Autor Thema: Nextion Meldung beim starten von FHEM  (Gelesen 593 mal)
Offline eisman
  • Full Member
« am: 13 April 2022, 15:41:24 »
bei mir kommt beim starten von FHEM die Meldung:
2022.04.13 15:40:33 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/42_Nextion.pm line 318, <$fh> line 14.
2022.04.13 15:40:33 1: stacktrace:
2022.04.13 15:40:33 1:     main::__ANON__                      called by ./FHEM/42_Nextion.pm (318)
2022.04.13 15:40:33 1:     main::Nextion_Attr                  called by fhem.pl (3934)
2022.04.13 15:40:33 1:     main::CallFn                        called by fhem.pl (3158)
2022.04.13 15:40:33 1:     main::CommandAttr                   called by fhem.pl (1275)
2022.04.13 15:40:33 1:     main::AnalyzeCommand                called by fhem.pl (1126)
2022.04.13 15:40:33 1:     main::AnalyzeCommandChain           called by fhem.pl (1415)
2022.04.13 15:40:33 1:     main::CommandInclude                called by fhem.pl (1275)
2022.04.13 15:40:33 1:     main::CommandInclude                called by fhem.pl (626)
2022.04.13 15:40:33 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/42_Nextion.pm line 318, <$fh> line 24.
link zum anderen beitrag
mfg
« Letzte Änderung: 13 April 2022, 15:46:52 von eisman »
1x FHEM Debian, Homematic / 1x FHEM Debian, FS20 / 1X FHEM Raspberry ,i2c,onewire,gpio
1x MQTT auf Windows 2012 Hyper-V-Server / 5x ESP8266(ESPeasy,ESPlink) mit 7"HMI
1x FHEM Windows / 1x Arduino Mega mit Configurable Firmata 2.06V
Offline eisman
  • Full Member
Antw:Nextion Meldung beim starten von FHEM
« Antwort #1 am: 17 April 2022, 15:10:33 »
und es war mehr
2022.04.17 15:02:47 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:02:47 1: stacktrace:
2022.04.17 15:02:47 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:02:47 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:02:47 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:02:47 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:02:47 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:02:47 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:02:52 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:02:52 1: stacktrace:
2022.04.17 15:02:52 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:02:52 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:02:52 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:02:52 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:02:52 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:02:52 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:03:14 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:03:14 1: stacktrace:
2022.04.17 15:03:14 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:03:14 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:03:14 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:03:14 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:03:14 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:03:14 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:03:38 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:03:38 1: stacktrace:
2022.04.17 15:03:38 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:03:38 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:03:38 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:03:38 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:03:38 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:03:38 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:04:44 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:04:44 1: stacktrace:
2022.04.17 15:04:44 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:04:44 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:04:44 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:04:44 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:04:44 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:04:44 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:04:47 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:04:47 1: stacktrace:
2022.04.17 15:04:47 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:04:47 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:04:47 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:04:47 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:04:47 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:04:47 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:05:10 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:05:10 1: stacktrace:
2022.04.17 15:05:10 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:05:10 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:05:10 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:05:10 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:05:10 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:05:10 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:05:37 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:05:37 1: stacktrace:
2022.04.17 15:05:37 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:05:37 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:05:37 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:05:37 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:05:37 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:05:37 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:06:40 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:06:40 1: stacktrace:
2022.04.17 15:06:40 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:06:40 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:06:40 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:06:40 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:06:40 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:06:40 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:06:42 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:06:42 1: stacktrace:
2022.04.17 15:06:42 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:06:42 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:06:42 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:06:42 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:06:42 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:06:42 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:07:05 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:07:05 1: stacktrace:
2022.04.17 15:07:05 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:07:05 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:07:05 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:07:05 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:07:05 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:07:05 1:     main::CallFn                        called by fhem.pl (780)
2022.04.17 15:07:35 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/11_FHT.pm line 434.
2022.04.17 15:07:35 1: stacktrace:
2022.04.17 15:07:35 1:     main::__ANON__                      called by ./FHEM/11_FHT.pm (434)
2022.04.17 15:07:35 1:     main::FHT_Parse                     called by fhem.pl (4127)
2022.04.17 15:07:35 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (975)
2022.04.17 15:07:35 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (840)
2022.04.17 15:07:35 1:     main::CUL_Read                      called by fhem.pl (3931)
2022.04.17 15:07:35 1:     main::CallFn                        called by fhem.pl (780)
decade-submarginal
