Shelly Plug
Begonnen von The-Holgi, 18 November 2022, 19:11:27
The-Holgi
Hallo, ich habe einen Shelly Plug Modell SHPLG2-1 als mqtt device eingebunden. Habe das template shelly plug aus der Liste ausgewählt. Soweit funktioniert alles,
würde nur gerne die aktuelle Leistung im webfrontend sehen. Hat da Jemand einen Tipp für mich?
define MQTT2_shellyplug_284AEE MQTT2_DEVICE shellyplug_284AEE
attr MQTT2_shellyplug_284AEE alias Trockner
attr MQTT2_shellyplug_284AEE devStateIcon {my $onl = ReadingsVal($name,'online','false') eq 'false' ? 'rot' : ReadingsVal($name,'new_fw','false') eq 'true' ? 'gelb' : 'gruen';; my $light = ReadingsVal($name,'state','off');; my $show = '<a href="';;$show .= $onl eq 'gelb' ? "/fhem?cmd.dummy=set $name x_update&XHR=1\">" : 'http://'.ReadingsVal($name,'ip','none').' "target="_blank">';; $show .= FW_makeImage("10px-kreis-$onl").'</a>';; "<div> $show <a href=\"/fhem?cmd.dummy=set $name toggle&XHR=1\">".FW_makeImage($light).'</a></div>' }
attr MQTT2_shellyplug_284AEE genericDeviceType switch
attr MQTT2_shellyplug_284AEE getList power:noArg shellies/shellyplug-284AEE/relay/power power
attr MQTT2_shellyplug_284AEE icon scene_clothes_dryer
attr MQTT2_shellyplug_284AEE model shellyplug
attr MQTT2_shellyplug_284AEE readingList shellies/shellyplug-284AEE/relay/0:.* {{ state => $EVENT, relay0 => $EVENT}}\
  shellies/shellyplug-284AEE/input/0:.* input0\
  shellies/shellyplug-284AEE/online:.* online\
  shellies/shellyplug-284AEE/announce:.* { json2nameValue($EVENT) }\
  shellies/announce:.* { $EVENT =~ m,..id...shellyplug-284AEE...mac.*, ? json2nameValue($EVENT) : return }\
shellyplug_284AEE:shellies/shellyplug-284AEE/info:.* { json2nameValue($EVENT) }\
shellyplug_284AEE:shellies/shellyplug-284AEE/relay/0/power:.* relay_0_power\
shellyplug_284AEE:shellies/shellyplug-284AEE/relay/0/energy:.* relay_0_energy
attr MQTT2_shellyplug_284AEE room Keller,MQTT2_DEVICE
attr MQTT2_shellyplug_284AEE setList off:noArg shellies/shellyplug-284AEE/relay/0/command off\
  on:noArg shellies/shellyplug-284AEE/relay/0/command on\
  x_update:noArg shellies/shellyplug-284AEE/command update_fw\
  x_mqttcom shellies/shellyplug-284AEE/command $EVTPART1
#   CFGFN
#   CID        shellyplug_284AEE
#   DEF        shellyplug_284AEE
#   FUUID      6377be74-f33f-6571-6f3e-46e299f6b7b2038a
#   IODev      myBroker2
#   LASTInputDev myBroker2
#   MSGCNT     386
#   NAME       MQTT2_shellyplug_284AEE
#   NR         280442
#   STATE      on
#   TYPE       MQTT2_DEVICE
#   eventCount 398
#   myBroker2_CONN myBroker2_192.168.178.161_1875
#   myBroker2_MSGCNT 386
#   myBroker2_TIME 2022-11-18 19:12:27
#   OLDREADINGS:
#   READINGS:
#     2022-11-18 18:18:44   IODev           myBroker2
#     2022-11-18 18:52:55   actions_stats_skipped 0
#     2022-11-18 18:19:10   attrTemplateVersion 20211030
#     2022-11-18 18:52:55   cfg_changed_cnt 0
#     2022-11-18 18:52:55   cloud_connected false
#     2022-11-18 18:52:55   cloud_enabled   false
#     2022-11-18 18:52:55   fs_free         165409
#     2022-11-18 18:52:55   fs_size         233681
#     2022-11-18 18:52:55   fw_ver          20221027-102248/v1.12.1-ga9117d3
#     2022-11-18 18:52:55   has_update      false
#     2022-11-18 18:52:55   id              shellyplug-284AEE
#     2022-11-18 18:52:55   ip              192.168.178.161
#     2022-11-18 18:52:55   mac             483FDA284AEE
#     2022-11-18 18:52:55   meters_1_counters_1 0.000
#     2022-11-18 18:52:55   meters_1_counters_2 0.000
#     2022-11-18 18:52:55   meters_1_counters_3 0.000
#     2022-11-18 18:52:55   meters_1_is_valid true
#     2022-11-18 18:52:55   meters_1_overpower 0.00
#     2022-11-18 18:52:55   meters_1_power  0.00
#     2022-11-18 18:52:55   meters_1_timestamp 0
#     2022-11-18 18:52:55   meters_1_total  0
#     2022-11-18 18:52:55   model           SHPLG2-1
#     2022-11-18 18:52:55   mqtt_connected  true
#     2022-11-18 18:52:55   new_fw          false
#     2022-11-18 18:52:55   online          true
#     2022-11-18 18:52:55   ram_free        40532
#     2022-11-18 18:52:55   ram_total       52088
#     2022-11-18 19:12:27   relay0          on
#     2022-11-18 19:12:27   relay_0_energy  0
#     2022-11-18 19:12:27   relay_0_power   0.00
#     2022-11-18 18:52:55   relays_1_has_timer false
#     2022-11-18 18:52:55   relays_1_ison   true
#     2022-11-18 18:52:55   relays_1_overpower false
#     2022-11-18 18:52:55   relays_1_source input
#     2022-11-18 18:52:55   relays_1_timer_duration 0
#     2022-11-18 18:52:55   relays_1_timer_remaining 0
#     2022-11-18 18:52:55   relays_1_timer_started 0
#     2022-11-18 18:52:55   serial          1
#     2022-11-18 19:12:27   state           on
#     2022-11-18 18:52:55   time
#     2022-11-18 18:52:55   unixtime        0
#     2022-11-18 18:52:55   update_has_update false
#     2022-11-18 18:52:55   update_new_version
#     2022-11-18 18:52:55   update_old_version 20221027-102248/v1.12.1-ga9117d3
#     2022-11-18 18:52:55   update_status   unknown
#     2022-11-18 18:52:55   uptime          2
#     2022-11-18 18:52:55   wifi_sta_connected true
#     2022-11-18 18:52:55   wifi_sta_ip     192.168.178.161
#     2022-11-18 18:52:55   wifi_sta_rssi   -82
#     2022-11-18 18:52:55   wifi_sta_ssid   TheGate
#   hmccu:
setstate MQTT2_shellyplug_284AEE on
