Raspberry SMS-USB-Stick nicht erreichbar - wie das mitkriegen ?
Begonnen von DL8EI Ralph, 03 Mai 2023, 22:05:30
DL8EI Ralph
throttled=0x0
pi@raspb:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] On node 0 totalpages: 241664
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:63
[    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
[    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 935028K/966656K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23436K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                   lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
                   modules : 0x7f000000 - 0x80000000   (  16 MB)
                     .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                     .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                     .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                      .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 26394 entries in 78 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000004] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000010] Switching to timer-based delay loop, resolution 52ns
[    0.000156] Console: colour dummy device 80x30
[    0.000167] console [tty1] enabled
[    0.000198] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.000207] pid_max: default: 32768 minimum: 301
[    0.000389] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000399] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000926] CPU: Testing write buffer coherency: ok
[    0.001215] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001573] Setting up static identity map for 0x100000 - 0x10003c
[    0.001653] rcu: Hierarchical SRCU implementation.
[    0.002082] smp: Bringing up secondary CPUs ...
[    0.002574] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.003082] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.003549] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.003611] smp: Brought up 1 node, 4 CPUs
[    0.003617] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.003620] CPU: All CPU(s) started in HYP mode.
[    0.003623] CPU: Virtualization extensions available.
[    0.004193] devtmpfs: initialized
[    0.010989] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.011123] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.011134] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.011466] pinctrl core: initialized pinctrl subsystem
[    0.011946] NET: Registered protocol family 16
[    0.013619] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.016580] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.016584] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.016706] Serial: AMBA PL011 UART driver
[    0.017884] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.035824] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[    0.036679] SCSI subsystem initialized
[    0.036794] usbcore: registered new interface driver usbfs
[    0.036823] usbcore: registered new interface driver hub
[    0.036873] usbcore: registered new device driver usb
[    0.050227] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
[    0.060072] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
[    0.071033] clocksource: Switched to clocksource arch_sys_counter
[    0.117017] VFS: Disk quotas dquot_6.6.0
[    0.117064] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.117169] FS-Cache: Loaded
[    0.117296] CacheFiles: Loaded
[    0.122400] NET: Registered protocol family 2
[    0.122819] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.122838] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.122893] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.122986] TCP: Hash tables configured (established 8192 bind 8192)
[    0.123066] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.123090] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.123261] NET: Registered protocol family 1
[    0.123593] RPC: Registered named UNIX socket transport module.
[    0.123596] RPC: Registered udp transport module.
[    0.123599] RPC: Registered tcp transport module.
[    0.123602] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.124557] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.126176] Initialise system trusted keyrings
[    0.126282] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.131451] FS-Cache: Netfs 'nfs' registered for caching
[    0.131758] NFS: Registering the id_resolver key type
[    0.131775] Key type id_resolver registered
[    0.131779] Key type id_legacy registered
[    0.131788] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.132999] Key type asymmetric registered
[    0.133004] Asymmetric key parser 'x509' registered
[    0.133032] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.133119] io scheduler noop registered
[    0.133122] io scheduler deadline registered (default)
[    0.133218] io scheduler cfq registered
[    0.133222] io scheduler mq-deadline registered (default)
[    0.133225] io scheduler kyber registered
[    0.134958] bcm2708_fb soc:fb: FB found 1 display(s)
[    0.140991] Console: switching to colour frame buffer device 80x30
[    0.143561] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 640x480
[    0.144105] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    0.144976] bcm2835-rng 3f104000.rng: hwrng registered
[    0.145135] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    0.145414] vc-sm: Videocore shared memory driver
[    0.145575] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    0.151109] brd: module loaded
[    0.156572] loop: module loaded
[    0.156917] Loading iSCSI transport class v2.0-870.
