[Erledigt] FritzBox STATE Device is offline
Begonnen von DL8EI Ralph, 14 April 2023, 14:49:24
DL8EI Ralph
Aber wo muss ich suchen, vorher ging es doch noch ?
   APICHECKED 1
   FUUID      63b325f2-f33f-a76b-61c3-9abc030705f2ace3
   HOST
   INTERVAL   60
   LUADATA    1
   LUAQUERY   1
   M3U_LOCAL  ./www/images/FritzBox.m3u
   M3U_URL    unknown
   NAME       FritzBox
   NR         834
   TIMEOUT    55
   TR064      0
   TYPE       FRITZBOX
   UPNP       -1
   VERSION    07.50.14
   eventCount 35
   OLDREADINGS:
     2023-04-14 14:08:32   box_connect     Connected
     2023-04-14 14:08:32   box_cpuTemp     64
     2023-04-14 14:08:32   box_dect        on
     2023-04-14 14:08:32   box_dsl_downStream 996.070
     2023-04-14 14:08:32   box_dsl_upStream 996.070
     2023-04-14 14:08:32   box_fwVersion   154.07.50
     2023-04-14 14:08:32   box_guestWlan   off
     2023-04-14 14:08:32   box_guestWlanCount 0
     2023-04-14 14:08:32   box_guestWlanRemain 0
     2023-04-14 14:08:32   box_last_connect_err ERROR_NONE
     2023-04-14 14:08:32   box_macFilter_active off
     2023-04-14 14:08:32   box_meshRole    master
     2023-04-06 19:43:17   box_model       FRITZ!Box 7590 [avm]
     2023-04-14 14:08:32   box_moh         default
     2023-04-14 14:08:32   box_powerRate   25
     2023-04-14 14:08:32   box_rateDown    2.331
     2023-04-14 14:08:32   box_rateUp      1.283
     2023-04-14 14:08:32   box_stdDialPort allFons
     2023-04-14 14:08:32   box_tr064       on
     2023-04-14 14:08:32   box_tr069       off
     2023-04-14 14:08:32   box_uptime      875040 sec = 10T 03:04:00
     2023-04-14 14:08:32   box_uptimeConnect 471481 sec = 5T 10:58:01
     2023-04-14 14:08:32   box_vdsl_downStreamRate 0
     2023-04-14 14:08:32   box_vdsl_upStreamRate 0
     2023-04-14 14:08:32   box_wlan_2.4GHz on
     2023-04-14 14:08:32   box_wlan_5GHz   on
     2023-04-14 14:36:24   retStat_lastReadout Device is offline
     2023-04-14 14:08:32   sip_error       0
     2023-04-14 14:36:24   state           Device is offline
   fhem:
     LOCAL      0
     definedHost
     is_double_wlan -1
     lastHour   0
     modulVersion $Date: 2023-04-13 12:32:45 +0200 (Thu, 13 Apr 2023) $
     sidTime    0
   helper:
     TimerCmd   FritzBox.Cmd
     TimerReadout FritzBox.Readout
   INTERVAL   60
   boxUser    MeinUser
   disable    0
   enableSIP  1
   fritzBoxIP 192.168.188.1
   room       Internet
   userReadings sip_error:(lastReadout.*) {sip_connect_check($name)}
   verbose    2
   webCmd     update
Ich bitte um eine FehlerSuchIdee.
Fernmelde-Opa übernahm FHEM-Installation und kämpft sich so durch.
Installation hat FS20, Homematic und einge exotische Teile.
juemuc
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
DL8EI Ralph
2023.04.14 15:05:55 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5581.
2023.04.14 15:04:55 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5581.
2023.04.14 15:03:55 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5581.
2023.04.14 15:02:55 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5581.
2023.04.14 15:01:55 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5581.
2023.04.14 15:00:55 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5581.
2023.04.14 14:59:55 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5581.
2023.04.14 14:58:55 1: PERL WARNING: Use of uninitialized value $host in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5581.