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:18:44 IODev myBroker2
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 actions_stats_skipped 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:19:10 attrTemplateVersion 20211030
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 cfg_changed_cnt 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 cloud_connected false
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 cloud_enabled false
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 fs_free 165409
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 fs_size 233681
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 fw_ver 20221027-102248/v1.12.1-ga9117d3
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 has_update false
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 id shellyplug-284AEE
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 ip 192.168.178.161
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 mac 483FDA284AEE
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 meters_1_counters_1 0.000
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 meters_1_counters_2 0.000
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 meters_1_counters_3 0.000
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 meters_1_is_valid true
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 meters_1_overpower 0.00
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 meters_1_power 0.00
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 meters_1_timestamp 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 meters_1_total 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 model SHPLG2-1
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 mqtt_connected true
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 new_fw false
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 online true
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 ram_free 40532
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 ram_total 52088
setstate MQTT2_shellyplug_284AEE 2022-11-18 19:12:27 relay0 on
setstate MQTT2_shellyplug_284AEE 2022-11-18 19:12:27 relay_0_energy 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 19:12:27 relay_0_power 0.00
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 relays_1_has_timer false
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 relays_1_ison true
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 relays_1_overpower false
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 relays_1_source input
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 relays_1_timer_duration 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 relays_1_timer_remaining 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 relays_1_timer_started 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 serial 1
setstate MQTT2_shellyplug_284AEE 2022-11-18 19:12:27 state on
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 time
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 unixtime 0
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 update_has_update false
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 update_new_version
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 update_old_version 20221027-102248/v1.12.1-ga9117d3
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 update_status unknown
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 uptime 2
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 wifi_sta_connected true
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 wifi_sta_ip 192.168.178.161
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 wifi_sta_rssi -82
setstate MQTT2_shellyplug_284AEE 2022-11-18 18:52:55 wifi_sta_ssid TheGate
Gruß Holger
Raspberry Pi 5
Hallo Holger,
beim plug-s sieht das devStateIcon so aus:
attr MQTT2_shellyplug_s_040E41 devStateIcon {my $onl = ReadingsVal($name,"online","false") eq "false"?"10px-kreis-rot" : ReadingsVal($name,"new_fw","false") eq "true" ? "10px-kreis-gelb" : "10px-kreis-gruen";; my $light = ReadingsVal($name,"state","off");; my $cons = ReadingsVal($name,"relay_0_power","unknown");; my $total = ReadingsVal($name,"relay_0_kWh","unknown");; my $temp = ReadingsVal($name,"temperature","-100");; "<a href=\"http://".ReadingsVal($name,"ip","none")." \"target=\"_blank\">".FW_makeImage($onl)."</a> <a href=\"/fhem?cmd.dummy=set $name toggle&XHR=1\">".FW_makeImage($light)."</a><div>Verbrauch: $cons / Total: $total/ Temp: $temp °C</div>"}
Da ist der aktuelle Verbrauch mit drin. Kannst Du ja zusammenbasteln.
