Hauptmenü
Milight Hub
Begonnen von Heisemer Bub, 14 Juli 2022, 13:33:54
Heisemer Bub
Hallo, probiere gerade das MilightBridge Modul aus (Hardware is esp8266)
In Fhem MQTT2 Server installiert und und hub (esp8266) mit dem MQTT2 verbunden.
   CFGFN
   Clients    :MilightDevice:
   DEF        192.168.200.167
   FUUID      62cea841-f33f-b652-e7ba-4d9457563151d32f
   HOST       192.168.200.167
   INTERVAL   100
   NAME       MilightBridge
   NR         2433
   NTFY_ORDER 50-MilightBridge
   PORT       8899
   SENDFAIL   0
   STATE      ok
   TYPE       MilightBridge
   cmdLastSent 1657794492.19262
   cmdQueueLock 0
   eventCount 2022
   0:
     NAME       wz.DeckenLampe
   1:
   2:
   3:
   4:
   5:
   6:
   7:
   8:
   MatchList:
     1:MilightDevice .*
     2022-07-14 13:09:34   sendFail        0
     2022-07-14 12:29:41   slot0           wz.DeckenLampe
     2022-07-14 12:29:41   slot1
     2022-07-14 12:29:41   slot2
     2022-07-14 12:29:41   slot3
     2022-07-14 12:29:41   slot4
     2022-07-14 12:29:41   slot5
     2022-07-14 12:29:41   slot6
     2022-07-14 12:29:41   slot7
     2022-07-14 12:29:41   slot8
     2022-07-14 13:09:34   state           ok
   cmdQueue:
   helper:
   hmccu:
   checkInterval 10
   event-on-change-reading state
   port       8899
   protocol   udp
   sendInterval 100
   AuthenticatedBy allowed
   AuthenticatedUser test
   BUF
   FD         37
   NAME       MQTT2_192.168.200.167_49156
   NR         9823
   PEER       192.168.200.167
   PORT       49156
   SNAME      MQTT2
   SSL
   STATE      Connected
   TEMPORARY  1
   TYPE       MQTT2_SERVER
   WBCallback
   cflags     194
   cid        milight-hub-1600842
   keepalive  15
   lastMsgTime 1657797061.58316
   protoNum   4
   protoTxt   MQTT
   usr        test
     2022-07-14 10:38:00   state           Connected
   subscriptions:
     milight/+/+/+ 1657787880.46751
   room       hidden
Nun möchte ich natürlich eine bulb steuern und habe ein milight device angelegt
   CFGFN
   DEF        RGB MilightBridge 0
   FUUID      62cfd709-f33f-b652-8df6-d56f6f0e75b903ee
   INIT       1
   IODev      MilightBridge
   LEDTYPE    RGB
   NAME       wz.DeckenLampe
   NR         9857
   NTFY_ORDER 50-wz.DeckenLampe
   SLOT       1
   SLOTID     1
   STATE      off
   TYPE       MilightDevice
   eventCount 117
     2022-07-14 10:42:49   IODev           MilightBridge
     2022-07-14 12:28:11   brightness      0
     2022-07-14 12:28:11   brightness_on   55
     2022-07-14 12:28:11   discoMode       0
     2022-07-14 12:28:11   discoSpeed      0
     2022-07-14 12:28:11   hsv             0,100,0
     2022-07-14 12:28:11   hue             0
     2022-07-14 12:28:11   previousState   0,100,55
     2022-07-14 12:28:11   rgb             000000
     2022-07-14 12:28:11   saturation      100
     2022-07-14 12:28:11   state           off
     2022-07-14 12:28:11   transitionInProgress 0
   helper:
     COMMANDSET on off toggle dimup dimdown discoModeUp:noArg discoModeDown:noArg discoSpeedUp:noArg discoSpeedDown:noArg pair unpair restorePreviousState:noArg saveState:noArg restoreState:noArg hsv rgb:colorpicker,RGB hue:colorpicker,HUE,0,1,360 saturation:slider,0,100,100 preset dim:slider,0,11,100 brightness:slider,0,11,100
     colorLevel 0
     targetHue  0
     targetSat  100
     targetTime 1657794491.03461
     targetVal  0
     COLORMAP:
       176
       175
       175
       174
       174
       173
       173
       172
       172
       171
       171
       170
       170
       169
       169
       168
       167
       167
       166
       166
       165
       165
       164
       164
       163
       163
       162
       162
       161
       161
       160
       159
       159
       158
       158
       157
       157
       156
       156
       155
       155
       154
       154
       153
       153
       152
       151
       151
       150
       150
       149
       149
       148
       148
       147
       147
       146
       146
       145
       145
       144
       143
       142
       142
       141
       140
       139
       138
       138
       137
       136
       135
       134
       134
       133
       132
       131
       130
       130
       129
       128
       127
       126