Naja steht doch da: HOST fehlt. ;)
Hintergrund ist im anderen FRITZBOX Thread zu finden: Ich denke: in der DEF muss jetzt die IP Adresse/Name der FB angegeben werden.
Das attr fritzBoxIP 192.168.188.1 ist jetzt glaub ich obsolete.
RalfRog
Ja lösche das Attribut und schreib die IP in DEF rein.
Danach sieht man sie auch unter Host (Internal Host).
Hattest nicht in der Vorgänger Version eine INFO3 wo drinstand, dass das Attribut nicht mehr unterstützt wird?
Gruß Ralf
DL8EI Ralph
#5
Ich bedanke mich. Nun tut es wieder.
Ein DEF hatte ich bis eben nicht. Das richtige Ergebnis brachte dann:  "defmod FritzBox FRITZBOX 192.168.188.1"
Unklar ist mir, woher Ihr das wisst und wo das stand ?
Meine Suche nach Fritzbox $host brachte allerlei, aber nicht dies.
Oder ich habe es in der Fülle übersehen.
Zitat von: DL8EI Ralph am 14 April 2023, 16:46:58Unklar ist mir, woher Ihr das wisst und wo das stand ?
Wir haben das Ohr am Geschehen  ;D
Möglicherweise ist der Umbau / die Entwicklung des Moduls FRITZBOX bezüglich der History noch nicht optimal ... aber sehr rasant.
Es gibt einen (fast persönlichen) "Wettstreit" zwischen Ralf und Jörg um die Modulweiterentwicklung  ;D - wenn man da mal einen halben Tag gefehlt hat, ist nicht nur ein Zug vorbeigerauscht. ;)
RalfRog
Eigentlich versuche ich nur beim Testen zu unterstützen  ;)
Die Feature-Requests kommen (bis auf das Logfile) ja gar nicht von mir  ;D.
Hier ist die letzte Meldung zum IP Attribut.
https://forum.fhem.de/index.php?msg=1271168
RalfRog
Zitat von: DL8EI Ralph link=msg=1272473 date=
quote author=DL8EI Ralph link=msg=1272473 date=1681483618]
Ein DEF hatte ich bis eben nicht....
Siehe Screenshot. Das DEF steht oben links.
Und in meiner Version 7.50.10 auf dem Lifesystem ist auch die INFO3 zu sehen.
DL8EI Ralph
Ja, da hast Du leider recht Recht. Ich bin da wohl etwas überfordert.
elhennig
Zitat von: DL8EI Ralph am 14 April 2023, 16:46:58Ich bedanke mich. Nun tut es wieder.
So geht es mir auch. Aber Danke für den Thread, damit kann ich nun auch wieder meine FB steuern.
rico5588
ich möchte das Thema nochmal vorholen, da ich seit einigen Tagen auch dieses Problem habe.
Ich habe das Gerät neu angelegt, hat aber nichts gebracht.
Zu ereichen per Ping aus der Komandozeile ist die Box.
Login geht und User und Pass sind geprüft. Anbei ein Log auszug.
Bitte um Hilfe.
↓Log Auszug
023.05.30 11:31:30.019 5: [Fritzbox | 7590 | 259.07.50 | Readout_Add_Reading.4013] - DEBUG: ->SECPORT: 49443
2023.05.30 11:31:30.019 4: [Fritzbox | 7590 | 259.07.50 | API_Check_Run.1704] - DEBUG: TR-064-SecurePort is 49443.
