on-for-timer schaltet nicht aus
Begonnen von TheOe, 12 November 2022, 16:51:33
TheOe
seit dem letzten Update schaltet on-for-timer nicht mehr aus, wenn der Timer etwa 90 oder größer ist.
Betroffen sind z.B. Hue und GHoma. FS20 mit "useSetExtensions 1" funktioniert.
define GHoma_d37ade GHoma d37ade
attr GHoma_d37ade userattr lightSceneParamsToSave lightSceneRestoreOnlyIfChanged:1,0
#   DEF        d37ade
#   FD         10
#   FUUID      xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxxxxxx
#   FWVERSION  2.1.14
#   IP         xxx.xxx.xxx.xxx
#   Id         d37ade
#   LASTSTATE  on
#   MAC        xx:xx:xx:xx:xx:xx
#   NAME       GHoma_d37ade
#   NR         178
#   PORT       11348
#   Pattern    3523
#   SNAME      GhomaBridge
#   STATE      on
#   TYPE       GHoma
#   eventCount 9
#   READINGS:
#     2022-11-12 16:47:35   cosphi          0.52
#     2022-11-12 16:47:34   current         0.09
#     2022-11-12 16:47:35   energy          8.111
#     2022-11-12 16:47:35   frequency       49.93
#     2022-11-12 16:47:34   maxpower        20.3
#     2022-11-12 16:47:34   power           10.52
#     2022-11-12 16:47:29   source          local
#     2022-11-12 16:47:29   state           on
#     2022-11-12 16:47:34   voltage         225.59
setstate GHoma_d37ade on
setstate GHoma_d37ade 2022-11-12 16:47:35 cosphi 0.52
setstate GHoma_d37ade 2022-11-12 16:47:34 current 0.09
setstate GHoma_d37ade 2022-11-12 16:47:35 energy 8.111
setstate GHoma_d37ade 2022-11-12 16:47:35 frequency 49.93
setstate GHoma_d37ade 2022-11-12 16:47:34 maxpower 20.3
setstate GHoma_d37ade 2022-11-12 16:47:34 power 10.52
setstate GHoma_d37ade 2022-11-12 16:47:29 source local
setstate GHoma_d37ade 2022-11-12 16:47:29 state on
setstate GHoma_d37ade 2022-11-12 16:47:34 voltage 225.59
define FS20_01 FS20 9707 13
attr FS20_01 userattr lightSceneParamsToSave lightSceneRestoreOnlyIfChanged:1,0
attr FS20_01 IODev CUBe1
attr FS20_01 follow-on-for-timer 1
attr FS20_01 group Licht
attr FS20_01 useSetExtensions 1
#   BTN        13
#   DEF        9707 13
#   IODev      CUBe1
#   NAME       FS20_01
#   NR         131
#   STATE      off
#   TYPE       FS20
#   XMIT       9707
#   CODE:
#     1          9707 13
#   READINGS:
#     2022-11-12 16:48:54   IODev           CUBe1
#     2022-11-12 16:23:13   state           off
setstate FS20_01 off
setstate FS20_01 2022-11-12 16:48:54 IODev CUBe1
setstate FS20_01 2022-11-12 16:23:13 state off
Kann mir jemand weiterhelfen?
2x Raspberry Pi 1B(+) | MAX | hue | Kodi
Bist du sicher, dass dein Server stressfrei durchläuft und nicht zwischendurch neu startet?
Die IODev-Zeit sieht komisch aus...
TheOe
Danke für den Hinweis.
Ich weiß nicht was es war, aber das heutige Update scheint das Problem aus der Welt geschaft zu haben.
