ble2mqtt - Bluetooth Anwesenheitserkennung
Begonnen von drhirn, 07 April 2022, 13:45:09
CoolTux
#150
@Patrick
Es ist wie verhext. Mit der neuen Version läuft es seit Stunden durch. Keine Ahnung wieso. Ich bleibe dran.
Aber hier mal was zum Thema Batterie
[2023-09-11 15:14:07] main: Version 0.15 started (device: hci0, mqtt server: 10.6.6.20:8883, mqtt user: -none-, mqtt fingerprint: -none-, get mqtt fingerprint: 0, mqtt topic: ble2mqtt, daemonize: 0, log level: 7, log target: syslog, absent interval: 300, rssi threshold: 10, watchdog threshold: 0, mac regex: 7C:2F:80:AA:5E:6C|7C:2F:80:98:B7:F8|7C:2F:80:AA:5E:28|7C:2F:80:98:B3:8E, debug: 9, debug bluetoothctl: 0, force battery: 0, battery max age: 48).
[2023-09-11 15:14:07] main::sanity_check: md5 digest of '/usr/local/sbin/ble2mqttd' is: 'a02bb3b10cfbec9a96d6c56c87541b1a'.
[2023-09-11 15:14:07] main::sanity_check: bluetoothctl found at '/usr/bin/bluetoothctl'.
[2023-09-11 15:14:07] main::sanity_check: gatttool found at '/usr/bin/gatttool'.
[2023-09-11 15:14:07] main::mqtt_check_reconnect: (Re-)connect detected, handling...
[2023-09-11 15:14:07] main: Sending 'menu scan'...
[2023-09-11 15:14:07] main: Sending 'clear'...
[2023-09-11 15:14:07] main: Sending 'duplicate-data on'...
[2023-09-11 15:14:07] main: Sending 'transport le'...
[2023-09-11 15:14:07] main: Sending 'back'...
[2023-09-11 15:14:07] main: Sending 'scan on'...
[2023-09-11 15:14:07] main: Sending 'version'...
[2023-09-11 15:14:07] main: Scan started.
[2023-09-11 15:14:07] main::__ANON__: Found bluetoothctl version 5.66.
[2023-09-11 15:14:07] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -73)
[2023-09-11 15:14:07] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (RSSI: -77)
[2023-09-11 15:14:07] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (TxPower: -44)
[2023-09-11 15:14:07] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -69)
[2023-09-11 15:14:08] ### Match (filtered): [CHG] 54:D2:72:31:26:7A (RSSI: -59)
[2023-09-11 15:14:08] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 15:14:08] ### Match (new):      [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 15:14:09] ### Match (filtered): [NEW] 44:CB:8B:29:0F:68 (LG SJ4R(68))
[2023-09-11 15:14:10] main::query_task: Executing query task. Querying 7C:2F:80:AA:5E:6C (count: 1, backoff: 2)...
[2023-09-11 15:14:10] +++ Device info:    7C:2F:80:AA:5E:6C public
[2023-09-11 15:14:10] +++ Device name:    7C:2F:80:AA:5E:6C 'Gigaset G-tag'
[2023-09-11 15:14:10] +++ Device battery  7C:2F:80:AA:5E:6C
[2023-09-11 15:14:10] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 15:14:10] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 15:14:13] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:14:15] ### Match (filtered): [NEW] D8:80:83:5B:EE:F4 (SONY XR-42A90K)
[2023-09-11 15:14:19] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:14:22] main::dump_task: Executing dump task.
[2023-09-11 15:14:22] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 14, last seen: 12, last published: 14, rssi: -72, published rssi: -80, query count: %, battery service: 1, battery: unknown (never)
[2023-09-11 15:14:25] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:14:27] ### Match (filtered): [CHG] 3C:5D:29:69:7F:B0 (RSSI: -82)
[2023-09-11 15:14:27] ### Match (filtered): [NEW] C0:E7:BF:F0:4A:0A (Max TV)
[2023-09-11 15:14:28] ### Match (filtered): [CHG] D8:80:83:5B:EE:F4 (UUIDs: 0000110a-0000-1000-8000-00805f9b34fb)
[2023-09-11 15:14:28] ### Match (filtered): [CHG] D8:80:83:5B:EE:F4 (UUIDs: 0000110c-0000-1000-8000-00805f9b34fb)
[2023-09-11 15:14:28] ### Match (filtered): [CHG] D8:80:83:5B:EE:F4 (UUIDs: 0000110e-0000-1000-8000-00805f9b34fb)
[2023-09-11 15:14:28] ### Match (filtered): [CHG] D8:80:83:5B:EE:F4 (UUIDs: 00001200-0000-1000-8000-00805f9b34fb)
[2023-09-11 15:14:28] ### Match (filtered): [CHG] D8:80:83:5B:EE:F4 (UUIDs: 00000000-0000-0000-0000-000000000000)
[2023-09-11 15:14:31] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:14:37] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:14:37] main::dump_task: Executing dump task.
[2023-09-11 15:14:37] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 29, last seen: 27, last published: 29, rssi: -72, published rssi: -80, query count: %, battery service: 1, battery: unknown (never)
[2023-09-11 15:14:43] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:14:45] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (RSSI: -96)
[2023-09-11 15:14:46] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 15:14:46] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 15:14:47] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (RSSI: -66)
[2023-09-11 15:14:48] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (RSSI: -77)
[2023-09-11 15:14:49] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:14:52] main::dump_task: Executing dump task.
[2023-09-11 15:14:52] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 44, last seen: 6, last published: 6, rssi: -80, published rssi: -80, query count: %, battery service: 1, battery: unknown (never)
[2023-09-11 15:14:55] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:01] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 15:15:01] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 15:15:01] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:07] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:07] main::dump_task: Executing dump task.
[2023-09-11 15:15:07] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 59, last seen: 6, last published: 21, rssi: -72, published rssi: -80, query count: %, battery service: 1, battery: unknown (never)
[2023-09-11 15:15:13] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:19] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:22] main::dump_task: Executing dump task.
[2023-09-11 15:15:22] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 74, last seen: 21, last published: 36, rssi: -72, published rssi: -80, query count: %, battery service: 1, battery: unknown (never)
[2023-09-11 15:15:25] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:31] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:37] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:37] main::dump_task: Executing dump task.
