Hier mal ein list des Devices
CULMAX0_MSGCNT 47
CULMAX0_TIME 2022-03-25 19:00:18
DEF HeatingThermostat 0df929
FUUID 5c44de8a-f33f-33d2-1657-a2cc62f2e788f654
IODev CULMAX0
LASTInputDev CULMAX0
MSGCNT 47
NAME Hzg_Sammy
NR 50
NTFY_ORDER 50-Hzg_Sammy
STATE 16.0
SVN 23517
TYPE MAX
TimeSlot 0
addr 0df929
devtype 1
type HeatingThermostat
webCmd desiredTemperature
2022-03-25 19:00:18 RSSI -57
2016-10-22 19:11:19 TimeInformationHour 5
2022-03-25 19:00:18 battery ok
2022-03-25 19:00:18 batteryState ok
2022-03-25 19:00:18 desiredTemperature 16.0
2022-03-25 19:00:18 deviation 6.3
2019-10-05 21:49:06 firmware 1.0
2022-03-25 19:00:18 gateway 1
2019-10-05 21:49:06 groupid 0
2022-03-25 13:23:15 lastTimeSync 2022-03-25 13:23:15
2022-03-16 15:12:12 lastcmd desiredTemperature 20.0 20.0
2022-03-25 19:00:18 mode auto
2022-03-25 13:23:15 msgcnt 111
2022-03-25 19:00:18 panel unlocked
2022-03-25 19:00:18 peerIDs 000000,0e6702
2022-03-25 19:00:18 peerList Broadcast,MAX_0e6702
2022-03-25 19:00:18 rferror 0
2022-03-25 19:00:18 state 16.0
2022-03-25 19:00:18 temperature 22.3
2019-10-05 21:49:06 testresult 160
2022-03-25 19:00:18 valveposition 0
2021-02-09 17:38:58 weekprofile-0-Sat-temp 16.0 °C / 20.0 °C / 16.0 °C
2021-02-09 17:38:58 weekprofile-0-Sat-time 00:00-09:00 / 09:00-19:00 / 19:00-24:00
2021-02-09 17:38:58 weekprofile-1-Sun-temp 16.0 °C / 20.0 °C / 16.0 °C
2021-02-09 17:38:58 weekprofile-1-Sun-time 00:00-09:00 / 09:00-19:00 / 19:00-24:00
2021-02-09 17:38:58 weekprofile-2-Mon-temp 16.0 °C / 20.0 °C / 16.0 °C
2021-02-09 17:38:58 weekprofile-2-Mon-time 00:00-09:00 / 09:00-19:00 / 19:00-24:00
2021-02-09 17:38:58 weekprofile-3-Tue-temp 16.0 °C / 20.0 °C / 16.0 °C
2021-02-09 17:38:58 weekprofile-3-Tue-time 00:00-09:00 / 09:00-19:00 / 19:00-24:00
2021-02-09 17:38:58 weekprofile-4-Wed-temp 16.0 °C / 20.0 °C / 16.0 °C
2021-02-09 17:38:58 weekprofile-4-Wed-time 00:00-09:00 / 09:00-19:00 / 19:00-24:00
2021-02-09 17:38:58 weekprofile-5-Thu-temp 16.0 °C / 20.0 °C / 16.0 °C
2021-02-09 17:38:58 weekprofile-5-Thu-time 00:00-09:00 / 09:00-19:00 / 19:00-24:00
2021-02-09 17:38:58 weekprofile-6-Fri-temp 16.0 °C / 20.0 °C / 16.0 °C
2021-02-09 17:38:58 weekprofile-6-Fri-time 00:00-09:00 / 09:00-19:00 / 19:00-24:00
helper:
io:
CUL_0:
raw Z0F0004600DF9290000000018002000DF
rssi -57
time 1648231218.13836
IODev CULMAX0
model HeatingThermostat
room MAX
userattr scnProcessByDesiChange:0,1 scnShutterList scnModeHandling:NOCHANGE,AUTO,MANUAL
verbose 1
Und ein list des CUL
CMDS BbCFiAZEGMKUYRTVWXefmltux
CUL_0_MSGCNT 2923
CUL_0_TIME 2022-03-25 20:44:52
Clients :CUL_MAX:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:STACKABLE:
DEF /dev/ttyACM0@9600 1034
DeviceName /dev/ttyACM0@9600
FD 16
FHTID 1034
FUUID 5c44de89-f33f-33d2-0118-96e436e882a877f6
NAME CUL_0
NR 40
NR_CMD_LAST_H 4
PARTIAL
RAWMSG Z0E940202064B290A0D73000118002C1A
RSSI -61
STATE Initialized
TYPE CUL
VERSION V 1.61 CUL868
initString X21
Zr
Za123456
Zw111111
MatchList:
1:CUL_MAX ^Z........................
