nach CCU3 installation please define first
Begonnen von kvn298, 23 Oktober 2022, 20:11:39
kvn298
Hallo ich habe Parallel zu FHEM eine VCCU3 auf dem Raspi laufen es funktioniert auch alles wunderbar. Jedoch bekomme ich nach dem Neustart von FHEM folgende Meldung
ZitatMessages collected while initializing FHEM:configfile: HMCCURPCPROC [d_rpc178129HmIP_RF] Invalid port or interface HmIP-RF
setuuid: Please define d_rpc178129HmIP_RF first
HMCCURPCPROC [d_rpc178129BidCos_RF] Invalid port or interface BidCos-RF
setuuid: Please define d_rpc178129BidCos_RF first
Ein "list" von dem Device ergebit dieses:
CCUNum     1
   CFGFN
   DEF        http://192.168.178.129 BidCos-RF
   FD         51
   FUUID      63447814-f33f-690b-9376-efca9272555bbae8
   IODev      pi_vccu
   NAME       d_rpc178129BidCos_RF
   NR         459
   RPCPID     1710
   RPCState   running
   STATE      running/OK
   TYPE       HMCCURPCPROC
   ccuip      192.168.178.129
   ccustate   active
   ccutype    CCU2/3
   eventCount 9
   host       192.168.178.129
   prot       http
   rpcid      178034178129
   rpcinterface BidCos-RF
   rpcip      192.168.178.129
   rpcport    2001
   version    5.0 222751518
     2022-10-10 21:53:07   rpcstate        running
     2022-10-10 21:53:08   state           OK
   hmccu:
     defaultaddr 192.168.178.34
     devspec    BidCos-RF
     evtime     0
     localaddr  192.168.178.34
     rpcstarttime 1665431588.04383
     rpc:
       avgdelay   0.0137995753090975
       cbport     7411
       cburl      http://192.168.178.34:7411/fh2001
       clkey      CB2001178034178129
       clurl      http://192.168.178.129:2001
       evtime     1666548413.40195
       methods    abortDeleteDevice,activateLinkParamset,addDevice,addLink,addVirtualDeviceInstance,changeKey,clearConfigCache,deleteDevice,deleteVolatileMetadata,determineParameter,exit,getAllMetadata,getDeviceDescription,getInstallMode,getKeyMismatchDevice,getLinkInfo,getLinkPeers,getLinks,getMetadata,getParamset,getParamsetDescription,getParamsetId,getServiceMessages,getValue,getVersion,getVolatileMetadata,hasVolatileMetadata,init,listBidcosInterfaces,listDevices,listReplaceableDevices,listTeams,logLevel,ping,putParamset,refreshDeployedDeviceFirmwareList,removeLink,replaceDevice,reportValueUsage,restoreConfigToDevice,rssiInfo,setBidcosInterface,setInstallMode,setInterfaceClock,setLinkInfo,setMetadata,setRFLGWInfoLED,setTeam,setTempKey,setValue,setVolatileMetadata,system.listMethods,system.methodHelp,updateFirmware,system.multicall
       multicall  system.multicall
       pid        1710
       port       2001
       requests   3733
       state      running
       sumdelay   51.3620193004608
       rec:
         DD         0
         EV         3722
         EX         0
         IN         0
         ND         52
         RA         0
         RD         0
         SL         1
         ST         7
         TO         0
         UD         0
       snd:
         DD         0
         EV         3447
         EX         0
         IN         0
         ND         52
         RA         0
         RD         0
         SL         1
         TO         0
         UD         0
   alias      CCU 178129 RPC BidCos-RF
   eventMap   /rpcserver on:on/rpcserver off:off/
   stateFormat rpcstate/state
   verbose    2
Ich finde nicht warum diese Meldung kommt, kann mir da jemand auf die Sprünge helfen?
Sany
Zitatich habe Parallel zu FHEM eine VCCU3
ZitatJedoch bekomme ich nach dem Neustart von FHEM folgende Meldung
vielleicht hilft das aus dem WIKI HMCCU unter Definition I/O-Device:
ZitatFalls die CCU als Software Service auf dem gleichen Rechner läuft wie FHEM, sollte bei der Definition der Parameter ccudelay angegeben werden. Die CCU Services brauchen beim Starten länger als FHEM (bis zu 2 Minuten). Durch ccudelay wird das neu angelegte I/O Device verzögert um die angegebene Anzahl Sekunden initialisiert. Die Vorgabe sind 180 Sekunden. Je nach Installation kann auch ein höherer Wert notwendig sein:
define d_ccu HMCCU 192.168.1.10 ccudelay=180
Der Start von FHEM wird dadurch nicht verzögert. Lediglich HMCCU wird verzögert initialisiert. Die verzögerte Initialisierung kann mit dem Parameter delayedinit erzwungen werden, greift dann also auch, wenn die CCU beim Start von FHEM erreichbar ist
ich kann jetzt nicht sagen, welche Fehlermeldungen kommen, wenn fhem startet aber die CCU noch nicht so weit ist, aber das sieht wohl ganz danach aus.
Sany
fhem als LXC auf Proxmox auf einem minix Z100 , weitere LXC mit ZigBee2MQTT, volvo2mqtt, MariaDB und Grafana.
[NEU: Homeassistant mit matter per mqtt an fhem].
Sowie Homematic, FS20, mySensors, Tasmota (MQTT2), Shelly(MQTT2), kein Z-Wave mehr  ....