       126
       125
       124
       123
       122
       122
       121
       120
       119
       118
       118
       117
       116
       115
       114
       114
       113
       112
       111
       110
       110
       109
       108
       107
       106
       106
       105
       104
       103
       102
       102
       101
       100
       99
       98
       98
       97
       96
       95
       95
       94
       93
       93
       92
       91
       91
       90
       89
       89
       88
       87
       87
       86
       85
       85
       84
       83
       83
       82
       81
       81
       80
       79
       79
       78
       77
       77
       76
       75
       75
       74
       73
       73
       72
       71
       71
       70
       69
       69
       68
       67
       67
       66
       65
       65
       64
       63
       63
       62
       61
       61
       60
       59
       59
       58
       57
       57
       56
       55
       55
       54
       53
       53
       52
       51
       51
       50
       49
       49
       48
       47
       47
       46
       45
       45
       44
       43
       43
       42
       41
       41
       40
       39
       39
       38
       37
       37
       36
       35
       35
       34
       33
       33
       32
       31
       31
       30
       29
       29
       28
       27
       27
       26
       25
       25
       24
       23
       23
       22
       21
       21
       20
       19
       19
       18
       17
       17
       17
       16
       15
       15
       14
       13
       12
       11
       11
       10
       9
       8
       7
       7
       6
       5
       4
       3
       3
       2
       1
       0
       254
       254
       253
       252
       251
       250
       250
       249
       248
       247
       246
       246
       245
       244
       243
       242
       242
       241
       240
       239
       238
       238
       237
       236
       235
       234
       234
       233
       232
       231
       230
       230
       229
       228
       227
       226
       226
       225
       224
       223
       222
       222
       221
       220
       219
       218
       218
       217
       216
       215
       214
       214
       213
       212
       211
       210
       210
       209
       208
       207
       206
       206
       205
       204
       203
       202
       202
       201
       200
       199
       198
       198
       197
       196
       195
       194
       194
       193
       192
       191
       190
       190
       189
       188
       187
       186
       186
       185
       184
       183
       182
       182
       181
       180
       179
       178
       178
       177
     GAMMAMAP:
       0
       11
       11
       11
       11
       11
       11
       11
       11
       11
       11
       11
       12
       13
       14
       15
       16
       17
       18
       19
       20
       21
       22
       23
       24
       25
       26
       27
       28
       29
       30
       31
       32
       33
       34
       35
       36
       37
       38
       39
       40
       41
       42
       43
       44
       45
       46
       47
       48
       49
       50
       51
       52
       53
       54
       55
       56
       57
       58
       59
       60
       61
       62
       63
       64
       65
       66
       67
       68
       69
       70
       71
       72
       73
       74
       75
       76
       77
       78
       79
       80
       81
       82
       83
       84
       85
       86
       87
       88
       89
       90
       91
       92
       93
       94
       95
       96
       97
       98
       99
       100
     cmdQueue:
   IODev      MilightBridge
   devStateIcon {(MilightDevice_devStateIcon($name),"toggle")}
   event-on-change-reading state,transitionInProgress
   lightSceneParamsToSave hsv
   restoreAtStart 1
   webCmd     on:off:dim:hue:rgb ffffff:rgb ff0000:rgb 00ff00:rgb 0000ff:rgb ffff00
leider kann ich die bulb so aber nicht ansteuern......