8:HMS ^810e04....(1|5|9).a001
D:CUL_IR ^I............
H:STACKABLE_CC ^\*
M:TSSTACKED ^\*
N:STACKABLE ^\*
2022-03-25 20:05:13 ccconf freq:868.300MHz bWidth:101KHz rAmpl:33dB sens:8dB
2022-03-23 10:22:38 cmds B b C F i A Z E G M K U Y R T V W X e f m l t u x
2022-03-25 18:23:34 credit10ms 581
2022-03-25 20:44:52 state Initialized
2018-02-15 18:40:34 uptime 101 04:44:48
2019-01-29 19:48:00 version V 1.61 CUL868
XMIT_TIME:
1648228995.24945
1648229001.76263
1648229008.2722
1648229014.78218
rfmode MAX
verbose 1
Ein Tagesauszug des Plotfiles
2022-03-24_19:01:03 Hzg_Sammy RSSI: -57.5
2022-03-24_19:01:03 Hzg_Sammy battery: ok
2022-03-24_19:01:03 Hzg_Sammy batteryState: ok
2022-03-24_19:01:03 Hzg_Sammy rferror: 0
2022-03-24_19:01:03 Hzg_Sammy gateway: 1
2022-03-24_19:01:03 Hzg_Sammy mode: auto
2022-03-24_19:01:03 Hzg_Sammy panel: unlocked
2022-03-24_19:01:03 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-24_19:01:03 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_01:23:14 Hzg_Sammy lastTimeSync: 2022-03-25 01:23:14
2022-03-25_01:23:15 Hzg_Sammy valveposition: 0
2022-03-25_01:23:15 Hzg_Sammy 16.0
2022-03-25_01:23:15 Hzg_Sammy desiredTemperature: 16.0
2022-03-25_01:23:15 Hzg_Sammy RSSI: -56
2022-03-25_01:23:15 Hzg_Sammy battery: ok
2022-03-25_01:23:15 Hzg_Sammy batteryState: ok
2022-03-25_01:23:15 Hzg_Sammy rferror: 0
2022-03-25_01:23:15 Hzg_Sammy gateway: 1
2022-03-25_01:23:15 Hzg_Sammy mode: auto
2022-03-25_01:23:15 Hzg_Sammy panel: unlocked
2022-03-25_09:01:09 Hzg_Sammy temperature: 21.1
2022-03-25_09:01:09 Hzg_Sammy deviation: 1.1
2022-03-25_09:01:09 Hzg_Sammy valveposition: 7
2022-03-25_09:01:09 Hzg_Sammy 20.0
2022-03-25_09:01:09 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:01:09 Hzg_Sammy RSSI: -55
2022-03-25_09:01:09 Hzg_Sammy battery: ok
2022-03-25_09:01:09 Hzg_Sammy batteryState: ok
2022-03-25_09:01:09 Hzg_Sammy rferror: 0
2022-03-25_09:01:09 Hzg_Sammy gateway: 1
2022-03-25_09:01:09 Hzg_Sammy mode: auto
2022-03-25_09:01:09 Hzg_Sammy panel: unlocked
2022-03-25_09:01:09 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:01:09 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:07:40 Hzg_Sammy temperature: 21.0
2022-03-25_09:07:40 Hzg_Sammy deviation: 1.0
2022-03-25_09:07:40 Hzg_Sammy valveposition: 8
2022-03-25_09:07:40 Hzg_Sammy 20.0
2022-03-25_09:07:40 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:07:40 Hzg_Sammy RSSI: -55
2022-03-25_09:07:40 Hzg_Sammy battery: ok
2022-03-25_09:07:40 Hzg_Sammy batteryState: ok
2022-03-25_09:07:40 Hzg_Sammy rferror: 0
2022-03-25_09:07:40 Hzg_Sammy gateway: 1
2022-03-25_09:07:40 Hzg_Sammy mode: auto
2022-03-25_09:07:40 Hzg_Sammy panel: unlocked
