Restore Lightscenes possible?
Begonnen von frank.j@me.com, 29 September 2022, 22:10:52
frank.j@me.com
Dear all,
I had to reinstall FHEM, and I am n ow looking for a way to restore the light scenes I have created in the old install. I have a backup of them and all its folders, is this possible?
As far as I see from the code, the LightScene data is writte to a file, wich is written in the same directory as the statefile, with the name LightScenes.save. The default should be log/LightScenes.save in the /opt/fhem directory. If you are using configDB, then this file is written to the database, see the configDB help on how to extract it.
I might be wrong, as I never used LightScene.
No, you're absolutely right.
It might be necessary to stop fhem prior to replace the file from a backup.
frank.j@me.com
