Keine Energiedaten von Shelly1PM am MQTT2_DEVICE
Begonnen von Homalix99, 01 August 2023, 14:44:52
Homalix99
mir ist aufgefallen (vermutlich nach dem letzten Fhem Update), dass in allen shelly-Objekten mit Typ MQTT2_DEVICE die Readings für Energy auf Null bleiben.
   CFGFN      ./FHEM/00_config_MQTT2.conf
   CID        shelly1pm_F4CFA2E38BD3
   DEF        shelly1pm_F4CFA2E38BD3
   FUUID      61cd9477-f33f-6b52-fd54-6aa8afe8e8ee1b1f
   IODev      myMQTT2Client
   LASTInputDev myMQTT2Client
   MSGCNT     298313
   NAME       MQTT2_SpuelMa
   NR         1657
   STATE      on
   TYPE       MQTT2_DEVICE
   eventCount 2250
   myMQTT2Client_MSGCNT 298313
   myMQTT2Client_TIME 2023-08-01 13:56:50
     2023-07-16 19:34:50   IODev           myMQTT2Client
     2023-07-20 18:29:08   cond            CONN
     2023-07-27 14:47:41   event
     2023-07-27 14:47:41   event_cnt       0
     2023-07-27 14:47:40   fw_ver          20211109-130756/v1.11.7-g682a0db
     2023-07-27 14:47:40   id              SpuelMa
     2023-08-01 13:56:50   input0          0
     2023-07-27 14:47:40   ip              192.168.3.65
     2023-08-01 10:32:51   loadState       off
     2023-07-27 14:47:40   mac             F4CFA2E38BD3
     2023-07-27 14:47:40   model           SHSW-PM
     2023-07-27 14:47:40   new_fw          false
     2023-07-27 14:47:40   online          true
     2023-08-01 13:56:50   overtemperature 0
     2023-08-01 13:56:50   relay0          on
     2023-08-01 13:56:50   relay_0_energy  0
     2023-08-01 13:56:50   relay_0_kWh     0.00
     2023-08-01 13:56:50   relay_0_power   0.66
     2023-08-01 13:56:50   state           on
     2023-08-01 13:56:50   temperature     44.84
   helper:
     bm:
       MQTT2_DEVICE_Get:
         cnt        6
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        01.08. 11:44:46
         max        0.000175952911376953
         tot        0.000645875930786133
         mAr:
           HASH(0x55a4563448)
           MQTT2_SpuelMa
       MQTT2_DEVICE_Set:
         cnt        24
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        01.08. 12:14:05
         max        0.0328531265258789
         tot        0.0521891117095947
         mAr:
           HASH(0x55a4563448)
           MQTT2_SpuelMa
   DbLogExclude .*
   IODev      myMQTT2Client
   comment    To get appropriate loadState values: Change the default limit "100" in readingList to your needs.
   devStateIcon {my $onl = ReadingsVal($name,"online","false") eq "false"?"10px-kreis-rot" : ReadingsVal($name,"new_fw","false") eq "true" ? "10px-kreis-gelb" : "10px-kreis-gruen"; my $light = ReadingsVal($name,"state","off"); my $cons = ReadingsVal($name,"relay_0_power","unknown"); my $total = ReadingsVal($name,"relay_0_kWh","unknown"); my $temp = ReadingsVal($name,"temperature","-100"); "<a href=\"http://".ReadingsVal($name,"ip","none")." \"target=\"_blank\">".FW_makeImage($onl)."</a> <a href=\"/fhem?cmd.dummy=set $name toggle&XHR=1\">".FW_makeImage($light)."</a><div>Verbrauch: $cons / Total: $total/ Temp: $temp °C</div>"}
   event-on-change-reading relay_0_power:0.2
   model      shelly1_w_energy_measuring
   readingList shellies/SpuelMa/relay/0:.* state
  shellies/SpuelMa/relay/0:.* relay0
  shellies/SpuelMa/input/0:.* input0
  shellies/SpuelMa/online:.* online
  shellies/announce:.* { $EVENT =~ m,..id...SpuelMa...mac.*, ? json2nameValue($EVENT) : return }
  shellies/SpuelMa/announce:.* { json2nameValue($EVENT) }
  shellies/SpuelMa/relay/0/power:.* relay_0_power
  shellies/SpuelMa/relay/0/power:.* { my $compare = $EVTPART0 < 100 ? "off":"on"; ReadingsVal($NAME,"loadState","off") ne $compare ? { 'loadState' => $compare } : return }
  shellies/SpuelMa/temperature:.* temperature
  shellies/SpuelMa/input_event/0:.* { json2nameValue($EVENT) }
  shellies/SpuelMa/overtemperature:.* overtemperature
  shellies/SpuelMa/relay/0/energy:.* relay_0_energy
  shellies/SpuelMa/relay/0/energy:.* {'relay_0_kWh' => sprintf("%.2f",$EVENT/60/1000)}
  shellies/SpuelMa/longpush/0:.* longpush_0
shelly1pm_F4CFA2E38BD3:shellies/SpuelMa/info:.* { json2nameValue($EVENT) }
shelly1pm_F4CFA2E38BD3:shellies/SpuelMa/temperature_status:.* temperature_status
   room       MQTT2_DEVICE
   setList    relay0:on,off,toggle shellies/SpuelMa/relay/0/command $EVTPART1
  toggle:noArg shellies/SpuelMa/relay/0/command toggle
  off:noArg shellies/SpuelMa/relay/0/command off
  on:noArg shellies/SpuelMa/relay/0/command on
  x_update:noArg shellies/SpuelMa/command update_fw
  x_mqttcom shellies/SpuelMa/command $EVTPART1
   setStateList on off toggle
   tolerance  2.2
   update_intervall 120
   userReadings relay_0_energy_total:relay_0_energy:.* monotonic {ReadingsNum("$name","relay_0_energy",0)}
   userattr   update_intervall tolerance
   webCmd     :
Ich habe nur "ältere" shelly1-PM, keine plus.
Wie bekomme ich wieder brauchbare Werte?
Das damalige Template bot noch shelly1_w_energy_measurement an.
Habe heute ein update der Templates durchgeführt, welches für neue Objekte greift, da erscheint in der Auswahl als einzig sinnvolles nur shelly1 und shellyPlus_1pm aber nichts für shelly1pm.
Die shellies sind auf dem neusten fw-Stand.
Current version: 20211109-130756/v1.11.7-g682a0db
You have latest version on your device!
Wie komme ich da weiter?
Alex
- RPI 4 fhem in Docker, 2 x Arduino Uno, HM-GW, HM-Dev. (Fensterkontakte, HK-Thermostate, div. Aktoren), JeeLink,
- GPIOs, HM-LAN, ESPs (MQTT2)
-Überwachung Fenster/Türen/Licht, HK-Thermostatregelung, Rollosteuerung, Überw. Betriebstemperaturen Heizung, Erfassung Gas/Wasser, PV-Anl., Wetter (WS1600)
Man kann ein shelly mit mqtt auch komplett ohne template einrichten.
Dann weiß man wenigstens, was man tut und warum etwas funktioniert (oder auch nicht funktioniert)
Zitat von: Homalix99 am 01 August 2023, 14:44:52Wie komme ich da weiter?
Es gab hier mal eine merkwürdige Heilungsvariante: https://forum.fhem.de/index.php?topic=133701.msg1276937#msg1276937
Ob das wirklich hilft kann ich nicht sagen, konnte mich nur daran erinnern ;)
Homalix99