2022-03-25_09:07:40 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:07:40 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:09:50 Hzg_Sammy temperature: 20.8
2022-03-25_09:09:50 Hzg_Sammy deviation: 0.8
2022-03-25_09:09:50 Hzg_Sammy valveposition: 9
2022-03-25_09:09:50 Hzg_Sammy 20.0
2022-03-25_09:09:50 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:09:50 Hzg_Sammy RSSI: -54.5
2022-03-25_09:09:50 Hzg_Sammy battery: ok
2022-03-25_09:09:50 Hzg_Sammy batteryState: ok
2022-03-25_09:09:50 Hzg_Sammy rferror: 0
2022-03-25_09:09:50 Hzg_Sammy gateway: 1
2022-03-25_09:09:50 Hzg_Sammy mode: auto
2022-03-25_09:09:50 Hzg_Sammy panel: unlocked
2022-03-25_09:09:50 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:09:50 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:12:00 Hzg_Sammy temperature: 20.8
2022-03-25_09:12:00 Hzg_Sammy deviation: 0.8
2022-03-25_09:12:00 Hzg_Sammy valveposition: 10
2022-03-25_09:12:00 Hzg_Sammy 20.0
2022-03-25_09:12:00 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:12:00 Hzg_Sammy RSSI: -54.5
2022-03-25_09:12:00 Hzg_Sammy battery: ok
2022-03-25_09:12:00 Hzg_Sammy batteryState: ok
2022-03-25_09:12:00 Hzg_Sammy rferror: 0
2022-03-25_09:12:00 Hzg_Sammy gateway: 1
2022-03-25_09:12:00 Hzg_Sammy mode: auto
2022-03-25_09:12:00 Hzg_Sammy panel: unlocked
2022-03-25_09:12:00 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:12:00 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:14:11 Hzg_Sammy temperature: 20.8
2022-03-25_09:14:11 Hzg_Sammy deviation: 0.8
2022-03-25_09:14:11 Hzg_Sammy valveposition: 11
2022-03-25_09:14:11 Hzg_Sammy 20.0
2022-03-25_09:14:11 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:14:11 Hzg_Sammy RSSI: -54.5
2022-03-25_09:14:11 Hzg_Sammy battery: ok
2022-03-25_09:14:11 Hzg_Sammy batteryState: ok
2022-03-25_09:14:11 Hzg_Sammy rferror: 0
2022-03-25_09:14:11 Hzg_Sammy gateway: 1
2022-03-25_09:14:11 Hzg_Sammy mode: auto
2022-03-25_09:14:11 Hzg_Sammy panel: unlocked
2022-03-25_09:14:11 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:14:11 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:16:21 Hzg_Sammy temperature: 20.8
2022-03-25_09:16:21 Hzg_Sammy deviation: 0.8
2022-03-25_09:16:21 Hzg_Sammy valveposition: 12
2022-03-25_09:16:21 Hzg_Sammy 20.0
2022-03-25_09:16:21 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:16:21 Hzg_Sammy RSSI: -54
2022-03-25_09:16:21 Hzg_Sammy battery: ok
2022-03-25_09:16:21 Hzg_Sammy batteryState: ok
2022-03-25_09:16:21 Hzg_Sammy rferror: 0
2022-03-25_09:16:21 Hzg_Sammy gateway: 1
2022-03-25_09:16:21 Hzg_Sammy mode: auto
2022-03-25_09:16:21 Hzg_Sammy panel: unlocked
2022-03-25_09:16:21 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:16:21 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:22:52 Hzg_Sammy temperature: 20.7
2022-03-25_09:22:52 Hzg_Sammy deviation: 0.7
