Readings Heishamon, hier SO Port Daten
Begonnen von Franz Tenbrock, 26 November 2022, 10:42:43
Franz Tenbrock
Hallo
nach einigen Problemen mit dem auslesen der Heishamon Daten kommt nun alle Daten rein, die von der Heatpump kann ich auch alle anzeigen und mit einem SVG Plot auch darstellen.
Die Daten vom SO Port kommen zwar auch rein, kann Sie aber nicht darstellen, da das Format wohl noch nicht stimmt
hier das list von mqtt2s:
   CONNECTS   6
   Clients    :MQTT2_DEVICE:MQTT_GENERIC_BRIDGE:
   ClientsKeepOrder 1
   DEF        1884 global
   FD         48
   FUUID      63795600-f33f-132e-6dd3-a36d0391adaab43b
   NAME       mqtt2s
   NR         866
   PORT       1884
   STATE      Initialized
   TYPE       MQTT2_SERVER
   eventCount 11
   MatchList:
     1:MQTT2_DEVICE ^.
     2:MQTT_GENERIC_BRIDGE ^.
     2022-11-26 08:31:25   RETAIN          {"panasonic_heat_pump/LWT":"Offline","panasonic_heat_pump/ip":"192.168.10.53","panasonic_heat_pump/main/Buffer_Installed":"0","panasonic_heat_pump/main/Buffer_Temp":"-78","panasonic_heat_pump/main/Bypass_Outlet_Temp":"-31","panasonic_heat_pump/main/Compressor_Current":"2.8","panasonic_heat_pump/main/Compressor_Freq":"21","panasonic_heat_pump/main/Cool_Delta":"5","panasonic_heat_pump/main/Cool_Energy_Consumption":"0","panasonic_heat_pump/main/Cool_Energy_Production":"0","panasonic_heat_pump/main/Cool_To_Heat_Temp":"10","panasonic_heat_pump/main/Cooling_Mode":"0","panasonic_heat_pump/main/DHW_Energy_Consumption":"0","panasonic_heat_pump/main/DHW_Energy_Production":"0","panasonic_heat_pump/main/DHW_Heat_Delta":"-8","panasonic_heat_pump/main/DHW_Heater_Operations_Hours":"0","panasonic_heat_pump/main/DHW_Heater_State":"0","panasonic_heat_pump/main/DHW_Holiday_Shift_Temp":"-15","panasonic_heat_pump/main/DHW_Installed":"0","panasonic_heat_pump/main/DHW_Target_Temp":"52","panasonic_heat_pump/main/DHW_Temp":"-128","panasonic_heat_pump/main/Defrost_Temp":"-31","panasonic_heat_pump/main/Defrosting_State":"0","panasonic_heat_pump/main/Discharge_Temp":"60","panasonic_heat_pump/main/Error":"No error","panasonic_heat_pump/main/Eva_Outlet_Temp":"3","panasonic_heat_pump/main/External_Heater_State":"0","panasonic_heat_pump/main/Fan1_Motor_Speed":"450","panasonic_heat_pump/main/Fan2_Motor_Speed":"0","panasonic_heat_pump/main/Force_DHW_State":"0","panasonic_heat_pump/main/Force_Heater_State":"0","panasonic_heat_pump/main/Heat_Delta":"3","panasonic_heat_pump/main/Heat_Energy_Consumption":"600","panasonic_heat_pump/main/Heat_Energy_Production":"4400","panasonic_heat_pump/main/Heat_Pump_Model":"20","panasonic_heat_pump/main/Heat_To_Cool_Temp":"15","panasonic_heat_pump/main/Heater_Delay_Time":"30","panasonic_heat_pump/main/Heater_On_Outdoor_Temp":"0","panasonic_heat_pump/main/Heater_Start_Delta":"-4","panasonic_heat_pump/main/Heater_Stop_Delta":"-2","panasonic_heat_pump/main/Heating_Mode":"0","panasonic_heat_pump/main/Heating_Off_Outdoor_Temp":"35","panasonic_heat_pump/main/Heatpump_State":"1","panasonic_heat_pump/main/High_Pressure":"22.6","panasonic_heat_pump/main/Holiday_Mode_State":"0","panasonic_heat_pump/main/Inside_Pipe_Temp":"35","panasonic_heat_pump/main/Internal_Heater_State":"0","panasonic_heat_pump/main/Ipm_Temp":"23","panasonic_heat_pump/main/Low_Pressure":"0","panasonic_heat_pump/main/Main_Hex_Outlet_Temp":"37","panasonic_heat_pump/main/Main_Inlet_Temp":"35","panasonic_heat_pump/main/Main_Outlet_Temp":"37","panasonic_heat_pump/main/Main_Schedule_State":"1","panasonic_heat_pump/main/Main_Target