use of uninitialized value in join or string at ./FHEM/31_HUEDevice.pm line 1501.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/31_HUEDevice.pm line 1468.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/31_HUEDevice.pm line 1480.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1608.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/31_HUEDevice.pm line 1622.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1791.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1792.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1793.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1794.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1812.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1837.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1839.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1840.
2022.01.12 21:53:36.256 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/31_HUEDevice.pm line 1843.
2022.01.12 21:53:36.257 1: ERROR: empty name in readingsBeginUpdate
2022.01.12 21:53:36.257 1: stacktrace:
2022.01.12 21:53:36.257 1:     main::readingsBeginUpdate           called by ./FHEM/31_HUEDevice.pm (1854)
2022.01.12 21:53:36.257 1:     main::HUEDevice_Parse               called by ./FHEM/30_HUEBridge.pm (1988)
2022.01.12 21:53:36.257 1:     main::HUEBridge_dispatch            called by FHEM/HttpUtils.pm (647)
2022.01.12 21:53:36.257 1:     main::__ANON__                      called by fhem.pl (771)
2022.01.12 21:53:36.257 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/31_HUEDevice.pm line 1887.
2022.01.12 21:53:36.257 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 4947.
2022.01.12 21:53:36.257 1: readingsUpdate(,colormode,hs) missed to call readingsBeginUpdate first.
2022.01.12 21:53:36.257 1:     main::readingsBulkUpdate            called by ./FHEM/31_HUEDevice.pm (1887)
2022.01.12 21:53:36.257 1: PERL WARNING: Use of uninitialized value in numeric ne (!=) at ./FHEM/31_HUEDevice.pm line 1888.
2022.01.12 21:53:36.257 1: readingsUpdate(,bri,205) missed to call readingsBeginUpdate first.
2022.01.12 21:53:36.257 1:     main::readingsBulkUpdate            called by ./FHEM/31_HUEDevice.pm (1888)
2022.01.12 21:53:36.257 1: PERL WARNING: Use of uninitialized value in numeric ne (!=) at ./FHEM/31_HUEDevice.pm line 1889.
2022.01.12 21:53:36.258 1: readingsUpdate(,ct,500 (2000K)) missed to call readingsBeginUpdate first.
2022.01.12 21:53:36.258 1: stacktrace:
2022.01.12 21:53:36.258 1:     main::readingsBulkUpdate            called by ./FHEM/31_HUEDevice.pm (1894)
2022.01.12 21:53:36.258 1:     main::HUEDevice_Parse               called by ./FHEM/30_HUEBridge.pm (1988)
2022.01.12 21:53:36.258 1:     main::HUEBridge_dispatch            called by FHEM/HttpUtils.pm (647)
2022.01.12 21:53:36.258 1:     main::__ANON__                      called by fhem.pl (771)
2022.01.12 21:53:36.258 1: PERL WARNING: Use of uninitialized value in numeric ne (!=) at ./FHEM/31_HUEDevice.pm line 1897.
2022.01.12 21:53:36.258 1: readingsUpdate(,hue,6553) missed to call readingsBeginUpdate first.
2022.01.12 21:53:36.258 1:     main::readingsBulkUpdate            called by ./FHEM/31_HUEDevice.pm (1897)
2022.01.12 21:53:36.258 1: PERL WARNING: Use of uninitialized value in numeric ne (!=) at ./FHEM/31_HUEDevice.pm line 1898.
2022.01.12 21:53:36.258 1: readingsUpdate(,sat,254) missed to call readingsBeginUpdate first.
2022.01.12 21:53:36.258 1:     main::readingsBulkUpdate            called by ./FHEM/31_HUEDevice.pm (1898)
2022.01.12 21:53:36.258 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/31_HUEDevice.pm line 1899.
2022.01.12 21:53:36.258 1: readingsUpdate(,xy,0.558,0.4086) missed to call readingsBeginUpdate first.
2022.01.12 21:53:36.258 1:     main::readingsBulkUpdate            called by ./FHEM/31_HUEDevice.pm (1899)
2022.01.12 21:53:36.259 1: readingsUpdate(,reachable,1) missed to call readingsBeginUpdate first.
