Log Fehlermeldungen bei FHEM Start
Begonnen von Burny4600, 15 Februar 2022, 12:15:12
Burny4600
Heute ist mir im Log nach dem Start folgendes ausgefallen.
2022.02.15 11:59:16.634 3: FS20 set AB_SG_BLGO off
2022.02.15 11:59:28.919 3: nanoCUL433_EG IT_set: EG_KUE_BB off
2022.02.15 11:59:29.143 2: IT IODev device didn't answer is command correctly:   raw => omFFFFF8F3
2022.02.15 11:59:29.384 3: nanoCUL433_EG IT_set: L_EG_TER off
2022.02.15 11:59:29.500 2: IT IODev device didn't answer is command correctly:   raw => omA8A86E85C46A01FFD4543742E23500FFEA2B0DD0B88D41E0FD
2022.02.15 11:59:30.783 3: nanoCUL433_EG IT_set: AB_SG_HT_WBL off
2022.02.15 11:59:30.900 2: IT IODev device didn't answer is command correctly:   raw => om913520C430E4
2022.02.15 11:59:30.901 3: nanoCUL433_OG2 IT_set: AB_GAO_WBL off
2022.02.15 11:59:31.125 2: IT IODev device didn't answer is command correctly:   raw => omAC48900B048180EA
2022.02.15 11:59:31.502 3: nanoCUL433_OG1 IT_set: OG1_VR_BLILO off
2022.02.15 11:59:31.619 2: IT IODev device didn't answer is command correctly:   raw => omFFD4543742E23500FFEA2A1BA1711A807FF5150DD0B88D4000FD
Was verursacht diesen Fehler?
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