_Temp":"36","panasonic_heat_pump/main/Max_Pump_Duty":"150","panasonic_heat_pump/main/Operating_Mode_State":"0","panasonic_heat_pump/main/Operations_Counter":"162","panasonic_heat_pump/main/Operations_Hours":"197","panasonic_heat_pump/main/Outside_Pipe_Temp":"2","panasonic_heat_pump/main/Outside_Temp":"5","panasonic_heat_pump/main/Pool_Temp":"-78","panasonic_heat_pump/main/Powerful_Mode_Time":"0","panasonic_heat_pump/main/Pump_Duty":"150","panasonic_heat_pump/main/Pump_Flow":"38.80","panasonic_heat_pump/main/Pump_Flowrate_Mode":"1","panasonic_heat_pump/main/Pump_Speed":"3850","panasonic_heat_pump/main/Quiet_Mode_Level":"0","panasonic_heat_pump/main/Quiet_Mode_Schedule":"0","panasonic_heat_pump/main/Room_Heater_Operations_Hours":"0","panasonic_heat_pump/main/Room_Heater_State":"0","panasonic_heat_pump/main/Room_Holiday_Shift_Temp":"-15","panasonic_heat_pump/main/Room_Thermostat_Temp":"23","panasonic_heat_pump/main/Solar_Frost_Protection":"5","panasonic_heat_pump/main/Solar_High_Limit":"80","panasonic_heat_pump/main/Solar_Mode":"0","panasonic_heat_pump/main/Solar_Off_Delta":"5","panasonic_heat_pump/main/Solar_On_Delta":"10","panasonic_heat_pump/main/Solar_Temp":"-78","panasonic_heat_pump/main/Sterilization_Max_Time":"10","panasonic_heat_pump/main/Sterilization_State":"0","panasonic_heat_pump/main/Sterilization_Temp":"65","panasonic_heat_pump/main/ThreeWay_Valve_State":"0","panasonic_heat_pump/main/Z1_Cool_Curve_Outside_High_Temp":"30","panasonic_heat_pump/main/Z1_Cool_Curve_Outside_Low_Temp":"20","panasonic_heat_pump/main/Z1_Cool_Curve_Target_High_Temp":"15","panasonic_heat_pump/main/Z1_Cool_Curve_Target_Low_Temp":"10","panasonic_heat_pump/main/Z1_Cool_Request_Temp":"28","panasonic_heat_pump/main/Z1_Heat_Curve_Outside_High_Temp":"15","panasonic_heat_pump/main/Z1_Heat_Curve_Outside_Low_Temp":"-1","panasonic_heat_pump/main/Z1_Heat_Curve_Target_High_Temp":"37","panasonic_heat_pump/main/Z1_Heat_Curve_Target_Low_Temp":"33","panasonic_heat_pump/main/Z1_Heat_Request_Temp":"24","panasonic_heat_pump/main/Z1_Temp":"23","panasonic_heat_pump/main/Z1_Water_Target_Temp":"36","panasonic_heat_pump/main/Z1_Water_Temp":"-78","panasonic_heat_pump/main/Z2_Cool_Curve_Outside_High_Temp":"30","panasonic_heat_pump/main/Z2_Cool_Curve_Outside_Low_Temp":"20","panasonic_heat_pump/main/Z2_Cool_Curve_Target_High_Temp":"15","panasonic_heat_pump/main/Z2_Cool_Curve_Target_Low_Temp":"10","panasonic_heat_pump/main/Z2_Cool_Request_Temp":"0","panasonic_heat_pump/main/Z2_Heat_Curve_Outside_High_Temp":"15","panasonic_heat_pump/main/Z2_Heat_Curve_Outside_Low_Temp":"-5","panasonic_heat_pump/main/Z2_Heat_Curve_Target_High_Temp":"55","panasonic_heat_pump/main/Z2_Heat_Curve_Target_Low_Temp":"35","panasonic_heat_pump/main/Z2_Heat_Request_Temp":"0","panasonic_heat_pump/main/Z2_Temp":"-128","panasonic_heat_pump/main/Z2_Water_Target_Temp":"45","panasonic_heat_pump/main/Z2_Water_Temp":"-78","panasonic_heat_pump/main/Zones_State":"0","panasonic_heat_pump/s0/Watt/1":"751","panasonic_heat_pump/s0/Watt/2":"0","panasonic_heat_pump/s0/Watthour/1":"1.00","panasonic_heat_pump/s0/Watthour/2":"0.00","panasonic_heat_pump/s0/WatthourTotal/1":"7867.00","panasonic_heat_pump/s0/WatthourTotal/2":"0.00","panasonic_heat_pump/stats":"{\u0022uptime\u0022:43643138,\u0022voltage\u0022:3.42,\u0022free memory\u0022:71,\u0022free heap\u0022:28384,\u0022wifi\u0022:94,\u0022mqtt reconnects\u0022:108,\u0022total reads\u0022:2179,\u0022good reads\u0022:2178,\u0022bad crc reads\u0022:0,\u0022bad header reads\u0022:120,\u0022too short reads\u0022:1,\u0022too long reads\u0022:0,\u0022timeout reads\u0022:0}"}
