Lay-Z Spa" WiFi-remote-for-Bestway-Lay-Z-SPA
Begonnen von Gasmast3r, 17 Juni 2022, 21:12:49
Beta-User
#30
Mit wenn ich die Gesamt-Message korrekt verstanden habe, käme als Zwischenstand in etwa das hier raus:
defmod MQTT2_test MQTT2_DEVICE TEST
attr MQTT2_test IODev m2server
attr MQTT2_test jsonMap TGT:desired-temp TMP:temperature PWR:state AIR:air
attr MQTT2_test readingList layzspa/times:.* { json2nameValue($EVENT, 'times_', $JSONMAP) }\
  layzspa/other:.* { json2nameValue($EVENT, 'other_', $JSONMAP) }\
  layzspa/message:.* { $EVENT =~ s/"(PWR|AIR)":1/"$1":"on"/g;; $EVENT =~ s/"(PWR|AIR)":0/"$1":"off"/g;; json2nameValue($EVENT,'',$JSONMAP) }\
  layzspa/Status:.* { $EVENT eq 'Alive' ? {LWT=>'online'} : {LWT=>'offline'} }\
  layzspa/MAC_Address:.* MAC_Address\
  layzspa/MQTT_Connect_Count:.* MQTT_Connect_Count\
  layzspa/reboot_time:.* reboot_time\
  layzspa/reboot_reason:.* reboot_reason\
  layzspa/button:.* button
attr MQTT2_test room TEST
attr MQTT2_test setList on:noArg layzspa/command { "CMD":4, "VALUE":0, "XTIME":0, "INTERVAL":0 }\
  off:noArg layzspa/command  { "CMD":4, "VALUE":1, "XTIME":0, "INTERVAL":0 }\
  desired-temp:slider,20,1,40 layzspa/command  {CMD:0,VALUE:$EVTPART1,XTIME:0,INTERVAL:0}\
  air:on,off { my $on = $EVTPART1 eq 'on'?1:0;; qq(layzspa/command { "CMD":2, "VALUE":$on, "XTIME":0, "INTERVAL":0 }) }\
  unit:Celsius,Fahrenheit { my $Cel = $EVTPART1 eq 'Celsius'?1:0;; qq(layzspa/command  { "CMD":1, "VALUE":$Cel, "XTIME":0, "INTERVAL":0 }) }\
  heater:on,off { my $on = $EVTPART1 eq 'on'?1:0;; qq(layzspa/command  { "CMD":3, "VALUE":$on, "XTIME":0, "INTERVAL":0 }) }
attr MQTT2_test setStateList on off
attr MQTT2_test webCmd on:off:air:heater:unit
EDITs: da war was doppelt bzw. zu viel...
Gasmast3r
hier mal der hide MQTT trafic
layzspa
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657539677,"LCK":1,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":40,"TMP":21,"CH1":32,"CH2":50,"CH3":49,"HJT":0,"BRT":3}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657539677,"CLTIME":1657126319,"FTIME":1657126321,"UPTIME":318703,"PUMPTIME":83253,"HEATINGTIME":516,"AIRTIME":100,"JETTIME":0,"COST":0.488826126,"FINT":7,"CLINT":7,"KWH":1.396646142,"TTTT":6923,"MINCLK":13}
Helsinki
layzspa/other
{"CONTENT":"OTHER","MQTT":0,"PressedButton":"1b1b","HASJETS":false,"RSSI":-64,"IP":"192.168.178.14","SSID":"My Home","FW":"2022-05-24","MODEL":"MIAMI2021"}
homeassistant
Helsinki
homeassistant/sensor/layzspa_temperature/config
{"device":{"configuration_url":"http://192.168.178.14","connections":[["mac","A8:48:FA:C0:66:63"]],"identifiers":12609123,"manufacturer":"Visualapproach","model":"MIAMI2021","name":"Layzspa WiFi controller","sw_version":"2022-05-24"},"name":"Layzspa temperature","unique_id":"sensor.layzspa_temperature12609123","state_topic":"layzspa/message","unit_of_measurement":"°F","value_template":"{{ value_json.TMP }}","expire_after":700,"availability_topic":"layzspa/Status","payload_available":"Alive","payload_not_available":"Dead","device_class":"temperature"}
Helsinki
homeassistant/sensor/layzspa_target_temperature/config
{"device":{"configuration_url":"http://192.168.178.14","connections":[["mac","A8:48:FA:C0:66:63"]],"identifiers":12609123,"manufacturer":"Visualapproach","model":"MIAMI2021","name":"Layzspa WiFi controller","sw_version":"2022-05-24"},"name":"Layzspa target temperature","unique_id":"sensor.layzspa_target_temperature12609123","state_topic":"layzspa/message","unit_of_measurement":"°F","value_template":"{{ value_json.TGT }}","expire_after":700,"availability_topic":"layzspa/Status","payload_available":"Alive","payload_not_available":"Dead","device_class":"temperature"}
Helsinki
homeassistant/climate/layzspa_climate/config