[2023-09-11 15:15:37] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 89, last seen: 36, last published: 51, rssi: -72, published rssi: -80, query count: %, battery service: 1, battery: unknown (never)
[2023-09-11 15:15:38] ### Match (filtered): [NEW] 3C:5D:29:69:7F:B0 (3C-5D-29-69-7F-B0)
[2023-09-11 15:15:43] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:49] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:15:51] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 15:15:51] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 15:15:52] main::dump_task: Executing dump task.
[2023-09-11 15:15:52] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 104, last seen: 1, last published: 1, rssi: -80, published rssi: -80, query count: %, battery service: 1, battery: unknown (never)
[2023-09-11 15:15:55] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:16:01] main::evaluation_task: Executing evaluation task.
[2023-09-11 15:16:06] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 15:16:06] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 15:16:08] main::battery_task: Executing battery task.
[2023-09-11 15:16:09] main::get_battery_level: gatttool (mac: 7C:2F:80:AA:5E:6C, address type: 'public'): 'connect to 7C:2F:80:AA:5E:6C: Function not implemented (38)'
[2023-09-11 15:16:09] main::battery_task: Battery level of device 7C:2F:80:AA:5E:6C is unknown, skipping reading update...
[2023-09-11 15:16:09] main: Sending 'menu scan'...
[2023-09-11 15:16:09] main: Sending 'clear'...
[2023-09-11 15:16:09] main: Sending 'duplicate-data on'...
[2023-09-11 15:16:09] main: Sending 'transport le'...
[2023-09-11 15:16:09] main: Sending 'back'...
[2023-09-11 15:16:09] main: Sending 'scan on'...
[2023-09-11 15:16:09] main: Sending 'version'...
[2023-09-11 15:16:09] main: Scan started.
[2023-09-11 15:16:09] main::__ANON__: Found bluetoothctl version 5.66.
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (RSSI: -76)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (TxPower: -44)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (ManufacturerData Key: 0x00c4)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (ManufacturerData Value:)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -73)
[2023-09-11 15:16:09] ### Match (filtered): [NEW] 48:3B:62:06:D5:CD (48-3B-62-06-D5-CD)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 44:CB:8B:29:0F:68 (RSSI: -58)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 44:CB:8B:29:0F:68 (ManufacturerData Key: 0x00c4)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 44:CB:8B:29:0F:68 (ManufacturerData Value:)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -74)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (ManufacturerData Key: 0x004c)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (ManufacturerData Value:)
[2023-09-11 15:16:09] ### Match (filtered): [NEW] 7F:13:D7:F6:DC:18 (7F-13-D7-F6-DC-18)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -72)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 60:BA:9E:12:60:0A (RSSI: -75)
[2023-09-11 15:16:09] ### Match (filtered): [NEW] 14:C1:4E:C3:A1:94 (14-C1-4E-C3-A1-94)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 44:CB:8B:29:0F:68 (RSSI: -59)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -71)
[2023-09-11 15:16:09] ### Match (filtered): [NEW] 54:E9:37:00:C2:DC (54-E9-37-00-C2-DC)
[2023-09-11 15:16:09] ### Match (filtered): [NEW] 75:7E:C0:79:DE:96 (75-7E-C0-79-DE-96)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 75:7E:C0:79:DE:96 (RSSI: -85)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 75:7E:C0:79:DE:96 (ManufacturerData Key: 0x012d)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 75:7E:C0:79:DE:96 (ManufacturerData Value:)
[2023-09-11 15:16:09] ### Match (filtered): [NEW] 61:E5:07:6A:A3:AC (61-E5-07-6A-A3-AC)
[2023-09-11 15:16:09] ### Match (filtered): [CHG] 44:CB:8B:29:0F:68 (R)
[2023-09-11 15:16:10] ### Match (filtered): [CHG] 48:3B:62:06:D5:CD (RSSI: -77)
[2023-09-11 15:16:10] ### Match (filtered): [CHG] 48:3B:62:06:D5:CD (ServiceData Key: 0000fe9f-0000-1000-8000-00805f9b34fb)
[2023-09-11 15:16:10] ### Match (filtered): [CHG] 48:3B:62:06:D5:CD (ServiceData Value:)
[2023-09-11 15:16:10] main::evaluation_task: Executing evaluation task.
Das TuxNet Wiki:
https://www.cooltux.net
CoolTux
Hier noch etwas mehr an Output
[2023-09-11 16:51:44] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -71
[2023-09-11 16:51:44] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -71)
[2023-09-11 16:51:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:51:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:51:58] main::dump_task: Executing dump task.
[2023-09-11 16:51:58] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3348, last seen: 1368, last published: 1371, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5870, last seen: 14, last published: 25, rssi: -71, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:51:58] ### Match (filtered): [NEW] C0:E7:BF:F0:4A:0A (Max TV)
[2023-09-11 16:52:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:03] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 16:52:03] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 16:52:05] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 16:52:05] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 16:52:05] ### Match (filtered): [NEW] FE:A1:46:00:00:0A (Armor X5)
[2023-09-11 16:52:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:13] main::dump_task: Executing dump task.
[2023-09-11 16:52:13] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3363, last seen: 1383, last published: 1386, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5885, last seen: 8, last published: 10, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:52:17] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 16:52:17] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 16:52:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:21] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 16:52:21] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 16:52:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:28] main::dump_task: Executing dump task.
[2023-09-11 16:52:28] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3378, last seen: 1398, last published: 1401, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5900, last seen: 7, last published: 7, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:52:29] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 16:52:29] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 16:52:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:31] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 16:52:31] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 16:52:35] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (RSSI: -85)
[2023-09-11 16:52:35] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (UUIDs: 0000110a-0000-1000-8000-00805f9b34fb)
[2023-09-11 16:52:35] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (UUIDs: 0000110c-0000-1000-8000-00805f9b34fb)
[2023-09-11 16:52:35] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (UUIDs: 0000110e-0000-1000-8000-00805f9b34fb)
[2023-09-11 16:52:35] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (UUIDs: 00001200-0000-1000-8000-00805f9b34fb)
[2023-09-11 16:52:35] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (UUIDs: 00000000-0000-0000-0000-000000000000)
[2023-09-11 16:52:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:36] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 16:52:36] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 16:52:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:43] main::dump_task: Executing dump task.