     2022-11-26 08:31:04   nrclients       1
     2022-11-26 08:05:29   state           Initialized
   clients:
     mqtt2s_192.168.10.53_56520 1
   retain:
     panasonic_heat_pump/LWT:
       ts         1669447860.34526
       val        Offline
     panasonic_heat_pump/ip:
       ts         1669447864.45152
       val        192.168.10.53
     panasonic_heat_pump/main/Buffer_Installed:
       ts         1669447859.76565
       val        0
     panasonic_heat_pump/main/Buffer_Temp:
       ts         1669447852.47542
       val        -78
     panasonic_heat_pump/main/Bypass_Outlet_Temp:
       ts         1669447854.0501
       val        -31
     panasonic_heat_pump/main/Compressor_Current:
       ts         1669447857.04866
       val        2.8
     panasonic_heat_pump/main/Compressor_Freq:
       ts         1669447884.96001
       val        21
     panasonic_heat_pump/main/Cool_Delta:
       ts         1669447847.84463
       val        5
     panasonic_heat_pump/main/Cool_Energy_Consumption:
       ts         1669447850.95589
       val        0
     panasonic_heat_pump/main/Cool_Energy_Production:
       ts         1669447850.90872
       val        0
     panasonic_heat_pump/main/Cool_To_Heat_Temp:
       ts         1669447858.85769
       val        10
     panasonic_heat_pump/main/Cooling_Mode:
       ts         1669447858.90543
       val        0
     panasonic_heat_pump/main/DHW_Energy_Consumption:
       ts         1669447851.04995
       val        0
     panasonic_heat_pump/main/DHW_Energy_Production:
       ts         1669447851.00281
       val        0
     panasonic_heat_pump/main/DHW_Heat_Delta:
       ts         1669447846.55813
       val        -8
     panasonic_heat_pump/main/DHW_Heater_Operations_Hours:
       ts         1669447859.38304
       val        0
     panasonic_heat_pump/main/DHW_Heater_State:
       ts         1669447855.42628
       val        0
     panasonic_heat_pump/main/DHW_Holiday_Shift_Temp:
       ts         1669447847.89139
       val        -15
     panasonic_heat_pump/main/DHW_Installed:
       ts         1669447859.81349
       val        0
     panasonic_heat_pump/main/DHW_Target_Temp:
       ts         1669447845.93437
       val        52
     panasonic_heat_pump/main/DHW_Temp:
       ts         1669447845.98369
       val        -128
     panasonic_heat_pump/main/Defrost_Temp:
       ts         1669447853.95571
       val        -31
     panasonic_heat_pump/main/Defrosting_State:
       ts         1669447847.93856
       val        0
     panasonic_heat_pump/main/Discharge_Temp:
       ts         1669447852.66423
       val        60
     panasonic_heat_pump/main/Error:
       ts         1669447852.38094
       val        No error
     panasonic_heat_pump/main/Eva_Outlet_Temp:
       ts         1669447854.00292
       val        3
     panasonic_heat_pump/main/External_Heater_State:
       ts         1669447855.57284
       val        0
     panasonic_heat_pump/main/Fan1_Motor_Speed:
       ts         1669447885.00762
       val        450
     panasonic_heat_pump/main/Fan2_Motor_Speed:
       ts         1669447855.66792
       val        0
     panasonic_heat_pump/main/Force_DHW_State:
       ts         1669447845.59669
       val        0
     panasonic_heat_pump/main/Force_Heater_State:
       ts         1669447857.09633
       val        0