2022.01.12 21:53:36.259 1: stacktrace:
2022.01.12 21:53:36.259 1:     main::readingsBulkUpdate            called by ./FHEM/31_HUEDevice.pm (1900)
2022.01.12 21:53:36.259 1:     main::HUEDevice_Parse               called by ./FHEM/30_HUEBridge.pm (1988)
2022.01.12 21:53:36.259 1:     main::HUEBridge_dispatch            called by FHEM/HttpUtils.pm (647)
2022.01.12 21:53:36.259 1:     main::__ANON__                      called by fhem.pl (771)
justme1968
zeig mal bitte noch die ausgabe von list TYPE=HUEDevice NR
Jamo
Habe ich Dir per PM geschickt.
Ich habe alle Hue Lampen / Lightstrips mit der Phillips Bridge angebunden, alles andere wie Tradfri / Osram / etc über ConbeeII Deconz.
justme1968
irgendetwas ist bei dir komisch. bitte das ergebnis von {Dumper $modules{HUEDevice}{defptr}}
daedalus0815
...ich kann das Problem von Jamo bestätigen.
Hab' dann die alte Version eingespielt und das LOG war damit sauber.
Bei Bedarf unterstütze ich auch gerne mit LOG-Auszüge etc....
Gutes Neues Jahr an alle
justme1968
sehr komisch...
könnt ihr bitte mal die HUEBridge version von hier: https://forum.fhem.de/index.php/topic,122075.msg1166634.html#msg1166634 probieren? hat das einfluß auf die meldungen?
Jamo
Hallo Justme,
die HueBridge in kombination mit der HUEDevice.pm aus dem gleichen thread,
oder mit dem HUEDevice.pm aus dem HueDevice.pm vom fhem svn?
justme1968
nur die bridge aus dem thread und das aktuelle device modul.
daedalus0815
Hallo Justme,
# $Id: 30_HUEBridge.pm 24296 2021-04-21 08:30:11Z justme1968 $
# $Id: 31_HUEDevice.pm 25444 2022-01-09 15:42:33Z justme1968 $
...im Einsatz und das Ergebnis nach restart fhem:
2022.01.16 12:39:58.830 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at .//FHEM/31_HUEDevice.pm line 1468.
2022.01.16 12:39:58.830 1: PERL WARNING: Use of uninitialized value in string eq at .//FHEM/31_HUEDevice.pm line 1480.
2022.01.16 12:39:58.831 1: PERL WARNING: Use of uninitialized value $name in hash element at .//FHEM/31_HUEDevice.pm line 1607.
2022.01.16 12:39:58.831 1: PERL WARNING: Use of uninitialized value in string eq at .//FHEM/31_HUEDevice.pm line 1621.
2022.01.16 12:39:58.831 1: PERL WARNING: Use of uninitialized value $name in hash element at .//FHEM/31_HUEDevice.pm line 1790.
2022.01.16 12:39:58.831 1: PERL WARNING: Use of uninitialized value $name in hash element at .//FHEM/31_HUEDevice.pm line 1791.
2022.01.16 12:39:58.832 1: PERL WARNING: Use of uninitialized value $name in hash element at .//FHEM/31_HUEDevice.pm line 1811.
2022.01.16 12:39:58.832 1: PERL WARNING: Use of uninitialized value $name in hash element at .//FHEM/31_HUEDevice.pm line 1836.
2022.01.16 12:39:58.832 1: PERL WARNING: Use of uninitialized value $name in hash element at .//FHEM/31_HUEDevice.pm line 1838.
2022.01.16 12:39:58.833 1: ERROR: empty name in readingsBeginUpdate
2022.01.16 12:39:58.833 1: stacktrace:
2022.01.16 12:39:58.833 1:     main::readingsBeginUpdate           called by .//FHEM/31_HUEDevice.pm (1853)
2022.01.16 12:39:58.833 1:     main::HUEDevice_Parse               called by .//FHEM/30_HUEBridge.pm (126)
2022.01.16 12:39:58.834 1:     main::HUEBridge_Read                called by fhem.pl (3896)
2022.01.16 12:39:58.834 1:     main::CallFn                        called by fhem.pl (774)
2022.01.16 12:39:58.834 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4682.