[2023-09-11 16:52:43] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3393, last seen: 1413, last published: 1416, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5915, last seen: 7, last published: 22, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:52:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:52:54] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (RSSI: -93)
[2023-09-11 16:52:58] main::dump_task: Executing dump task.
[2023-09-11 16:52:58] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3408, last seen: 1428, last published: 1431, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5930, last seen: 22, last published: 37, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:53:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:06] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (RSSI: -84)
[2023-09-11 16:53:09] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (RSSI: -96)
[2023-09-11 16:53:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:13] main::dump_task: Executing dump task.
[2023-09-11 16:53:13] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3423, last seen: 1443, last published: 1446, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5945, last seen: 37, last published: 52, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:53:16] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -71
[2023-09-11 16:53:16] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -71)
[2023-09-11 16:53:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:22] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (RSSI: -84)
[2023-09-11 16:53:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:26] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (RSSI: -93)
[2023-09-11 16:53:28] main::dump_task: Executing dump task.
[2023-09-11 16:53:28] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3438, last seen: 1458, last published: 1461, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5960, last seen: 12, last published: 12, rssi: -71, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:53:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:39] ### Match (filtered): [CHG] C0:E7:BF:F0:4A:0A (RSSI: -84)
[2023-09-11 16:53:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:43] main::dump_task: Executing dump task.
[2023-09-11 16:53:43] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3453, last seen: 1473, last published: 1476, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5975, last seen: 27, last published: 27, rssi: -71, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:53:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:50] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 16:53:50] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 16:53:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:53:58] main::dump_task: Executing dump task.
[2023-09-11 16:53:58] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3468, last seen: 1488, last published: 1491, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 5990, last seen: 8, last published: 8, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:53:58] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 16:53:58] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 16:54:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:54:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:54:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:54:13] main::dump_task: Executing dump task.
[2023-09-11 16:54:13] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3483, last seen: 1503, last published: 1506, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6005, last seen: 15, last published: 23, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:54:13] ### Match (filtered): [NEW] FE:A1:46:00:00:0A (Armor X5)
[2023-09-11 16:54:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:54:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:54:28] main::dump_task: Executing dump task.
[2023-09-11 16:54:28] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3498, last seen: 1518, last published: 1521, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6020, last seen: 30, last published: 38, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:54:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:54:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:54:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 16:54:43] main::dump_task: Executing dump task.
[2023-09-11 16:54:43] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 3513, last seen: 1533, last published: 1536, rssi: -76, published rssi: -70, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6035, last seen: 45, last published: 53, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 16:54:43] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -81
[2023-09-11 16:54:43] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -81)
[2023-09-11 16:54:46] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 16:54:46] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
Das TuxNet Wiki:
CoolTux
Nun ist es doch passiert. Um genau 17:21:20 kam das absent. Ich habe ein absentinterval von 300, nur falls das relevant sein sollte. Ich bin zu Hause, mein Dongle auch. Meine MAC 7C_2F_80_AA_5E_6C
[2023-09-11 17:07:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:07:13] main::dump_task: Executing dump task.
[2023-09-11 17:07:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6785, last seen: 3, last published: 3, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:07:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:07:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:07:28] main::dump_task: Executing dump task.
[2023-09-11 17:07:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6800, last seen: 18, last published: 18, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:07:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:07:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:07:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:07:43] main::dump_task: Executing dump task.
[2023-09-11 17:07:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6815, last seen: 33, last published: 33, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:07:45] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:07:45] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:07:46] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 17:07:46] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 17:07:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:07:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:07:57] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -66)
[2023-09-11 17:07:58] main::dump_task: Executing dump task.
[2023-09-11 17:07:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6830, last seen: 12, last published: 13, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:07:58] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -74)
[2023-09-11 17:08:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:02] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:08:02] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:08:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:13] main::dump_task: Executing dump task.
[2023-09-11 17:08:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6845, last seen: 11, last published: 11, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:08:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:28] main::dump_task: Executing dump task.
[2023-09-11 17:08:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6860, last seen: 26, last published: 26, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:08:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:30] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -66)
[2023-09-11 17:08:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:38] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -74)
[2023-09-11 17:08:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:43] main::dump_task: Executing dump task.
[2023-09-11 17:08:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6875, last seen: 41, last published: 41, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:08:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:08:58] main::dump_task: Executing dump task.
[2023-09-11 17:08:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6890, last seen: 56, last published: 56, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:09:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:07] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 17:09:07] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 17:09:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:13] main::dump_task: Executing dump task.
[2023-09-11 17:09:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6905, last seen: 6, last published: 6, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:09:16] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -66)
[2023-09-11 17:09:17] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -74)
[2023-09-11 17:09:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:23] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:09:23] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:09:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:28] main::dump_task: Executing dump task.
[2023-09-11 17:09:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6920, last seen: 5, last published: 5, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:09:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:33] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 17:09:33] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 17:09:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:43] main::dump_task: Executing dump task.
[2023-09-11 17:09:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6935, last seen: 10, last published: 20, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:09:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:49] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:09:49] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:09:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:09:58] main::dump_task: Executing dump task.
[2023-09-11 17:09:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6950, last seen: 9, last published: 9, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:10:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:11] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -66)
[2023-09-11 17:10:12] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -74)
[2023-09-11 17:10:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:13] main::dump_task: Executing dump task.
[2023-09-11 17:10:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6965, last seen: 24, last published: 24, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:10:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:21] ### Match (filtered): [NEW] FE:A1:46:00:00:0A (Armor X5)
[2023-09-11 17:10:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:28] main::dump_task: Executing dump task.
[2023-09-11 17:10:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6980, last seen: 39, last published: 39, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:10:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:36] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -66)
[2023-09-11 17:10:36] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 17:10:36] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 17:10:40] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -74)
[2023-09-11 17:10:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:43] main::dump_task: Executing dump task.
