Moin zusammen,
ich bekomme seit neuestem für ein RT die folgende CUL-Meldung:
2022.11.20 12:44:36.910 5: CUL_HM set bad_dg_RT_Clima ?
2022.11.20 12:44:37.006 5: CUL_HM set bad_dg_RT_Clima ?
2022.11.20 12:44:37.061 5: CUL_HM set bad_dg_RT_Clima ?
2
Config Heating Control (CUL_HM = VCCU):
DEF 24035904
FUUID 637a19e7-f33f-d7a9-80cf-69d40f4ae71c6b15
NAME bad_dg_RT_Clima
NR 418
NTFY_ORDER 48-bad_dg_RT_Clima
STATE T: 18.8 desired: 17.5 valve: 0
STILLDONETIME 0
TYPE CUL_HM
chanNo 04
device bad_dg_RT
disableNotifyFn 1
2022-11-20 12:42:28 CommandAccepted yes
2021-02-01 21:06:22 R-boostPeriod 10 min
2021-02-01 21:06:22 R-boostPos 100 %
2021-02-01 21:06:22 R-btnNoBckLight off
2021-02-01 21:06:22 R-dayTemp 21 C
2021-02-01 21:06:22 R-daylightSaveTime on
2021-02-01 21:06:22 R-decalcTime 11:00
2021-02-01 21:06:22 R-decalcWeekday Sat
2021-02-01 21:06:22 R-modePrioManu all
2021-02-01 21:06:22 R-modePrioParty all
2021-02-01 21:06:22 R-nightTemp 17 C
2021-02-01 21:06:22 R-noMinMax4Manu off
2021-02-01 21:06:22 R-regAdaptive on
2021-02-01 21:06:22 R-reguExtI 15
2021-02-01 21:06:22 R-reguExtP 30
2021-02-01 21:06:22 R-reguExtPstart 30
2022-04-16 16:29:40 R-reguIntI 17
2022-04-16 16:29:40 R-reguIntP 32
2022-04-16 16:29:40 R-reguIntPstart 40
2021-02-01 21:06:22 R-showInfo time
2021-02-01 21:06:22 R-showWeekday off
2021-02-01 21:06:18 R-sign off
2021-02-01 21:06:22 R-tempMax 30.5 C
2021-02-01 21:06:22 R-tempMin 4.5 C
2021-02-01 21:06:22 R-tempOffset 0.0K
2021-02-01 21:06:22 R-valveErrPos 15 %
2022-09-17 08:40:07 R-valveMaxPos 85 %
2021-02-01 21:06:22 R-valveOffsetRt 0 %
2021-02-01 21:06:22 R-winOpnBoost off
2021-02-01 21:06:22 R-winOpnDetFall 1.4 K
2021-02-01 21:06:22 R-winOpnMode off
2021-02-01 21:06:22 R-winOpnPeriod 15 min
2021-02-01 21:06:22 R-winOpnTempI 12 C
2022-09-17 08:40:07 R_0_tempListSat 06:00 17.0 22:00 21.0 24:00 17.0
2022-09-17 08:40:07 R_1_tempListSun 06:00 17.0 22:00 21.0 24:00 17.0
2022-09-17 08:40:07 R_2_tempListMon 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-09-17 08:40:07 R_3_tempListTue 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-09-17 08:40:07 R_4_tempListWed 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-09-17 08:40:07 R_5_tempListThu 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-09-17 08:40:07 R_6_tempListFri 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-09-17 08:40:07 R_tempList_State verified
2022-11-20 14:59:11 ValvePosition 0
2022-11-20 14:59:11 boostTime -
2022-09-17 08:34:56 cfgState updating
2022-11-20 12:42:28 commState CMDs_done
2022-11-20 14:59:11 controlMode manual
2022-11-20 14:59:11 desired-temp 17.5
2022-11-20 14:59:11 measured-temp 18.8
2022-11-20 14:59:11 partyEnd -
2022-11-20 14:59:11 partyStart -
2022-11-20 14:59:11 partyTemp -
2022-11-20 12:42:28 recentStateType ack
2022-11-20 14:59:11 state T: 18.8 desired: 17.5 valve: 0
helper:
peerFriend peerRTteam2
peerIDsState complete
peerOpt p:thermostat
regLst 1,7
cmds:
TmplKey :no:noAssTs
TmplTs 1668952525.26159
cmdKey 1:0:0::bad_dg_RT:0095:04:
cmdLst:
burstXmit noArg
clear [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
controlManu (on|off|5.0..30.0;0.5)
controlMode (auto|manual|boost|day|night)
controlParty -temp- -startDate- -startTime- -endDate- -endTime-
desired-temp (on|off|5.0..30.0;0.5)
getConfig noArg
getRegRaw (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
inhibit [(on|{off})]
peerBulk -peer1,peer2,...- [({set}|unset)]
peerSmart -peerOpt-
regBulk -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
regSet [(prep|{exec})] -regName- -value- [-peerChn-]
sign [(on|{off})]
sysTime noArg
tempListFri [(prep|{exec})] -HH:MM- -temp- [...]
tempListMon [(prep|{exec})] -HH:MM- -temp- [...]
tempListSat [(prep|{exec})] -HH:MM- -temp- [...]
tempListSun [(prep|{exec})] -HH:MM- -temp- [...]
tempListThu [(prep|{exec})] -HH:MM- -temp- [...]
tempListTmpl [({verify}|restore)] [[-file-:]-templateName-]
tempListTue [(prep|{exec})] -HH:MM- -temp- [...]
tempListWed [(prep|{exec})] -HH:MM- -temp- [...]
tempTmplSet -tempTmpl-
tplDel -tplDel-
lst:
condition slider,0,1,255
peer
peerOpt az_RT_ClimaTeam,db_RT_ClimaTeam,ez_RT_ClimaTeam,kz_RT_ClimaTeam,sz1_dg_RT_ClimaTeam,sz2_dg_RT_ClimaTeam,wz_RT_ClimaTeam
tplDel
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
param -param-
reg -addr- -list- [-peerChn-]
regList noArg
regTable noArg
regVal -addr- -list- [-peerChn-]
saveConfig [-filename-]
tplInfo noArg
expert:
def 1
det 1
raw 0
tpl 0
peerIDsH:
00000000 broadcast
role:
chn 1
shRegR:
07 00
tmpl:
DbLogInclude ValvePosition,controlMode,desired-temp,measured-temp
alias DG-Bad
battery_change 2022-03-28 20:47:30
event-on-change-reading ValvePosition,controlMode,desired-temp,measured-temp
expert allReg
group Heizung Bedienung
model HM-CC-RT-DN
peerIDs 00000000
room Zentrale
sortby 01
verbose 5
2
Ich bekomme pro definierter HeatingControl jeweils eine Fehlermeldung, obwohl die Bedingungen nicht zutreffen, d.h. die HC ist per IF Bedingung inaktiv.
Wenn ich diese eigentlich inaktiven HCs auf DISABLE setze, reduzieren sich die Fehlermeldungen im gleichen Verhältnis.
Alle anderen RT's und deren HCs laufen in meiner Installation ohne Probleme.
Da ich nichts geändert habe, kann ich mir das Verhalten nicht erklären.
Hat jemand schon mal ähnliches beobachtet und vlt. schon eine Lösung?
Grüße und danke
Lars