{"device":{"configuration_url":"http://192.168.178.14","connections":[["mac","A8:48:FA:C0:66:63"]],"identifiers":12609123,"manufacturer":"Visualapproach","model":"MIAMI2021","name":"Layzspa WiFi controller","sw_version":"2022-05-24"},"name":"Layzspa temperature control","unique_id":"climate.layzspa_climate12609123","max_temp":104,"min_temp":68,"precision":1,"temperature_unit":"F","modes":["fan_only", "off", "heat"],"mode_command_topic":"layzspa/command","mode_command_template":"{CMD:3,VALUE:{%if value == \"heat\" %}1{% else %}0{% endif %},XTIME:0,INTERVAL:0}","mode_state_topic":"layzspa/message","mode_state_template":"{% if value_json.RED == 1 %}heat{% elif value_json.GRN == 1 %}heat{% else %}off{% endif %}","action_topic":"layzspa/message","action_template":"{% if value_json.RED == 1 %}heating{% elif value_json.GRN == 1 %}idle{% elif value_json.FLT == 1 %}fan{% else %}off{% endif %}","temperature_state_topic":"layzspa/message","temperature_state_template":"{{ value_json.TGT }}","current_temperature_topic":"layzspa/message","current_temperature_template":"{{ value_json.TMP }}","temperature_command_topic":"layzspa/command","temperature_command_template":"{CMD:0,VALUE:{{ value|int }},XTIME:0,INTERVAL:0}","power_command_topic":"layzspa/command","payload_on":"{CMD:4,VALUE:1,XTIME:0,INTERVAL:0}","payload_off":"{CMD:4,VALUE:0,XTIME:0,INTERVAL:0}","availability_topic":"layzspa/Status","payload_available":"Alive","payload_not_available":"Dead"}
Helsinki
{"device":{"configuration_url":"http://192.168.178.14","connections":[["mac","A8:48:FA:C0:66:63"]],"identifiers":12609123,"manufacturer":"Visualapproach","model":"MIAMI2021","name":"Layzspa WiFi controller","sw_version":"2022-05-24"},"name":"Layzspa temperature","unique_id":"sensor.layzspa_temperature12609123","state_topic":"layzspa/message","unit_of_measurement":"°C","value_template":"{{ value_json.TMP }}","expire_after":700,"availability_topic":"layzspa/Status","payload_available":"Alive","payload_not_available":"Dead","device_class":"temperature"}
Helsinki
{"device":{"configuration_url":"http://192.168.178.14","connections":[["mac","A8:48:FA:C0:66:63"]],"identifiers":12609123,"manufacturer":"Visualapproach","model":"MIAMI2021","name":"Layzspa WiFi controller","sw_version":"2022-05-24"},"name":"Layzspa target temperature","unique_id":"sensor.layzspa_target_temperature12609123","state_topic":"layzspa/message","unit_of_measurement":"°C","value_template":"{{ value_json.TGT }}","expire_after":700,"availability_topic":"layzspa/Status","payload_available":"Alive","payload_not_available":"Dead","device_class":"temperature"}
Helsinki
{"device":{"configuration_url":"http://192.168.178.14","connections":[["mac","A8:48:FA:C0:66:63"]],"identifiers":12609123,"manufacturer":"Visualapproach","model":"MIAMI2021","name":"Layzspa WiFi controller","sw_version":"2022-05-24"},"name":"Layzspa temperature control","unique_id":"climate.layzspa_climate12609123","max_temp":40,"min_temp":20,"precision":1,"temperature_unit":"C","modes":["fan_only", "off", "heat"],"mode_command_topic":"layzspa/command","mode_command_template":"{CMD:3,VALUE:{%if value == \"heat\" %}1{% else %}0{% endif %},XTIME:0,INTERVAL:0}","mode_state_topic":"layzspa/message","mode_state_template":"{% if value_json.RED == 1 %}heat{% elif value_json.GRN == 1 %}heat{% else %}off{% endif %}","action_topic":"layzspa/message","action_template":"{% if value_json.RED == 1 %}heating{% elif value_json.GRN == 1 %}idle{% elif value_json.FLT == 1 %}fan{% else %}off{% endif %}","temperature_state_topic":"layzspa/message","temperature_state_template":"{{ value_json.TGT }}","current_temperature_topic":"layzspa/message","current_temperature_template":"{{ value_json.TMP }}","temperature_command_topic":"layzspa/command","temperature_command_template":"{CMD:0,VALUE:{{ value|int }},XTIME:0,INTERVAL:0}","power_command_topic":"layzspa/command","payload_on":"{CMD:4,VALUE:1,XTIME:0,INTERVAL:0}","payload_off":"{CMD:4,VALUE:0,XTIME:0,INTERVAL:0}","availability_topic":"layzspa/Status","payload_available":"Alive","payload_not_available":"Dead"}
hier sind auch Timer für Filterwechsel oder Chlor Prüfen angegeben