[2023-09-11 17:10:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 6995, last seen: 7, last published: 7, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:10:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:10:58] main::dump_task: Executing dump task.
[2023-09-11 17:10:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7010, last seen: 22, last published: 22, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:11:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:13] main::dump_task: Executing dump task.
[2023-09-11 17:11:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7025, last seen: 37, last published: 37, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:11:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:28] main::dump_task: Executing dump task.
[2023-09-11 17:11:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7040, last seen: 52, last published: 52, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:11:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:31] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:11:31] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:11:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:43] main::dump_task: Executing dump task.
[2023-09-11 17:11:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7055, last seen: 12, last published: 12, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:11:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:11:58] main::dump_task: Executing dump task.
[2023-09-11 17:11:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7070, last seen: 27, last published: 27, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:12:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:04] ### Match (filtered): [CHG] 54:D2:72:31:26:7A (RSSI: -48)
[2023-09-11 17:12:04] ### Match (filtered): [NEW] 3C:5D:29:69:7F:B0 (3C-5D-29-69-7F-B0)
[2023-09-11 17:12:04] ### Match (filtered): [CHG] 54:D2:72:31:26:7A (RSSI: -62)
[2023-09-11 17:12:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:13] main::dump_task: Executing dump task.
[2023-09-11 17:12:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7085, last seen: 42, last published: 42, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:12:16] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 17:12:16] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 17:12:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:28] main::dump_task: Executing dump task.
[2023-09-11 17:12:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7100, last seen: 12, last published: 12, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:12:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:43] main::dump_task: Executing dump task.
[2023-09-11 17:12:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7115, last seen: 27, last published: 27, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:12:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:49] ### Match (filtered): [NEW] 3C:5D:29:69:7F:B0 (3C-5D-29-69-7F-B0)
[2023-09-11 17:12:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:12:58] main::dump_task: Executing dump task.
[2023-09-11 17:12:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7130, last seen: 42, last published: 42, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:13:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:13] main::dump_task: Executing dump task.
[2023-09-11 17:13:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7145, last seen: 57, last published: 57, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:13:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:18] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:13:18] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:13:20] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -71
[2023-09-11 17:13:20] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -71)
[2023-09-11 17:13:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:28] main::dump_task: Executing dump task.
[2023-09-11 17:13:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7160, last seen: 8, last published: 10, rssi: -71, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:13:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:35] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -79
[2023-09-11 17:13:35] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -79)
[2023-09-11 17:13:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:43] main::dump_task: Executing dump task.
[2023-09-11 17:13:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7175, last seen: 8, last published: 8, rssi: -79, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:13:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:13:58] main::dump_task: Executing dump task.
[2023-09-11 17:13:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7190, last seen: 23, last published: 23, rssi: -79, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:14:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:06] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -71
[2023-09-11 17:14:06] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -71)
[2023-09-11 17:14:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:13] main::dump_task: Executing dump task.
[2023-09-11 17:14:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7205, last seen: 7, last published: 7, rssi: -71, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:14:15] main::cleanup_task: Cleanup finished, deleted 0 devices in 0 seconds.
[2023-09-11 17:14:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:21] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:14:21] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:14:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:25] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -70
[2023-09-11 17:14:25] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -70)
[2023-09-11 17:14:28] main::dump_task: Executing dump task.
[2023-09-11 17:14:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7220, last seen: 3, last published: 3, rssi: -70, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:14:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:41] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:14:41] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:14:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:43] main::dump_task: Executing dump task.
[2023-09-11 17:14:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7235, last seen: 2, last published: 2, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:14:44] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -66)
[2023-09-11 17:14:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:53] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -74)
[2023-09-11 17:14:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:14:58] main::dump_task: Executing dump task.
[2023-09-11 17:14:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7250, last seen: 17, last published: 17, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:14:59] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 17:14:59] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 17:15:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:12] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:13] main::dump_task: Executing dump task.
[2023-09-11 17:15:13] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7265, last seen: 14, last published: 14, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:15:17] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:15:17] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:15:18] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:24] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:27] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -72
[2023-09-11 17:15:27] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -72)
[2023-09-11 17:15:28] main::dump_task: Executing dump task.
[2023-09-11 17:15:28] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7280, last seen: 1, last published: 11, rssi: -72, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:15:30] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:34] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -80
[2023-09-11 17:15:34] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -80)
[2023-09-11 17:15:36] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:42] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:43] main::dump_task: Executing dump task.
[2023-09-11 17:15:43] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7295, last seen: 9, last published: 9, rssi: -80, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:15:47] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -71
[2023-09-11 17:15:47] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -71)
[2023-09-11 17:15:48] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:54] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:15:58] main::dump_task: Executing dump task.
[2023-09-11 17:15:58] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7310, last seen: 11, last published: 24, rssi: -71, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:16:00] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:06] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:12] main::battery_task: Executing battery task.
[2023-09-11 17:16:13] main::get_battery_level: gatttool (mac: 7C:2F:80:AA:5E:6C, address type: 'public'): 'connect to 7C:2F:80:AA:5E:6C: Function not implemented (38)'
[2023-09-11 17:16:13] main::battery_task: Battery level of device 7C:2F:80:AA:5E:6C is unknown, skipping reading update...
[2023-09-11 17:16:13] main: Sending 'menu scan'...
[2023-09-11 17:16:13] main: Sending 'clear'...
[2023-09-11 17:16:13] main: Sending 'duplicate-data on'...
[2023-09-11 17:16:13] main: Sending 'transport le'...
[2023-09-11 17:16:13] main: Sending 'back'...
[2023-09-11 17:16:13] main: Sending 'scan on'...
[2023-09-11 17:16:13] main: Sending 'version'...
[2023-09-11 17:16:13] main: Scan started.
[2023-09-11 17:16:13] main::__ANON__: Found bluetoothctl version 5.66.
[2023-09-11 17:16:14] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -69)
[2023-09-11 17:16:14] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -69)
[2023-09-11 17:16:14] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:14] main::dump_task: Executing dump task.