[    0.157316] libphy: Fixed MDIO Bus: probed
[    0.157375] usbcore: registered new interface driver lan78xx
[    0.157404] usbcore: registered new interface driver smsc95xx
[    0.157413] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.185096] dwc_otg 3f980000.usb: base=(ptrval)
[    0.385212] Core Release: 2.80a
[    0.385217] Setting default values for core params
[    0.385236] Finished setting default values for core params
[    0.585407] Using Buffer DMA mode
[    0.585411] Periodic Transfer Interrupt Enhancement - disabled
[    0.585414] Multiprocessor Interrupt Enhancement - disabled
[    0.585418] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.585428] Dedicated Tx FIFOs mode
[    0.585683] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ba904000 dma = 0xfa904000 len=9024
[    0.585698] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.585702] dwc_otg: Microframe scheduler enabled
[    0.585732] WARN::hcd_init_fiq:457: FIQ on core 1
[    0.585737] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
[    0.585745] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[    0.585754] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.585773] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.585792] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[    0.585827] Init: Port Power? op_state=1
[    0.585830] Init: Power Port (0)
[    0.585966] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.585972] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.585976] usb usb1: Product: DWC OTG Controller
[    0.585981] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
[    0.585985] usb usb1: SerialNumber: 3f980000.usb
[    0.586314] hub 1-0:1.0: USB hub found
[    0.586341] hub 1-0:1.0: 1 port detected
[    0.586645] dwc_otg: FIQ enabled
[    0.586648] dwc_otg: NAK holdoff enabled
[    0.586651] dwc_otg: FIQ split-transaction FSM enabled
[    0.586656] Module dwc_common_port init
[    0.586794] usbcore: registered new interface driver usb-storage
[    0.586886] mousedev: PS/2 mouse device common for all mice
[    0.587353] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    0.587477] bcm2835-cpufreq: min=1200000 max=1200000
[    0.587722] sdhci: Secure Digital Host Controller Interface driver
[    0.587725] sdhci: Copyright(c) Pierre Ossman
[    0.587930] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[    0.588127] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    0.588192] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.589321] ledtrig-cpu: registered to indicate activity on CPUs
[    0.589420] hidraw: raw HID events driver (C) Jiri Kosina
[    0.589513] usbcore: registered new interface driver usbhid
[    0.589516] usbhid: USB HID core driver
[    0.590048] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[    0.591069] [vc_sm_connected_init]: start
[    0.598026] [vc_sm_connected_init]: end - returning 0
[    0.598628] Initializing XFRM netlink socket
[    0.598642] NET: Registered protocol family 17
[    0.598706] Key type dns_resolver registered
[    0.598988] Registering SWP/SWPB emulation handler
[    0.599330] registered taskstats version 1
[    0.599340] Loading compiled-in X.509 certificates
[    0.603179] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    0.603230] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.604118] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 53, base_baud = 50000000) is a 16550
[    0.604678] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    0.604683] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[    0.630448] sdhost: log_buf @ (ptrval) (fa907000)
[    0.668266] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    0.669780] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.671291] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.673997] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    0.677749] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.678430] of_cfs_init
[    0.678484] of_cfs_init: OK
[    0.678863] Waiting for root device /dev/mmcblk0p7...
[    0.744093] random: fast init done
[    0.765380] mmc0: host does not support reading read-only switch, assuming write-enable
[    0.768840] mmc0: new high speed SDHC card at address aaaa
[    0.769515] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    0.773902]  mmcblk0: p1 p2 < p5 p6 p7 >
[    0.784952] mmc1: new high speed SDIO card at address 0001
[    0.801312] Indeed it is in host mode hprt0 = 00021501
[    0.865667] EXT4-fs (mmcblk0p7): INFO: recovery required on readonly filesystem
[    0.865671] EXT4-fs (mmcblk0p7): write access will be enabled during recovery
[    1.011060] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.011141] Indeed it is in host mode hprt0 = 00001101
[    1.251214] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[    1.251222] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.251982] hub 1-1:1.0: USB hub found
[    1.252064] hub 1-1:1.0: 5 ports detected
[    1.571058] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    1.701213] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[    1.701220] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.703684] smsc95xx v1.0.6
[    1.793026] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c6:67:fb
[    1.891055] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[    2.051162] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6f70, bcdDevice= 6.00
[    2.051171] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.051176] usb 1-1.3: Product: HB-RF-USB
[    2.051181] usb 1-1.3: Manufacturer: Alexander Reinert
[    2.051185] usb 1-1.3: SerialNumber: A9651ZFU
[    2.151082] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[    2.208889] EXT4-fs (mmcblk0p7): orphan cleanup on readonly fs
[    2.245753] EXT4-fs (mmcblk0p7): 22 orphan inodes deleted
[    2.245757] EXT4-fs (mmcblk0p7): recovery complete
[    2.267368] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    2.267409] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    2.275029] devtmpfs: mounted
[    2.277731] Freeing unused kernel memory: 1024K
[    2.294269] usb 1-1.4: New USB device found, idVendor=03eb, idProduct=204b, bcdDevice= 0.00
[    2.294275] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.294280] usb 1-1.4: Product: CUL868
[    2.294285] usb 1-1.4: Manufacturer: busware.de
[    2.301243] Run /sbin/init as init process
[    2.767481] systemd[1]: System time before build time, advancing clock.