Entschuldige das ich DOOF FRAGE aber ich habe Psychische Probleme und Leide an ADHS mit Kognitiver-Hyperaktivität.
Beta-User
a) wenn du mich verärgern willst, zeigst du noch mehr von dem Homeassistant-config-Quatsch  >:(
b) für den Rest hätte ich gerne EINE Schaltanweisung im kompletten Ablauf, wie sie der FHEM-MQTT2_SERVER mit "show MQTT traffic" anzeigt: Was geht raus, was kommt zurück?
Irgendeinen Zwischenstand statisch mitgeteilt zu bekommen, bringt mir nichts, weil der Bezug völlig unklar ist... (und dir im übrigen auch nicht, du solltest dir das im Ablauf ansehen!)
Gasmast3r
#33
War nicht meine absicht
hier wenn ich die Temperatur setze
er sendet für jeden °C eine neue message
SENT
layzspa/command
{CMD:0,VALUE:34,XTIME:0,INTERVAL:0}
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547385,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":36,"TMP":22,"CH1":32,"CH2":50,"CH3":50,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547385,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1071,"PUMPTIME":1071,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.00437325,"FINT":7,"CLINT":7,"KWH":0.012495001,"TTTT":-1189,"MINCLK":12}
Helsinki
layzspa/other
{"CONTENT":"OTHER","MQTT":0,"PressedButton":"1b1b","HASJETS":false,"RSSI":-62,"IP":"192.168.178.14","SSID":"My Home","FW":"2022-05-24","MODEL":"MIAMI2021"}
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547385,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":36,"TMP":22,"CH1":32,"CH2":51,"CH3":54,"HJT":0,"BRT":6}
Helsinki
layzspa/times
Helsinki
layzspa/other
{"CONTENT":"OTHER","MQTT":0,"PressedButton":"1b1b","HASJETS":false,"RSSI":-63,"IP":"192.168.178.14","SSID":"My Home","FW":"2022-05-24","MODEL":"MIAMI2021"}
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547386,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":35,"TMP":22,"CH1":32,"CH2":51,"CH3":53,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547386,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1072,"PUMPTIME":1072,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.004377333,"FINT":7,"CLINT":7,"KWH":0.012506668,"TTTT":-1190,"MINCLK":11}
Helsinki
layzspa/other
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547387,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":51,"CH3":52,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547387,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1073,"PUMPTIME":1073,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.004381416,"FINT":7,"CLINT":7,"KWH":0.012518332,"TTTT":-1191,"MINCLK":12}
Helsinki
layzspa/other
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547388,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":32,"CH3":32,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547388,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1073,"PUMPTIME":1073,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.004381416,"FINT":7,"CLINT":7,"KWH":0.012518332,"TTTT":-1192,"MINCLK":8}
Helsinki
layzspa/other
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547388,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":51,"CH3":52,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547388,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1074,"PUMPTIME":1074,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.0043855,"FINT":7,"CLINT":7,"KWH":0.01253,"TTTT":-1192,"MINCLK":13}
Helsinki
layzspa/other
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547389,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":32,"CH3":32,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547389,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1074,"PUMPTIME":1074,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.0043855,"FINT":7,"CLINT":7,"KWH":0.01253,"TTTT":-1193,"MINCLK":7}
Helsinki
layzspa/other
{"CONTENT":"OTHER","MQTT":0,"PressedButton":"1b1b","HASJETS":false,"RSSI":-61,"IP":"192.168.178.14","SSID":"My Home","FW":"2022-05-24","MODEL":"MIAMI2021"}
