ich habe per MQTT(1) Hichi IR Wifi mit Tasmota SML angebunden unf würde gern die Verbrauchwerte meine Stromzählers im FHEM als Readings darstellen.
CFGFN
FUUID 62f01818-f33f-6825-237c-479820581d732e5a
IODev myMQTTBroker
NAME hichi_ir_wifi
NR 14910
STATE ???
TYPE MQTT_DEVICE
eventCount 70
2022-08-08 18:50:54 Heap 20
2022-08-08 18:40:50 INFO1 {"Info1":{"Module":"Sonoff Basic","Version":"11.1.0(tasmota)","FallbackTopic":"cmnd/DVES_DB9AEC_fb/","GroupTopic":"cmnd/tasmotas/"}}
2022-08-08 18:40:50 INFO2 {"Info2":{"WebServerMode":"Admin","Hostname":"hichi-ir-wifi-6892","IPAddress":"192.168.40.57"}}
2022-08-08 18:40:50 INFO3 {"Info3":{"RestartReason":"External System","BootCount":8}}
2022-08-07 21:53:13 IODev myMQTTBroker
2022-08-08 18:40:50 LWT Online
2022-08-08 18:50:54 LoadAvg 19
2022-08-08 18:50:54 MqttCount 1
2022-08-08 18:50:54 POWER OFF
2022-08-08 18:40:50 RESULT {"POWER":"OFF"}
2022-08-08 18:50:54 SENSOR {"Time":"2022-08-08T17:50:54","Strom":{"Verbrauch_T1":0.2340676,"Verbrauch_T2":38.7910753,"Verbrauch_Summe":39.0251429,"Einspeisung_Summe":0.1978549,"Watt_L1":271.33,"Watt_L2":14.24,"Watt_L3":1.43,"Watt_Summe":287.01,"Volt_L1":227.9,"Volt_L2":228.5,"Volt_L3":228.8}}
2022-08-08 18:50:54 STATE {"Time":"2022-08-08T17:50:54","Uptime":"0T00:10:09","UptimeSec":609,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"xxx","BSSId":"E0:28:6D:37:69:86","Channel":6,"Mode":"11n","RSSI":52,"Signal":-74,"LinkCount":1,"Downtime":"0T00:00:03"}}
2022-08-08 18:50:54 Sleep 50
2022-08-08 18:50:54 SleepMode Dynamic
2022-08-08 18:50:54 Time 2022-08-08T17:50:54
2022-08-08 18:50:54 Uptime 0T00:10:09
2022-08-08 18:50:54 UptimeSec 609
2022-08-08 18:50:54 Wifi_AP 1
2022-08-08 18:50:54 Wifi_BSSId E0:28:6D:37:69:86
2022-08-08 18:50:54 Wifi_Channel 6
2022-08-08 18:50:54 Wifi_Downtime 0T00:00:03
2022-08-08 18:50:54 Wifi_LinkCount 1
2022-08-08 18:50:54 Wifi_Mode 11n
2022-08-08 18:50:54 Wifi_RSSI 52
2022-08-08 18:50:54 Wifi_SSId xxxxxx
2022-08-08 18:50:54 Wifi_Signal -74
2022-08-08 18:50:54 transmission-state incoming publish received
message_ids:
sets:
subscribe:
+/hichi_ir_wifi/+
tele/hichi_ir_wifi/LWT
tele/hichi_ir_wifi/SENSOR
tele/hichi_ir_wifi/STATE
cmnd/hichi_ir_wifi/POWER
tele/hichi_ir_wifi/INFO1
tele/hichi_ir_wifi/INFO2
tele/hichi_ir_wifi/INFO3
stat/hichi_ir_wifi/RESULT
stat/hichi_ir_wifi/POWER
subscribeExpr:
^[^/]+\/hichi_ir_wifi\/([^/]+)$
^tele\/hichi_ir_wifi\/LWT$
^tele\/hichi_ir_wifi\/SENSOR$
^tele\/hichi_ir_wifi\/STATE$
^cmnd\/hichi_ir_wifi\/POWER$
^tele\/hichi_ir_wifi\/INFO1$
^tele\/hichi_ir_wifi\/INFO2$
^tele\/hichi_ir_wifi\/INFO3$
^stat\/hichi_ir_wifi\/RESULT$
^stat\/hichi_ir_wifi\/POWER$
subscribeQos:
+/hichi_ir_wifi/+
cmnd/hichi_ir_wifi/POWER 0
stat/hichi_ir_wifi/POWER 0
stat/hichi_ir_wifi/RESULT 0
tele/hichi_ir_wifi/INFO1 0
tele/hichi_ir_wifi/INFO2 0
tele/hichi_ir_wifi/INFO3 0
tele/hichi_ir_wifi/LWT 0
tele/hichi_ir_wifi/SENSOR 0
tele/hichi_ir_wifi/STATE 0
subscribeReadings:
cmnd/hichi_ir_wifi/POWER:
cmd
name POWER
stat/hichi_ir_wifi/POWER:
cmd
name POWER
stat/hichi_ir_wifi/RESULT:
cmd
name RESULT
tele/hichi_ir_wifi/INFO1:
cmd
name INFO1
tele/hichi_ir_wifi/INFO2:
cmd
name INFO2
tele/hichi_ir_wifi/INFO3:
cmd
name INFO3
tele/hichi_ir_wifi/LWT:
cmd
name LWT
tele/hichi_ir_wifi/SENSOR:
cmd
name SENSOR
tele/hichi_ir_wifi/STATE:
cmd
name STATE
IODev myMQTTBroker
autoSubscribeReadings +/hichi_ir_wifi/+
room Keller
subscribeReading_INFO1 tele/hichi_ir_wifi/INFO1
subscribeReading_INFO2 tele/hichi_ir_wifi/INFO2
subscribeReading_INFO3 tele/hichi_ir_wifi/INFO3
subscribeReading_LWT tele/hichi_ir_wifi/LWT
subscribeReading_POWER stat/hichi_ir_wifi/POWER
subscribeReading_RESULT stat/hichi_ir_wifi/RESULT
subscribeReading_SENSOR tele/hichi_ir_wifi/SENSOR
subscribeReading_STATE tele/hichi_ir_wifi/STATE
Aufgrung der würde ich ungerne auf MQTT2 migrieren.
Wie kann ich besser die Sensoren als einzelne Readings anbinden?
Danke für die Hilfestellung.
Gruss