[    2.888000] NET: Registered protocol family 10
[    2.888832] Segment Routing with IPv6
[    2.921181] random: systemd: uninitialized urandom read (16 bytes read)
[    2.922838] random: systemd: uninitialized urandom read (16 bytes read)
[    2.925918] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    2.926235] systemd[1]: Detected architecture arm.
[    2.927223] systemd[1]: Set hostname to <raspb>.
[    2.964020] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read)
[    3.360760] systemd[1]: Listening on udev Kernel Socket.
[    3.361184] systemd[1]: Listening on udev Control Socket.
[    3.361323] systemd[1]: Listening on Syslog Socket.
[    3.378202] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.378395] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.379013] systemd[1]: Created slice System Slice.
[    3.380968] systemd[1]: Mounting RPC Pipe File System...
[    3.460562] i2c /dev entries driver
[    3.736321] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    3.778666] systemd-journald[96]: Received request to flush runtime journal from PID 1
[    4.032527] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    4.033965] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    4.033976] [vc_sm_connected_init]: start
[    4.036278] [vc_sm_connected_init]: installed successfully
[    4.049264] media: Linux media interface: v0.10
[    4.088161] videodev: Linux video capture interface: v2.00
[    4.176466] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    4.180548] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    4.197476] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    4.203365] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    4.210820] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    4.210829] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    4.216982] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    4.216993] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    4.219842] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    4.219849] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    4.325618] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[    4.326320] usbcore: registered new interface driver cdc_acm
[    4.326325] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.369261] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.407475] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.442526] generic_raw_uart: loading out-of-tree module taints kernel.
[    4.474628] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    4.478375] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[    4.478535] usbcore: registered new interface driver brcmfmac
[    4.490542] usb 1-1.3: Found HB-RF-USB at usb-3f980000.usb-1.3
[    4.562534] usbcore: registered new interface driver hb_rf_usb
[    4.716518] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[    4.716582] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[    4.717138] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[    4.986342] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    4.986352] brcmfmac: power management disabled
[    5.351065] usb 1-1.5: new high-speed USB device number 6 using dwc_otg
[    5.492254] usb 1-1.5: New USB device found, idVendor=12d1, idProduct=1446, bcdDevice= 0.00
[    5.492265] usb 1-1.5: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[    5.492270] usb 1-1.5: Product: HUAWEI Mobile
[    5.492275] usb 1-1.5: Manufacturer: HUAWEI Technology
[    5.496939] usb-storage 1-1.5:1.0: USB Mass Storage device detected
[    5.497630] scsi host0: usb-storage 1-1.5:1.0
[    5.498191] usb-storage 1-1.5:1.1: USB Mass Storage device detected
[    5.500195] scsi host1: usb-storage 1-1.5:1.1
[    5.554404] usbcore: registered new interface driver uas
[    6.351799] random: crng init done
[    6.351816] random: 7 urandom warning(s) missed due to ratelimiting
[    6.355662] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    6.554777] scsi 1:0:0:0: Direct-Access     HUAWEI   MMC Storage      2.31 PQ: 0 ANSI: 2
[    6.559797] scsi 0:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[    6.571406] sd 1:0:0:0: [sda] Attached SCSI removable disk
[    6.652633] sd 1:0:0:0: Attached scsi generic sg0 type 0
[    6.652744] scsi 0:0:0:0: Attached scsi generic sg1 type 5
[    6.848735] usb 1-1.5: USB disconnect, device number 6
[    6.898281] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    6.907234] raw-uart raw-uart: Reset radio module
[    8.446715] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[   12.554140] eq3loop: created slave mmd_hmip