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547389,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":51,"CH3":52,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547389,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1075,"PUMPTIME":1075,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.004389583,"FINT":7,"CLINT":7,"KWH":0.012541667,"TTTT":-1193,"MINCLK":7}
Helsinki
layzspa/other
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547390,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":32,"CH3":32,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547390,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1075,"PUMPTIME":1075,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.004389583,"FINT":7,"CLINT":7,"KWH":0.012541667,"TTTT":-1194,"MINCLK":12}
Helsinki
layzspa/other
Helsinki
layzspa/message
Helsinki
layzspa/times
Helsinki
layzspa/other
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547390,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":51,"CH3":52,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547390,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1076,"PUMPTIME":1076,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.004393667,"FINT":7,"CLINT":7,"KWH":0.012553333,"TTTT":-1194,"MINCLK":12}
Helsinki
layzspa/other
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547391,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":50,"CH3":50,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547391,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1076,"PUMPTIME":1076,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.004393667,"FINT":7,"CLINT":7,"KWH":0.012553333,"TTTT":-1195,"MINCLK":10}
Helsinki
layzspa/other
hier wenn ich die Pumpe ausschalte
SENT
layzspa/command
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547429,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":0,"FLT":0,"TGT":34,"TMP":22,"CH1":32,"CH2":50,"CH3":50,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547429,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1115,"PUMPTIME":1115,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.004552917,"FINT":7,"CLINT":7,"KWH":0.013008334,"TTTT":-1233,"MINCLK":10}
Helsinki
layzspa/other
hier wenn ich die Heizung einschalte( geht die Pumpe mit an )
Helsinki
layzspa/message
{"CONTENT":"STATES","TIME":1657547477,"LCK":0,"PWR":1,"UNT":1,"AIR":0,"GRN":0,"RED":1,"FLT":1,"TGT":34,"TMP":22,"CH1":32,"CH2":50,"CH3":50,"HJT":0,"BRT":6}
Helsinki
layzspa/times
{"CONTENT":"TIMES","TIME":1657547477,"CLTIME":1657546357,"FTIME":1657126321,"UPTIME":1163,"PUMPTIME":1115,"HEATINGTIME":0,"AIRTIME":0,"JETTIME":0,"COST":0.00456225,"FINT":7,"CLINT":7,"KWH":0.013035,"TTTT":-1281,"MINCLK":9}
Helsinki
layzspa/other
um es schöner zu gestalten fehlt mir das bessere wissen wie man sowas verschönert um die informationen besser darstellen zu können mit Jason map und was es da noch alles für möglichkeiten giebt
Beta-User
OK, das mit dem wiederholenden Rückmelden ist nicht allzu schön, aber besser wie keine Rückmeldung ;) .
Demnach stimmen zumindest mal die "Kreise" (setList+jsonMap) für desired-temp und temperature. Oder?
SENT
layzspa/command
Helsinki
layzspa/message
Helsinki
Helsinki
layzspa/message
Demnach wäre "FLT" das Kürzel für die Pumpe? Kannst du das bitte mal verifizieren, indem du händisch an Gerät direkt schaltest? Dann sollten eigentlich auch Messages kommen (hoffe ich zumindest).
Demnach wäre in jsonMap nicht "PWR:state" zu mappen, sondern "FLT:state"
Oder hat "PWR" eine spezielle Bedeutung und wir brauchen doch einen zusätzlichen "pump"-Schalter?
Deswegen der deutliche Hinweis, dass man sich sowas "im Fluss" erschließen muss. Ich kann nur etwas Therie liefern (und habe eine gewisse Übung darin zu erraten, wie was gemeint sein kann), aber die Details musst du dann selbst rausfieseln.
Und hast du eine Idee, für was die CHx-Kürzel sind? Gibt es eine Beleuchtung?
