Autor Thema: EnOcean Pi maybe working, TF100l not working problem  (Gelesen 694 mal)
Offline Kassu
  • New Member
« am: 13 Januar 2022, 15:40:14 »
Hi, so i'm Kassu and in a desperate need of help to get my setup running. I have Raspberry Pi 3 B with EnOcean Pi (TCM 301) attatched to it. The Rasp is running bullseye. I configured the config.txt by adding "enable_uart = 1" and "dtoverlay=disable-bt". I also deleted the row including ttyAMA0 in cmdline.txt, updated the Raspberry etc. I also set the baud rate with "sudo stty -f /dev/ttyAMA0 57600".  However when trying to do hexdump < /dev/ttyAMA0 it just stays and returns nothing and i have to stop it with CTRL+C. I don't even know if it is supposed to return something at this point. And this is what ls -l /dev gives me in which serial0 = ttyAMA0 and serial1 = ttyS0:
total 0
crw-r--r--  1 root root     10, 235 Jan 13 14:34 autofs
drwxr-xr-x  2 root root         580 Jan 13 14:34 block
crw-------  1 root root     10, 234 Jan 13 14:34 btrfs-control
drwxr-xr-x  3 root root          60 Jan  1  1970 bus
crw-------  1 root root     10,  63 Jan 13 14:34 cachefiles
crw-rw----  1 root video   240,   0 Jan 13 14:34 cec0
drwxr-xr-x  2 root root        3220 Jan 13 14:34 char
crw--w----  1 root tty       5,   1 Jan 13 14:34 console
crw-------  1 root root     10, 203 Jan 13 14:34 cuse
drwxr-xr-x  7 root root         140 Jan 13 14:34 disk
drwxr-xr-x  2 root root          80 Jan  1  1970 dma_heap
drwxr-xr-x  3 root root         100 Jan 13 14:34 dri
crw-rw----  1 root video    29,   0 Jan 13 14:34 fb0
lrwxrwxrwx  1 root root          13 Aug  7 06:58 fd -> /proc/self/fd
crw-rw-rw-  1 root root      1,   7 Jan 13 14:34 full
crw-rw-rw-  1 root root     10, 229 Jan 13 14:34 fuse
crw-rw----  1 root gpio    254,   0 Jan 13 14:34 gpiochip0
crw-rw----  1 root gpio    254,   1 Jan 13 14:34 gpiochip1
crw-rw----  1 root gpio    254,   2 Jan 13 14:34 gpiochip2
crw-rw----  1 root gpio    246,   0 Jan 13 14:34 gpiomem
crw-------  1 root root    244,   0 Jan 13 14:34 hidraw0
crw-------  1 root root    244,   1 Jan 13 14:34 hidraw1
crw-------  1 root root    244,   2 Jan 13 14:34 hidraw2
crw-------  1 root root    244,   3 Jan 13 14:34 hidraw3
crw-------  1 root root     10, 183 Jan 13 14:34 hwrng
crw-rw----  1 root i2c      89,   2 Jan 13 14:34 i2c-2
lrwxrwxrwx  1 root root          12 Aug  7 06:58 initctl -> /run/initctl
drwxr-xr-x  4 root root         260 Jan 13 14:34 input
crw-r--r--  1 root root      1,  11 Jan 13 14:34 kmsg
lrwxrwxrwx  1 root root          28 Aug  7 06:58 log -> /run/systemd/journal/dev-log
brw-rw----  1 root disk      7,   0 Jan 13 14:34 loop0
brw-rw----  1 root disk      7,   1 Jan 13 14:34 loop1
brw-rw----  1 root disk      7,   2 Jan 13 14:34 loop2
brw-rw----  1 root disk      7,   3 Jan 13 14:34 loop3
brw-rw----  1 root disk      7,   4 Jan 13 14:34 loop4
brw-rw----  1 root disk      7,   5 Jan 13 14:34 loop5
brw-rw----  1 root disk      7,   6 Jan 13 14:34 loop6
brw-rw----  1 root disk      7,   7 Jan 13 14:34 loop7
crw-rw----  1 root disk     10, 237 Jan 13 14:34 loop-control
drwxr-xr-x  2 root root          60 Jan 13 14:34 mapper