     panasonic_heat_pump/main/Heat_Delta:
       ts         1669447846.60589
       val        3
     panasonic_heat_pump/main/Heat_Energy_Consumption:
       ts         1669447846.27055
       val        600
     panasonic_heat_pump/main/Heat_Energy_Production:
       ts         1669447846.2228
       val        4400
     panasonic_heat_pump/main/Heat_Pump_Model:
       ts         1669447859.4306
       val        20
     panasonic_heat_pump/main/Heat_To_Cool_Temp:
       ts         1669447858.81011
       val        15
     panasonic_heat_pump/main/Heater_Delay_Time:
       ts         1669447859.62165
       val        30
     panasonic_heat_pump/main/Heater_On_Outdoor_Temp:
       ts         1669447858.76224
       val        0
     panasonic_heat_pump/main/Heater_Start_Delta:
       ts         1669447859.66943
       val        -4
     panasonic_heat_pump/main/Heater_Stop_Delta:
       ts         1669447859.71831
       val        -2
     panasonic_heat_pump/main/Heating_Mode:
       ts         1669447858.66728
       val        0
     panasonic_heat_pump/main/Heating_Off_Outdoor_Temp:
       ts         1669447858.71412
       val        35
     panasonic_heat_pump/main/Heatpump_State:
       ts         1669447845.50076
       val        1
     panasonic_heat_pump/main/High_Pressure:
       ts         1669447855.71521
       val        22.6
     panasonic_heat_pump/main/Holiday_Mode_State:
       ts         1669447846.4148
       val        0
     panasonic_heat_pump/main/Inside_Pipe_Temp:
       ts         1669447853.90848
       val        35
     panasonic_heat_pump/main/Internal_Heater_State:
       ts         1669447855.52574
       val        0
     panasonic_heat_pump/main/Ipm_Temp:
       ts         1669447854.09792
       val        23
     panasonic_heat_pump/main/Low_Pressure:
       ts         1669447857.00146
       val        0
     panasonic_heat_pump/main/Main_Hex_Outlet_Temp:
       ts         1669447852.6166
       val        37
     panasonic_heat_pump/main/Main_Inlet_Temp:
       ts         1669447845.7425
       val        35
     panasonic_heat_pump/main/Main_Outlet_Temp:
       ts         1669447845.79058
       val        37
     panasonic_heat_pump/main/Main_Schedule_State:
       ts         1669447846.12754
       val        1
     panasonic_heat_pump/main/Main_Target_Temp:
       ts         1669447845.83851
       val        36
     panasonic_heat_pump/main/Max_Pump_Duty:
       ts         1669447859.57335
       val        150
     panasonic_heat_pump/main/Operating_Mode_State:
       ts         1669447845.69465
       val        0
     panasonic_heat_pump/main/Operations_Counter:
       ts         1669447846.07945
       val        162
     panasonic_heat_pump/main/Operations_Hours:
       ts         1669447846.03177
       val        197
     panasonic_heat_pump/main/Outside_Pipe_Temp:
       ts         1669447846.50997
       val        2
     panasonic_heat_pump/main/Outside_Temp:
       ts         1669447846.17548
       val        5
     panasonic_heat_pump/main/Pool_Temp:
       ts         1669447852.56935
       val        -78
     panasonic_heat_pump/main/Powerful_Mode_Time:
       ts         1669447846.31951
       val        0
     panasonic_heat_pump/main/Pump_Duty:
       ts         1669447859.47848
       val        150
     panasonic_heat_pump/main/Pump_Flow:
       ts         1669447884.91242
       val        38.80
     panasonic_heat_pump/main/Pump_Flowrate_Mode:
       ts         1669447860.10061