Alternativ habe ich noch ein Device angelegt
   CFGFN
   CONNECTION bridge-V3
   DEF        RGBW2 bridge-V3:192.168.200.167
   FUUID      62ceb765-f33f-b652-5340-965fb7064dda3284
   IP         192.168.200.167
   LEDTYPE    RGBW2
   NAME       wmilight1
   NR         2890
   NTFY_ORDER 50-wmilight1
   PORT       8899
   PROTO      0
   SLOT       5
   STATE      off
   TYPE       WifiLight
   eventCount 39
     2022-07-14 12:28:41   RGB             000000
     2022-07-14 12:28:41   brightness      0
     2022-07-14 12:28:41   hue             0
     2022-07-14 12:28:41   saturation      0
     2022-07-14 12:28:41   state           off
   helper:
     COMMANDSET on off dim dimup dimdown HSV RGB sync pair unpair
     colorLevel 0
     colorValue -1
     llLock     0
     mode       0
     targetTime 1657794521.56755
     whiteLevel 0
     COLORMAP:
       168
       167
       167
       166
       166
       165
       165
       164
       163
       163
       162
       162
       161
       161
       160
       159
       159
       158
       158
       157
       157
       156
       156
       155
       154
       154
       153
       153
       152
       152
       151
       150
       150
       149
       149
       148
       148
       147
       146
       146
       145
       145
       144
       144
       143
       142
       142
       141
       141
       140
       140
       139
       139
       138
       137
       137
       136
       136
       135
       135
       134
       133
       132
       132
       131
       130
       129
       129
       128
       127
       126
       126
       125
       124
       123
       122
       122
       121
       120
       119
       119
       118
       117
       116
       116
       115
       114
       113
       113
       112
       111
       110
       109
       109
       108
       107
       106
       106
       105
       104
       103
       103
       102
       101
       100
       99
       99
       98
       97
       96
       96
       95
       94
       93
       93
       92
       91
       90
       90
       89
       88
       87
       87
       86
       86
       85
       85
       84
       84
       83
       83
       82
       82
       81
       81
       80
       79
       79
       78
       78
       77
       77
       76
       76
       75
       75
       74
       74
       73
       73
       72
       71
       71
       70
       70
       69
       69
       68
       68
       67
       67
       66
       66
       65
       65
       64
       63
       63
       62
       62
       61
       61
       60
       60
       59
       59
       58
       58
       57
       57
       56
       55
       54
       54
       53
       52
       51
       50
       50
       49
       48
       47
       46
       46
       45
       44
       43
       42
       42
       41
       40
       39
       38
       38
       37
       36
       35
       34
       34
       33
       32
       31
       30
       30
       29
       28
       27
       26
       26
       25
       24
       23
       22
       22
       21
       20
       19
       18
       18
       17
       16
       15
       14
       14
       13
       12
       11
       10
       10
       9
       9
       8
       7
       6
       5
       4
       3
       2
       2
       1
       0
       254
       253
       252
       251
       250
       249
       248
       247
       246
       245
       244
       243
       243
       242
       241
       240
       239
       238
       237
       236
       235
       234
       233
       232
       231
       230
       229
       229
       228
       227
       226
       225
       224
       223
       222
       221
       220
       219
       218
       217
       216
       215
       215
       214
       213
       212
       211
       210
       209
       208
       207
       207
       206
       205