Gasmast3r
#35
Hy
Bekannt
AIR = Luftdüsen
BRT = Helligkeit Display
FLT = Pumpe( Filter)
PWR = Gerät ein/aus
UNT = °C/1 oder °F/0
RED = Heizung
LCK = Tastensperre
das kann ich jetzt so sagen, zumindestens kann ich so meine zustände bestimmen
unbekannt
CH1-3 noch nicht rausgefunden
eventuell für andere Modelle
GRN
HJT (solte wohl Hydrojet sein also anderes modell)
Beta-User
Na ja, dann kannst du ja mal zumindest anfangen zu mappen.
Komisch ist das "example" (hattest du irgendwo hier gepostet):
{CMD:0, VALUE:1, XTIME:0, INTERVAL:100}
Würde tippen, dass der "CMD:0"-Zweig zugleich als Hauptschalter dient?
Also diese Payload das Ding ausschaltet:
{CMD:0, VALUE:0, XTIME:0, INTERVAL:100}
Gasmast3r
AIR = Luftdüsen  CMD:2
FLT = Pumpe( Filter)  CMD:4
PWR = Gerät ein/aus
UNT = °C/1 oder °F/0 CMD:1
RED = Heizung  CMD:3
LCK = Tastensperre
TGT = Temperatur einstellen CMD:0
Habe mir 5 Devices angefertigt die soweit funktionieren inkl zusandsänderung wenn ich es wo anders schalte.
die idee war noch es in 1 Device zusammen zu fügen
Beta-User
? was ist mit meinem Beispiel-Code?
Bis auf das "falsche" mapping von "pump" auf "state" sollte das passen...
Gasmast3r
#39
den zweiten habe ich garnicht gesehen
hier meine derzeitige zusammenstellung
Bubble
defmod MQTT2_Helsinki_CH2 MQTT2_DEVICE Helsinki
attr MQTT2_Helsinki_CH2 alexaName Bubble
attr MQTT2_Helsinki_CH2 alias BUBBLE
attr MQTT2_Helsinki_CH2 autocreate 0
attr MQTT2_Helsinki_CH2 group Spa
attr MQTT2_Helsinki_CH2 readingList Helsinki:layzspa/times:.* { json2nameValue($EVENT, 'times_', $JSONMAP) }\
Helsinki:layzspa/other:.* { json2nameValue($EVENT, 'other_', $JSONMAP) }\
Helsinki:layzspa/message:.* { json2nameValue($EVENT,'',$JSONMAP) }\
Helsinki:layzspa/Status:.* Status\
Helsinki:layzspa/MAC_Address:.* MAC_Address\
Helsinki:layzspa/MQTT_Connect_Count:.* MQTT_Connect_Count\
Helsinki:layzspa/reboot_time:.* reboot_time\
Helsinki:layzspa/reboot_reason:.* reboot_reason\
Helsinki:layzspa/button:.* button\
attr MQTT2_Helsinki_CH2 room MQTT2_DEVICE
attr MQTT2_Helsinki_CH2 setList on:noArg layzspa/command  { "CMD":2, "VALUE":1, "XTIME":0, "INTERVAL":0 }\\
  off:noArg layzspa/command  { "CMD":2, "VALUE":0, "XTIME":0, "INTERVAL":0 }\
attr MQTT2_Helsinki_CH2 stateFormat read
attr MQTT2_Helsinki_CH2 userReadings read {(ReadingsVal($name,"AIR","1") eq "1")?"on":"off"}
attr MQTT2_Helsinki_CH2 webCmd :
Heizung
defmod MQTT2_Helsinki_CH3 MQTT2_DEVICE Helsinki_BUBBLE
attr MQTT2_Helsinki_CH3 alexaName SPA
attr MQTT2_Helsinki_CH3 alias HEATER
attr MQTT2_Helsinki_CH3 autocreate 0
attr MQTT2_Helsinki_CH3 group Spa
attr MQTT2_Helsinki_CH3 readingList Helsinki:layzspa/times:.* { json2nameValue($EVENT, 'times_', $JSONMAP) }\
attr MQTT2_Helsinki_CH3 room MQTT2_DEVICE
attr MQTT2_Helsinki_CH3 setList on:noArg layzspa/command  { "CMD":3, "VALUE":1, "XTIME":0, "INTERVAL":0 }\\
  off:noArg layzspa/command  { "CMD":3, "VALUE":0, "XTIME":0, "INTERVAL":0 }
attr MQTT2_Helsinki_CH3 stateFormat read