2022.01.16 12:39:58.834 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 4946.
2022.01.16 12:39:58.835 1: readingsUpdate(,reachable,0) missed to call readingsBeginUpdate first.
2022.01.16 12:39:58.835 1: stacktrace:
2022.01.16 12:39:58.835 1:     main::readingsBulkUpdate            called by .//FHEM/31_HUEDevice.pm (1899)
2022.01.16 12:39:58.835 1:     main::HUEDevice_Parse               called by .//FHEM/30_HUEBridge.pm (126)
2022.01.16 12:39:58.836 1:     main::HUEBridge_Read                called by fhem.pl (3896)
2022.01.16 12:39:58.836 1:     main::CallFn                        called by fhem.pl (774)
2022.01.16 12:39:58.836 1: PERL WARNING: Use of uninitialized value in numeric ne (!=) at .//FHEM/31_HUEDevice.pm line 1940.
2022.01.16 12:39:58.836 1: PERL WARNING: Use of uninitialized value in numeric ne (!=) at .//FHEM/31_HUEDevice.pm line 1943.
2022.01.16 12:39:58.837 1: PERL WARNING: Use of uninitialized value in string ne at .//FHEM/31_HUEDevice.pm line 1969.
2022.01.16 12:39:58.837 1: readingsUpdate(,state,unreachable) missed to call readingsBeginUpdate first.
2022.01.16 12:39:58.837 1: stacktrace:
2022.01.16 12:39:58.837 1:     main::readingsBulkUpdate            called by .//FHEM/31_HUEDevice.pm (1969)
2022.01.16 12:39:58.837 1:     main::HUEDevice_Parse               called by .//FHEM/30_HUEBridge.pm (126)
2022.01.16 12:39:58.838 1:     main::HUEBridge_Read                called by fhem.pl (3896)
2022.01.16 12:39:58.838 1:     main::CallFn                        called by fhem.pl (774)
2022.01.16 12:39:58.838 1: PERL WARNING: Use of uninitialized value $dev in hash element at fhem.pl line 3765.
VG
daedalus0815
Gerade update gemacht....,
..immer noch mit bekannten LOG-Fehlern:
31_HUEDevice.pm        25449 2022-01-10 14:41:00Z justme1968
LOG-fehlerfrei bleibt die Kombi...:
31_HUEDevice.pm        25430 2022-01-06 17:28:13Z justme1968
VG
VG
daedalus0815
SIZE 86524 aus o.e. thread:    30_HUEBridge.pm        24296 2021-04-21 08:30:11Z justme1968
SIZE 86454                              31_HUEDevice.pm        25449 2022-01-10 14:41:00Z justme1968
....mit bekannten LOG-Fehler ...
justme1968
#13
bitte probiert mal die angehängte version.
kann es sein das ihr nicht alle lampen/gruppen/sensoren auch in fhem als device angelegt habt?
edit 2022-01-17: ist inzwischen eingecheckt
daedalus0815
Ich verbinde mit deconz...und übernehme möglicherweise nicht alle Devices nach fhem....
Kleiner bug in deinem file ?:
2022.01.16 13:46:11.608 1: reload: Error:Modul 31_HUEDevice deactivated:
syntax error at .//FHEM/31_HUEDevice.pm line 1502, near ")
                                       return"
2022.01.16 13:46:11.608 0: syntax error at .//FHEM/31_HUEDevice.pm line 1502, near ")
                                       return"
2022.01.16 13:46:11.646 1: reload: Error:Modul 31_HUEDevice deactivated:
                                       return"
2022.01.16 13:46:11.646 0: syntax error at .//FHEM/31_HUEDevice.pm line 1502, near ")
                                       return"
2022.01.16 13:46:11.683 1: reload: Error:Modul 31_HUEDevice deactivated:
                                       return"
2022.01.16 13:46:11.683 0: syntax error at .//FHEM/31_HUEDevice.pm line 1502, near ")
                                       return"