2022-03-25_09:22:52 Hzg_Sammy valveposition: 14
2022-03-25_09:22:52 Hzg_Sammy 20.0
2022-03-25_09:22:52 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:22:52 Hzg_Sammy RSSI: -54.5
2022-03-25_09:22:52 Hzg_Sammy battery: ok
2022-03-25_09:22:52 Hzg_Sammy batteryState: ok
2022-03-25_09:22:52 Hzg_Sammy rferror: 0
2022-03-25_09:22:52 Hzg_Sammy gateway: 1
2022-03-25_09:22:52 Hzg_Sammy mode: auto
2022-03-25_09:22:52 Hzg_Sammy panel: unlocked
2022-03-25_09:22:52 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:22:52 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:42:24 Hzg_Sammy temperature: 21.1
2022-03-25_09:42:24 Hzg_Sammy deviation: 1.1
2022-03-25_09:42:24 Hzg_Sammy valveposition: 12
2022-03-25_09:42:24 Hzg_Sammy 20.0
2022-03-25_09:42:24 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:42:24 Hzg_Sammy RSSI: -54.5
2022-03-25_09:42:24 Hzg_Sammy battery: ok
2022-03-25_09:42:24 Hzg_Sammy batteryState: ok
2022-03-25_09:42:24 Hzg_Sammy rferror: 0
2022-03-25_09:42:24 Hzg_Sammy gateway: 1
2022-03-25_09:42:24 Hzg_Sammy mode: auto
2022-03-25_09:42:24 Hzg_Sammy panel: unlocked
2022-03-25_09:42:24 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:42:24 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:44:34 Hzg_Sammy temperature: 21.2
2022-03-25_09:44:34 Hzg_Sammy deviation: 1.2
2022-03-25_09:44:34 Hzg_Sammy valveposition: 11
2022-03-25_09:44:34 Hzg_Sammy 20.0
2022-03-25_09:44:34 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:44:34 Hzg_Sammy RSSI: -54.5
2022-03-25_09:44:34 Hzg_Sammy battery: ok
2022-03-25_09:44:34 Hzg_Sammy batteryState: ok
2022-03-25_09:44:34 Hzg_Sammy rferror: 0
2022-03-25_09:44:34 Hzg_Sammy gateway: 1
2022-03-25_09:44:34 Hzg_Sammy mode: auto
2022-03-25_09:44:34 Hzg_Sammy panel: unlocked
2022-03-25_09:44:34 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:44:34 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:46:44 Hzg_Sammy temperature: 21.3
2022-03-25_09:46:44 Hzg_Sammy deviation: 1.3
2022-03-25_09:46:44 Hzg_Sammy valveposition: 9
2022-03-25_09:46:44 Hzg_Sammy 20.0
2022-03-25_09:46:44 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:46:44 Hzg_Sammy RSSI: -55
2022-03-25_09:46:44 Hzg_Sammy battery: ok
2022-03-25_09:46:44 Hzg_Sammy batteryState: ok
2022-03-25_09:46:44 Hzg_Sammy rferror: 0
2022-03-25_09:46:44 Hzg_Sammy gateway: 1
2022-03-25_09:46:44 Hzg_Sammy mode: auto
2022-03-25_09:46:44 Hzg_Sammy panel: unlocked
2022-03-25_09:46:44 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:46:44 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:48:55 Hzg_Sammy temperature: 21.4
2022-03-25_09:48:55 Hzg_Sammy deviation: 1.4
2022-03-25_09:48:55 Hzg_Sammy valveposition: 7
2022-03-25_09:48:55 Hzg_Sammy 20.0