attr MQTT2_Helsinki_CH3 userReadings read {(ReadingsVal($name,"RED","1") eq "1")?"on":"off"}
attr MQTT2_Helsinki_CH3 webCmd :
Pumpe
defmod MQTT2_Helsinki_CH4 MQTT2_DEVICE Helsinki
attr MQTT2_Helsinki_CH4 alexaName Pumpe
attr MQTT2_Helsinki_CH4 alias PUMP
attr MQTT2_Helsinki_CH4 autocreate 0
attr MQTT2_Helsinki_CH4 group Spa
attr MQTT2_Helsinki_CH4 readingList Helsinki:layzspa/times:.* { json2nameValue($EVENT, 'times_', $JSONMAP) }\
attr MQTT2_Helsinki_CH4 room MQTT2_DEVICE
attr MQTT2_Helsinki_CH4 setList on:noArg layzspa/command  { "CMD":4, "VALUE":1, "XTIME":0, "INTERVAL":0 }\\
  off:noArg layzspa/command  { "CMD":4, "VALUE":0, "XTIME":0, "INTERVAL":0 }
attr MQTT2_Helsinki_CH4 stateFormat read
attr MQTT2_Helsinki_CH4 userReadings read {(ReadingsVal($name,"FLT","1") eq "1")?"on":"off"}
attr MQTT2_Helsinki_CH4 webCmd :
Temperatur
defmod MQTT2_Helsinki MQTT2_DEVICE Helsinki
attr MQTT2_Helsinki alexaName SPA
attr MQTT2_Helsinki alias TEMPERATUR
attr MQTT2_Helsinki autocreate 0
attr MQTT2_Helsinki genericDeviceType thermostat
attr MQTT2_Helsinki group Spa
attr MQTT2_Helsinki icon temp_control
attr MQTT2_Helsinki readingList Helsinki:layzspa/message:.* { json2nameValue($EVENT,'',$JSONMAP) }\
Helsinki:homeassistant/sensor/layzspa_temperature/config:.* { json2nameValue($EVENT, 'config_', $JSONMAP) }\
Helsinki:homeassistant/sensor/layzspa_target_temperature/config:.* { json2nameValue($EVENT, 'config_', $JSONMAP) }\
Helsinki:homeassistant/climate/layzspa_climate/config:.* { json2nameValue($EVENT, 'config_', $JSONMAP) }\
attr MQTT2_Helsinki room MQTT2_DEVICE
attr MQTT2_Helsinki setList TGT:slider,20,1,40 layzspa/command  {CMD:0,VALUE:$EVTPART1,XTIME:0,INTERVAL:0}
attr MQTT2_Helsinki stateFormat TMP config_unit_of_measurement
attr MQTT2_Helsinki webCmd TGT
UNIT °C/°F
defmod MQTT2_Helsinki_CH5 MQTT2_DEVICE Helsinki
attr MQTT2_Helsinki_CH5 alias Unit (F/C)
attr MQTT2_Helsinki_CH5 autocreate 0
attr MQTT2_Helsinki_CH5 group Spa
attr MQTT2_Helsinki_CH5 readingList Helsinki:layzspa/times:.* { json2nameValue($EVENT, 'times_', $JSONMAP) }\
Helsinki:layzspa/homeassistant/switch/layzspa_temperature_unit:.* { json2nameValue($EVENT,'',$JSONMAP) }
attr MQTT2_Helsinki_CH5 room MQTT2_DEVICE
attr MQTT2_Helsinki_CH5 setList °C:noArg layzspa/command  { "CMD":1, "VALUE":1, "XTIME":0, "INTERVAL":0 }\\
  °F:noArg layzspa/command  { "CMD":1, "VALUE":0, "XTIME":0, "INTERVAL":0 }\
attr MQTT2_Helsinki_CH5 stateFormat read
attr MQTT2_Helsinki_CH5 userReadings read {(ReadingsVal($NAME,"UNT","1") eq "1")?"°C":"°F"}
attr MQTT2_Helsinki_CH5 webCmd °C:°F
nicht so geil wie deine versionen
Gasmast3r
#40
der passt recht gut
on off muste ich tauschen
on =0 zu =1
off =1 zu=0
heizung muss ich noch mal ändern und den Slider hinzufügen
bei Heizung und Celsius bekomme ich keine satus update wenn ich es per Web schalte
das birnen symbol geht auch nicht steht halt nur 1 oder 0
Bild ist meine Version
Gasmast3r
#41
so habe dein Beispiel noch mal angepasst nun klappt alles
