[27.01.22] hue seit update unbrauchbar
Begonnen von the ratman, 27 Januar 2022, 16:22:55
the ratman
hiho,
seit dem heutigen update bekomme ich beim z.b. schalten einer lampe pro klick:2022.01.27 16:15:22 1:  PERL WARNING: Use of uninitialized value in string ne at ./FHEM/30_HUEBridge.pm line 1283.
2022.01.27 16:15:22 1:  stacktrace:
2022.01.27 16:15:22 1:      main::__ANON__                      called by ./FHEM/30_HUEBridge.pm (1283)
2022.01.27 16:15:22 1:      main::HUEBridge_V2IdOfV1Id          called by ./FHEM/31_HUEDevice.pm (1163)
2022.01.27 16:15:22 1:      main::HUEDevice_Set                 called by fhem.pl (3898)
2022.01.27 16:15:22 1:      main::CallFn                        called by fhem.pl (1932)
2022.01.27 16:15:22 1:      main::DoSet                         called by fhem.pl (1974)
2022.01.27 16:15:22 1:      main::CommandSet                    called by fhem.pl (2853)
2022.01.27 16:15:22 1:      main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3271)
2022.01.27 16:15:22 1:      main::FW_devState                   called by ./FHEM/95_FLOORPLAN.pm (594)
2022.01.27 16:15:22 1:      main::FP_show                       called by ./FHEM/95_FLOORPLAN.pm (380)
2022.01.27 16:15:22 1:      main::FP_CGI                        called by ./FHEM/01_FHEMWEB.pm (992)
2022.01.27 16:15:22 1:      main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (598)
2022.01.27 16:15:22 1:      main::FW_Read                       called by fhem.pl (3898)
2022.01.27 16:15:22 1:      main::CallFn                        called by fhem.pl (776)
2022.01.27 16:15:22 1:  PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/31_HUEDevice.pm line 1165.
2022.01.27 16:15:22 1:      main::__ANON__                      called by ./FHEM/31_HUEDevice.pm (1165)
2022.01.27 16:15:22 1:      main::FW_devState                   called by ./FHEM/33_readingsGroup.pm (560)
2022.01.27 16:15:22 1:      main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (1109)
2022.01.27 16:15:22 1:      main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1210)
2022.01.27 16:15:22 1:      main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (3376)
log eingekürzt, weils hier sonst nicht rein passt. schalten lässt sich dann natürlich auch nix mehr.
mit den gestrigen 2 hue-files tritt das problem nicht auf
→do↑p!dnʇs↓shit←
justme1968
mir ist nicht klar wie an dieser stelle etwas nicht initialisiert sein kann. das sollte nicht passieren. schon garnicht bei einem klick und selbst wenn sollte es das schalten nicht verhindern. ich habe noch zwei sicherheitsabfagen eingebaut. Schuhe morgen mal ob das hilft.
bisher ist das ganze auch noch nicht bei mir oder einem anderen aufgefallen.
daedalus0815
Hallo @justme1968
echt nix für ungut....bei mir geht auch mal wieder nix.
Okay...Das war jetzt nicht sehr konstruktiv...ich würde mich gern als Beta-Tester anbieten.... "the ratman" vielleicht auch.
In letzter Zeit sind die RollOuts etwas suboptimal....damit muss man doch nicht alle fhemLer belasten.
Meine Schalt-DOIFs gehen halt von gewisssen Rahmenbedingungen aus, die in der Vergangenheit gegeben waren....
Und der Event-Manager meldet momentan auch mal nix mehr....da kann ja ergo nix schalten
Ich spiel jetzt eine alte Version ein   ;) ....mal wieder
daedalus0815
Hallo @the ratman
...wieso treffen wir uns hier immer wieder ?   ;)
Sind wir vielleicht die einzigen in der Kombi Zigbee/deconz oder irre ich mich ?
VG
the ratman
thx @justme1968 fürs richten - ich berichte dann morgen.
allerdings frag ich mich, warum dann die gestrigen 2 .pm's funzen.
btw - ich hab kein deconz oder so - ich habe exakt 1 philips hue bridge - die eckige aus 2015.
dazu hab ich auch nur philips-zeug und offiziell unterstützte sensoren. hier ein paar daten, wenn's hilft:manufacturer Signify
modelName Philips hue bridge 2015
modelid BSB002
name ratOhaus-HUE
swversion 1949203030
updatestate 0
zigbeechannel 20
als betatester eigne ich mich normal weniger - ich hab nur ein echtsystem, keine ahnung und eine frau mit großem nudelholz.