[2023-09-11 17:16:14] Known devices (1):
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7326, last seen: 27, last published: 40, rssi: -71, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:16:14] ### Match (filtered): [CHG] 54:D2:72:31:26:7A (RSSI: -57)
[2023-09-11 17:16:15] ### Match RSSI:       [CHG] 7C:2F:80:98:B3:8E -> -77
[2023-09-11 17:16:15] ### Match (new):      [CHG] 7C:2F:80:98:B3:8E (RSSI: -77)
[2023-09-11 17:16:16] ### Match RSSI:       [CHG] 7C:2F:80:AA:5E:6C -> -75
[2023-09-11 17:16:16] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (RSSI: -75)
[2023-09-11 17:16:16] ### Match:            [CHG] 7C:2F:80:AA:5E:6C (UUIDs: 0000180f-0000-1000-8000-00805f9b34fb)
[2023-09-11 17:16:17] main::query_task: Executing query task. Querying 7C:2F:80:98:B3:8E (count: 1, backoff: 2)...
[2023-09-11 17:16:17] +++ Device info:    7C:2F:80:98:B3:8E public
[2023-09-11 17:16:17] +++ Device name:    7C:2F:80:98:B3:8E 'Gigaset G-tag'
[2023-09-11 17:16:17] +++ Device battery  7C:2F:80:98:B3:8E
[2023-09-11 17:16:20] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:26] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:29] main::dump_task: Executing dump task.
[2023-09-11 17:16:29] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 14, last seen: 14, last published: 14, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7341, last seen: 13, last published: 13, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:16:32] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:38] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:40] ### Match (filtered): [CHG] 3C:5D:29:69:7F:B0 (RSSI: -82)
[2023-09-11 17:16:44] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:44] main::dump_task: Executing dump task.
[2023-09-11 17:16:44] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 29, last seen: 29, last published: 29, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7356, last seen: 28, last published: 28, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:16:50] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:56] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:16:59] main::dump_task: Executing dump task.
[2023-09-11 17:16:59] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 44, last seen: 44, last published: 44, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7371, last seen: 43, last published: 43, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:17:02] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:08] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:14] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:14] main::dump_task: Executing dump task.
[2023-09-11 17:17:14] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 59, last seen: 59, last published: 59, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7386, last seen: 58, last published: 58, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:17:20] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:26] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:29] main::dump_task: Executing dump task.
[2023-09-11 17:17:29] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 74, last seen: 74, last published: 74, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7401, last seen: 73, last published: 73, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:17:32] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:38] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:42] ### Match (filtered): [NEW] 3C:5D:29:69:7F:B0 (3C-5D-29-69-7F-B0)
[2023-09-11 17:17:44] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:44] main::dump_task: Executing dump task.
[2023-09-11 17:17:44] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 89, last seen: 89, last published: 89, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7416, last seen: 88, last published: 88, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:17:50] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:56] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:17:59] main::dump_task: Executing dump task.
[2023-09-11 17:17:59] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 104, last seen: 104, last published: 104, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7431, last seen: 103, last published: 103, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:18:02] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:08] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:14] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:14] main::dump_task: Executing dump task.
[2023-09-11 17:18:14] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 119, last seen: 119, last published: 119, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7446, last seen: 118, last published: 118, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:18:20] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:26] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:29] main::dump_task: Executing dump task.
[2023-09-11 17:18:29] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 134, last seen: 134, last published: 134, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7461, last seen: 133, last published: 133, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:18:32] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:38] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:44] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:44] main::dump_task: Executing dump task.
[2023-09-11 17:18:44] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 149, last seen: 149, last published: 149, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7476, last seen: 148, last published: 148, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:18:50] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:56] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:18:59] main::dump_task: Executing dump task.
[2023-09-11 17:18:59] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 164, last seen: 164, last published: 164, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7491, last seen: 163, last published: 163, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:19:02] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:02] ### Match (filtered): [NEW] 3C:5D:29:69:7F:B0 (3C-5D-29-69-7F-B0)
[2023-09-11 17:19:08] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:14] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:14] main::dump_task: Executing dump task.
[2023-09-11 17:19:14] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 179, last seen: 179, last published: 179, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7506, last seen: 178, last published: 178, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:19:18] ### Match (filtered): [NEW] FE:A1:46:00:00:0A (Armor X5)
[2023-09-11 17:19:20] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:26] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:29] main::dump_task: Executing dump task.
[2023-09-11 17:19:29] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 194, last seen: 194, last published: 194, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7521, last seen: 193, last published: 193, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:19:32] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:38] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:44] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:44] main::dump_task: Executing dump task.
[2023-09-11 17:19:44] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 209, last seen: 209, last published: 209, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7536, last seen: 208, last published: 208, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:19:50] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:56] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:19:59] main::dump_task: Executing dump task.
[2023-09-11 17:19:59] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 224, last seen: 224, last published: 224, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7551, last seen: 223, last published: 223, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:20:02] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:03] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -60)
[2023-09-11 17:20:03] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -74)
[2023-09-11 17:20:08] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:14] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:14] main::dump_task: Executing dump task.
[2023-09-11 17:20:14] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 239, last seen: 239, last published: 239, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7566, last seen: 238, last published: 238, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:20:20] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:26] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:29] main::dump_task: Executing dump task.
[2023-09-11 17:20:29] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 254, last seen: 254, last published: 254, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7581, last seen: 253, last published: 253, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:20:32] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:34] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -66)
[2023-09-11 17:20:35] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -74)
[2023-09-11 17:20:38] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:44] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:44] main::dump_task: Executing dump task.
[2023-09-11 17:20:44] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 269, last seen: 269, last published: 269, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7596, last seen: 268, last published: 268, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:20:48] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -66)
[2023-09-11 17:20:49] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -74)
[2023-09-11 17:20:50] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:56] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:20:59] main::dump_task: Executing dump task.
[2023-09-11 17:20:59] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 284, last seen: 284, last published: 284, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7611, last seen: 283, last published: 283, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:21:02] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:08] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:14] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:14] main::dump_task: Executing dump task.
