Nach Update Fehlermeldung?
Begonnen von Jörg, 08 Juni 2013, 09:59:07
Jörg
Könnt ihr mir sagen, was das ist?
2013.06.08 09:43:15 2: CUL1: unknown message ? (? (K71705173F9 isF3CC3D1398A1B is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:43:52 2: CUL1: unknown message ? (? (? (K71705173F9 isFAK013402473E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:44:56 2: CUL1: unknown message ? (? (? (? (K7170517C MK71719173F8 is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:46:49 2: CUL1: unknown message ? (? (? (? (? (K717K013402473C is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:49:46 2: CUL1: unknown message ? (? (? (? (? (? (K7K013402473C is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:50:43 2: CUL1: unknown message ? (? (? (? (? (? (? (K71725173F8 is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:52:43 2: CUL1: unknown message ? (? (? (? (? (? (? (? K0134024740 is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:53:28 2: CUL1: unknown message ? (? (? (? (? (? (? F288201212120 is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:53:37 2: CUL1: unknown message ? (? (? (? (? (? (? A G M R T V W X 28820121211E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:53:37 2: CUL1: unknown message ? (K71736172FA is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:55:15 2: CUL1: unknown message ? (? (? (oW X e f m F28820120211C is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:55:20 2: CUL1: unknown message ? (? (? (? (oW X e f A G M R T V W X 28820120211B is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:55:22 2: CUL1: unknown message ? (? (? (? (? (oW one of B C F i F3cc32800 is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.06.08 09:55:40 2: CUL1: unknown message ? (? (? (? (? (? (oWF K013402473A is unknown) Use one of B C F i A G M R T V W X e f m l t u x
Puschel74
ZitatKönnt ihr mir sagen, was das ist?
Klar. Oder zumindest kann ich es versuchen.
Dein CUL empfängt sowas
ZitatK71705173F9 isF3CC3D1398A1B
(und div. andere Daten) und kann damit nichts anfangen.
Daher die Meldungen.
justme1968
ich hatte solche meldungen schon wenn die usbschnittstelle nicht richtig initialisiert/konfiguriert ist. z.b. geschwindigkeit,echo,...
gib mal mit @38400 die geschwindigkeit noch mit an.
  andre
splash
Konnest du die USB Schnittstelle neu installieren?
Geht es jetzt?
Jörg
Das hat nichts gebracht.
Davon abgesehen, hat es ja auch die ganze Zeit ohne das "@38400" funktioniert. Erst mit dem letzten Update fing der Mist an.
Mag sein, liegt aber daran, dass bei der USB-Schnittstelle echo aktiv ist.
Insb. Linux Distributionen aendern gerne solche defaultwerte, deswegen ist eine Verbindung ohne @38400 (oder irgendeine andere gueltige Baudrate) ein Gluecksspiel.
Jörg
Den Cul habe ich seit heute Morgen mit define CUL1 CUL /dev/busware_cul@38400 1234 in der fhem.cfg eingetragen.
Aber das hat nichts geändert. Die Fehlermeldungen sind noch genau so da, wie vorher.
Selbst eine Baudrate von 2400 funktioniert nicht. Wie kann ich denn sonst noch das Echo abschalten?
Oder soll ich wie Splash vorgeschlagen hat die USB-Schnittstelle neu installieren?
Wenn ja, wie geht das?
Klaus Rubik
Hallo Jörg,
konntest Du das Problem inzwischen lösen? Bei mir tritt der gleiche Fehler auf...
Klaus
FHEM 6.0 auf RPI4 mit CUL868, AEOTEC, RFXTRX 433
CUL_WS  : S300TH              FHT         : FHT80B, FHT80TF
HMS        : HMS100-TF         FBDECT   : DECT!200, FRITZ!Powerline 546E
FS20       : FS20DI10, FS20ST, FS20WS1, FS20DU-2, FS20 FMS
Jörg
Hi Klaus,
tut mir leid, aber das Problem besteht immer noch.
Ich kann nur sagen, dass ich noch einen CUL getestet habe, mit dem Ergebnis, dass der auch so reagiert. Also kann man davon ausgehen, dass es nicht am CUL liegt.
Mein CUL empfängt zwar, aber kann nicht senden.
justme1968
schau mit 'stty -F <device>' nach ob das lokale echo ein oder aus ist. es muss aus sein.
  andre
Jörg
Hi Andre,
das Ergebnis ist:
speed 9600 baud; line = 0;
-brkint -imaxbel
justme1968
es sollte etwas in der art sein:speed 9600 baud; line = 0;
min = 1; time = 0;
-cread
-brkint -icrnl -imaxbel
-opost -onlcr
-isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
vor allem die -echo sind wichtig.
versuch die mal mit stty zu setzen.
  andre
Jörg
stty -F /dev/ttyACM0 -echo
scheint nicht zu gehen.
Und mit stty -F /dev/ttyACM0
bekomme ich nur
-brkint -imaxbel
justme1968
was genau bedeutet scheint nicht zu gehen ?
versuch mal die andere syntax zum setzen:
stty -echo < /dev/ttyACM0
  andre
Jörg
Auch mit der anderen Syntax ändert sich nichts.
Wenn ich das eingebe, sollte dann eine Bestätigungsmeldung kommen, oder sieht man da nichts?