→do↑p!dnʇs↓shit←
daedalus0815
thx @justme1968
in der aktuellen Version
Event-Monitor:
2022-01-28 08:25:25 HUEDevice HUESwitch2 1000
2022-01-28 08:25:26 HUEDevice HUESwitch2 1002
Der ALTE DOIF-Ausschnitt:
DOELSEIF
([HUESwitch2:"^100"]  and [?HUE_Tresen:&STATE] eq "on" )
   ( set HUE_Tresen off )
DOELSEIF
( [HUESwitch2:"^100"]  and  [?HUE_Tresen:&STATE] eq "off" )
   ( set HUE_Tresen pct 48   )
Die Logik:
HUESwitch2 gedrückt UND Licht an, dann Licht aus
HUESwitch2 gedrückt UND Licht aus, dann Licht an
Soweit, so gut...das hatte bisher funktioniert in der alten Version.
In der neuen HUE-Version kann ich nicht mehr ausschalten....das Licht geht direkt wieder an:
Es scheint so zu sein, dass in der neuen Version der HUE_Tresen:&STATE   "zu schnell"  8) ein Update erfährt.
"Zu schnell" ist natürlich relativ, da man das ja auch als Verbesserung betrachten kann und sich das Problem nach
dieser Erkenntnis umgehen läßt:
Der NEUE DOIF-Ausschnitt:
DOELSEIF
([HUESwitch2:"^1002"]  and [?HUE_Tresen:&STATE] eq "on" )
DOELSEIF
( [HUESwitch2:"^1002"]  and  [?HUE_Tresen:&STATE] eq "off" )
   ( set HUE_Tresen on   )
Mir fällt immer mal wieder auf, dass eine optional einstellbare TOT-Zeit über das gesammte DOIF z.B. nach Auslösung eines DOIFs-Events
wirklich nützlich wäre.
cmdPause zieht hier ja nicht, da sich der Ausführungszweig über das rasend schnelle &STATE ändert....
Vielleicht könnte man sich mit einem DOIF wait als Hotfix zwar helfen, das würde aber ungewollt das Schalten  verzögern
Vielleich hat ja jemand eine Idee, wie man immer an das LETZTE HUE-event (im Beispiel: 1002) kommt, da
dort beim Länger-drücken eine 1003 steht.
Mit einer generell einstellbaren DOIF-Totzeit  wäre man in der o.e. ALTEN-DOIF-Version immer aus dem Schneider ...
justme1968
zu doif kann ich dir nichts sagen. das verwende ich nicht. das verhalten sollte aber unabhängig davon sein ob doif oder notify.
was mir auffällt:
- warum STATE? das ist immer ungeschickt da es kein reading ist, von stateFormat beeinflußt wird und
  nicht zum gleichen zeitpunkt wie wie die readings vom modul aktualisiert wird sondern von fhem selber
- zu schnell gibt es nicht :). die events kommen rein wie sie kommen und werden weitergeleitet.
  eher war es so das in der alten version events 'verschluckt' wurden.
- die alte version hat das event nicht genau genau genug spezifiziert sondern reagiert auf drücken und
  loslassen.in verbindung mit dem vorherigen punkt passte die logik meiner meinung nach nicht. auf ein
  drücken kommt immer ein loslassen und d.h. im gleichen drücken und loslassen vorgang schaltest du
  erst ein dann aus. wenn das vorher ging ist das denke ich eher zufall. besser ist es das event immer so
  genau wie möglich zu spezifizieren. eine totzeit ist in diesem fall ein workaround um die ungenaue event
  angabe auszubügeln.
- (je nach taster und bridge:) warum machst du das über fhem und nicht über direkte verknüpfung/regeln?
daedalus0815
#7
Jau, dem kann ich folgen....heute kommt halt mehr durch....wurde ja auch so vom Device abgesetzt.
Bedauerlicherweise steht man (justme1968) dann durch Updates auch gleich unter Verdacht....Sorry  :'(.
.....das Dickicht lichtet sich...die für mich beste Lösung sieht jetzt so aus, die erste 1000er - Sequenz zu eliminieren:
Die erste Bedingung fängt nun das  "HUESwitch2 1000" der Sequenz ab.....:
( [HUESwitch2:"000"]   )
DOELSEIF       ### alle 100xxxxx
DOELSEIF
Zur Totzeit-Diskussion:
https://forum.fhem.de/index.php/topic,125792.0.html
P.S:
....direktes Binding:
Bei mir steht ja auch nicht " set HUE_Becken on"
sondern  "set HUE_Becken pct 68".... und das noch in verschieden Varianten für verschiedene Uhrzeiten (Morgens/Abends) und
Abhängigkeiten zum Alarmstatus...... Weil man's mit FHEM halt so toll kann   :)
DANKE
justme1968
ja. events immer immer genau genug spezifizieren.
zum direkten binding: deshalb hatte ich ja geschrieben je nach bridge und taster... kann man auch aus der bridge etwas anderes als nur on setzen und auch zeitabhängig anderes. die hue app kann das eingeschränkt, iconnecthue kann das flexibler und fhem kann das am flexibelsten (da du die rules im quelltext abfassen kannst) und am schlechtesten dokumentiert (da du die hue entwickler doku lesen musst).
justme1968
was ich oben noch vergessen habe der einzig wirklich sinnvolle weg um festzustellen ob eine lampe an oder aus ist ist das onoff reading. alle anderen readings und erst recht STATE haben in bestimmten randbedingungen werte über die du stolpern könntest.
the ratman
sorry, a bissi später dran
gleich nach dem update nach dem öffnen des floorplan im log: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/31_HUEDevice.pm line 1165.
