Revision 26813: 22_HOMEMODE: v1.5.6 - change from double quotes to single quotes where ...
Begonnen von System, 07 Dezember 2022, 22:30:33
System
22_HOMEMODE: v1.5.6 - change from double quotes to single quotes where possible, substitute problematic characters for regex matching with dashes within cal events, add more logging for PRESENCE devices, add attributes HomeCMDtwilight-sr_naut and HomeCMDtwilight-ss_naut, fix unassigned variable, fix humidity reading from sensor gets overwritten by weather device, remove helper for external humidity sensor
Source: Revision 26813: 22_HOMEMODE: v1.5.6 - change from double quotes to single quotes where ...