       val        1
     panasonic_heat_pump/main/Pump_Speed:
       ts         1669447856.95404
       val        3850
     panasonic_heat_pump/main/Quiet_Mode_Level:
       ts         1669447846.3672
       val        0
     panasonic_heat_pump/main/Quiet_Mode_Schedule:
       ts         1669447845.64639
       val        0
     panasonic_heat_pump/main/Room_Heater_Operations_Hours:
       ts         1669447859.33402
       val        0
     panasonic_heat_pump/main/Room_Heater_State:
       ts         1669447855.47859
       val        0
     panasonic_heat_pump/main/Room_Holiday_Shift_Temp:
       ts         1669447852.42771
       val        -15
     panasonic_heat_pump/main/Room_Thermostat_Temp:
       ts         1669447849.48102
       val        23
     panasonic_heat_pump/main/Solar_Frost_Protection:
       ts         1669447860.00402
       val        5
     panasonic_heat_pump/main/Solar_High_Limit:
       ts         1669447860.05283
       val        80
     panasonic_heat_pump/main/Solar_Mode:
       ts         1669447859.86129
       val        0
     panasonic_heat_pump/main/Solar_Off_Delta:
       ts         1669447859.95658
       val        5
     panasonic_heat_pump/main/Solar_On_Delta:
       ts         1669447859.90909
       val        10
     panasonic_heat_pump/main/Solar_Temp:
       ts         1669447852.52234
       val        -78
     panasonic_heat_pump/main/Sterilization_Max_Time:
       ts         1669447857.23872
       val        10
     panasonic_heat_pump/main/Sterilization_State:
       ts         1669447857.14382
       val        0
     panasonic_heat_pump/main/Sterilization_Temp:
       ts         1669447857.19168
       val        65
     panasonic_heat_pump/main/ThreeWay_Valve_State:
       ts         1669447846.46238
       val        0
     panasonic_heat_pump/main/Z1_Cool_Curve_Outside_High_Temp:
       ts         1669447858.57195
       val        30
     panasonic_heat_pump/main/Z1_Cool_Curve_Outside_Low_Temp:
       ts         1669447858.6195
       val        20
     panasonic_heat_pump/main/Z1_Cool_Curve_Target_High_Temp:
       ts         1669447858.47739
       val        15
     panasonic_heat_pump/main/Z1_Cool_Curve_Target_Low_Temp:
       ts         1669447858.52467
       val        10
     panasonic_heat_pump/main/Z1_Cool_Request_Temp:
       ts         1669447848.03227
       val        28
     panasonic_heat_pump/main/Z1_Heat_Curve_Outside_High_Temp:
       ts         1669447849.38652
       val        15
     panasonic_heat_pump/main/Z1_Heat_Curve_Outside_Low_Temp:
       ts         1669447849.43355
       val        -1
     panasonic_heat_pump/main/Z1_Heat_Curve_Target_High_Temp:
       ts         1669447848.07955
       val        37
     panasonic_heat_pump/main/Z1_Heat_Curve_Target_Low_Temp:
       ts         1669447848.12662
       val        33
     panasonic_heat_pump/main/Z1_Heat_Request_Temp:
       ts         1669447847.98555
       val        24
     panasonic_heat_pump/main/Z1_Temp:
       ts         1669447854.1449
       val        23
     panasonic_heat_pump/main/Z1_Water_Target_Temp:
       ts         1669447851.09697
       val        36
     panasonic_heat_pump/main/Z1_Water_Temp:
       ts         1669447849.62347
       val        -78
     panasonic_heat_pump/main/Z2_Cool_Curve_Outside_High_Temp:
       ts         1669447859.23896
       val        30
     panasonic_heat_pump/main/Z2_Cool_Curve_Outside_Low_Temp:
       ts         1669447859.2863