attr MQTT2_test1 jsonMap TGT:desired-temp TMP:temperature FLT:state AIR:air RED:heater UNT:unit
attr MQTT2_test1 readingList layzspa/times:.* { json2nameValue($EVENT, 'times_', $JSONMAP) }\
  layzspa/message:.* { $EVENT =~ s/"(FLT|AIR|RED)":1/"$1":"on"/g;;;; $EVENT =~ s/"(FLT|AIR|RED)":0/"$1":"off"/g;;;; json2nameValue($EVENT,'',$JSONMAP) }\
  layzspa/message:.* { $EVENT =~ s/"(UNT)":1/"$1":"Celsius"/g;;;; $EVENT =~ s/"(UNT)":0/"$1":"Fahrenheit"/g;;;; json2nameValue($EVENT,'',$JSONMAP) }
attr MQTT2_test1 room TEST
attr MQTT2_test1 setList on:noArg layzspa/command { "CMD":4, "VALUE":1, "XTIME":0, "INTERVAL":0 }\
  off:noArg layzspa/command  { "CMD":4, "VALUE":0, "XTIME":0, "INTERVAL":0 }\
  air:on,off { my $on = $EVTPART1 eq 'on'?1:0;;;; qq(layzspa/command { "CMD":2, "VALUE":$on, "XTIME":0, "INTERVAL":0 }) }\
  unit:Celsius,Fahrenheit { my $Celsius = $EVTPART1 eq 'Celsius'?1:0;;;; qq(layzspa/command  { "CMD":1, "VALUE":$Celsius, "XTIME":0, "INTERVAL":0 }) }\
  heater:on,off { my $on = $EVTPART1 eq 'on'?1:0;;;; qq(layzspa/command  { "CMD":3, "VALUE":$on, "XTIME":0, "INTERVAL":0 }) }
attr MQTT2_test1 setStateList on off
attr MQTT2_test1 webCmd on:off:air:heater:unit:desired-temp
INTERVAL:100 soll wohl für alle 100sec sendet er das
das habe ich noch gefunden
doc["LCK"] = _cio.states[LOCKEDSTATE];
    doc["PWR"] = _cio.states[POWERSTATE];
    doc["UNT"] = _cio.states[UNITSTATE];
    doc["AIR"] = _cio.states[BUBBLESSTATE];
    doc["GRN"] = _cio.states[HEATGRNSTATE];
    doc["RED"] = _cio.states[HEATREDSTATE];
    doc["FLT"] = _cio.states[PUMPSTATE];
    doc["TGT"] = _cio.states[TARGET];
    doc["TMP"] = _cio.states[TEMPERATURE];
    doc["CH1"] = _cio.states[CHAR1];
    doc["CH2"] = _cio.states[CHAR2];
    doc["CH3"] = _cio.states[CHAR3]; */
const settarget = 0;
const setunit = 1;
const setbubbles = 2;
const setheat = 3;
const setpump = 4;
const resetq = 5;
const rebootesp = 6;
const gettarget = 7;
const resettimes = 8;
const resetcltimer = 9;
const resetftimer = 10;
Gasmast3r
Hy da nun alles soweit läuft,( um es mit Alexa zu nutzen in Einzel devices) wollte ich mich noch mal für die Hilfe bedanken.
Ich hoffe es hilft noch dem ein oder anderen User.
Beta-User
 :) Danke für die Rückmeldung, freut mich sehr, wenn es jetzt so ist, wie du es haben willst.
Was Einzeldevices angeht, würde ich das hier anders lösen, nämlich ein "Gesamtdevice" bauen und dann die beiden "Sonderdevices" per readingsProxy vereinzeln. So wie du das jetzt aufgezogen hast, machst du sehr viele Auswertungen und auch Events zusätzlich. Sollte man m.E. vermeiden... (Zur Klarstellung: Da wo es attrTemplate für MQTT2_DEVICE per "split" machen, sind die Einzeldevices in der Regel reduziert auf das eine Reading, die readingList ist enstpechend kurz und json2nameValue()/jsonMap beerdigt direkt den Rest...).
Gasmast3r
Hy ich denke wenn es mehr Interesse giebt könnte man das sicher in Angriff nehmen, Rechenleistung jetzt sollte ja sicherlich vernachlässigbar sein.
