Popp Flow Stopp 2 ohne Bild
Begonnen von Rampler, 04 September 2022, 15:05:11
Rampler
ich habe den popp Flow Stop 2 erfolgreich in Betrieb genommen:
https://popp.eu/de/produkte/flow-stop-2/
Funktioniert soweit auch super, allerdings fehlt das Bild.
Hier mal das Listing von dem Gerät:
   DEF        e7c578f9 16
   FUUID      62e3be83-f33f-b6d9-c458-35d4c6954c206de9
   IODev      ZWAVE
   NAME       HZ.ws
   NR         644
   STATE      on
   TYPE       ZWave
   ZWaveSubDevice no
   cmdsPending 0
   eventCount 2
   homeId     e7c578f9
   isWakeUp
   lastMsgSent 1662285170.46176
   nodeIdHex  10
     2022-09-03 19:03:59   IODev           ZWAVE
     2022-09-04 14:54:22   alive           alive
     2022-08-01 21:51:17   assocGroup_1    Max 5 Nodes ZWAVE
     2022-08-01 21:51:17   assocGroups     1
     2022-08-29 12:54:00   model           Popp & Co 009501 Flow Stop
     2022-08-29 12:54:00   modelConfig     popp/009501.xml
     2022-08-29 12:54:00   modelId         0154-0005-0003
     2022-08-25 23:11:15   neighborList    HZ.co PR.button HZ.kompressor HZ.wm2
     2022-08-25 22:57:47   neighborUpdate  done
     2022-08-01 21:52:36   powerlvl        current 0 remain 0
     2022-08-31 18:21:29   reportedState   on
     2022-09-04 11:52:52   routeInfo       timeToCb:0.08 repeaters:2 rssi0:-57 dBm rssi1:N/A rssi2:N/A ackCh:1 lastCh:1 scheme:LastWorkingRoute rep:SK.licht HZ.kompressor at 40kbps routeTries:1 lastFailed:
     2022-09-04 11:52:50   state           on
     2022-08-31 18:21:29   swbStatus       255
     2022-09-04 11:52:52   timeToAck       1.990
     2022-09-04 11:52:52   transmit        OK
     2022-08-01 21:52:12   zwavePlusInfo   version:01 role:AlwaysOnSlave node:Z-Wave+Node installerIcon:1500 userIcon:1500
   alias      WasserStop
   classes    ZWAVEPLUS_INFO VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY POWERLEVEL ASSOCIATION ASSOCIATION_GRP_INFO SWITCH_BINARY SWITCH_ALL BASIC
   devStateIcon on:aurora@green:off off:aurora@yellow:on .*:checkbox_checked@red
   event-on-change-reading state,reportedState
   icon       aurora
   neighborListPos 253,55
   readingsWatcher 90000,,state
   room       Heizraum,Wassermelder
   vclasses   ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BASIC:1 DEVICE_RESET_LOCALLY:1 MANUFACTURER_SPECIFIC:2 POWERLEVEL:1 SWITCH_ALL:1 SWITCH_BINARY:1
   verbose    2
VG Klaus
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Trixie), ZWAVE, HM-Classic, Matter und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
Die Bilder kommen von https://products.z-wavealliance.org.
Ich habe da dieses Geraet nicht aufgelistet gefunden.
Rampler
Ok, was kann/muss ich tun dass das Device ind die https://products.z-wavealliance.org aufgenommen wird ?
DetlefR
Hallo Klaus,
zur Not gibt es einen Workaround.
  • Besorg dir ein Bild und kopiere es nach /opt/fhem/www/deviceimages/zwave.
  • In /opt/fhem/FHEM/lib gibt es zwei Dateien zwave_....links.csv.gz
  • Entpacke die zwave_pepperlinks.csv.gz. Da hat sich am längsten nichts getan.
  • Füge in der entpackten zwave_pepperlinks.csv eine Zeile hinzu.
    Das erste ist modelId  des betreffenden Device
    Das zweite ist eigentlich der link zum Download. Bleibt aber leer
    Das dritte ist der Dateiname des Bildes
  • Die csv wieder einpacken. FHEM restart. Fertig
Ich habe auf die Art Bilder bei Geräten hinzugefügt die kein Reading modelId geliefert haben.
Detlef
ZitatOk, was kann/muss ich tun dass das Device ind die https://products.z-wavealliance.org aufgenommen wird ?
Ich nehme an, dass sowas vom Hersteller initiiert wird, und  dachte, dass es Teil der Z-Wave Zertifizierung ist.
Rampler
Zitat von: DetlefR am 05 September 2022, 11:39:07
Hallo Klaus,
Sorry Detlef,
bei mir funktioniert das nicht, ich vermute das hängt damit zusammen, dass das Device in der openzwave_deviceconfig.xml.gz definiert ist.
2022.09.05 20:28:00 3: ZWave got config for popp/009501.xml from ./FHEM/lib/openzwave_deviceconfig.xml.gz
VG Klaus
DetlefR
Schade.
Vielleicht kommt ja irgendwann noch das offizielle Bild.
Rampler
Hallo Experts,
leider hat der Flow Stop noch immer kein Bild.
Gibt es da nichts was ich machen kann ?
VG Klaus
ZitatGibt es da nichts was ich machen kann ?
Selbst Foto machen, es in /opt/fhem/www/deviceimages/zwave ablegen.
Die Datei /opt/fhem/FHEM/lib/zwave_pepperlinks.csv.gz erweitern mit <modelId>,,<BildName-OhnePfad>
Test: ein Refresh im Browser sollte reichen, wenn nicht, FHEM Neustarten.
Wenn alles klappt, Foto und modelId hier anhaengen, und wir bauen das ein.
Rampler
Hat funktioniert..
Hinzugefügte Zeile in zwave_pepperlinks.csv.gz:
VG Klaus
Danke, habs eingecheckt, bzw. das Bild hochgeladen.
Rampler
Nach dem heutigem update ist die Zeile:
in die zwave_pepperlinks.csv.gz aufgenommen. DANKE
Sollte nicht das Bild (Flow-Stop.jpg) auch nach /opt/fhem/www/deviceimages/zwave/* verteilt worden sein ?
VG Klaus
ZitatSollte nicht das Bild (Flow-Stop.jpg) auch nach /opt/fhem/www/deviceimages/zwave/* verteilt worden sein ?
Das ist nur ein "Cache" Verzeichnis, d.h. wird nur bei Bedarf gefuellt.
Das ZWave Modul laedt das Bild von fhem.de wenn das Geraet vorhanden ist, und die Detailseite zum ersten mal aufgerufen wird.