[2023-09-11 17:21:14] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 1, name: Gigaset G-tag, address type: public, first seen: 299, last seen: 299, last published: 299, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 1, name: Gigaset G-tag, address type: public, first seen: 7626, last seen: 298, last published: 298, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:21:18] ### Match (filtered): [CHG] 54:D2:72:31:26:7A (ManufacturerData Key: 0x004c)
[2023-09-11 17:21:18] ### Match (filtered): [CHG] 54:D2:72:31:26:7A (ManufacturerData Value:)
[2023-09-11 17:21:19] ### Match (filtered): [CHG] 54:D2:72:31:26:7A (ManufacturerData Key: 0x004c)
[2023-09-11 17:21:19] ### Match (filtered): [CHG] 54:D2:72:31:26:7A (ManufacturerData Value:)
[2023-09-11 17:21:20] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:20] main::evaluation_task: Device 7C:2F:80:98:B3:8E is now absent.
[2023-09-11 17:21:20] main::evaluation_task: Device 7C:2F:80:AA:5E:6C is now absent.
[2023-09-11 17:21:24] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (ManufacturerData Key: 0x004c)
[2023-09-11 17:21:24] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (ManufacturerData Value:)
[2023-09-11 17:21:25] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (ManufacturerData Key: 0x004c)
[2023-09-11 17:21:25] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (ManufacturerData Value:)
[2023-09-11 17:21:26] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:28] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -77)
[2023-09-11 17:21:28] ### Match (filtered): [CHG] 54:D2:72:FF:44:F4 (RSSI: -69)
[2023-09-11 17:21:29] main::dump_task: Executing dump task.
[2023-09-11 17:21:29] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 314, last seen: 314, last published: 314, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 0, name: Gigaset G-tag, address type: public, first seen: 7641, last seen: 313, last published: 313, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:21:32] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:38] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:40] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -66)
[2023-09-11 17:21:40] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -74)
[2023-09-11 17:21:41] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -66)
[2023-09-11 17:21:41] ### Match (filtered): [CHG] 00:A0:50:78:57:93 (RSSI: -74)
[2023-09-11 17:21:43] ### Match (filtered): [NEW] 3C:5D:29:69:7F:B0 (3C-5D-29-69-7F-B0)
[2023-09-11 17:21:44] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:44] main::dump_task: Executing dump task.
[2023-09-11 17:21:44] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 329, last seen: 329, last published: 329, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 0, name: Gigaset G-tag, address type: public, first seen: 7656, last seen: 328, last published: 328, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:21:50] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:56] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:21:59] main::dump_task: Executing dump task.
[2023-09-11 17:21:59] Known devices (2):
        mac: 7C:2F:80:98:B3:8E, present: 0, name: Gigaset G-tag, address type: public, first seen: 344, last seen: 344, last published: 344, rssi: -77, published rssi: -77, query count: %, battery service: 1, battery: unknown (never)
        mac: 7C:2F:80:AA:5E:6C, present: 0, name: Gigaset G-tag, address type: public, first seen: 7671, last seen: 343, last published: 343, rssi: -75, published rssi: -72, query count: %, battery service: 1, battery: 85 (1694441771)
[2023-09-11 17:22:02] main::evaluation_task: Executing evaluation task.
[2023-09-11 17:22:08] main::evaluation_task: Executing evaluation task.
Das TuxNet Wiki:
PatrickR
Hi!
Sowohl bei der Battery-Geschichte als auch bei dem Absent wären mehr Logs gut. Bei Absent sehe ich leider nur den Teil, bei dem keine Beacons reinkommen (d. h. ab 300s vor dem Fehlerzeitpunkt) nicht den Teil davor, bei dem mutmaßlich noch alles geklappt hat.
Die Fehlermeldung bei Battery hatte ich auch vereinzelt bekommen, teilweise auch, wenn der Tag zwar in der Nähe war, aber an der Grenze der Reichweite. Das wird sich aber vermutlich (s. o.) erholen, wenn ble2mqttd länger läuft. Es schaut jede Stunde, welche Geräte zur Abfrage anstehen und fragt sie ab. Das sind jene Geräte, die erreichbar sind, die Batterieabfrage unterstützen und deren letzter Batteriewert entweder unbekannt oder älter als 48h ist. Ergo: Es wird stündlich probiert, den Wert zu bekommen bis es klappt.
Patrick
lepresenced - Tracking von Bluetooth-LE-Tags (Gigaset G-Tag) mittels PRESENCE
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the universe trying to produce bigger and better idiots. So far, the universe is winning." - Rich Cook
CoolTux
Guten Morgen.
Ganzer Debug Log kann hier eingesehen werden.
Ist rund 42Mb groß. Ich konnte es aber ohne Probleme im vi öffnen.
Das TuxNet Wiki:
PatrickR
#155
Hi!
Zitat von: CoolTux am 12 September 2023, 05:48:47Ganzer Debug Log kann hier eingesehen werden.
Ah, ein Log, sehr gut.
Zum Battery Level:
[2023-09-11 15:16:09] main::get_battery_level: gatttool (mac: 7C:2F:80:AA:5E:6C, address type: 'public'): 'connect to 7C:2F:80:AA:5E:6C: Function not implemented (38)'
[2023-09-11 16:16:11] main::get_battery_level: gatttool (mac: 7C:2F:80:AA:5E:6C, address type: 'public'): 'handle: 0x001b      value: 55 '
Wie Du siehst schlägt es immer noch fehl, aber da ble2mqttd es stündlich so lange probiert, bis es klappt, klappt es um 16:16:11. Um 17:16:13 wird es wieder probiert, was eigentlich nicht passieren kann, da der Wert zu diesem Zeitpunkt eine Stunde alt ist, was deutlich unter 48 Stunden liegt. Da aber an der Datei rumeditiert wurde, schiebe ich das mal darauf.
Zur Absent-Geschichte:
Das ist schon etwas spannender. Um 17:16 tauchen *8E und *6C das letzte Mal auf, danach nicht mehr. Andere Geräte wie *7A und *F4 kommen aber weiterhin, d. h. gatttool scannt erfolgreich. Meine Theorie wäre daher, dass die G-Tags nicht mehr senden, z. B. weil irgendetwas anderes mit ihnen redet. Ich hatte bei meinen Tags z. B. das Problem, dass sie nicht mehr bzw. deutlich seltener gesendet haben wenn sie mit der G-Tag-App verbunden waren. Das Problem könnte auch z. B. ein Batterieskript (auch auf einem anderen Host) sein. Die Batterieabfrage von ble2mqttd schließe ich erstmal aus, da nur einer der zwei Tags abgefragt wird. Auch könnte es sein, dass die Tags außer Reichweite des Hosts sind oder durch andere Funkphänomene nicht mehr dort ankommen.