       205
       204
       203
       203
       202
       201
       201
       200
       199
       199
       198
       197
       197
       196
       195
       195
       194
       193
       193
       192
       191
       191
       190
       189
       189
       188
       187
       187
       186
       185
       185
       184
       183
       183
       182
       181
       181
       180
       179
       179
       178
       177
       177
       176
       175
       175
       174
       173
       173
       172
       171
       171
       170
       169
       169
     GAMMAMAP:
       0
       0.182084917038383
       0.470591230357907
       0.820096073367633
       1.21622432924022
       1.65107624587364
       2.11950570346478
       2.61783651126499
       3.14328343499055
       3.69364788963403
       4.26714092851856
       4.86227250061747
       5.47777824197178
       6.112568939676
       6.76569440648595
       7.43631690144944
       8.12369109476553
       8.82714865073238
       9.54608615125084
       10.2799554881179
       11.0282561143647
       11.7905287188301
       12.566350006457
       13.3553283490082
       14.1571001291331
       14.971326642687
       15.7976914549342
       16.6358981290745
       17.4856682626968
       18.3467397808198
       19.2188654442296
       20.1018115396355
       20.9953567242883
       21.899291002556
       22.8134148158172
       23.7375382301393
       24.6714802087245
       25.615067958155
       26.5681363391464
       27.5305273339062
       28.5020895633382
       29.4826778482926
       30.4721528098611
       31.470380504392
       32.4772320894657
       33.4925835175601
       34.5163152545402
       35.5483120204638
       36.5884625504948
       37.6366593739748
       38.6927986099313
       39.7567797774927
       40.8285056198529
       41.9078819405719
       42.994817451133
       44.0892236287856
       45.1910145838062
       46.3001069353943
       47.4164196955005
       48.5398741599513
       49.6703938062953
       50.8079041978503
       51.9523328934805
       53.1036093626722
       54.2616649055192
       55.4264325772608
       56.5978471170475
       57.7758448806357
       58.9603637767409
       60.1513432067978
       61.3487240079
       62.5524483987055
       63.7624599281173
       64.9787034265577
       66.2011249596724
       67.429671784312
       68.6642923066494
       69.9049360423029
       71.1515535783445
       72.4040965370806
       73.6625175415008
       74.9267701822992
       76.1968089863762
       77.4725893867394
       78.7540676937228
       80.0412010674534
       81.3339474914964
       82.6322657476148
       83.9361153915856
       85.2454567300145
       86.5602507980997
       87.8804593382937
       89.2060447798182
       90.5369702189896
       91.8731994003132
       93.21469669831
       94.5614271000383
       95.9133561882787
       97.2704501253487
       98.6326756375187
       100
     hlCmdQueue:
     llCmdQueue:
mit diesem device kann ich die bulb ein- und ausschalten mit weisser Farbe, aber mehr nicht.
Könnt ihr mir auf die Sprünge helfen bzgl. dem Milight RGBW Device was ich da noch vergessen habe bz. falsch mache?
Gelesen habe ich schon im Wiki unter milight device aber so richtig schlau werde ich nicht daraus.
Vielen Dank
Beta-User
Vorab mal: Willkommen hier im FHEM-Forum.
...also...:
- Wenn du den sidoh-Hub hast, solltest du die Milight.*-Module direkt wieder vergessen, der MQTT(2)-Weg ist sehr viel einfacher.
- Spricht denn die Bridge bereits mit dem MQTT2_SERVER? (Es müßte mind. ein MQTT2_DEVICE geben)
Wenn ja: Bitte das erst (!) hier zeigen (raw-list) und das "milight-bridge"-attrTemplate (wie auch immer das genau heißen mag) darauf per "set"-Befehl anwenden. Danach die Bulb mit dem Web-Interface des Hub schalten (Farbe ändern, ein/aus, irgendwas).
Danach sollte es ein 2. Device geben. Dafür dann das passende "milight-bulb"-attrTemplate auswählen und anwenden.
Danach sollte das Prinzip klarer sein.