       val        20
     panasonic_heat_pump/main/Z2_Cool_Curve_Target_High_Temp:
       ts         1669447859.14379
       val        15
     panasonic_heat_pump/main/Z2_Cool_Curve_Target_Low_Temp:
       ts         1669447859.19148
       val        10
     panasonic_heat_pump/main/Z2_Cool_Request_Temp:
       ts         1669447849.57585
       val        0
     panasonic_heat_pump/main/Z2_Heat_Curve_Outside_High_Temp:
       ts         1669447859.04743
       val        15
     panasonic_heat_pump/main/Z2_Heat_Curve_Outside_Low_Temp:
       ts         1669447859.0964
       val        -5
     panasonic_heat_pump/main/Z2_Heat_Curve_Target_High_Temp:
       ts         1669447858.95237
       val        55
     panasonic_heat_pump/main/Z2_Heat_Curve_Target_Low_Temp:
       ts         1669447858.99997
       val        35
     panasonic_heat_pump/main/Z2_Heat_Request_Temp:
       ts         1669447849.52822
       val        0
     panasonic_heat_pump/main/Z2_Temp:
       ts         1669447854.1925
       val        -128
     panasonic_heat_pump/main/Z2_Water_Target_Temp:
       ts         1669447851.14379
       val        45
     panasonic_heat_pump/main/Z2_Water_Temp:
       ts         1669447850.8618
       val        -78
     panasonic_heat_pump/main/Zones_State:
       ts         1669447859.52589
       val        0
     panasonic_heat_pump/s0/Watt/1:
       ts         1669447884.43827
       val        751
     panasonic_heat_pump/s0/Watt/2:
       ts         1669447884.27407
       val        0
     panasonic_heat_pump/s0/Watthour/1:
       ts         1669447884.35579
       val        1.00
     panasonic_heat_pump/s0/Watthour/2:
       ts         1669447884.19198
       val        0.00
     panasonic_heat_pump/s0/WatthourTotal/1:
       ts         1669447884.39717
       val        7867.00
     panasonic_heat_pump/s0/WatthourTotal/2:
       ts         1669447884.23329
       val        0.00
     panasonic_heat_pump/stats:
       ts         1669447884.48072
       val        {"uptime":43643138,"voltage":3.42,"free memory":71,"free heap":28384,"wifi":94,"mqtt reconnects":108,"total reads":2179,"good reads":2178,"bad crc reads":0,"bad header reads":120,"too short reads":1,"too long reads":0,"timeout reads":0}
   autocreate simple
   room       MQTT
   userReadings panasonic_heat_pump/s0/Watt/Buffer_Installed
wenn ich nun den mqtt2s server aufrufe kann ich:
Show MQTT traffic
anklicken und dann kommt das hier (nur Auszug)
asonic_heat_pump/raw/data
q�V�RIUYUUUUe)�����qq��������{x~yy�������{���������������=x� ~||~UUU!xY"e�� 4e�� �e����22��222�������a�a�1"yy���
HeishaMon
panasonic_heat_pump/log
Sat Nov 26 09:40:08 2022 (51367559): New webserver client: 192.168.10.50:63765
HeishaMon
Sat Nov 26 09:40:08 2022 (51367581): Closing webserver client: 192.168.10.50:63765
HeishaMon
Sat Nov 26 09:40:14 2022 (51372920): Pulses seen on S0 port 1: Good: 16909 Bad: 165 Average good pulse width: 32
HeishaMon
Sat Nov 26 09:40:14 2022 (51372923): Measured Watthour on S0 port 1: 0.50
HeishaMon
0.50
HeishaMon
Sat Nov 26 09:40:14 2022 (51372927): Measured total Watthour on S0 port 1: 8510.00
HeishaMon
8510.00
HeishaMon
Sat Nov 26 09:40:14 2022 (51372934): Calculated Watt on S0 port 1: 8
HeishaMon
8
das hier ist das was mich vor allem interessiert:
8510.00
das ist der Gesamtverbrauch, den würde ich gerne langfristig tagesaktuell, wochenaktuell, monatsaktuell in Fhem anzeigen um zu sehen wie der Energieverbrauch der Anlage ist.