2022-03-25_09:48:55 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:48:55 Hzg_Sammy RSSI: -54.5
2022-03-25_09:48:55 Hzg_Sammy battery: ok
2022-03-25_09:48:55 Hzg_Sammy batteryState: ok
2022-03-25_09:48:55 Hzg_Sammy rferror: 0
2022-03-25_09:48:55 Hzg_Sammy gateway: 1
2022-03-25_09:48:55 Hzg_Sammy mode: auto
2022-03-25_09:48:55 Hzg_Sammy panel: unlocked
2022-03-25_09:48:55 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:48:55 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:51:05 Hzg_Sammy temperature: 21.4
2022-03-25_09:51:05 Hzg_Sammy deviation: 1.4
2022-03-25_09:51:05 Hzg_Sammy valveposition: 6
2022-03-25_09:51:05 Hzg_Sammy 20.0
2022-03-25_09:51:05 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:51:05 Hzg_Sammy RSSI: -55
2022-03-25_09:51:05 Hzg_Sammy battery: ok
2022-03-25_09:51:05 Hzg_Sammy batteryState: ok
2022-03-25_09:51:05 Hzg_Sammy rferror: 0
2022-03-25_09:51:05 Hzg_Sammy gateway: 1
2022-03-25_09:51:05 Hzg_Sammy mode: auto
2022-03-25_09:51:05 Hzg_Sammy panel: unlocked
2022-03-25_09:51:05 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:51:05 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:53:15 Hzg_Sammy temperature: 21.5
2022-03-25_09:53:15 Hzg_Sammy deviation: 1.5
2022-03-25_09:53:15 Hzg_Sammy valveposition: 5
2022-03-25_09:53:15 Hzg_Sammy 20.0
2022-03-25_09:53:15 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:53:15 Hzg_Sammy RSSI: -54.5
2022-03-25_09:53:15 Hzg_Sammy battery: ok
2022-03-25_09:53:15 Hzg_Sammy batteryState: ok
2022-03-25_09:53:15 Hzg_Sammy rferror: 0
2022-03-25_09:53:15 Hzg_Sammy gateway: 1
2022-03-25_09:53:15 Hzg_Sammy mode: auto
2022-03-25_09:53:15 Hzg_Sammy panel: unlocked
2022-03-25_09:53:15 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:53:15 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:55:25 Hzg_Sammy temperature: 21.6
2022-03-25_09:55:25 Hzg_Sammy deviation: 1.6
2022-03-25_09:55:25 Hzg_Sammy valveposition: 3
2022-03-25_09:55:25 Hzg_Sammy 20.0
2022-03-25_09:55:25 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:55:25 Hzg_Sammy RSSI: -54.5
2022-03-25_09:55:25 Hzg_Sammy battery: ok
2022-03-25_09:55:25 Hzg_Sammy batteryState: ok
2022-03-25_09:55:25 Hzg_Sammy rferror: 0
2022-03-25_09:55:25 Hzg_Sammy gateway: 1
2022-03-25_09:55:25 Hzg_Sammy mode: auto
2022-03-25_09:55:25 Hzg_Sammy panel: unlocked
2022-03-25_09:55:25 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:55:25 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_09:57:36 Hzg_Sammy temperature: 21.6
2022-03-25_09:57:36 Hzg_Sammy deviation: 1.6
2022-03-25_09:57:36 Hzg_Sammy valveposition: 2
2022-03-25_09:57:36 Hzg_Sammy 20.0
2022-03-25_09:57:36 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_09:57:36 Hzg_Sammy RSSI: -54.5
2022-03-25_09:57:36 Hzg_Sammy battery: ok
