line 0: Script error
Begonnen von SamNitro, 17 Mai 2023, 16:35:27
SamNitro
wenn ich im Browser bei IOS zurück wische also auf die Seite davor bekomme ich eine Meldung
Zitatline 0:
Script error.
Kann mir einer sagen woran das liegt oder wo ich suchen muss? Welche infos benötigt ihr?
WEB:
   BYTES_READ 8185949
   BYTES_WRITTEN 4596487035
   CONNECTS   3034
   DEF        8083 global
   FD         8
   FUUID      5c473500-f33f-19ae-22a0-04a4cb28092cf2a9
   NAME       WEB
   NR         32
   NTFY_ORDER 50-WEB
   PORT       8083
   STATE      Initialized
   TYPE       FHEMWEB
     2023-05-06 03:16:49   state           Initialized
   CORS       1
   JavaScripts codemirror/fhem_codemirror.js pgm2/fhem_details.js
   codemirrorParam { "theme": "blackboard", "lineNumbers": true, "lineWrapping": true, "height": "auto", "matchBrackets": true }
   confirmDelete 1
   csrfToken  none
   detailLinks 10
   editConfig 1
   extraRooms name=WeekdayTimer:devspec=TYPE=WeekdayTimer
name=DOIF:devspec=TYPE=DOIF
name=At:devspec=TYPE=at
name=Notify:devspec=TYPE=notify
name=Structure:devspec=TYPE=structure
   longpoll   websocket
   menuEntries HM,http://10.1.1.7' target='_blank,Z2M,http://10.1.1.4:8080' target='_blank,
   room       Fhem
   roomIcons  Save.config:message_attention
   sortRooms  Fhem Interface Systembefehle Muster Unsorted
   stylesheetPrefix hausautomatisierung_com
global:
   DEF        no definition
   FD         3
   NAME       global
   NR         1
   STATE      no definition
   TYPE       Global
   currentlogfile ./log/fhem-2023-05-17.log
   eventCount 123
   init_errors Messages collected while initializing FHEM:SecurityCheck:
  WEB is not password protected
  m2s is not password protected
  telnetPort is not password protected
Protect this FHEM installation by configuring the allowed device allowed
You can disable this message with attr global motd none
   logfile    ./log/fhem-%Y-%m-%d.log
   autoload_undefined_devices 1
   autosave   0
   backup_before_update 0
   commandref modular
   configfile configDB
   dnsServer  10.1.1.1
   ignoreRegexp ^N\/A.*
   language   DE
   latitude   51.044008
   longitude  6.583385
   modpath    .
   motd       none
   nrarchive  6
   room       Fhem
   sendStatistics never
   stacktrace 0
   statefile  ./log/fhem.save
   updateInBackground 1
   userattr   DbLogExclude DbLogExclude:textField-long DbLogInclude DbLogInclude:textField-long DbLogValueFn:textField-long alexaName alexaProactiveEvents:1,0 alexaRoom appOptions:textField-long cmdIcon devStateIcon devStateIcon:textField-long devStateStyle genericDeviceType:switch,outlet,light,blind,speaker,thermostat homebridgeMapping:textField-long icon mqttAlias mqttAlias:textField-long mqttDefaults mqttDefaults:textField-long mqttDisable:both,incoming,outgoing mqttForward:all,none mqttPublish mqttPublish:textField-long mqttSubscribe mqttSubscribe:textField-long readingsWatcher siriName sortby webCmd webCmdLabel:textField-long widgetOverride
   verbose    3
   version    fhem.pl:27410/2023-04-07
(Intel-Nuc Proxmox) (Homematic) (EnOcean) (CUL868) (CUL433) (Zigbee2MQTT) (ESP8266) (Echo) (DUOFERN)
SamNitro
Scheint leider etwas anders zu sein. Websocket ist gesetzt.
Habe jetzt die Meldung erstmal deaktiviert.
Toto1973
Da ich aktuell gerade wieder das Problem habe, hole ich dieses Thread mal hervor.
Aktuell habe ich bei einer FHEM-Instanz diese Fehlermeldung: webauthnInterceptor.js line 0:
Script error.
Weiß jemand, wo da der Fehler liegt?
Raspberry PI2, Rademacher DuoFern Stick, CUL, 2 x SCC,  JeeLink 868 Mhz, JeeLink 433 Mhz, 3x Magic UFO LED WiFi Controller, 4x MAX BC-RT-TRX-CyG, 2x MAX Fensterkontakt, 5x Rademacher Gurtwickler, 6x TX29DTH-it, 2x TX25-it als Helligkeitssensor, 1X HM-ES-PM, 6x Sonoff, 7x G-Homa, PIR-1000
webauthnInterceptor.js klingt fuer mich nach Browser Extension.
Das kann man verifizieren, indem man die Seite im Inkognito Modus aufruft, da werden per Voreinstellung keine Extensions verwendet.
Weiterhin wurde ich die JavaScript-Console des Browser oeffnen, und da die Details anzeigen.
marc
#5
Ich habe nun leider auch seit einiger Zeit diesen Fehler.
MacOS, Firefox:
Script error.
Nervt ziemlich, da dieses Fenster nach jedem Click kommt. Jemand eine Idee, wie wir das weiter eingrenzen und lösen können ?
marc
Ich habe es bei mir eingrenzen und auch lösen können.
Es ist das Plugin/die Erweiterung des Passwortmanagers "enpass".
Wenn ich diese Erweiterung aktiviere kommt sofort, und bis jetzt ausschließlich auf der FHEM Oberfläche, das "webauthnInterceptor.js" Error Popup.
Wenn ich die Erweiterung deaktiviere, läuft alles fehlerfrei.......
