Weekprofile schreibt log voll - getDeviceType
Begonnen von matze1999, 29 März 2022, 11:22:49
matze1999
ich hab mehrere Weekprofile eingerichtet, diese schreiben regelmäßig das log voll, Beispiel:
2022.03.29 09:16:09 5: BadWP(Notify): global, DELETED
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): start
2022.03.29 09:16:09 5: BadWP(getDeviceType): type: weekprofile
2022.03.29 09:16:09 4: BadWP(getDeviceType): OKutscherKammerWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device OKutscherKammerWP
2022.03.29 09:16:09 5: BadWP(getDeviceType): type: MQTT2_DEVICE
2022.03.29 09:16:09 5: BadWP(getDeviceType): attr MQTT2_DEVICE
2022.03.29 09:16:09 4: BadWP(getDeviceType): found MQTT2_DEVICE but not configured for weekprofile
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_3E6DCA is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_625C08_CH4 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_E8E3C7_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1614DD is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): type: WeekdayTimer
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT Bad_Thermostat  weekprofile:BadWP:default:default
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_BAD is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_BAD
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_93AF3B is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_B642D9 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_206EBF_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_190C3E is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): KuecheWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device KuecheWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_9D9C35_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_8450AB is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_11960_0064504 weekprofile:OSZWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OKI is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OKI
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1DA17C is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_15F0F8 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CCBC8D_CH3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_9D9C35 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_173D0D_USB is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_11961_0763056 weekprofile:OWCWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OWC is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OWC
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_5D7E0E is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_206EBF is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_625C08_CH3 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT ThermostatWC  weekprofile:WCWP:default:default
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_WC is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_WC
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_B642D9_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_E8E3C7 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBox_09995_0448403 weekprofile:HandtuchWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_Handtuch is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_Handtuch
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1614DD_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_D21560 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_87E834_CH5 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CAAA31 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CCBC8D_CH4 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_15F0F8_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1DA17C_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): OGZWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device OGZWP
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT ThermostatKutscherkammer weekprofile:OKutscherKammerWP:default:Sommer
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OKutscherkammer is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OKutscherkammer
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_F6D6E7 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_486458_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_EF41A8 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_C699D5 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1DA17C_CH3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_15F0F8_CH3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CCBC8D is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CAB019 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_B60FAD is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_E8ED93 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_C6C974 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_11960_0003328 weekprofile:OFlurWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OFlur is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OFlur
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CA9D2A is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): OFlurWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device OFlurWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_625C08_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_B60FB6_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_9D9C35_CH4 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_11960_0064376 weekprofile:OSZWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OSZ is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OSZ
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_54A212 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_9D9C35_CH6 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_490BE3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_B60FAD_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_626FD4_CH5 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CA8225 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_E8ED93_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CCBC8D_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_C699D5_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_486458 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_F6D6E7_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): OWCWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device OWCWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_9D9C35_CH3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_D61F5E is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_190C30 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_206EBF_CH3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_B60FB6 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_625C08 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_10971_0290648 weekprofile:OBadWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OBad is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OBad
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_207234_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): WohnzimmerWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WohnzimmerWP
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_13356_0917456 weekprofile:OKuecheWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OKUL is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OKUL