2023.05.30 11:31:30.019 5: [Fritzbox | 7590 | 259.07.50 | API_Check_Run.1779] - DEBUG: Read 'jason_boxinfo'
2023.05.30 11:31:30.030 5: [Fritzbox | 7590 | 259.07.50 | API_Check_Run.1787] - DEBUG: jason_boxinfo returned:
<j:BoxInfo xmlns:j="http://jason.avm.de/updatecheck/">
<j:Name>FRITZ!Box 7590 AX</j:Name>
<j:HW>259</j:HW>
<j:Version>259.07.50</j:Version>
<j:Revision>104313</j:Revision>
<j:Serial>DC15C8DF8331</j:Serial>
<j:OEM>avm</j:OEM>
<j:Lang>de</j:Lang>
<j:Annex>B</j:Annex>
<j:Lab></j:Lab>
<j:Country>049</j:Country>
<j:Flag>crashreport</j:Flag>
<j:Flag>mesh_master</j:Flag>
<j:Flag>remote_login_service</j:Flag>
<j:UpdateConfig>3</j:UpdateConfig></j:BoxInfo>
2023.05.30 11:31:30.030 5: [Fritzbox | 7590 | 259.07.50 | Readout_Add_Reading.4013] - DEBUG: box_model: FRITZ!Box 7590 AX
2023.05.30 11:31:30.031 5: [Fritzbox | 7590 | 259.07.50 | Readout_Add_Reading.4013] - DEBUG: box_oem: avm
2023.05.30 11:31:30.031 5: [Fritzbox | 7590 | 259.07.50 | Readout_Add_Reading.4013] - DEBUG: box_fwVersion: 259.07.50
2023.05.30 11:31:30.031 5: [Fritzbox | 7590 | 259.07.50 | Readout_Add_Reading.4013] - DEBUG: ->APICHECKED: 1
2023.05.30 11:31:30.031 4: [Fritzbox | 7590 | 259.07.50 | API_Check_Run.1835] - INFO: Captured 10 values
2023.05.30 11:31:30.031 5: [Fritzbox | 7590 | 259.07.50 | API_Check_Run.1836] - DEBUG: Handover to main process (146): ->LUAQUERY|1|->LUADATA|1|->TR064|1|->SECPORT|49443|box_model|FRITZ!Box 7590 AX|box_oem|avm|box_fwVersion|259.07.50|->APICHECKED|1|readoutTime|5.51
2023.05.30 11:31:30.033 5: [Fritzbox | 7590 | 259.07.50 | Readout_Done.3678] - DEBUG: Back at main process
2023.05.30 11:31:30.034 5: [Fritzbox | 7590 | 259.07.50 | Readout_Process.3703] - DEBUG: box_ disable list: none
2023.05.30 11:31:30.034 5: [Fritzbox | 7590 | 259.07.50 | Readout_Process.3828] - DEBUG: SET box_fwVersion = '259.07.50'
2023.05.30 11:31:30.034 5: [Fritzbox | 7590 | 259.07.50 | Readout_Process.3828] - DEBUG: SET box_model = 'FRITZ!Box 7590 AX [avm]'
2023.05.30 11:31:30.034 5: [Fritzbox | 7590 | 259.07.50 | Readout_Process.3879] - DEBUG: BulkUpdate lastReadout: 9 values captured in 5.51 s
2023.05.30 11:31:34.511 4: [Fritzbox | 7590 | 259.07.50 | Readout_Start.1615] - INFO: Fork process FRITZBOX_Readout_Run_Web
2023.05.30 11:31:34.523 4: [Fritzbox | 7590 | 259.07.50 | Readout_Run_Web.1881] - INFO: Prepare query string for luaQuery.
