Viele (Warn-)Meldungen im Logfile
Begonnen von VolkerL, 04 April 2023, 12:10:15
VolkerL
mir ist gerade aufgefallen, dass die Logfiles sehr groß sind und beim genaueren Betrachten sind mir ganz viele (Warn-)Meldungen darin aufgefallen, die sich auch immer wiederholen. Verbose steht in der fhem.cfg auf verbose 3.
2023.04.04 11:55:20 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 5013.
2023.04.04 11:55:20 1: stacktrace:
2023.04.04 11:55:20 1:     main::__ANON__                      called by fhem.pl (5013)
2023.04.04 11:55:20 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/73_GardenaSmartBridge.pm (1086)
2023.04.04 11:55:20 1:     FHEM::GardenaSmartBridge::WriteReadings called by ./FHEM/73_GardenaSmartBridge.pm (913)
2023.04.04 11:55:20 1:     FHEM::GardenaSmartBridge::ResponseProcessingFinalFromSubProcessing called by ./FHEM/73_GardenaSmartBridge.pm (930)
2023.04.04 11:55:20 1:     FHEM::GardenaSmartBridge::PollChild called by fhem.pl (3501)
2023.04.04 11:55:20 1:     main::HandleTimeout                 called by fhem.pl (705)
2023.04.04 11:55:21 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/73_GardenaSmartBridge.pm (1092)
2023.04.04 11:55:21 1:     FHEM::GardenaSmartBridge::WriteReadings called by ./FHEM/73_GardenaSmartBridge.pm (913)
2023.04.04 11:55:21 1:     FHEM::GardenaSmartBridge::ResponseProcessingFinalFromSubProcessing called by ./FHEM/73_GardenaSmartBridge.pm (930)
2023.04.04 11:55:21 1:     FHEM::GardenaSmartBridge::PollChild called by fhem.pl (3501)
2023.04.04 11:55:21 1:     main::HandleTimeout                 called by fhem.pl (705)
2023.04.04 11:55:21 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 5013.
2023.04.04 11:55:21 1: stacktrace:
2023.04.04 11:55:21 1:     main::__ANON__                      called by fhem.pl (5013)
2023.04.04 11:55:21 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/73_GardenaSmartBridge.pm (1099)
2023.04.04 11:55:21 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/73_GardenaSmartBridge.pm (1101)
2023.04.04 11:55:21 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/73_GardenaSmartBridge.pm (1106)
2023.04.04 11:55:21 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/73_GardenaSmartBridge.pm (1108)
2023.04.04 11:55:22 3: CUL_HM set HM_23DB3E statusRequest noArg
2023.04.04 11:55:24 3: CUL_HM set HM_409980 statusRequest noArg
2023.04.04 11:55:33 3: CUL_HM set Rauchm_Garage statusRequest noArg
2023.04.04 11:55:48 1: PERL WARNING: Argument "0;1" isn't numeric in numeric gt (>) at ./FHEM/98_SVG.pm line 1630.
2023.04.04 11:55:48 1: stacktrace:
2023.04.04 11:55:48 1:     main::__ANON__                      called by ./FHEM/98_SVG.pm (1630)
2023.04.04 11:55:48 1:     main::SVG_render                    called by ./FHEM/98_SVG.pm (1236)
2023.04.04 11:55:48 1:     main::SVG_doShowLog                 called by ./FHEM/98_SVG.pm (283)
2023.04.04 11:55:48 1:     main::SVG_FwFn                      called by ./FHEM/01_FHEMWEB.pm (2150)
2023.04.04 11:55:48 1:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1198)
2023.04.04 11:55:48 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2023.04.04 11:55:48 1:     main::FW_Read                       called by fhem.pl (3978)
2023.04.04 11:55:48 1:     main::CallFn                        called by fhem.pl (784)
2023.04.04 11:55:48 1: PERL WARNING: Argument "0;1" isn't numeric in subtraction (-) at ./FHEM/98_SVG.pm line 2009.
2023.04.04 11:55:48 1:     main::__ANON__                      called by ./FHEM/98_SVG.pm (2009)
2023.04.04 11:55:59 3: CUL_HM set Schalt_Pool_Filter statusRequest noArg
2023.04.04 11:56:01 3: CUL_HM set Bewaes_Pool statusRequest noArg
2023.04.04 11:56:02 3: CUL_HM set Bewaes_Tomaten statusRequest noArg
2023.04.04 11:56:04 3: CUL_HM set Bewaes_Straeucher statusRequest noArg
2023.04.04 11:56:13 3: CUL_HM set Schalt_Power_Sw statusRequest noArg
2023.04.04 11:56:14 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 5013.