Helmi55
Servus
hab beim plug-s dieses userReadings angelegt:
relay_0_energy_kWh:relay_0_energy.* monotonic {ReadingsVal($NAME,"relay_0_energy",0)/60/1000.0}, Kosten:relay_0_energy_kWh.* { sprintf("%.2f",(ReadingsVal($NAME,"relay_0_energy_kWh",0) + 0.0)*.2);;}
Helmut
System1 fhem 6.1 auf RPi 4B mit 4GB, HMUSBConfig, DS9490R-1Wire, Busware USB 868, Pool-Solarsteuerung mit FHEM. System2 fhem 6.1 auf RPi 4B mit 4GB (Bullseye) mit Busware USB 868 und 433 und HMUARTLGW für Haussteuerung
https://www.flickr.com/photos/canonhelmi/
The-Holgi
Danke für eure Hilfe. Habe es jetzt so wie ich es mir vorgestellt habe:
attr MQTT2_shellyplug_284AEE alias Waschmaschine
attr MQTT2_shellyplug_284AEE comment To get appropriate loadState values: Change the default limit "100" in readingList to your needs.
attr MQTT2_shellyplug_284AEE devStateIcon {my $onl = ReadingsVal($name,'online','false') eq 'false'?'10px-kreis-rot' : ReadingsVal($name,'new_fw','false') eq 'true' ? '10px-kreis-gelb' : '10px-kreis-gruen';; my $light = ReadingsVal($name,'state','off');; my $cons = ReadingsVal($name,'relay_0_power','unknown');; my $total = ReadingsVal($name,'relay_0_kWh','unknown');; "<a href=\"http://".ReadingsVal($name,'ip','none')." \"target=\"_blank\">".FW_makeImage($onl)."</a> <a href=\"/fhem?cmd.dummy=set $name toggle&XHR=1\">".FW_makeImage($light)."</a><div>Verbrauch: $cons / Total: $total</div>"}
attr MQTT2_shellyplug_284AEE icon scene_washing_machine
attr MQTT2_shellyplug_284AEE model shelly1_w_energy_measuring
  shellies/shellyplug-284AEE/relay/0/power:.* { my $compare = $EVTPART0 < 100 ? 'off':'on';; ReadingsVal($NAME,'loadState','off') ne $compare ? { loadState => $compare } : return }\
  shellies/shellyplug-284AEE/temperature_f:.* {}\
  shellies/shellyplug-284AEE/input_event/0:.* { json2nameValue($EVENT) }\
  shellies/shellyplug-284AEE/relay/0/energy:.* { relay_0_energy => $EVENT, relay_0_kWh => sprintf("%.2f",$EVENT/60/1000)}\
  shellies/shellyplug-284AEE/longpush/0:.* longpush_0\
attr MQTT2_shellyplug_284AEE setList relay0:on,off,toggle shellies/shellyplug-284AEE/relay/0/command $EVTPART1\
  toggle:noArg shellies/shellyplug-284AEE/relay/0/command toggle\
attr MQTT2_shellyplug_284AEE setStateList on off toggle
attr MQTT2_shellyplug_284AEE userReadings relay_0_energy_total:relay_0_energy:.* monotonic {ReadingsNum($name,'relay_0_energy',0)}
attr MQTT2_shellyplug_284AEE webCmd :
#   CFGFN
#   FUUID      6378bf8d-f33f-6571-d356-247152af5fa63e8c
#   IODev      myBroker2
#   MSGCNT     66
#   NR         296953
#   STATE      on
#   TYPE       MQTT2_DEVICE
#   eventCount 72
#   myBroker2_CONN myBroker2_192.168.178.161_12778
#   myBroker2_MSGCNT 66
#   myBroker2_TIME 2022-11-19 12:44:41
#   OLDREADINGS:
#   READINGS:
#     2022-11-19 12:35:41   IODev           myBroker2
#     2022-11-19 12:36:32   actions_stats_skipped 0
#     2022-11-19 12:36:31   attrTemplateVersion 20220408
#     2022-11-19 12:36:32   cfg_changed_cnt 0
#     2022-11-19 12:36:32   cloud_connected false
#     2022-11-19 12:36:32   cloud_enabled   false
#     2022-11-19 12:36:32   fs_free         165409
#     2022-11-19 12:36:32   fs_size         233681
#     2022-11-19 12:36:32   fw_ver          20221027-102248/v1.12.1-ga9117d3
#     2022-11-19 12:36:32   has_update      false
#     2022-11-19 12:36:32   id              shellyplug-284AEE
#     2022-11-19 12:36:32   ip              192.168.178.161
#     2022-11-19 12:36:32   mac             483FDA284AEE
#     2022-11-19 12:36:32   meters_1_counters_1 0.000
#     2022-11-19 12:36:32   meters_1_counters_2 0.000
#     2022-11-19 12:36:32   meters_1_counters_3 0.000
#     2022-11-19 12:36:32   meters_1_is_valid true
#     2022-11-19 12:36:32   meters_1_overpower 0.00
#     2022-11-19 12:36:32   meters_1_power  0.00
#     2022-11-19 12:36:32   meters_1_timestamp 1668861392
#     2022-11-19 12:36:32   meters_1_total  0
#     2022-11-19 12:36:32   model           SHPLG2-1
#     2022-11-19 12:36:32   mqtt_connected  true
#     2022-11-19 12:36:32   new_fw          false
#     2022-11-19 12:36:32   online          true
#     2022-11-19 12:36:32   ram_free        39944
#     2022-11-19 12:36:32   ram_total       52088
#     2022-11-19 12:44:41   relay0          on
#     2022-11-19 12:44:41   relay_0_energy  0
#     2022-11-19 12:44:41   relay_0_energy_total 0
#     2022-11-19 12:44:41   relay_0_kWh     0.00
#     2022-11-19 12:44:41   relay_0_power   0.00
#     2022-11-19 12:36:32   relays_1_has_timer false
#     2022-11-19 12:36:32   relays_1_ison   true
#     2022-11-19 12:36:32   relays_1_overpower false
#     2022-11-19 12:36:32   relays_1_source mqtt
#     2022-11-19 12:36:32   relays_1_timer_duration 0
#     2022-11-19 12:36:32   relays_1_timer_remaining 0
#     2022-11-19 12:36:32   relays_1_timer_started 0
#     2022-11-19 12:36:32   