2022-03-25_09:57:36 Hzg_Sammy batteryState: ok
2022-03-25_09:57:36 Hzg_Sammy rferror: 0
2022-03-25_09:57:36 Hzg_Sammy gateway: 1
2022-03-25_09:57:36 Hzg_Sammy mode: auto
2022-03-25_09:57:36 Hzg_Sammy panel: unlocked
2022-03-25_09:57:36 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_09:57:36 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_10:01:56 Hzg_Sammy temperature: 21.7
2022-03-25_10:01:56 Hzg_Sammy deviation: 1.7
2022-03-25_10:01:56 Hzg_Sammy valveposition: 1
2022-03-25_10:01:56 Hzg_Sammy 20.0
2022-03-25_10:01:56 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_10:01:56 Hzg_Sammy RSSI: -54.5
2022-03-25_10:01:56 Hzg_Sammy battery: ok
2022-03-25_10:01:56 Hzg_Sammy batteryState: ok
2022-03-25_10:01:56 Hzg_Sammy rferror: 0
2022-03-25_10:01:56 Hzg_Sammy gateway: 1
2022-03-25_10:01:56 Hzg_Sammy mode: auto
2022-03-25_10:01:56 Hzg_Sammy panel: unlocked
2022-03-25_10:01:56 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_10:01:56 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_10:10:37 Hzg_Sammy temperature: 21.8
2022-03-25_10:10:37 Hzg_Sammy deviation: 1.8
2022-03-25_10:10:37 Hzg_Sammy valveposition: 0
2022-03-25_10:10:37 Hzg_Sammy 20.0
2022-03-25_10:10:37 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_10:10:37 Hzg_Sammy RSSI: -54.5
2022-03-25_10:10:37 Hzg_Sammy battery: ok
2022-03-25_10:10:37 Hzg_Sammy batteryState: ok
2022-03-25_10:10:37 Hzg_Sammy rferror: 0
2022-03-25_10:10:37 Hzg_Sammy gateway: 1
2022-03-25_10:10:37 Hzg_Sammy mode: auto
2022-03-25_10:10:37 Hzg_Sammy panel: unlocked
2022-03-25_10:10:37 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_10:10:37 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_13:23:15 Hzg_Sammy lastTimeSync: 2022-03-25 13:23:15
2022-03-25_13:23:16 Hzg_Sammy valveposition: 0
2022-03-25_13:23:16 Hzg_Sammy 20.0
2022-03-25_13:23:16 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_13:23:16 Hzg_Sammy RSSI: -57
2022-03-25_13:23:16 Hzg_Sammy battery: ok
2022-03-25_13:23:16 Hzg_Sammy batteryState: ok
2022-03-25_13:23:16 Hzg_Sammy rferror: 0
2022-03-25_13:23:16 Hzg_Sammy gateway: 1
2022-03-25_13:23:16 Hzg_Sammy mode: auto
2022-03-25_13:23:16 Hzg_Sammy panel: unlocked
2022-03-25_13:41:11 Hzg_Sammy temperature: 21.4
2022-03-25_13:41:11 Hzg_Sammy deviation: 1.4
2022-03-25_13:41:11 Hzg_Sammy valveposition: 1
2022-03-25_13:41:11 Hzg_Sammy 20.0
2022-03-25_13:41:11 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_13:41:11 Hzg_Sammy RSSI: -56.5
2022-03-25_13:41:11 Hzg_Sammy battery: ok
2022-03-25_13:41:11 Hzg_Sammy batteryState: ok
2022-03-25_13:41:11 Hzg_Sammy rferror: 0
2022-03-25_13:41:11 Hzg_Sammy gateway: 1
2022-03-25_13:41:11 Hzg_Sammy mode: auto
2022-03-25_13:41:11 Hzg_Sammy panel: unlocked