Heisemer Bub
ja danke Dir
...also...:
ja ich habe den Sido Hub (WebIf siehe Bild-> das müsset der doch sein)
ja ich denke siehe Bild. ich habe in der Bridge die IP:Port MQTT angegeben mit benutzer und pass
hoffe die raw-list passt
defmod MQTT2_192.168.200.167_49156 MQTT2_SERVER
attr MQTT2_192.168.200.167_49156 room hidden
setstate MQTT2_192.168.200.167_49156 Connected
setstate MQTT2_192.168.200.167_49156 2022-07-14 10:38:00 state Connected
defmod MilightBridge MilightBridge 192.168.200.167
attr MilightBridge checkInterval 10
attr MilightBridge event-on-change-reading state
attr MilightBridge port 8899
attr MilightBridge protocol udp
attr MilightBridge sendInterval 100
setstate MilightBridge ok
setstate MilightBridge 2022-07-14 14:31:37 sendFail 0
setstate MilightBridge 2022-07-14 12:29:41 slot0 wz.DeckenLampe
setstate MilightBridge 2022-07-14 12:29:41 slot1
setstate MilightBridge 2022-07-14 12:29:41 slot2
setstate MilightBridge 2022-07-14 12:29:41 slot3
setstate MilightBridge 2022-07-14 12:29:41 slot4
setstate MilightBridge 2022-07-14 12:29:41 slot5
setstate MilightBridge 2022-07-14 12:29:41 slot6
setstate MilightBridge 2022-07-14 12:29:41 slot7
setstate MilightBridge 2022-07-14 12:29:41 slot8
setstate MilightBridge 2022-07-14 14:31:37 state ok
Sorry das habe ich nicht verstanden...das heisst ich muss in das device "MilightBridge udn da dann wo der set button ist das Template  Attribut auswählen? wenn du das meinst ...ich finde da kein Attr namens template.
Beta-User
#3
Mache mal
list TYPE=MQTT2_DEVICE
Diese Art Device kennt dann auch "set ... attrTemplate"  ;)
Und nochmal: vergiss direkt wieder, dass es TYPE=MilightBridge überhaupt gibt. Das verwirrt nur, ich würde es direkt löschen (und auch eventuelle MilightDevice-Instanzen)...
Nachtrag: Hier steht etwas mehr dazu: https://wiki.fhem.de/wiki/MQTT2-Module_-_Praxisbeispiele#Milight-Bridge
Heisemer Bub
#4
Zitat von: Beta-User am 14 Juli 2022, 14:44:01
Mache mal
Hallo Beta-User,
das sind meine Shellys.....da ist noch keine lampe angelegt :-(
Spotlight_Eingang
Spotlight_Esszimmer
Spotlight_Terrasse
Frage noch...das Captcha kann man nicht abstellen?
ja das habe ich auch schon gefunden und gelesen...so richtig schlau bin ich noch nicht daraus geworden ;-)
das sind die Einstellung des Hubs schau:
Beta-User
Das captcha dürfte jetzt dann Vergangenheit sein, kommt nur für die ersten paar Posts.
Da du ein paar Shelly als MQTT2_DEVICE hast, kennst du das Prinzip ja schon.
Wenn jetzt für den Hub (!) kein Gerät angelegt worden ist, stimmen die Zugangsinfos zum MQTT2_SERVER nicht, die du dort auf dem Hub hinterlegt hast. Bitte gegenchecken, dann müßte nach einem Neustart (des Hub) dann auch ein weiteres MQTT2_DEVICE angelegt werden (vorausgesetzt, du hast am zentralen MQTT2_SERVER nicht autocreate deaktiviert (oder das globale device).
Heisemer Bub
#6
Also global ist "autocreate" aktiviert.
Im eigentlichen MQQT Server ist nichts zu finden mit "autocreate"
   CONNECTS   14
   Clients    :MQTT2_DEVICE:MQTT_GENERIC_BRIDGE:
   ClientsKeepOrder 1
   DEF        1883 192.168.200.39
   FD         9
   FUUID      605edad1-f33f-b652-ee21-b7284dd166e9a200
   NAME       MQTT2
   NR         31
   PORT       1883
   STATE      Initialized
   TYPE       MQTT2_SERVER
   eventCount 28
   MatchList:
     1:MQTT2_DEVICE ^.
     2:MQTT_GENERIC_BRIDGE ^.