2023.05.30 11:31:34.523 4: [Fritzbox | 7590 | 259.07.50 | Readout_Run_Web.1995] - ReadOut gestartet: &radio=configd:settings/WEBRADIO/list(Name)&box_dect=dect:settings/enabled&handsetCount=dect:settings/Handset/count&handset=dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)&wlanList=wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest)&wlanListNew=wlan:settings/wlanlist/list(mac,speed,rssi)&lanDevice=landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID)&lanDeviceNew=landevice:settings/landevice/list(mac,ip,ethernet,guest,name,active,online,wlan,speed,UID)&init=telcfg:settings/Foncontrol&box_stdDialPort=telcfg:settings/DialPort&dectUser=telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName,NoRingTime,RingAllowed,NoRingTimeFlags,NoRingWithNightSetting)&fonPort=telcfg:settings/MSN/Port/list(Name,MSN)&diversity=telcfg:settings/Diversity/list(MSN,Active,Destination)&box_moh=telcfg:settings/MOHType&box_uptimeHours=uimodlogic:status/uptime_hours&box_uptimeMinutes=uimodlogic:status/uptime_minutes&box_fwVersion=logic:status/nspver&box_fwVersion_neu=uimodlogic:status/nspver&box_powerRate=power:status/rate_sumact&tam=tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)&box_cpuTemp=power:status/act_temperature&box_tr064=tr064:settings/enabled&box_tr069=tr069:settings/enabled&box_upnp=box:settings/upnp_activated&box_upnpCtrl=box:settings/upnp_control_activated&box_fwUpdate=updatecheck:status/update_available_hint&is_double_wlan=wlan:settings/feature_flags/DBDC&box_wlan_24GHz=wlan:settings/ap_enabled&box_wlan_5GHz=wlan:settings/ap_enabled_scnd&box_guestWlan=wlan:settings/guest_ap_enabled&box_guestWlanRemain=wlan:settings/guest_time_remain&box_macFilter_active=wlan:settings/is_macfilter_active&TodayBytesReceivedHigh=inetstat:status/Today/BytesReceivedHigh&TodayBytesReceivedLow=inetstat:status/Today/BytesReceivedLow&TodayBytesSentHigh=inetstat:status/Today/BytesSentHigh&TodayBytesSentLow=inetstat:status/Today/BytesSentLow&GSM_RSSI=gsm:settings/RSSI&GSM_NetworkState=gsm:settings/NetworkState&GSM_AcT=gsm:settings/AcT&UMTS_enabled=umts:settings/enabled&userTicket=userticket:settings/ticket/list(id)&dslStatGlobalIn=dslstatglobal:status/in&dslStatGlobalOut=dslstatglobal:status/out
2023.05.30 11:31:34.523 5: [Fritzbox | 7590 | 259.07.50 | Web_OpenCon.5868] - DEBUG: checking HOST -> 192.168.9.7
2023.05.30 11:31:35.880 3: [Fritzbox | 7590 | 259.07.50 | Get.1342] - INFO: get Fritzbox fritzLog
2023.05.30 11:31:35.881 1: PERL WARNING: Use of uninitialized value $val[0] in string eq at ./FHEM/72_FRITZBOX.pm line 1357.
2023.05.30 11:31:35.881 1: PERL WARNING: Use of uninitialized value $val[0] in string eq at ./FHEM/72_FRITZBOX.pm line 1358.
2023.05.30 11:31:35.881 1: PERL WARNING: Use of uninitialized value $val[0] in string eq at ./FHEM/72_FRITZBOX.pm line 1362.
2023.05.30 11:31:35.881 1: PERL WARNING: Use of uninitialized value $logInfo in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 6345.
2023.05.30 11:31:35.881 1: PERL WARNING: Use of uninitialized value $webCmdArray[13] in join or string at ./FHEM/72_FRITZBOX.pm line 6345.
2023.05.30 11:31:35.881 3: [Fritzbox | 7590 | 259.07.50 | Fritz_Log_Info.6345] - INFO: set Fritzbox  xhr 1 lang de page log xhrId log useajax 1 no_sidrenew  filter
2023.05.30 11:31:35.881 5: [Fritzbox | 7590 | 259.07.50 | Web_OpenCon.5868] - DEBUG: checking HOST -> 192.168.9.7
2023.05.30 11:31:39.528 4: [Fritzbox | 7590 | 259.07.50 | Web_OpenCon.5898] - INFO: Host 192.168.9.7 not available
2023.05.30 11:31:39.528 4: [Fritzbox | 7590 | 259.07.50 | Readout_Run_Web.2000] - INFO: Device is offline
2023.05.30 11:31:40.889 4: [Fritzbox | 7590 | 259.07.50 | Web_OpenCon.5898] - INFO: Host 192.168.9.7 not available
2023.05.30 11:31:40.890 1: PERL WARNING: Use of uninitialized value $logInfo in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 6350.