crw-rw----  1 root video   241,   0 Jan 13 14:34 media0
crw-rw----  1 root video   241,   1 Jan 13 14:34 media1
crw-r-----  1 root kmem      1,   1 Jan 13 14:34 mem
brw-rw----  1 root disk    179,   0 Jan 13 14:34 mmcblk0
brw-rw----  1 root disk    179,   1 Jan 13 14:34 mmcblk0p1
brw-rw----  1 root disk    179,   2 Jan 13 14:34 mmcblk0p2
drwxrwxrwt  2 root root          40 Jan  1  1970 mqueue
drwxr-xr-x  2 root root          60 Jan 13 14:34 net
crw-rw-rw-  1 root root      1,   3 Jan 13 14:34 null
crw-------  1 root root    108,   0 Jan 13 14:34 ppp
crw-rw-rw-  1 root tty       5,   2 Jan 13 16:22 ptmx
drwxr-xr-x  2 root root           0 Aug  7 06:58 pts
brw-rw----  1 root disk      1,   0 Jan 13 14:34 ram0
brw-rw----  1 root disk      1,   1 Jan 13 14:34 ram1
brw-rw----  1 root disk      1,  10 Jan 13 14:34 ram10
brw-rw----  1 root disk      1,  11 Jan 13 14:34 ram11
brw-rw----  1 root disk      1,  12 Jan 13 14:34 ram12
brw-rw----  1 root disk      1,  13 Jan 13 14:34 ram13
brw-rw----  1 root disk      1,  14 Jan 13 14:34 ram14
brw-rw----  1 root disk      1,  15 Jan 13 14:34 ram15
brw-rw----  1 root disk      1,   2 Jan 13 14:34 ram2
brw-rw----  1 root disk      1,   3 Jan 13 14:34 ram3
brw-rw----  1 root disk      1,   4 Jan 13 14:34 ram4
brw-rw----  1 root disk      1,   5 Jan 13 14:34 ram5
brw-rw----  1 root disk      1,   6 Jan 13 14:34 ram6
brw-rw----  1 root disk      1,   7 Jan 13 14:34 ram7
brw-rw----  1 root disk      1,   8 Jan 13 14:34 ram8
brw-rw----  1 root disk      1,   9 Jan 13 14:34 ram9
crw-rw-rw-  1 root root      1,   8 Jan 13 14:34 random
drwxr-xr-x  2 root root          60 Jan  1  1970 raw
crw-rw-r--+ 1 root netdev   10, 242 Jan 13 14:34 rfkill
lrwxrwxrwx  1 root root           7 Jan 13 14:34 serial0 -> ttyAMA0
lrwxrwxrwx  1 root root           5 Jan 13 14:34 serial1 -> ttyS0
drwxrwxrwt  2 root root          40 Jan 13 16:22 shm
drwxr-xr-x  3 root root         180 Jan 13 14:34 snd
lrwxrwxrwx  1 root root          15 Aug  7 06:58 stderr -> /proc/self/fd/2
lrwxrwxrwx  1 root root          15 Aug  7 06:58 stdin -> /proc/self/fd/0
lrwxrwxrwx  1 root root          15 Aug  7 06:58 stdout -> /proc/self/fd/1
crw-rw-rw-  1 root tty       5,   0 Jan 13 14:34 tty
crw--w----  1 root tty       4,   0 Jan 13 14:34 tty0
crw-------  1 pi   tty       4,   1 Jan 13 14:34 tty1
crw--w----  1 root tty       4,  10 Jan 13 14:34 tty10
crw--w----  1 root tty       4,  11 Jan 13 14:34 tty11
crw--w----  1 root tty       4,  12 Jan 13 14:34 tty12
crw--w----  1 root tty       4,  13 Jan 13 14:34 tty13
crw--w----  1 root tty       4,  14 Jan 13 14:34 tty14
crw--w----  1 root tty       4,  15 Jan 13 14:34 tty15
crw--w----  1 root tty       4,  16 Jan 13 14:34 tty16
crw--w----  1 root tty       4,  17 Jan 13 14:34 tty17
crw--w----  1 root tty       4,  18 Jan 13 14:34 tty18
crw--w----  1 root tty       4,  19 Jan 13 14:34 tty19
crw--w----  1 root tty       4,   2 Jan 13 14:34 tty2
crw--w----  1 root tty       4,  20 Jan 13 14:34 tty20
crw--w----  1 root tty       4,  21 Jan 13 14:34 tty21
crw--w----  1 root tty       4,  22 Jan 13 14:34 tty22