[   12.554894] eq3loop: created slave mmd_bidcos
[   13.293068] usb 1-1.5: new high-speed USB device number 7 using dwc_otg
[   13.432539] usb 1-1.5: New USB device found, idVendor=12d1, idProduct=14ac, bcdDevice= 0.00
[   13.432553] usb 1-1.5: New USB device strings: Mfr=4, Product=3, SerialNumber=0
[   13.432558] usb 1-1.5: Product: HUAWEI Mobile
[   13.432563] usb 1-1.5: Manufacturer: HUAWEI Technology
[   13.441483] usb-storage 1-1.5:1.5: USB Mass Storage device detected
[   13.471175] scsi host0: usb-storage 1-1.5:1.5
[   13.471763] usb-storage 1-1.5:1.6: USB Mass Storage device detected
[   13.485592] scsi host1: usb-storage 1-1.5:1.6
[   13.587366] usbcore: registered new interface driver usbserial_generic
[   13.587762] usbserial: USB Serial support registered for generic
[   13.593654] usbcore: registered new interface driver cdc_ether
[   13.613889] usbcore: registered new interface driver option
[   13.613991] usbserial: USB Serial support registered for GSM modem (1-port)
[   13.614579] option 1-1.5:1.0: GSM modem (1-port) converter detected
[   13.614994] usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB0
[   13.615513] option 1-1.5:1.3: GSM modem (1-port) converter detected
[   13.615871] usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB1
[   13.616055] option 1-1.5:1.4: GSM modem (1-port) converter detected
[   13.616309] usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB2
[   13.625344] usbcore: registered new interface driver cdc_wdm
[   13.634576] usbcore: registered new interface driver qmi_wwan
[   14.555007] scsi 1:0:0:0: Direct-Access     HUAWEI   MMC Storage      2.31 PQ: 0 ANSI: 2
[   14.556140] sd 1:0:0:0: Attached scsi generic sg0 type 0
[   14.559012] scsi 0:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[   14.569104] sd 1:0:0:0: [sda] Attached SCSI removable disk
[   14.572817] sr 0:0:0:0: [sr0] scsi-1 drive
[   14.572828] cdrom: Uniform CD-ROM driver Revision: 3.20
[   14.573833] sr 0:0:0:0: Attached scsi CD-ROM sr0
[   14.574363] sr 0:0:0:0: Attached scsi generic sg1 type 5
[   14.822344] eq3loop: eq3loop_open_slave() mmd_bidcos
[   18.543504] fuse init (API version 7.27)
[   21.293831] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[   24.618130] uart-pl011 3f201000.serial: no DMA platform data
[   34.041617] eq3loop: eq3loop_open_slave() mmd_hmip
[   34.041768] eq3loop: eq3loop_close_slave() mmd_hmip
[   34.045281] eq3loop: eq3loop_open_slave() mmd_hmip
[   34.045440] eq3loop: eq3loop_close_slave() mmd_hmip
[   34.055864] eq3loop: eq3loop_open_slave() mmd_hmip
[   49.600772] usb 1-1.5: USB disconnect, device number 7
[   49.602252] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[   49.602359] option 1-1.5:1.0: device disconnected
[   49.606428] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[   49.606562] option 1-1.5:1.3: device disconnected
[   49.607116] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[   49.607177] option 1-1.5:1.4: device disconnected
[   54.251107] usb 1-1.5: new high-speed USB device number 8 using dwc_otg
[   54.392409] usb 1-1.5: New USB device found, idVendor=12d1, idProduct=14ac, bcdDevice= 0.00
[   54.392418] usb 1-1.5: New USB device strings: Mfr=4, Product=3, SerialNumber=0
[   54.392422] usb 1-1.5: Product: HUAWEI Mobile
[   54.392427] usb 1-1.5: Manufacturer: HUAWEI Technology
[   54.397769] option 1-1.5:1.0: GSM modem (1-port) converter detected
[   54.398005] usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB1
[   54.398770] option 1-1.5:1.3: GSM modem (1-port) converter detected
[   54.399036] usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB2
[   54.399278] option 1-1.5:1.4: GSM modem (1-port) converter detected
[   54.399446] usb 1-1.5: GSM modem (1-port) converter now attached to ttyUSB3
[   54.399655] usb-storage 1-1.5:1.5: USB Mass Storage device detected
[   54.399969] scsi host0: usb-storage 1-1.5:1.5
[   54.400455] usb-storage 1-1.5:1.6: USB Mass Storage device detected
[   54.400729] scsi host1: usb-storage 1-1.5:1.6
[   55.434919] scsi 1:0:0:0: Direct-Access     HUAWEI   MMC Storage      2.31 PQ: 0 ANSI: 2
[   55.435610] sd 1:0:0:0: Attached scsi generic sg0 type 0
[   55.436693] scsi 0:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[   55.444805] sd 1:0:0:0: [sda] Attached SCSI removable disk
[   55.447550] sr 0:0:0:0: [sr0] scsi-1 drive
[   55.448562] sr 0:0:0:0: Attached scsi CD-ROM sr0
[   55.449094] sr 0:0:0:0: Attached scsi generic sg1 type 5
Fernmelde-Opa übernahm FHEM-Installation und kämpft sich so durch.