2023.05.30 11:31:40.902 5: [Fritzbox | 7590 | 259.07.50 | Readout_Done.3678] - DEBUG: Back at main process
2023.05.30 11:31:40.902 5: [Fritzbox | 7590 | 259.07.50 | Readout_Process.3703] - DEBUG: box_ disable list: none
2023.05.30 11:31:40.902 4: [Fritzbox | 7590 | 259.07.50 | Readout_Process.3714] - DEBUG: Reset SID
↓Devise
defmod Fritzbox FRITZBOX 192.168.9.7
attr Fritzbox alias Fritzbox Master
attr Fritzbox boxUser ***
attr Fritzbox event-min-interval .*:600
attr Fritzbox event-on-change-reading .*
attr Fritzbox event-on-update-reading mac_.*
attr Fritzbox room HWRaum
setstate Fritzbox Device is offline
setstate Fritzbox 2023-05-30 11:31:30 box_fwVersion 259.07.50
setstate Fritzbox 2023-05-30 11:31:30 box_model FRITZ!Box 7590 AX [avm]
setstate Fritzbox 2023-05-30 12:46:39 retStat_lastReadout Device is offline
setstate Fritzbox 2023-05-30 12:46:39 state Device is offline
Geht nicht gibt's nicht.
NUC-I3+Proxmox, Fritzbox 7590 AX, Synology DS423+
Dimplex Wärmepumpe, Lüftungsanlage, Solarlog 1200
HM,IT,Lacross,EspEasy,Modbus,MQTT2, Freund von Shelly
JoWiemann
#12
Bitte um Hilfe.
ein vollständiges List des Fritzbox Device wäre schon mal hilfreich.
Anbei habe ich Dir eine Version angehängt, in der ich noch eine zusätzliche Informatione eingebaut habe.
Grüße Jörg
Jörg Wiemann
rico5588
anbei das List
   APICHECKED 1
   DEF        192.168.9.7
   FUUID      6475bdf3-f33f-bec9-384e-10e782156893b7b9
   HOST       192.168.9.7
   INTERVAL   300
   LUADATA    1
   LUAQUERY   1
   MODEL      FRITZ!Box 7590 AX
   NAME       Fritzbox
   NR         1138
   SECPORT    49443
   TIMEOUT    55
   TR064      1
   TYPE       FRITZBOX
   UPNP       -1
   VERSION    07.50.17g
   _BETA      0
   eventCount 26
     2023-05-30 14:36:39   retStat_lastReadout Device is offline
     2023-05-30 14:36:39   state           Device is offline
   fhem:
     LOCAL      0
     definedHost 192.168.9.7
     is_double_wlan -1
     lastHour   0
     modulVersion $Date: 2023-05-09 10:32:31 +0200 (Tue, 09 May 2023) $
     sidTime    0
   helper:
     TimerCmd   Fritzbox.Cmd
     TimerReadout Fritzbox.Readout
   boxUser    rmb
   room       HWRaum
Die neue Version kann ich erst später testen, wenn ich wieder daheim bin.
rico5588
Hier das List von der neuen Version.
Bis jetzt hat sich nichts geändert.
   APICHECKED 1
   DEF        192.168.9.7
   HOST       192.168.9.7
   INTERVAL   300
   LUADATA    1
   LUAQUERY   1
   NAME       Fritzbox
   NR         1138
   SECPORT    49443
   TIMEOUT    55
   TR064      1
   TYPE       FRITZBOX
   UPNP       -1
   VERSION    07.50.17h
   _BETA      0
   eventCount 2
     2023-05-30 20:40:04   box_fwVersion   259.07.50
     2023-05-30 20:40:04   box_model       FRITZ!Box 7590 AX [avm]
     2023-05-30 20:40:15   retStat_lastReadout Device is offline
     2023-05-30 20:40:15   state           Device is offline
   fhem:
     LOCAL      0
     is_double_wlan -1
     lastHour   0
     modulVersion $Date: 2023-04-28 20:26:52 +0200 (Fri, 28 Apr 2023) $
     sidTime    0
   helper:
   boxUser    rmb
   room       HWRaum