crw--w----  1 root tty       4,  23 Jan 13 14:34 tty23
crw--w----  1 root tty       4,  24 Jan 13 14:34 tty24
crw--w----  1 root tty       4,  25 Jan 13 14:34 tty25
crw--w----  1 root tty       4,  26 Jan 13 14:34 tty26
crw--w----  1 root tty       4,  27 Jan 13 14:34 tty27
crw--w----  1 root tty       4,  28 Jan 13 14:34 tty28
crw--w----  1 root tty       4,  29 Jan 13 14:34 tty29
crw--w----  1 root tty       4,   3 Jan 13 14:34 tty3
crw--w----  1 root tty       4,  30 Jan 13 14:34 tty30
crw--w----  1 root tty       4,  31 Jan 13 14:34 tty31
crw--w----  1 root tty       4,  32 Jan 13 14:34 tty32
crw--w----  1 root tty       4,  33 Jan 13 14:34 tty33
crw--w----  1 root tty       4,  34 Jan 13 14:34 tty34
crw--w----  1 root tty       4,  35 Jan 13 14:34 tty35
crw--w----  1 root tty       4,  36 Jan 13 14:34 tty36
crw--w----  1 root tty       4,  37 Jan 13 14:34 tty37
crw--w----  1 root tty       4,  38 Jan 13 14:34 tty38
crw--w----  1 root tty       4,  39 Jan 13 14:34 tty39
crw--w----  1 root tty       4,   4 Jan 13 14:34 tty4
crw--w----  1 root tty       4,  40 Jan 13 14:34 tty40
crw--w----  1 root tty       4,  41 Jan 13 14:34 tty41
crw--w----  1 root tty       4,  42 Jan 13 14:34 tty42
crw--w----  1 root tty       4,  43 Jan 13 14:34 tty43
crw--w----  1 root tty       4,  44 Jan 13 14:34 tty44
crw--w----  1 root tty       4,  45 Jan 13 14:34 tty45
crw--w----  1 root tty       4,  46 Jan 13 14:34 tty46
crw--w----  1 root tty       4,  47 Jan 13 14:34 tty47
crw--w----  1 root tty       4,  48 Jan 13 14:34 tty48
crw--w----  1 root tty       4,  49 Jan 13 14:34 tty49
crw--w----  1 root tty       4,   5 Jan 13 14:34 tty5
crw--w----  1 root tty       4,  50 Jan 13 14:34 tty50
crw--w----  1 root tty       4,  51 Jan 13 14:34 tty51
crw--w----  1 root tty       4,  52 Jan 13 14:34 tty52
crw--w----  1 root tty       4,  53 Jan 13 14:34 tty53
crw--w----  1 root tty       4,  54 Jan 13 14:34 tty54
crw--w----  1 root tty       4,  55 Jan 13 14:34 tty55
crw--w----  1 root tty       4,  56 Jan 13 14:34 tty56
crw--w----  1 root tty       4,  57 Jan 13 14:34 tty57
crw--w----  1 root tty       4,  58 Jan 13 14:34 tty58
crw--w----  1 root tty       4,  59 Jan 13 14:34 tty59
crw--w----  1 root tty       4,   6 Jan 13 14:34 tty6
crw--w----  1 root tty       4,  60 Jan 13 14:34 tty60
crw--w----  1 root tty       4,  61 Jan 13 14:34 tty61
crw--w----  1 root tty       4,  62 Jan 13 14:34 tty62
crw--w----  1 root tty       4,  63 Jan 13 14:34 tty63
crw--w----  1 root tty       4,   7 Jan 13 14:34 tty7
crw--w----  1 root tty       4,   8 Jan 13 14:34 tty8
crw--w----  1 root tty       4,   9 Jan 13 14:34 tty9
crw-rw----  1 root dialout 204,  64 Jan 13 15:41 ttyAMA0
crw-------  1 root root      5,   3 Jan 13 14:34 ttyprintk
crw-rw----  1 root dialout   4,  64 Jan 13 14:34 ttyS0
crw-------  1 root root     10, 239 Jan 13 14:34 uhid
crw-------  1 root root     10, 223 Jan 13 14:34 uinput
crw-rw-rw-  1 root root      1,   9 Jan 13 14:34 urandom
drwxr-xr-x  2 root root          60 Aug  7 06:58 usb
drwxr-xr-x  3 root root          60 Jan 13 14:34 v4l
crw-rw----  1 root video   243,   0 Jan 13 14:34 vchiq