habe gerade Brett vor dem Kopf wie ich das definieren soll
habe schon zu readingsgroup etc einiges gelesen, aber die Syntax ist mir nicht klar
cubi3, Cul 868, ESA2000WZ, EM1000GZ,  FS20, dashboard, 1-Wire, Max Thermos, Max Wandthermo, Max Lan, Fritzbox callmonitor, , nanocul, HM Led16, HM Bewegungsmelder, HM Schalter, RPi, banana, ESP8266, DoorPi
Franz Tenbrock
wenn ich mir nun das Logfile   MQTT2_HeishaMon-2022.log anschaue finde ich dort einen Abschnitt mit den Werten die ich benötige, zB Measured total Watthour on S0 port 1: 419.50
2022-11-25_21:00:52 MQTT2_HeishaMon log: Fri Nov 25 20:00:51 2022 (2211191): Pulses seen on S0 port 1: Good: 728 Bad: 0 Average good pulse width: 32
2022-11-25_21:00:52 MQTT2_HeishaMon log: Fri Nov 25 20:00:51 2022 (2211237): Measured Watthour on S0 port 1: 2.00
2022-11-25_21:00:52 MQTT2_HeishaMon log: Fri Nov 25 20:00:51 2022 (2211239): Measured total Watthour on S0 port 1: 419.50
2022-11-25_21:00:52 MQTT2_HeishaMon log: Fri Nov 25 20:00:51 2022 (2211241): Calculated Watt on S0 port 1: 1442
2022-11-25_21:00:52 MQTT2_HeishaMon log: Fri Nov 25 20:00:52 2022 (2211640): Received 203 bytes data
2022-11-25_21:00:52 MQTT2_HeishaMon log: Fri Nov 25 20:00:52 2022 (2211642): Checksum and header received ok!
2022-11-25_21:00:52 MQTT2_HeishaMon log: Fri Nov 25 20:00:52 2022 (2211647): received TOP14 Outside_Temp: 10
lin_win
Hallo Franz,
habe gestern meinen HeishaMon bei Tindie bestellt, alles was ich jetzt von mir gebe ist (noch) graue Theorie.
Es ist sicher kein S0 Port. Das gab es zu ISDN Zeiten im Telefon.
Es ist nur eine S0 Schnittstelle, da wird im Stromzähler einfach ein Kontakt geschlossen  und die Anzahl wird gezählt.
Auf dem 4. Bild ist der Anschluß von bis zu 2 Stromzählern erläutert:
https://www.tindie.com/products/thehognl/heishamon-communication-pcb/
Franz Tenbrock
ok
ja habe schon einen Eltako Zähler drin und der liefert ja auch schon die Daten
im Log stehen sie ja schon
ich bekomme sie nur noch nicht in einer Readingsgroup angezeigt.
Gisbert
Hallo Franz,
Wenn ich dich richtig verstanden habe, geht es dir um die graphische Darstellung.
Wenn du uns verraten könntest, wie da Reading heißt - das musst du schließlich auch auswählen, wenn du eine Grafik erstellen möchtest, und zudem sollte es auch in der Definition des log-Devices stehen -, dann könnte ich dir auch sagen, welches $fld
  • du eintragen musst, um an deinen Wert für die Grafik zu kommen; so bleibt es ein Rätselraten.
    Viele Grüße Gisbert
Franz Tenbrock
Hallo Gisbert
Sorry
hier geht es weiter :
https://forum.fhem.de/index.php/topic,130399.msg1247927.html#new
ich bin nun weiter
nun gehts ans ausrechnen vom Tagesverbrauch ;-)