serial          7
#     2022-11-19 12:44:41   state           on
#     2022-11-19 12:36:32   time            12:36
#     2022-11-19 12:36:32   unixtime        1668857792
#     2022-11-19 12:36:32   update_has_update false
#     2022-11-19 12:36:32   update_new_version 20221027-102248/v1.12.1-ga9117d3
#     2022-11-19 12:36:32   update_old_version 20221027-102248/v1.12.1-ga9117d3
#     2022-11-19 12:36:32   update_status   idle
#     2022-11-19 12:36:32   uptime          62407
#     2022-11-19 12:36:32   wifi_sta_connected true
#     2022-11-19 12:36:32   wifi_sta_ip     192.168.178.161
#     2022-11-19 12:36:32   wifi_sta_rssi   -81
#     2022-11-19 12:36:32   wifi_sta_ssid   XXXXX
#     2022-11-19 12:36:31   x_mqttcom       set announce
#   hmccu:
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:35:41 IODev myBroker2
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 actions_stats_skipped 0
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:31 attrTemplateVersion 20220408
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 cfg_changed_cnt 0
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 cloud_connected false
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 cloud_enabled false
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 fs_free 165409
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 fs_size 233681
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 fw_ver 20221027-102248/v1.12.1-ga9117d3
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 has_update false
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 id shellyplug-284AEE
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 ip 192.168.178.161
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 mac 483FDA284AEE
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 meters_1_counters_1 0.000
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 meters_1_counters_2 0.000
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 meters_1_counters_3 0.000
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 meters_1_is_valid true
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 meters_1_overpower 0.00
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 meters_1_power 0.00
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 meters_1_timestamp 1668861392
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 meters_1_total 0
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 model SHPLG2-1
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 mqtt_connected true
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 new_fw false
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 online true
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 ram_free 39944
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 ram_total 52088
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:44:41 relay0 on
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:44:41 relay_0_energy 0
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:44:41 relay_0_energy_total 0
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:44:41 relay_0_kWh 0.00
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:44:41 relay_0_power 0.00
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 relays_1_has_timer false
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 relays_1_ison true
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 relays_1_overpower false
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 relays_1_source mqtt
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 relays_1_timer_duration 0
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 relays_1_timer_remaining 0
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 relays_1_timer_started 0
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 serial 7
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:44:41 state on
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 time 12:36
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 unixtime 1668857792
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 update_has_update false
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 update_new_version 20221027-102248/v1.12.1-ga9117d3
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 update_old_version 20221027-102248/v1.12.1-ga9117d3
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 update_status idle
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 uptime 62407
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 wifi_sta_connected true
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 wifi_sta_ip 192.168.178.161
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 wifi_sta_rssi -81
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:32 wifi_sta_ssid TheGate
setstate MQTT2_shellyplug_284AEE 2022-11-19 12:36:31 x_mqttcom set announce
Raspberry Pi 5