crw-rw----  1 root video   247,   0 Jan 13 14:34 vcio
crw-------  1 root root    248,   0 Jan 13 14:34 vc-mem
crw-rw----  1 root tty       7,   0 Jan 13 14:34 vcs
crw-rw----  1 root tty       7,   1 Jan 13 14:34 vcs1
crw-rw----  1 root tty       7,   2 Jan 13 14:34 vcs2
crw-rw----  1 root tty       7,   3 Jan 13 14:34 vcs3
crw-rw----  1 root tty       7,   4 Jan 13 14:34 vcs4
crw-rw----  1 root tty       7,   5 Jan 13 14:34 vcs5
crw-rw----  1 root tty       7,   6 Jan 13 14:34 vcs6
crw-rw----  1 root tty       7,   7 Jan 13 14:34 vcs7
crw-rw----  1 root tty       7, 128 Jan 13 14:34 vcsa
crw-rw----  1 root tty       7, 129 Jan 13 14:34 vcsa1
crw-rw----  1 root tty       7, 130 Jan 13 14:34 vcsa2
crw-rw----  1 root tty       7, 131 Jan 13 14:34 vcsa3
crw-rw----  1 root tty       7, 132 Jan 13 14:34 vcsa4
crw-rw----  1 root tty       7, 133 Jan 13 14:34 vcsa5
crw-rw----  1 root tty       7, 134 Jan 13 14:34 vcsa6
crw-rw----  1 root tty       7, 135 Jan 13 14:34 vcsa7
crw-rw----  1 root video    10,  62 Jan 13 14:34 vcsm-cma
crw-rw----  1 root tty       7,  64 Jan 13 14:34 vcsu
crw-rw----  1 root tty       7,  65 Jan 13 14:34 vcsu1
crw-rw----  1 root tty       7,  66 Jan 13 14:34 vcsu2
crw-rw----  1 root tty       7,  67 Jan 13 14:34 vcsu3
crw-rw----  1 root tty       7,  68 Jan 13 14:34 vcsu4
crw-rw----  1 root tty       7,  69 Jan 13 14:34 vcsu5
crw-rw----  1 root tty       7,  70 Jan 13 14:34 vcsu6
crw-rw----  1 root tty       7,  71 Jan 13 14:34 vcsu7
crw-------  1 root root     10, 137 Jan 13 14:34 vhci
crw-rw----+ 1 root video    81,   4 Jan 13 14:34 video10
crw-rw----+ 1 root video    81,   5 Jan 13 14:34 video11
crw-rw----+ 1 root video    81,   6 Jan 13 14:34 video12
crw-rw----+ 1 root video    81,   0 Jan 13 14:34 video13
crw-rw----+ 1 root video    81,   1 Jan 13 14:34 video14
crw-rw----+ 1 root video    81,   2 Jan 13 14:34 video15
crw-rw----+ 1 root video    81,   3 Jan 13 14:34 video16
crw-rw----+ 1 root video    81,   7 Jan 13 14:34 video18
crw-------  1 root root     10, 130 Jan 13 14:34 watchdog
crw-------  1 root root    250,   0 Jan 13 14:34 watchdog0
crw-rw-rw-  1 root root      1,   5 Jan 13 14:34 zero
After this i thought that let's just try to install FHEM and i did. The EnOcean in the left did not come but after adding one it did. First i added TF100L by eltako (A5-38-08) with these (i took the outlet off and put it back in and the teach is supposed to be on then?):
define Swit EnOcean <id behind the outlet> A5-38-08
set Swit teach
And here is also the log file in the FHEM (in fhem config the TCM_ESP.. is defined with baud rate of 57600) :
2022.01.13 16:34:48 1: Including fhem.cfg
2022.01.13 16:34:49 3: WEB: port 8083 opened
2022.01.13 16:34:49 2: eventTypes: loaded 7 lines from ./log/eventTypes.txt
2022.01.13 16:34:49 3: Opening TCM_ESP3_0 device /dev/ttyAMA0
2022.01.13 16:34:49 3: Setting TCM_ESP3_0 serial parameters to 57600,8,N,1
2022.01.13 16:34:49 3: TCM_ESP3_0 device opened
2022.01.13 16:34:50 2: EnOcean Cryptographic functions are not available.
2022.01.13 16:34:53 2: EnOcean XML functions are not available.