     2022-07-14 12:28:42   RETAIN          {"":"{\u0022status\u0022:\u0022disconnected_clean\u0022,\u0022firmware\u0022:\u0022milight-hub\u0022,\u0022version\u0022:\u00221.10.8\u0022,\u0022ip_address\u0022:\u0022192.168.200.167\u0022,\u0022reset_reason\u0022:\u0022External System\u0022}","MQTT state topic pattern":"{\u0022state\u0022:\u0022OFF\u0022,\u0022brightness\u0022:0,\u0022bulb_mode\u0022:\u0022white\u0022,\u0022color\u0022:{\u0022r\u0022:255,\u0022g\u0022:255,\u0022b\u0022:255}}"}
     2022-07-14 10:38:00   nrclients       1
     2022-07-10 09:24:47   state           Initialized
   clients:
     MQTT2_192.168.200.167_49156 1
   retain:
       ts         1657787880.36835
       val        {"status":"disconnected_clean","firmware":"milight-hub","version":"1.10.8","ip_address":"192.168.200.167","reset_reason":"External System"}
     MQTT state topic pattern:
       ts         1657794522.9407
       val        {"state":"OFF","brightness":0,"bulb_mode":"white","color":{"r":255,"g":255,"b":255}}
   alias      MQTT2
Wobei....der miligt hub ist doch verbunden mit dem MQTT2 server in Fhem:
Beta-User
#7
Dann mach mal an deinem "normalen" MQTT2_SERVER "show MQTT traffic" an und boote das Ding neu. Wenn dort (am M2S) "nichts" zu autocreate eingestellt ist (und FHEM aktuell ist!), ist "simple" aktiv. Ansonsten: Da wurde mal was übermittelt, was nach irgendeinem autodiscovery-Mist aussieht. Das kann man auf dem Hub abschalten (wenn man es nur für FHEM braucht, sonst ist es (später) ein Fall für ignoreRegexp).
Aber erst mal sollte das Device angelegt werden, sonst ist irgendwas faul.
Nachtrag: Die temporären Instanzen sind ja ganz nett, aber eigentlich interessiert mich der zentrale Server im Zweifel deutlich mehr.
Nachtrag 2: Ggf. musst du am Hub noch irgendwas mit "LWT" oder "last will" konfigurieren bzw. einfach eine Leuchte schalten. Kurz: Dafür sorgen, dass was (verwertbares) gesendet (und dann empfangen) wird.
Heisemer Bub
O.K. danke dir mal....also wenn ich im meinem zentralen MQTT2 Server show klicke dann kommt nix....da muss ich noch mal schauen udn probieren....
wichtig wäre mir ob die mqtt einstellungen im hub o.k. sind?
Also wird auch nix übertragen...
Kannst du bitte mal das Bild noch anschauen vom Hub mit den MQTT Einstellungen...stimmt das soweit?
Beta-User
"Im Prinzip" vermutlich. Im Detail kenne ich deine Adressen nicht, aber ich sehe Unterschiede zu dem, was in https://wiki.fhem.de/wiki/MQTT2-Module_-_Praxisbeispiele#Einstellungen_am_MiLight-Hub zu finden ist.
Allgemeiner Hinweis: Ich gehe prinzipiell davon aus, dass das Wiki insbesondere dann genau durchgearbeitet wird, wenn ich auf ziemlich konkrete Stellen verlinke. Da alles nochmal gegenzuchecken verdirbt mir direkt die Lust am Helfen!
Falls da Fehler drin sind (oder sich was geändert hat), korrigiere ich es gerne, bin dann aber auf konkrete Hinweise angewiesen. Vorliegend gehe ich aber davon aus, dass noch alles paßt (ich habe das Ding nämlich auch seit Jahren stressfrei im Einsatz).
Heisemer Bub
#10
Hallo, ich bins nochmal....
Habe jetzt im milight hub unter settings -> mqtt -> MQTT Client Status Topic folgendes eingetragen :
milight/LWT
danach habe ich das Licht mit dem entsprechendem RGB Bulb an und aus gemacht und siehe da es hat sich nun was erstellt:
dann bin ich wie Beta-User gescherrieben in die Anwendungsbeispiele gegangen udn habe dort dann gelesen das man unter attr template das esp:milight rgb bulb ausgewählt.....soweit so gut....nach dem auswählen kommen aber noch Parametereingaben????
Was muss da eingetragen werden? Ist in den Beispielen nicht beschrieben...
Frage noch...was bedeutet das erzeugte MQTT2_milight_0xABCD_1..........-2........-3........-4??