2022-03-25_13:41:11 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_13:41:11 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_13:43:21 Hzg_Sammy temperature: 21.2
2022-03-25_13:43:21 Hzg_Sammy deviation: 1.2
2022-03-25_13:43:21 Hzg_Sammy valveposition: 3
2022-03-25_13:43:21 Hzg_Sammy 20.0
2022-03-25_13:43:21 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_13:43:21 Hzg_Sammy RSSI: -56.5
2022-03-25_13:43:21 Hzg_Sammy battery: ok
2022-03-25_13:43:21 Hzg_Sammy batteryState: ok
2022-03-25_13:43:21 Hzg_Sammy rferror: 0
2022-03-25_13:43:21 Hzg_Sammy gateway: 1
2022-03-25_13:43:21 Hzg_Sammy mode: auto
2022-03-25_13:43:21 Hzg_Sammy panel: unlocked
2022-03-25_13:43:21 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_13:43:21 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_13:45:32 Hzg_Sammy temperature: 21.2
2022-03-25_13:45:32 Hzg_Sammy deviation: 1.2
2022-03-25_13:45:32 Hzg_Sammy valveposition: 4
2022-03-25_13:45:32 Hzg_Sammy 20.0
2022-03-25_13:45:32 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_13:45:32 Hzg_Sammy RSSI: -56.5
2022-03-25_13:45:32 Hzg_Sammy battery: ok
2022-03-25_13:45:32 Hzg_Sammy batteryState: ok
2022-03-25_13:45:32 Hzg_Sammy rferror: 0
2022-03-25_13:45:32 Hzg_Sammy gateway: 1
2022-03-25_13:45:32 Hzg_Sammy mode: auto
2022-03-25_13:45:32 Hzg_Sammy panel: unlocked
2022-03-25_13:45:32 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_13:45:32 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_13:47:42 Hzg_Sammy temperature: 21.2
2022-03-25_13:47:42 Hzg_Sammy deviation: 1.2
2022-03-25_13:47:42 Hzg_Sammy valveposition: 5
2022-03-25_13:47:42 Hzg_Sammy 20.0
2022-03-25_13:47:42 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_13:47:42 Hzg_Sammy RSSI: -57
2022-03-25_13:47:42 Hzg_Sammy battery: ok
2022-03-25_13:47:42 Hzg_Sammy batteryState: ok
2022-03-25_13:47:42 Hzg_Sammy rferror: 0
2022-03-25_13:47:42 Hzg_Sammy gateway: 1
2022-03-25_13:47:42 Hzg_Sammy mode: auto
2022-03-25_13:47:42 Hzg_Sammy panel: unlocked
2022-03-25_13:47:42 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_13:47:42 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_14:11:35 Hzg_Sammy temperature: 21.5
2022-03-25_14:11:35 Hzg_Sammy deviation: 1.5
2022-03-25_14:11:35 Hzg_Sammy valveposition: 4
2022-03-25_14:11:35 Hzg_Sammy 20.0
2022-03-25_14:11:35 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_14:11:35 Hzg_Sammy RSSI: -56.5
2022-03-25_14:11:35 Hzg_Sammy battery: ok
2022-03-25_14:11:35 Hzg_Sammy batteryState: ok
2022-03-25_14:11:35 Hzg_Sammy rferror: 0
2022-03-25_14:11:35 Hzg_Sammy gateway: 1
2022-03-25_14:11:35 Hzg_Sammy mode: auto
2022-03-25_14:11:35 Hzg_Sammy panel: unlocked
2022-03-25_14:11:35 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_14:11:35 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_14:15:55 Hzg_Sammy temperature: 21.6