2023.04.04 11:56:14 1: stacktrace:
2023.04.04 11:56:14 1:     main::__ANON__                      called by fhem.pl (5013)
2023.04.04 11:56:14 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1425)
2023.04.04 11:56:14 1:     main::Shelly_proc2G                 called by ./FHEM/36_Shelly.pm (1071)
2023.04.04 11:56:14 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (755)
2023.04.04 11:56:14 1:     main::__ANON__                      called by fhem.pl (781)
2023.04.04 11:56:14 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1426)
2023.04.04 11:57:08 3: set Trocken Ja : Please define Trocken first
2023.04.04 11:57:08 3: n_regen_janein return value: Please define Trocken first
2023.04.04 11:57:14 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 5013.
2023.04.04 11:57:14 1: stacktrace:
2023.04.04 11:57:14 1:     main::__ANON__                      called by fhem.pl (5013)
2023.04.04 11:57:14 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1425)
2023.04.04 11:57:14 1:     main::Shelly_proc2G                 called by ./FHEM/36_Shelly.pm (1071)
2023.04.04 11:57:14 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (755)
2023.04.04 11:57:14 1:     main::__ANON__                      called by fhem.pl (781)
2023.04.04 11:57:14 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1426)
2023.04.04 11:58:15 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 5013.
2023.04.04 11:58:15 1: stacktrace:
2023.04.04 11:58:15 1:     main::__ANON__                      called by fhem.pl (5013)
2023.04.04 11:58:15 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1425)
2023.04.04 11:58:15 1:     main::Shelly_proc2G                 called by ./FHEM/36_Shelly.pm (1071)
2023.04.04 11:58:15 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (755)
2023.04.04 11:58:15 1:     main::__ANON__                      called by fhem.pl (781)
2023.04.04 11:58:15 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1426)
2023.04.04 11:59:15 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 5013.
2023.04.04 11:59:15 1: stacktrace:
2023.04.04 11:59:15 1:     main::__ANON__                      called by fhem.pl (5013)
2023.04.04 11:59:15 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1425)
2023.04.04 11:59:15 1:     main::Shelly_proc2G                 called by ./FHEM/36_Shelly.pm (1071)
2023.04.04 11:59:15 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (755)
2023.04.04 11:59:15 1:     main::__ANON__                      called by fhem.pl (781)
2023.04.04 11:59:15 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1426)
2023.04.04 11:59:31 3: set Trocken Ja : Please define Trocken first
2023.04.04 11:59:31 3: n_regen_janein return value: Please define Trocken first
2023.04.04 12:00:15 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 5013.
2023.04.04 12:00:15 1: stacktrace:
2023.04.04 12:00:15 1:     main::__ANON__                      called by fhem.pl (5013)
2023.04.04 12:00:15 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1425)
2023.04.04 12:00:15 1:     main::Shelly_proc2G                 called by ./FHEM/36_Shelly.pm (1071)
2023.04.04 12:00:15 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (755)
2023.04.04 12:00:15 1:     main::__ANON__                      called by fhem.pl (781)
2023.04.04 12:00:15 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1426)
2023.04.04 12:00:59 3: COC: Unknown code A0628E901BCC7A2, help me!
2023.04.04 12:01:16 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 5013.
2023.04.04 12:01:16 1: stacktrace:
2023.04.04 12:01:16 1:     main::__ANON__                      called by fhem.pl (5013)
2023.04.04 12:01:16 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1425)
2023.04.04 12:01:16 1:     main::Shelly_proc2G                 called by ./FHEM/36_Shelly.pm (1071)
2023.04.04 12:01:16 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (755)
2023.04.04 12:01:16 1:     main::__ANON__                      called by fhem.pl (781)
2023.04.04 12:01:16 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (1426)
Woran liegt das, bzw. liegt der Fehler bei mir? Es funktioniert eigentlich alles.
Volker
Raspberry PI mit fhem 5.8, COC & HM-CFG-LAN für Homematic & CUL für FS20
Zitat von: VolkerL am 04 April 2023, 12:10:15Verbose steht in der fhem.cfg auf verbose 3.
Ja, aber die ausführlichen Meldungen werden durch das globale Attribut stacktrace produziert.
Hast Du zufällig einen Rasenmäher, der gerade im Winterschlaf ist und die GardenaSmartBridge versucht trotzdem regelmäßig, dessen Status abzufragen?
VolkerL
Hallo betateilchen,
Ja der Mäher steht noch in der Garage und wartet auf wärmere Temperaturen.
Ich habe die "GardenaBridge" mal deaktiviert, seit dem sind die Meldungen schon mal weg. Jetzt sind nur welche mit "36_Shelly.pm" drin.
Das könnte ein Shelly3pm vor der Wallbox sein. Da mache ich immer die Sicherung raus, wenn ich sie nicht brauche und dadurch ist der Shelly dann auch nicht mit Strom versorgt. Das probiere ich nach Feierabend mal, ob es auch daran liegt.
Danke und viele Grüße
Volker
Zitat von: VolkerL am 04 April 2023, 12:50:25Jetzt sind nur welche mit "36_Shelly.pm" drin.
Das ist laut stacktrace höchstwahrscheinlich das gleiche Problem mit der Nichterreichbarkeit.
Kannst Du das Shelly nicht auf MQTT umstellen?