Ich dachte immer für eine bulb wird auch ein Device erzeugt und angelegt??
irgend nen kleinen fehler mach ich noch oder?
Beta-User
Hättest du beide Abweichungen korrigiert oder nur den LWT-Topic ergänzt?
Heisemer Bub
#12
Guten Morgen,
ich habe das mit dem LWT in den Hub eingetragen wie Du gesagt hattest.
Dürfte denn beim erstellen des Templates dieses PopUp nicht kommen wenn alles stimmen würde?
Hier das jetzige list vom Hub
   CID        milight_hub_1600842
   DEF        milight_hub_1600842
   FUUID      62d02283-f33f-b652-4840-20796a91f87a1165
   IODev      MQTT2
   LASTInputDev MQTT2
   MQTT2_CONN MQTT2_192.168.200.167_49161
   MQTT2_MSGCNT 1
   MQTT2_TIME 2022-07-15 07:36:32
   MSGCNT     1
   NAME       MQTT2_milight_hub_1600842
   NR         131
   STATE      <a href="http://192.168.200.167" target="_blank">
connected
</a>Version:
1.10.8
   TYPE       MQTT2_DEVICE
   eventCount 1
     2022-07-15 07:36:31   IODev           MQTT2
     2022-07-14 20:36:20   attrTemplateVersion 20200701
     2022-07-15 07:36:32   firmware        milight-hub
     2022-07-15 07:36:32   ip_address      192.168.200.167
     2022-07-15 07:36:32   reset_reason    External System
     2022-07-15 07:36:32   status          connected
     2022-07-15 07:36:32   version         1.10.8
   autocreate 1
   bridgeRegexp milight/[^/]*at[^/]+/(0x[0-9a-fA-F]{1,4})/.*/([0-8])?.*:.* "milight_$1_$2"
   devStateIcon connected:10px-kreis-gruen disconnected.*:10px-kreis-rot
   icon       mqtt
   model      esp_milight_hub_bridge
   readingList milight/LWT:.* { json2nameValue($EVENT) }
   room       MQTT2_DEVICE
   setStateList on off
   stateFormat <a href="http://ip_address" target="_blank">
status
</a>Version:
version
und vom Device:
   CID        milight_0xABCD_1
   DEF        milight_0xABCD_1
   FUUID      62d05c5d-f33f-b652-0ae9-1205912cc1e3b3e7
   IODev      MQTT2
   NAME       MQTT2_milight_0xABCD_1
   NR         137
   STATE      set_on
   TYPE       MQTT2_DEVICE
   eventCount 9
     2022-07-14 20:11:41   associatedWith  MQTT2_milight_hub_1600842
     2022-07-14 20:45:42   attrTemplateVersion 20200522 or prior
     2022-07-15 07:37:36   brightness      set 90
     2022-07-14 20:46:47   command         set set_white
     2022-07-15 07:37:37   hue             set 108
     2022-07-15 07:37:34   state           set_on
   alexaName  Test
   comment    To switch device also on when changing brightness, change payload pattern to {"status":"ON","$EVTPART0":"$EVTPART1"} or add a new element to setList, similar to brightness, e.g.brightness_on and change payload pattern as described.