Es gibt jetzt mehrere Möglichkeiten, das weiter einzugrenzen. Einerseits könnte man auf einer anderen Hardware parallel scannen und so verifizieren, dass die Tags nach wie vor senden. Andererseits, falls es wirklich konkurrierende (Batterie-)skripte gibt, könnte man mal in deren Log schauen, ob um ca. 17:16 etwas mit den Tags angestellt wurde.
Interessant ist übrigens auch, dass Deine G-Tags ohnehin nur selten senden. Meine senden etwa alle zwei Sekunden.
Patrick
CoolTux
Alles klar. Ich danke Dir erstmal für die Auswertung. Ich werde dann wohl mal schauen müssen was da los ist.
Das TuxNet Wiki:
https://www.cooltux.net
CoolTux
Kleiner Zwischenbericht. Bei mir scheint sich das Problem erledigt zu haben nachdem ich die Filter entfernt habe. Frag mich nicht  ???
Das TuxNet Wiki:
drhirn
Zitat von: drhirn am 04 September 2023, 11:39:49Frage: Wäre es nicht sinnvoll, das present-Reading als retained zu schicken?
Ich hatte im Urlaub öfter mal das Problem, dass meine Residents plötzlich zuhause waren. Weiß aber noch nicht, warum genau das passiert ist.
Also. Das passiert offenbar, wenn niemand zuhause ist, FHEM neu startet und sich eines der ble2mqtt-Devices aufgehängt hat (bzw. die Verbindung zum WLAN verloren). Aktueller Status: Ich bin im Büro aber laut FHEM auch zuhause.
setstate ble2mqttDevice 2023-10-02 12:49:39 presence present
setstate ble2mqttDevice 2023-09-17 12:30:53 presence_bad present
setstate ble2mqttDevice 2023-09-17 12:30:58 presence_kueche present
setstate ble2mqttDevice 2023-10-02 12:49:39 presence_vorraum absent
setstate ble2mqttDevice 2023-10-02 12:49:39 presence_wohnzimmer absent
setstate ble2mqttDevice 2023-10-02 12:49:39 room bad
Ich war wohl am 17.09. umd 12:30 zuhause. Danach haben zwei Devices nicht mehr reagiert, stehen aber auf "present". Ich habe jetzt gerade eines der beiden neu gestartet. Bleibt aber auf present, obwohl ich nicht zuhause bin. Ist klar, es empfängt ja auch keine Daten. Das Reading kann also gar nicht aktualisiert werden.
Das FHEM-Device sieht so aus:
define ble2mqttDevice MQTT2_DEVICE FHEM
attr ble2mqttDevice devicetopic ble2mqtt/.*/7C_2F_80_AF_1A_F5
attr ble2mqttDevice event-on-change-reading .*
attr ble2mqttDevice readingList FHEM:ble2mqtt/wohnzimmer/state:.* state\
FHEM:ble2mqtt/wohnzimmer/heartbeat:.* heartbeat\
$DEVICETOPIC/rssi:.* {my $room=(split m{[/]}x,$TOPIC)[1];;;; my $roomMax=$room;;;; my $rssiMax=$EVENT;;;; my @readings = grep { $_ =~ m{\Arssi_(?!$room).*}x } keys %{$defs{"$NAME"}->{READINGS}};;;; for (@readings) {my $rssiTmp=ReadingsVal($NAME,$_,'-100');;;; my $roomTmp=(split m{[_]}x,$_)[1];;;; if(($rssiMax gt $rssiTmp)&&(ReadingsVal($NAME,"presence_".$roomTmp,'absent') eq 'present')) {$rssiMax=$rssiTmp;;;;$roomMax=$roomTmp}};;;; {rssi=>$rssiMax,room=>$roomMax,"rssi_$room"=>$EVENT}}\
$DEVICETOPIC/lastseen:.* {lastseen=>strftime "%Y-%m-%d %H:%M:%S", localtime($EVENT)}\
$DEVICETOPIC/present:.* {my $roomAct=(split m{[/]}x,$TOPIC)[1];;;; my $rssi=ReadingsVal($NAME,"rssi_".$roomAct,'-100');;;;;;;;my $presenceAct=$EVENT?'present':'absent';;;; my $presenceTotal=$presenceAct;;;; my $room=$EVENT ? $roomAct:'';;;; my @readings = grep { $_ =~ m{\Apresence_(?!$roomAct).*}x } keys %{$defs{$NAME}->{READINGS}};;;; for (@readings) {if(ReadingsVal($NAME,$_,'absent') eq 'present') {my $roomTmp=(split m{[_]}x,$_)[1];;;; my $rssiTmp=ReadingsVal($NAME,"rssi_".$roomTmp,'-100');;;;if($rssi gt $rssiTmp){$room=$roomTmp;;;;$presenceTotal='present';;;; $rssi=$rssiTmp}}};;;; {"presence_$roomAct"=>$presenceAct, room=>$room, presence=>$presenceTotal, state=>$presenceTotal}}\
ble2mqttd/wohnzimmer:.* state
Retained Messages helfen da auch nicht, sind sogar kontraproduktiv im täglichen Einsatz.
Wie könnten wir das lösen? Irgendwie muss ein Event ausgelöst werden. Eventuell von ble2mqtt, wenn ein MAC-Filter gesetzt ist?
PatrickR
Hi!
Zitat von: drhirn am 02 Oktober 2023, 15:18:28Wie könnten wir das lösen? Irgendwie muss ein Event ausgelöst werden. Eventuell von ble2mqtt, wenn ein MAC-Filter gesetzt ist?