2022.01.28 14:07:57 1:  stacktrace:
2022.01.28 14:07:57 1:      main::__ANON__                      called by ./FHEM/31_HUEDevice.pm (1165)
2022.01.28 14:07:57 1:      main::HUEDevice_Set                 called by fhem.pl (3898)
2022.01.28 14:07:57 1:      main::CallFn                        called by fhem.pl (1932)
2022.01.28 14:07:57 1:      main::DoSet                         called by fhem.pl (1974)
2022.01.28 14:07:57 1:      main::CommandSet                    called by fhem.pl (2853)
2022.01.28 14:07:57 1:      main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3271)
2022.01.28 14:07:57 1:      main::FW_devState                   called by ./FHEM/95_FLOORPLAN.pm (594)
2022.01.28 14:07:57 1:      main::FP_show                       called by ./FHEM/95_FLOORPLAN.pm (380)
2022.01.28 14:07:57 1:      main::FP_CGI                        called by ./FHEM/01_FHEMWEB.pm (992)
2022.01.28 14:07:57 1:      main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (598)
2022.01.28 14:07:57 1:      main::FW_Read                       called by fhem.pl (3898)
2022.01.28 14:07:57 1:      main::CallFn                        called by fhem.pl (776)
2022.01.28 14:07:57 1:  PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/31_HUEDevice.pm line 1165.
2022.01.28 14:07:58 1:  PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/31_HUEDevice.pm line 1165.
2022.01.28 14:07:58 1:  stacktrace:
2022.01.28 14:07:58 1:      main::__ANON__                      called by ./FHEM/31_HUEDevice.pm (1165)
2022.01.28 14:07:58 1:      main::HUEDevice_Set                 called by fhem.pl (3898)
2022.01.28 14:07:58 1:      main::CallFn                        called by fhem.pl (1932)
2022.01.28 14:07:58 1:      main::DoSet                         called by fhem.pl (1974)
2022.01.28 14:07:58 1:      main::CommandSet                    called by fhem.pl (2853)
2022.01.28 14:07:58 1:      main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3271)
2022.01.28 14:07:58 1:      main::FW_devState                   called by ./FHEM/33_readingsGroup.pm (560)
2022.01.28 14:07:58 1:      main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (1109)
2022.01.28 14:07:58 1:      main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1210)
2022.01.28 14:07:58 1:      main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (3376)
2022.01.28 14:07:58 1:      main::FW_devState                   called by ./FHEM/95_FLOORPLAN.pm (594)
2022.01.28 14:07:58 1:      main::FP_show                       called by ./FHEM/95_FLOORPLAN.pm (380)
2022.01.28 14:07:58 1:      main::FP_CGI                        called by ./FHEM/01_FHEMWEB.pm (992)
2022.01.28 14:07:58 1:      main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (598)
2022.01.28 14:07:58 1:      main::FW_Read                       called by fhem.pl (3898)
2022.01.28 14:07:58 1:      main::CallFn                        called by fhem.pl (776)
bei jedem ein/aus-schalten einer hue lampe - aber immerhin kann ich sie wieder abschalten *g*:2022.01.28 14:09:13 1:  PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/31_HUEDevice.pm line 1165.
2022.01.28 14:09:13 1:  stacktrace:
2022.01.28 14:09:13 1:      main::__ANON__                      called by ./FHEM/31_HUEDevice.pm (1165)
2022.01.28 14:09:13 1:      main::HUEDevice_Set                 called by fhem.pl (3898)
2022.01.28 14:09:13 1:      main::CallFn                        called by fhem.pl (1932)
2022.01.28 14:09:13 1:      main::DoSet                         called by fhem.pl (1974)
2022.01.28 14:09:13 1:      main::CommandSet                    called by fhem.pl (2853)
2022.01.28 14:09:13 1:      main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3271)
2022.01.28 14:09:13 1:      main::FW_devState                   called by ./FHEM/33_readingsGroup.pm (1466)
2022.01.28 14:09:13 1:      main::readingsGroup_Notify          called by fhem.pl (3898)
2022.01.28 14:09:13 1:      main::CallFn                        called by fhem.pl (3815)
2022.01.28 14:09:13 1:      main::DoTrigger                     called by fhem.pl (4913)
2022.01.28 14:09:13 1:      main::readingsEndUpdate             called by ./FHEM/31_HUEDevice.pm (2066)
2022.01.28 14:09:13 1:      main::HUEDevice_Parse               called by ./FHEM/30_HUEBridge.pm (2570)
2022.01.28 14:09:13 1:      main::HUEBridge_dispatch            called by FHEM/HttpUtils.pm (741)
2022.01.28 14:09:13 1:      main::HttpUtils_DataComplete        called by FHEM/HttpUtils.pm (638)
2022.01.28 14:09:13 1:      main::__ANON__                      called by fhem.pl (773)
2022.01.28 14:09:15 1:  PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/31_HUEDevice.pm line 1165.