   devStateIcon {zigbee2mqtt_devStateIcon255($name,"hex",1)}
   eventMap   /set_white:Weiss/night_mode:Nacht/white_mode:white/
   genericDeviceType light
   homebridgeMapping Brightness=brightness::brightness,maxValue=100,factor=0.39216,delay=true
   icon       light_control
   model      esp_milight_hub_rgbw_bulb
   readingList 0xABCD_1/states/0xABCD/rgbw/1:.* { json2nameValue($EVENT) }
  0xABCD_1/states/0xABCD/rgbw/0:.* { json2nameValue($EVENT) }
  0xABCD_1/updates/0xABCD/rgbw/1:.* { json2nameValue($EVENT) }
  0xABCD_1/updates/0xABCD/rgbw/0:.* { json2nameValue($EVENT) }
   room       MQTT2_DEVICE
   setExtensionsEvent 1
   setList    on:noArg 0xABCD_1/0xABCD/rgbw/1 {"status":"ON"}
  on_transition:slider,3,10,3600 0xABCD_1/0xABCD/rgbw/1 {"status":"ON","transition":$EVTPART1}
  off:noArg 0xABCD_1/0xABCD/rgbw/1 {"status":"OFF"}
  off_transition:slider,3,10,3600 0xABCD_1/0xABCD/rgbw/1 {"status":"OFF","transition":$EVTPART1}
  brightness:colorpicker,BRI,0,15,255 0xABCD_1/0xABCD/rgbw/1 {"$EVTPART0":"$EVTPART1"}
  hue:colorpicker,HUE,0,1,359 0xABCD_1/0xABCD/rgbw/1 {"$EVTPART0":"$EVTPART1"}
  command:uzsuSelectRadio,Weiss,Nacht 0xABCD_1/0xABCD/rgbw/1 {"$EVTPART0":"$EVTPART1"}
   setStateList on off
   userReadings hex:color_r.* {Color::rgb2hex(ReadingsVal($name,"color_r",255),ReadingsVal($name,"color_g",255),ReadingsVal($name,"color_b",255))}, hue:bulb_mode.*white {"0"}
   webCmd     brightness:hue:command
Frage: Warum erzeugt fhem hier mehrere devices mit xxxxx_1 xxxxx_2 xxxxx_3 ?
Und das device MQTT2_milight_hub_1600842 ist ja wie in den Beispielen beschrieben der Hub das stimmt ja oder?
Was mir noch auffällt ist, wenn ich zb. bei device MQTT2_milight_0xABCD_1 das Lampensymbol drücke -> passiert nix :-( das dürfte doch auch nicht sein...hier müsste ich doch schalten können zu ON/OFF
Beta-User
OK, den 2. Fehler scheinst du ja jetzt auch gefunden zu haben, und das Popup kommt nicht mehr?
Wenn bei der Anwendung von attrTemplate "komische" Fragen kommen (z.B. nach Topic-Strukturen), ist das in der Regel ein Hinweis darauf, dass was nicht stimmt
Ich spekuliere: Du hast eine (mehrkanalige) Fernbedienung und da diverse Knöpfe gedrückt? Oder am Hub die Kanäle gewechselt?
Vielleicht zur Erklärung: Ein "Originales Gateway"  oder eine Fernbedienung "kann" in der Regel bis zu 4 "Gruppen" (einzelnes Leuchtmittel oder mehrere zusammen) schalten. Daneben können "alle zusammen" über den Kanal "0" geschaltet werden. Eine Fernbedienung mit 4 Kanälen wird daher 5 Topics befüllen (0-5 hinten), das ergibt 4 Leuchten, von denen jede auch das "0-er-Topic" abbonniert.
Jedenfalls ist das Aufsplitten so korrekt, um das ausdrücklich zu beantworten, von daher scheint auch das Hub-attrTemplate zu passen.
Um die Frage zu beantworten, müßte man erst mal wissen, was "passiert nix" bedeutet (ich tippe: ein real existierendes Leuchtmittel schaltet nicht?). Dann lautet die Gegenfrage: Schaltet das Leuchtmittel denn, wenn du es über den Hub direkt versuchst? Wenn nein: nicht gepairt => manual des Leuchtmittels konsultieren.
Heisemer Bub
#14
Nee glaub nicht den Fehler gefunden zu haben...denn wenn ich _2 _3 drücke kommt erst auch wieder diese Abfragen.
nein, ich habe keine Fernbedienung. Wo ich den bulb in CN bestellt habe sollte eigentlich eine FB mitgeliefert werden -> ist aber nie angekommen....deshalb muss ich ja alles über den Hub machen.....aber wenn ich im Hub WebIf bin und die bulb mit Strom versorgt ist.......kann ich auch nicht schalten also an und aus und die Farben verstellen...irgendwo ist hier noch der Wurm drinne....
ich müsste ja wenn alles jetzt korrekt verbunden wäre auch im webif des hubs unter meiner IP (siehe Bild) wenn ich zb. den Slider ON/OFF bewege die bulb schalten können richtig? udn das tut es noch nicht :-(