Ich habe die Fehlerbeschreibung jetzt mehrfach gelesen und leider nicht verstanden. Wenn sich aber ble2mqtt-Instanzen (nicht Devices) aufhängen bzw. deren Netzwerk nicht steht, solltest Du das zuerst angehen. Du könntest alternativ statt des Present-Topics lastseen auswerten und daraus den Präsenzstatus ableiten. Aber dann bekommst Du bei defekten ble2mqtt-Instanzen fehlerhafte Abwesenheiten (statt wie jetzt fehlerhafte Anwesenheiten). Zusätzlich könntest Du durch Auswertung des ble2mqtt-state-topics noch einen Alarm auslösen wenn eine ble2mqtt-Instanz auf Grund von Netzwerkproblemen wieder an der Funktion gehindert wird.
Patrick
DasQ
Dürfte ich fragen was hier als Empfänger fungiert?
Ich hab was ähnliches ohne dieses Modul am laufen über Tasmota auf 3 ESP32 im Haus verteilt.
Fhem in Proxmox on MacMini
Absoluter Befürworter der Konsequenten-Kleinschreibung https://de.wikipedia.org/wiki/Kleinschreibung
Infos zu Klimawandel http://www.globalcarbonatlas.org
PatrickR
Hi!
Zitat von: DasQ am 04 Oktober 2023, 16:35:02Dürfte ich fragen was hier als Empfänger fungiert?
Ein Linux-Rechner, z. B. Raspberry Pi mit Bluetooth-Modul.
Zitat von: DasQ am 04 Oktober 2023, 16:35:02Ich hab was ähnliches ohne dieses Modul am laufen über Tasmota auf 3 ESP32 im Haus verteilt.
Dann hast Du die schönere Lösung :)
Patrick
DasQ
Sorry fürs OT, aber schöner verbitte ich mir  :)) (da fällt mir gerade wieder ein ich sollte dringend ne 12v Leitung durchs Haus legen und die Dinger unterputz verstecken)🫣
Btw hier der Thread von mir verlinkt wie ich das gemacht hab. Wenn fragen nur zu. Läuft seither bis auf reichweiten Problemen perfekt. Gibt ein zwei Winkel die sind nicht perfekt ausgeleuchtet. Aber da wollte ich noch ein passendes Tasmota für meine rolladen Sonoff DualR3 ESP32 basteln.
Gasmast3r
Hy mit etwas Hilfe habe ich ble2mqtt nun am laufen aber er findet keine Bluetooth Geräte.
pi@FTUI3:~ $ sudo systemctl status ble2mqttd
● ble2mqttd.service - ble2mqttd
     Loaded: loaded (/etc/systemd/system/ble2mqttd.service; enabled; vendor preset: enabled)
     Active: active (running) since Sun 2023-11-05 13:03:10 CET; 2min 9s ago
   Main PID: 433 (ble2mqttd)
      Tasks: 2 (limit: 868)
        CPU: 1.914s
     CGroup: /system.slice/ble2mqttd.service
             ├─ 433 /usr/bin/perl /usr/local/bin/ble2mqttd --mqttserver 192.168.178.110:1883 --mqtttopic ble2mqtt/Tab --mac (11:22:33:44:55>
             └─1053 bluetoothctl
Nov 05 13:03:12 FTUI3 ble2mqttd[433]: main::sanity_check: md5 digest of '/usr/local/bin/ble2mqttd' is: '1146c98e6c1ab082c580f89eb5bdbaa5'.
Nov 05 13:03:12 FTUI3 ble2mqttd[433]: main::sanity_check: bluetoothctl found at '/usr/bin/bluetoothctl'.
Nov 05 13:03:12 FTUI3 ble2mqttd[433]: main::sanity_check: gatttool found at '/usr/bin/gatttool'.
Nov 05 13:03:12 FTUI3 ble2mqttd[433]: main::mqtt_check_reconnect: (Re-)connect detected, handling...
Nov 05 13:03:12 FTUI3 ble2mqttd[433]: /usr/local/bin/ble2mqttd: connect: Network is unreachable
Nov 05 13:03:12 FTUI3 ble2mqttd[433]: main: Scan started.
Nov 05 13:03:12 FTUI3 ble2mqttd[433]: main::__ANON__: Found bluetoothctl version 5.55.
Nov 05 13:04:12 FTUI3 ble2mqttd[433]: main::mqtt_check_reconnect: (Re-)connect detected, handling...
Nov 05 13:05:12 FTUI3 ble2mqttd[433]: main: Scan started.
Nov 05 13:05:12 FTUI3 ble2mqttd[433]: main::__ANON__: Found bluetoothctl version 5.55.
defmod MQTT2_ble2mqttd_FTUI3 MQTT2_DEVICE ble2mqttd_FTUI3
attr MQTT2_ble2mqttd_FTUI3 readingList ble2mqttd_FTUI3:ble2mqtt/Tab/heartbeat:.* heartbeat\
ble2mqttd_FTUI3:ble2mqtt/Tab/state:.* state
attr MQTT2_ble2mqttd_FTUI3 room MQTT2_DEVICE
setstate MQTT2_ble2mqttd_FTUI3 connected
setstate MQTT2_ble2mqttd_FTUI3 2023-11-05 09:47:27 IODev MQTT2_FHEM_Server
setstate MQTT2_ble2mqttd_FTUI3 2023-11-05 13:07:12 heartbeat 1699186032
setstate MQTT2_ble2mqttd_FTUI3 2023-11-05 13:04:12 state connected
pi@FTUI3:~ $ sudo hcitool lescan
Set scan parameters failed: Input/output error
lepresenced läuft nicht mehr
pi@FTUI3:~ $ sudo service lepresenced status
Unit lepresenced.service could not be found.
komisch ist die mac vom internet Bluetooth
pi@FTUI3:~ $ hcitool dev
Devices:
        hci0    AA:AA:AA:AA:AA:AA
bin mit meinem Wissensstand am ende ok der ist auch nicht sehr ausgeprägt was Linux angeht.
Entschuldige das ich DOOF FRAGE aber ich habe Psychische Probleme und Leide an ADHS mit Kognitiver-Hyperaktivität.
drhirn
Hast du irgend ein Tool, mit dem du den MQTT-Verkehr mitlesen kannst? Den hier z.B.: http://mqtt-explorer.com/.
Und das hier ist irritierend:
Sicher, dass der MQTT-Broker erreichbar ist?
Hast du FHEM und ble2mqtt auf einem Rechner?