2022.01.13 16:34:53 1: Including ./log/fhem.save
2022.01.13 16:34:53 3: TCM TCM_ESP3_0 set reset
2022.01.13 16:34:54 3: TCM TCM_ESP3_0 get baseID
2022.01.13 16:34:54 2: TCM TCM_ESP3_0 RESPONSE: BaseID: FFF79600 RemainingWriteCycles: 0A
2022.01.13 16:34:54 3: TCM TCM_ESP3_0 get version
2022.01.13 16:34:54 2: TCM TCM_ESP3_0 RESPONSE: APIVersion: 02060900 APPVersion: 020F0000 ChipID: 051AEF2C ChipVersion: 454F0103 Desc: GATEWAYCTRL
2022.01.13 16:34:54 3: TCM TCM_ESP3_0 set repeater 0000
2022.01.13 16:34:54 2: TCM TCM_ESP3_0 repeater 0000 restored
2022.01.13 16:34:54 3: TCM TCM_ESP3_0 set smartAckMailboxMax 0
2022.01.13 16:34:54 2: TCM TCM_ESP3_0 smartAckMailboxMax 0 restored
2022.01.13 16:34:54 3: TCM TCM_ESP3_0 set mode 00
2022.01.13 16:34:54 2: TCM TCM_ESP3_0 RESPONSE: NOT_SUPPORTED
2022.01.13 16:34:54 3: TCM TCM_ESP3_0 set maturity 01
2022.01.13 16:34:54 2: TCM TCM_ESP3_0 maturity 01 restored
2022.01.13 16:34:54 2: TCM TCM_ESP3_0 initialized
2022.01.13 16:34:54 2: TCM registered transceiver BaseID: FFF79600 ChipID: 051AEF2C
2022.01.13 16:34:54 1: usb create starting
2022.01.13 16:34:54 3: Probing ZWDongle device /dev/serial1
2022.01.13 16:34:54 3: Probing CUL device /dev/ttyS0
2022.01.13 16:34:54 1: usb create end
2022.01.13 16:34:54 2: EnOcean swit XML functions are not available
2022.01.13 16:34:54 0: Featurelevel: 6.1
2022.01.13 16:34:54 0: Server started with 9 defined entities (fhem.pl:25193/2021-11-07 perl:5.032001 os:linux user:fhem pid:2523)
2022.01.13 16:35:26 2: AttrTemplates: got 230 entries
The Swit did came and it could be found under the EnOcean of the left side. However the on/off did not change the light etc it did not work and i don't know if the EnOcean even sends anything, does it work, because i can't test because the hexdump doesn't return anything. I hope someone can tell me if the EnOcean Pi is even working?
Offline Kassu
  • New Member
Antw:EnOcean Pi maybe working, TF100l not working problem
« Antwort #1 am: 13 Januar 2022, 16:50:48 »
A small update: I donwloaded a EnOceanSpy for the rasp and with that one i got it working. When pressing PTM215 and running the spy for ttyAMA0 i get something like shown below. The one below is now done with hexdump. This is a step forward. Next i need to try to add something to fhem.
pi@raspberrypi:~ $ hexdump -C < /dev/ttyAMA0
00000000  55 00 07 07 01 7a f6 10  fe f9 03 5d 30 02 ff ff  |U....z.....]0...|
00000010  ff ff 2a 00 d0 55 00 07  07 01 7a f6 00 fe f9 03  |..*..U....z.....|
00000020  5d 20 03 ff ff ff ff 2a  00 47 55 00 07 07 01 7a  |] .....*.GU....z|
00000030  f6 30 fe f9 03 5d 30 03  ff ff ff ff 2a 00 f1 55  |.0...]0.....*..U|
00000040  00 07 07 01 7a f6 00 fe  f9 03 5d 20 02 ff ff ff  |....z.....] ....|
00000050  ff 2a 00 98 55 00 07 07  01 7a f6 50 fe f9 03 5d  |.*..U....z.P...]|
00000060  30 02 ff ff ff ff 2a 00  2b 55 00 07 07 01 7a f6  |0.....*.+U....z.|
00000070  00 fe f9 03 5d 20 02 ff  ff ff ff 2a 00 98 55 00  |....] .....*..U.|
But thanks very much for this community i have gone this far. Bu still need help adding stuff to fhem,
Offline Kassu
  • New Member
« Antwort #2 am: 13 Januar 2022, 21:51:48 »
Sorry about my stuff. I've figured it out. The Eltako TF100D switch had a unique way of setting the teach mode. If it has a connected button, you need to activate the teach mode with that by pressing in certain way. And after that with already mentioned set ID teach i was able to add it to my fhem. Also the hexdump does not print anything if no EnOCean signals are being transmitted, that's one thing i learned. Most of my answers i found from this community so thank you.
