Timeout for PRESENCE
Begonnen von australien, 25 April 2022, 16:35:06
australien
ich bekomme in mein log permanent folgende Meldung
2022.04.25 15:28:08 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11078
2022.04.25 15:28:08 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11079
2022.04.25 15:28:20 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11082
2022.04.25 15:28:20 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11083
2022.04.25 15:28:20 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11084
2022.04.25 15:28:20 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11085
2022.04.25 15:28:20 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11086
2022.04.25 15:29:24 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11093
2022.04.25 15:29:24 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11094
2022.04.25 15:29:42 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11098
2022.04.25 15:29:42 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 11099
2022.04.25 15:30:00 2: PRESENCE (Anwesend_alt_Roxxx) - check returned a valid result after 7 unsuccesful retries
2022.04.25 15:30:03 2: PRESENCE (Anwesend_alt_Kaxxxxx) - check returned a valid result after 8 unsuccesful retries
2022.04.25 15:30:04 2: PRESENCE (Anwesend_alt_Royyy) - check returned a valid result after 8 unsuccesful retries
2022.04.25 15:30:27 2: PRESENCE (Anwesend_alt_Stccc) - check returned a valid result after 8 unsuccesful retries
2022.04.25 15:30:39 2: PRESENCE (Anwesend_alt_Kayyyy) - check returned a valid result after 8 unsuccesful retries
2022.04.25 15:31:03 2: PRESENCE (Anwesend_alt_Soxxx) - check returned a valid result after 6 unsuccesful retries
2022.04.25 15:31:17 2: PRESENCE (Anwesend_alt_Fixx) - check returned a valid result after 8 unsuccesful retries
2022.04.25 15:31:26 2: PRESENCE (Anwesend_alt_Fiyyy) - check returned a valid result after 8 unsuccesful retries
2022.04.25 15:31:33 2: PRESENCE (Anwesend_alt_Syxxx) - check returned a valid result after 8 unsuccesful retries
Wie bekomme ich die weg, ohne Verbose 0 ;)
raspberry pi3
signalduino, Shelly1, Shelly2, Sonos, Unifi
Amazon Fire Tablet 7 | Noname Android Tablet 10"
Vielleicht dafür sorgen, dass Deine LocalFunction() korrekt arbeitet und einen Wert zurückliefert, anstatt in einen Timeout zu laufen?
australien
klingt ja gut, nur lief diese so ca 2 Jahre ohne Fehlermeldung.
DEF   function {ReadingsVal("my_unifi__controller","Frxxx-IPHONE-XS","") eq "connected" ? 1:0}
raspberry pi3
australien
gibt es dafür eine neue Syntax? Oder was ist daran für den timeout verantwortlich?
raspberry pi3
Frank_Huber
Wenn Unifi dahinter ist, warum dann nicht komplett mit Unifi?
defmod Frank_Handy UnifiClient Frank-Handy-S88
attr Frank_Handy DbLogExclude .*
attr Frank_Handy event-on-change-reading .*
attr Frank_Handy stateFormat {ReadingsVal($name,"presence","absent") eq "absent" ? "absent since ".ReadingsVal($name,"_f_last_seen","") : "present since ".ReadingsVal($name,"_f_uptime","")}
attr Frank_Handy userReadings presence:fhem_state.* {(ReadingsVal($name,'fhem_state','disconnected') eq 'disconnected' ? 'absent' : 'present') }
australien
Danke, das werde ich versuchen. Als ich das System eingerichtet hatte, hatte ich keine Ahnung dass es den unificlient gibt.
raspberry pi3
Frank_Huber
Ja, FHEM ist so umfangreich, manchmal dauert es bis man "alles" kennenlernt. ;-)