2022.01.28 14:09:15 1:  stacktrace:
2022.01.28 14:09:15 1:      main::__ANON__                      called by ./FHEM/31_HUEDevice.pm (1165)
2022.01.28 14:09:15 1:      main::HUEDevice_Set                 called by fhem.pl (3898)
2022.01.28 14:09:15 1:      main::CallFn                        called by fhem.pl (1932)
2022.01.28 14:09:15 1:      main::DoSet                         called by fhem.pl (1974)
2022.01.28 14:09:15 1:      main::CommandSet                    called by fhem.pl (2853)
2022.01.28 14:09:15 1:      main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3271)
2022.01.28 14:09:15 1:      main::FW_devState                   called by ./FHEM/33_readingsGroup.pm (1466)
2022.01.28 14:09:15 1:      main::readingsGroup_Notify          called by fhem.pl (3898)
2022.01.28 14:09:15 1:      main::CallFn                        called by fhem.pl (3815)
2022.01.28 14:09:15 1:      main::DoTrigger                     called by fhem.pl (4913)
2022.01.28 14:09:15 1:      main::readingsEndUpdate             called by ./FHEM/31_HUEDevice.pm (2066)
2022.01.28 14:09:15 1:      main::HUEDevice_Parse               called by ./FHEM/30_HUEBridge.pm (2570)
2022.01.28 14:09:15 1:      main::HUEBridge_dispatch            called by FHEM/HttpUtils.pm (741)
2022.01.28 14:09:15 1:      main::HttpUtils_DataComplete        called by FHEM/HttpUtils.pm (638)
2022.01.28 14:09:15 1:      main::__ANON__                      called by fhem.pl (773)
ich geh wieder auf die version von vorgestern zurück ...
→do↑p!dnʇs↓shit←
Jamo
ja, die Meldung "HUEDevice.pm line 1165" habe ich auch, aber generell läufts! Dank an justme!!!
Bullseye auf iNUC, Homematic + HMIP(UART/HMUSB), Debmatic, HUEBridge, Zigbee/Conbee III, FB7690, Alexa (fhem-lazy), Livetracking, LaCrosse JeeLink, LoRaWan / TTN / Chirpstack, Sonos, ESPresence
justme1968
ich habe eben eine version eingecheckt die noch mehr mögliche warnungen abfängt. ansonsten kannst du stacktrace auch ausschalten bis es gebraucht wird.
the ratman
#13
neues update schaut gut aus.
keine warnings beim anstarten, keine warnings beim lampen schalten und mein saugbot steht bis jetzt auch still in seiner ecke.
seit ich stacktrace an hab, krieg ich keine schimpfer mehr von den programmierern hier, weil gleich ein haufen infos mit kommt. außerdem ists in meinen augen besser, probleme zu lösen, als sie zu ignorieren ... besser wird sowas ja eher selten mit der zeit *g*.
aja, weil ma schon so schön beim reden sind:
da ich wegen state und nicht state hier gelesen zu haben meine. was mach ich mit meinem schalter für den bot in so nem falle?
der liefert die info nur am state und in keinem eigenen reading - wenn du da was machen wollen würdest, würd ich mich nicht beschweren.
das wären dimmer, jener art:manufacturername Signify Netherlands B.V.
modelid RWL021
on 1
productname Hue dimmer switch
reachable 1
swversion 6.1.1.28573
type ZLLSwitch
mehr readings gibts da nicht:IODev huebridge 2022-01-29 10:09:30
battery 28 2022-01-29 10:08:52
batteryPercent 28 2022-01-29 10:08:52
batteryState normal 2022-01-29 10:08:52
eventtype repeat 2022-01-28 17:38:47
input 1 2022-01-28 17:38:47
reachable 1 2022-01-28 17:38:48
state 1003 2022-01-28 17:38:48
→do↑p!dnʇs↓shit←
justme1968
@daedalus0815: falls du auch mit der engen event definition noch probleme hast schau dir bitte mal die erklärung und die test version von hier: https://forum.fhem.de/index.php/topic,11020.msg1204325.html#msg1204325 an.