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_626FD4 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_87E834_CH3 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_11960_0029304 weekprofile:OKuecheWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OKUR is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OKUR
2022.03.29 09:16:09 4: BadWP(getDeviceType): OBadWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device OBadWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_8EAA1E is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1798A6_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_625C08_CH5 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_161A1C_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_E8EF15 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT Schlafzimmer_Thermostat  weekprofile:SchlafzimmerWP:default:default
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_SZ is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_SZ
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT Kinderzimmer_Thermostat  weekprofile:KinderzimmerWP:default:default
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_KIZ is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_KIZ
2022.03.29 09:16:09 4: BadWP(getDeviceType): KinderzimmerWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device KinderzimmerWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_87E834_CH4 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_8EAA1E_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CCBC8D_CH5 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_87E834_CH6 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_626FD4_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): OSZWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device OSZWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_207234 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): SchlafzimmerWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device SchlafzimmerWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_E8EF15_CH2 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_11961_0463648 weekprofile:OGZWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OGZ is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OGZ
2022.03.29 09:16:09 4: BadWP(getDeviceType): HandtuchWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device HandtuchWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): OKuecheWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device OKuecheWP
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_11961_0628792 weekprofile:OGZWP:default:Heizen
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OErker is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OErker
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_161A1C is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1798A6 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_173D0D_CH3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_173D0D_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_F9B0D9 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_C6960F_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1798A6_CH4 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_F93825 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_9D9C35_CH5 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_6C3AB1_CH2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_6136A7 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_61DD3B is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_AAC355 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_15F0F8_USB is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_626FD4_CH3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_87E834 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1DA17C_USB is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_6CA8FD is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): WCWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WCWP
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_13356_0906072  weekprofile:OWohnzimmerWP:default:default
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OWZL is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OWZL
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT FBDECT_FritzBoxO_14456_0396192  weekprofile:OWohnzimmerWP:default:default
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_OWZR is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_OWZR
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_6C3AB1 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_C651CB is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_C6960F is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_1798A6_CH3 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_173D0D is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_F8DDE2 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_626FD4_CH4 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_CA7258 is not supported
2022.03.29 09:16:09 4: BadWP(getDeviceType): OWohnzimmerWP is type WEEKPROFILE
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device OWohnzimmerWP
2022.03.29 09:16:09 4: BadWP(getDeviceType): MQTT2_DVES_87E834_CH2 is not supported
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT Kueche_Thermostat  weekprofile:KuecheWP:default:default
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_KUE is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_KUE
2022.03.29 09:16:09 5: BadWP(getDeviceType): def WDT Wohnzimmer_Thermostat  weekprofile:WohnzimmerWP:default:default
2022.03.29 09:16:09 4: BadWP(getDeviceType): WDT_WZ is type WDT
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): add device WDT_WZ
2022.03.29 09:16:09 5: BadWP(weekprofile_refreshSendDevList): 33 devices in list
hier noch das BadWP:
Raw
defmod BadWP weekprofile
attr BadWP alias BadWP
attr BadWP room Badezimmer,Heizung
setstate BadWP created
setstate BadWP 2022-03-28 22:04:38 profile_count 3
setstate BadWP 2022-03-28 22:04:38 state created
List:
   CONFIGFILE ./log/weekprofile-BadWP.cfg
   FUUID      605f52bd-f33f-214e-e3d3-f8db8a08a8abcaaa
   NAME       BadWP
   NR         35
   NTFY_ORDER 50-BadWP
   STATE      created
   TYPE       weekprofile
   PROFILES:
     HASH(0x38b9f60)
     HASH(0x5087bd8)
     HASH(0x506be08)
   SNDDEVLIST:
     HASH(0x5a8e4f8)
     HASH(0x1f7d140)
     HASH(0x5470930)
     HASH(0x58248b0)
     HASH(0x5421cb0)
     HASH(0x53a1608)
     HASH(0x53adbd8)
     HASH(0x5aa2e10)
     HASH(0x50dd468)
     HASH(0x5101fc8)
     HASH(0x59662b8)
     HASH(0x50e2670)
     HASH(0x4e171c0)
     HASH(0x5aa5f98)
     HASH(0x59e7738)
     HASH(0x50def58)
     HASH(0x55f3008)
     HASH(0x5a661f0)
     HASH(0x551aec8)
     HASH(0x5a8ee70)
     HASH(0x53af830)
     HASH(0x5a72ad0)
     HASH(0x5a99aa0)
     HASH(0x5a6eda0)
     HASH(0x54900f8)
     HASH(0x59dfee0)
     HASH(0x59e0168)
     HASH(0x5a669e8)
     HASH(0x55a74b8)
     HASH(0x50df168)
     HASH(0x5967250)
     HASH(0x54017c0)
     HASH(0x35c1798)
   TEMPMAP:
   TOPICS:
     default
   alias      BadWP
Ist das normal? Oder wo liegt der Fehler?
matze1999
Beta-User
Für einen (wohl von global kommenden) verbose-Level von "5" würde ich auf
Zitat von: matze1999 am 29 März 2022, 11:22:49
Ist das normal?
mit "aber klar doch" antworten wollen...
