Error:Modul 00_MQTT2_CLIENT deactivate after error
Begonnen von kroonen, 14 April 2022, 14:30:34
kroonen
I updated fhem, and now I get an error on the MQTT2_CLIENT
Global symbol "$FW_chash" requires explicit package name (did you forget to declare "my $FW_chash"?) at ./FHEM/00_MQTT2_CLIENT.pm line 724, <$fh> line 20.
any idea how to solve this?
The update has been complete? As Rudi has posted in https://forum.fhem.de/index.php/topic,127223.msg1217668.html#msg1217668, there are a few more pieces of code affected to get that up and running.
"update check" might reveal problems in the update process.
Sorry, my fault, I fixed it now.
In your configuration MQTT2_CLIENT is defined before a FHEMWEB instance. As a workaround you could change that, or wait until the FHEM-update tomorrow.
kroonen