2022-03-25_14:15:55 Hzg_Sammy deviation: 1.6
2022-03-25_14:15:55 Hzg_Sammy valveposition: 3
2022-03-25_14:15:55 Hzg_Sammy 20.0
2022-03-25_14:15:55 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_14:15:55 Hzg_Sammy RSSI: -56.5
2022-03-25_14:15:55 Hzg_Sammy battery: ok
2022-03-25_14:15:55 Hzg_Sammy batteryState: ok
2022-03-25_14:15:55 Hzg_Sammy rferror: 0
2022-03-25_14:15:55 Hzg_Sammy gateway: 1
2022-03-25_14:15:55 Hzg_Sammy mode: auto
2022-03-25_14:15:55 Hzg_Sammy panel: unlocked
2022-03-25_14:15:55 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_14:15:55 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_14:18:05 Hzg_Sammy temperature: 21.6
2022-03-25_14:18:05 Hzg_Sammy deviation: 1.6
2022-03-25_14:18:05 Hzg_Sammy valveposition: 1
2022-03-25_14:18:05 Hzg_Sammy 20.0
2022-03-25_14:18:05 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_14:18:05 Hzg_Sammy RSSI: -56.5
2022-03-25_14:18:05 Hzg_Sammy battery: ok
2022-03-25_14:18:05 Hzg_Sammy batteryState: ok
2022-03-25_14:18:05 Hzg_Sammy rferror: 0
2022-03-25_14:18:05 Hzg_Sammy gateway: 1
2022-03-25_14:18:05 Hzg_Sammy mode: auto
2022-03-25_14:18:05 Hzg_Sammy panel: unlocked
2022-03-25_14:18:05 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_14:18:05 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_14:22:26 Hzg_Sammy temperature: 21.7
2022-03-25_14:22:26 Hzg_Sammy deviation: 1.7
2022-03-25_14:22:26 Hzg_Sammy valveposition: 0
2022-03-25_14:22:26 Hzg_Sammy 20.0
2022-03-25_14:22:26 Hzg_Sammy desiredTemperature: 20.0
2022-03-25_14:22:26 Hzg_Sammy RSSI: -56.5
2022-03-25_14:22:26 Hzg_Sammy battery: ok
2022-03-25_14:22:26 Hzg_Sammy batteryState: ok
2022-03-25_14:22:26 Hzg_Sammy rferror: 0
2022-03-25_14:22:26 Hzg_Sammy gateway: 1
2022-03-25_14:22:26 Hzg_Sammy mode: auto
2022-03-25_14:22:26 Hzg_Sammy panel: unlocked
2022-03-25_14:22:26 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_14:22:26 Hzg_Sammy peerIDs: 000000,0e6702
2022-03-25_19:00:18 Hzg_Sammy temperature: 22.3
2022-03-25_19:00:18 Hzg_Sammy deviation: 6.3
2022-03-25_19:00:18 Hzg_Sammy valveposition: 0
2022-03-25_19:00:18 Hzg_Sammy 16.0
2022-03-25_19:00:18 Hzg_Sammy desiredTemperature: 16.0
2022-03-25_19:00:18 Hzg_Sammy RSSI: -57
2022-03-25_19:00:18 Hzg_Sammy battery: ok
2022-03-25_19:00:18 Hzg_Sammy batteryState: ok
2022-03-25_19:00:18 Hzg_Sammy rferror: 0
2022-03-25_19:00:18 Hzg_Sammy gateway: 1
2022-03-25_19:00:18 Hzg_Sammy mode: auto
2022-03-25_19:00:18 Hzg_Sammy panel: unlocked
2022-03-25_19:00:18 Hzg_Sammy peerList: Broadcast,MAX_0e6702
2022-03-25_19:00:18 Hzg_Sammy peerIDs: 000000,0e6702
Angehängt ein Bild des Plots
Es ist derzeit nur dieses Device mit dem CUL verbunden.
