MASSIVE Fehlermeldungen aus dem Fritzbox Modul
Begonnen von Christian72D, 30 Januar 2023, 08:55:01
Christian72D
Ich habe eben gesehen, daß mein Log fast explodiert (260 MB groß für diesen Monat) und bin dabei auf abertausende Meldungen vom FB Modul gestoßen.
Was ist das Problem?
2023.01.30 08:23:36 1: PERL WARNING: Use of uninitialized value $host in pattern match (m//) at .//FHEM/72_FRITZBOX.pm line 741.
2023.01.30 08:23:36 1: PERL WARNING: Use of uninitialized value $host in string ne at .//FHEM/72_FRITZBOX.pm line 758.
2023.01.30 08:23:36 1: PERL WARNING: Use of uninitialized value in string ne at .//FHEM/72_FRITZBOX.pm line 758.
2023.01.30 08:23:36 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at .//FHEM/72_FRITZBOX.pm line 779.
2023.01.30 08:23:37 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at .//FHEM/72_FRITZBOX.pm line 791.
2023.01.30 08:23:37 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at .//FHEM/72_FRITZBOX.pm line 807.
2023.01.30 08:23:37 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at .//FHEM/72_FRITZBOX.pm line 881.
2023.01.30 08:23:37 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at .//FHEM/72_FRITZBOX.pm line 896.
2023.01.30 08:23:37 1: ERROR: empty name in readingsBeginUpdate
2023.01.30 08:23:37 1: stacktrace:
2023.01.30 08:23:37 1:     main::readingsBeginUpdate           called by .//FHEM/72_FRITZBOX.pm (1794)
2023.01.30 08:23:37 1:     main::FRITZBOX_Readout_Process      called by .//FHEM/72_FRITZBOX.pm (1776)
2023.01.30 08:23:37 1:     main::FRITZBOX_Readout_Done         called by (eval 4694306) (1)
2023.01.30 08:23:37 1:     (eval)                              called by fhem.pl (1167)
2023.01.30 08:23:37 1:     main::AnalyzePerlCommand            called by fhem.pl (1196)
2023.01.30 08:23:37 1:     main::AnalyzeCommand                called by fhem.pl (1123)
2023.01.30 08:23:37 1:     main::AnalyzeCommandChain           called by .//FHEM/98_telnet.pm (263)
2023.01.30 08:23:37 1:     main::telnet_Read                   called by fhem.pl (3931)
2023.01.30 08:23:37 1:     main::CallFn                        called by fhem.pl (780)
2023.01.30 08:23:37 1: readingsUpdate(,lastReadout,9 values captured in 0.27 s) missed to call readingsBeginUpdate first.
2023.01.30 08:23:37 1:     main::readingsBulkUpdate            called by .//FHEM/72_FRITZBOX.pm (1916)
2023.01.30 08:23:37 1:     main::FRITZBOX_Readout_Done         called by (eval 4694308) (1)
yersinia
ZitatWas ist das Problem?
Du schreibst nicht, welche Version du nutzt. Du schreibst nicht, wie aktuell dein FHEM ist. Du bist nicht im richtigen Board - richtig wäre FRITZ!Box. Dort würdest du auch sehen, dass JoWiemann die Modulpflege übernommen hat und dieses gerade umbaut. Ggf verschiebst du dein Thema dorthin. Dann wird dir bestimmt auch geholfen - insb wenn du Version und ein list des FritzBox devices lieferst. ;)
viele Grüße, yersinia
FHEM 6.4 (SVN) on RPi 4B with RasPi OS Trixie (perl 5.40.1) | FTUI
JoWiemann
welche Version des Moduls hast Du installiert? Welche Fritz!Box und welche Fritz!OS Version?
Grüße Jörg
Jörg Wiemann
Christian72D
Laut Untertitel der von dir genannten Gruppe (hatte ich vor meinem Post schon gesehen) geht's dort um "FHEM auf Avm FRITZ!Box.".
Also das was früher machbar war.
Oder müsste das mal aktualisiert werden?
JoWiemann
Hallo Christian,
hm, das ist zunehmend in den Hintergrund gerückt und nur noch sehr selten ein Thema. Der Fokus ist aktuell eher Fhem und Fritz!Box / -Repeater
Grüße Jörg
Jörg Wiemann
Christian72D
Ok dann lösch ich hier und mach da einen neuen auf mit den Infos.
JoWiemann
Du kannst doch verschieben. Unten links hast Du den Button.
Jörg Wiemann