Installation hat FS20, Homematic und einge exotische Teile.
RalfRog
Dann check mal hin und wieder ob es bei "throttled=0x0 " bleibt.
Die SD Karte scheint aus meiner Sicht zumindest merkwürdig partitioniert:
Die verwaisten Inodes scheinen auf deiner Rootpartition zu sein root=/dev/mmcblk0p7.
Wenn es bei throttled=0x0 bleibt wäre nach einem Neustart mal zu schauen, dass das nicht mehr kommt:
   [2.208889] EXT4-fs (mmcblk0p7): orphan cleanup on readonly fs
Dann war vermutlich die UnderVoltage dafür verantwortlich.
Nachdem der Stick erkannt und am USB angemeldet wurde halte ich diese Meldung den Mobile Stick betreffend auch nicht für normal (zu viel Strom??):
  [6.848735] usb 1-1.5: USB disconnect, device number 6
um dann neu erkannt zu werden
  [13.293068] usb 1-1.5: new high-speed USB device number 7 using dwc_otg
dann
  [49.600772] usb 1-1.5: USB disconnect, device number 7
=> die Idee mit dem gespeisten HUB ist sicher nicht die Schlechteste
Wernieman
Was mich immer noch stohrt: Du hast mindestens 3 mal die Meldung, das Massenspeicher/GSM-Modem gefunden wurden. Auch wenn es kein Power Down vorher gab, stimmt da irgendetwas nicht.
Kleine Frage: Hast Du auch hm-Zeug installiert?
Weißt Du überhaupt, was alles auf dem Pi läuft?
Und was ich schon mal gefragt habe: Was für USB-Geräte hast Du alles angeschlossen?
Und wegen Version: Auf der Konsole bitte ein:
cat /etc/debian_version
- Bitte um Input für Output
DL8EI Ralph
#18
pi@raspb:~ $ vcgencmd get_throttled
throttled=0x0
pi@raspb:~ $ cat /etc/debian_version
9.13
Ja, es ist jede Menge an FS20 und HM direkt installiert.
Es soll auch mal HM-iP installiert gewesen sein, habe aber keine Teile davon.
Es soll auch eine überwachte USV angeschlossen gewesen sein, die habe ich aber nicht.
Ich werde mir einen USB-Hub imit Netzteil bestellen.
Aktuelle USB sind: GSM-Stick mit Installations-CD-Rom, 868-CUL von Busware, HM-CUL von Reinert.
Es soll mal ein 432-CUL angeschlossen gewesen sein, habe ich aber nicht.
Zu der Partitionierung kann ich nichts sagen, das war so, als ich es übernahm.
Ich habe vor eine neue SD-karte einzusetzen.
Nur weiß ich nicht, wie man die bisherige Installation auf die dann neue SD funktionierend überträgt ohne Linux-Rechner.
Würde ich clonen, dann würde IMHO die (falschen) Partitionen auch mit übertragen.
Neu installieren möchte ich eher nicht, nur im Notfall, wenn es gar nicht anders geht. Ich fürchte zu scheitern.
Wernieman
9.13
Also ich befürchte, Du musst daran denken, upzudaten. Debian Stretch ist seit 30.06.2022 "out of Life"
Meine Empfehlung: Schaffe Dir Zeitnah einen 2. Raspi an und richte den ein. Dann kannst Du üben .....
und wenn ich lese, was schon mal installiert war (und wie), dann dürfte es ein schlecht wartbares Bastelsystem sein ...
Und Nein, bitte komme nicht mit "läuft doch aktuell". Wenn Du irgendwann mal Probleme kriegst, kannst Du eben mit dem aktuellen System diese nicht lösen.. Und so ein Ausfall kommt genau dann, wenn Du es am wenigsten gebrauchen kannst und keine Zeit hast. Lieber VORHER migrieren und sauber (dokumentiert) aufsetzen. Sonst hast Du irgendwann ein "heftiges Problem" ....
DL8EI Ralph
#20
OK, ich kaufe einen.
Möchtest Du mir eine aktuelle und funktionierende Installationsanleitung für den RasPi für Laien empfehlen?
Wernieman
Gucke mal bei Ottos Techblog (ist hie irgendwo im Forum schon mal erwähnt worden) nach .....
Wernieman
Ws mir noch einfällt: Bitte ein "Server Installation" ohne Desktop! Die Grafische Oberfläche macht Dir sonst nur Schwierigkeiten ...
