[gelöst] dbrep Datenbank-Backup
Begonnen von thburkhart, 18 Dezember 2022, 23:17:03
thburkhart
ich habe irgendwann mal folgendes zum Datenbank-Backup definiert
Code: [Auswählen]
define at_dblog_THBDump at *04:00:00 set Report_DumpsRows dumpMySQL clientSide
attr at_dblog_THBDump alias THBDUMP 4:00
attr at_dblog_THBDump room DBLog,xTimer
#   COMMAND    set Report_DumpsRows dumpMySQL clientSide
#   DEF        *04:00:00 set Report_DumpsRows dumpMySQL clientSide
#   FUUID      61daea6a-f33f-21fb-b2e6-a7e04cc6a8d5bed2
#   NAME       at_dblog_THBDump
#   NR         46
#   PERIODIC   yes
#   RELATIVE   no
#   REP        -1
#   STATE      Next: 04:00:00
#   TIMESPEC   04:00:00
#   TRIGGERTIME 1671418800
#   TRIGGERTIME_FMT 2022-12-19 04:00:00
#   TYPE       at
#   READINGS:
#     2022-12-18 20:32:48   state           Next: 04:00:00
setstate at_dblog_THBDump Next: 04:00:00
setstate at_dblog_THBDump 2022-12-18 20:32:48 state Next: 04:00:00
mein dbrep sieht so aus:
[code]define ReportDbLog_THB DbRep dblog_THB
attr ReportDbLog_THB alias DBRep
attr ReportDbLog_THB room DBLog
#   DATABASE   fhem
#   DEF        dblog_THB
#   FUUID      639501de-f33f-fd5f-0709-1a9ddf60b65cb43f
#   FVERSION   93_DbRep.pm:v8.50.7-s26865/2022-12-17
#   LASTCMD    initial database connect stopped due to attribute 'fastStart'
#   MODEL      Client
#   NAME       ReportDbLog_THB
#   NOTIFYDEV  global,ReportDbLog_THB
#   NR         55
#   NTFY_ORDER 50-ReportDbLog_THB
#   ROLE       Client
#   STATE      initialized
#   TYPE       DbRep
#   UTF8       0
#   HELPER:
#     DBLOGDEVICE dblog_THB
#     IDRETRIES  3
#     PACKAGE    main
#     VERSION    8.50.7
#   READINGS:
#     2022-12-18 23:22:33   state           initialized
setstate ReportDbLog_THB initialized
setstate ReportDbLog_THB 2022-12-18 23:22:33 state initialized
[/code]
und noch dblog:
[code]define dblog_THB DbLog ./configDB.conf .*:(temperature|power|humidity|va_temperature|va_humidity|humidity_value|desiredTemperature|valveposition|battery|oilfox_metering_liters).*
attr dblog_THB DbLogType Current/History
attr dblog_THB alias dblog_THB
attr dblog_THB asyncMode 1
attr dblog_THB bulkInsert 0
attr dblog_THB cacheLimit 5000
attr dblog_THB commitMode ac:on_ta:off
attr dblog_THB event-min-interval state:600
attr dblog_THB room DBLog
attr dblog_THB syncInterval 30
attr dblog_THB useCharfilter 1
attr dblog_THB verbose 2
#   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
#   CONFIGURATION ./configDB.conf
#   DEF        ./configDB.conf .*:(temperature|power|humidity|va_temperature|va_humidity|humidity_value|desiredTemperature|valveposition|battery|oilfox_metering_liters).*
#   FD         5
#   FUUID      6395a74c-f33f-fd5f-bf68-e3ca20a9e2cee3df
#   FVERSION   93_DbLog.pm:v5.5.3-s26750/2022-12-10
#   MODE       asynchronous
#   MODEL      MYSQL
#   NAME       dblog_THB
#   NR         2
#   NTFY_ORDER 50-dblog_THB
#   PID        750
#   REGEXP     .*:(temperature|power|humidity|va_temperature|va_humidity|humidity_value|desiredTemperature|valveposition|battery|oilfox_metering_liters).*
#   SBP_PID    833
#   SBP_STATE  running
#   STATE      connected
#   TYPE       DbLog
#   UTF8       0
#   dbconn     mysql:database=fhem;host=localhost;port=3306
#   dbuser     fhemuser
#   eventCount 32
#   HELPER:
#     COLSET     1
#     DEVICECOL  64
#     EVENTCOL   512
#     OLDSTATE   connected
#     PACKAGE    main
#     READINGCOL 64
#     TC         current
#     TH         history
#     TYPECOL    64
#     UNITCOL    32
#     VALUECOL   128
#     VERSION    5.5.3
#   OLDREADINGS:
#   READINGS:
#     2022-12-18 23:39:17   CacheOverflowLastNum 0
#     2022-12-11 12:26:51   CacheOverflowLastState normal
#     2022-12-18 23:39:17   CacheUsage      15
#     2022-12-18 23:39:17   NextSync        2022-12-18 23:39:47 or when CacheUsage 5000 is reached
#     2022-12-18 23:39:17   state           connected
setstate dblog_THB connected
setstate dblog_THB 2022-12-18 23:39:17 CacheOverflowLastNum 0
setstate dblog_THB 2022-12-11 12:26:51 CacheOverflowLastState normal
setstate dblog_THB 2022-12-18 23:39:17 CacheUsage 15
setstate dblog_THB 2022-12-18 23:39:17 NextSync 2022-12-18 23:39:47 or when CacheUsage 5000 is reached
setstate dblog_THB 2022-12-18 23:39:17 state connected
[/code]
ist das soweit korrekt ? auch das unspezifische "clientside"
Fehlermeldung bekomme ich nicht direkt; weiß aber auch nicht, wohin das backup geschrieben wird.
bitte um Hilfe
lg
Thomas
1 RASPI4B, 1 RASPI3B, 2 CUL, 2 Jeelink, 60 Tuya-Devices (Schalter, Dimmer, Sensoren, Cameras), 30 HUE-Lampen, 5 MAX! WTs, 16 MAX! HTs, 12 MAX! FKs, 1 Bresser 5in1, 1 OilFox, 8 ALEXA Echos und Dots, FHEM, 5 Tasmota-Devices, SonOff -Bridge, PowerFox, Buderus KM200
thburkhart
habe ich in der falschen Gruppe gefragt?
