Daten aus Websocket zerlegen
Begonnen von buec65, 09 Oktober 2023, 10:31:59
buec65
Hallo, ich versuche Daten von einem Gerät über Websocket einzulesen und bekomme dabei immer eine ganze Zeile Werte
Ich hätte gerne die Werte position für die zugehörige shadeId (davon gibt es mehrere von 0 bis 4 sind angelegt) und würde die in Reading bringen wollen
  DEF        ws://192.168.10.89:8080
  DeviceName ws:192.168.10.89:8080
  FD        4
  FUUID      65157e00-f33f-05ec-925b-ea374e8d5ac8da0f
  NAME      SomFy_RTS_02
  NR        50
  PARTIAL
  STATE      opened
  TYPE      UBUS_CLIENT
  WEBSOCKET  1
  eventCount 1
  lastid    0
  method    websocket
  session    00000000000000000000000000000000
    2023-10-09 09:22:54  state          opened
  header:
    Sec-WebSocket-Protocol ubus-json
  helper:
  rpc:
    SomFy_RTS_02:call:0:
      id        SomFy_RTS_02:call:0
      jsonrpc    2.0
      method    call
      params:
        session
        login
        HASH(0x38c4e80)
  room      SomFy
  verbose    5
das notify dazu
  DEF        SomFy_RTS_02:UNKNOWNCODE.{"shadeId": 3,"type": .*,"remoteAddress": .*,"name": .*,    "direction": .*,    "position": .*,    "target": .*,    "mypos": .*,    "myTiltPos": .*,    "tiltType": .*,    "tiltDirection": .*,    "tiltTarget": .*,    "tiltPosition": .*,    "flipCommands": .*,    "flipPosition": .*,    "flags": .*,    "sunSensor": .*,    "light": .*,    "sortOrder": 2} {}
  FUUID      651e6b66-f33f-05ec-2a86-6a3d4b0899d34502
  NAME      SomFy_RTS_02_notify_3
  NOTIFYDEV  SomFy_RTS_02
  NR        60
  NTFY_ORDER 50-SomFy_RTS_02_notify_3
  REGEXP    SomFy_RTS_02:UNKNOWNCODE.{"shadeId":
  STATE      active
  TYPE      notify
    2023-10-09 09:22:50  state          active
    2023-10-05 08:56:46  triggeredByDev  SomFy_RTS_02
    2023-10-05 08:56:46  triggeredByEvent UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":970383,"name":"Mitte","direction":0,"position":0,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
  addStateEvent 1
  readLog    1
  room      SomFy
FileLog
  DEF        ./log/SomFy_RTS_02_FileLog_1.log SomFy_RTS_02:UNKNOWNCODE.{"shadeId":3,"type":.*,"remoteAddress":.*,"name":.*,"direction":.*,"position":.*,"target":.*,"mypos":.*,"myTiltPos":.*,"tiltType":.*,"tiltDirection":.*,"tiltTarget":.*,"tiltPosition":.*,"flipCommands":.*,"flipPosition":.*,"flags":.*,"sunSensor":.*,"light":.*,"sortOrder":.*}
  FD        7
  FUUID      65239bc1-f33f-05ec-4925-dd66193ff7ba4340
  NAME      SomFy_RTS_02_FileLog_1
  NR        67
  NTFY_ORDER 50-SomFy_RTS_02_FileLog_1
  REGEXP    SomFy_RTS_02:UNKNOWNCODE.{"shadeId":3,"type":.*,"remoteAddress":.*,"name":.*,"direction":.*,"position":.*,"target":.*,"mypos":.*,"myTiltPos":.*,"tiltType":.*,"tiltDirection":.*,"tiltTarget":.*,"tiltPosition":.*,"flipCommands":.*,"flipPosition":.*,"flags":.*,"sunSensor":.*,"light":.*,"sortOrder":.*}
  STATE      active
  TYPE      FileLog
  currentlogfile ./log/SomFy_RTS_02_FileLog_1.log
    2023-10-09 09:18:53  linesInTheFile  1626
  room      SomFy
2023-10-09_09:17:38 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"remoteAddress":374799,"cmd":"My","source":"internal","rcode":248,"sourceAddress":374799}
2023-10-09_09:17:38 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":0,"position":7,"target":7,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
2023-10-09_09:18:51 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":-1,"position":6,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
2023-10-09_09:18:51 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":-1,"position":5,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
2023-10-09_09:18:51 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":-1,"position":4,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
2023-10-09_09:18:52 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":-1,"position":3,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
2023-10-09_09:18:52 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":-1,"position":2,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
2023-10-09_09:18:52 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":-1,"position":1,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
2023-10-09_09:18:53 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":-1,"position":0,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
2023-10-09_09:18:53 SomFy_RTS_02 UNKNOWNCODE {"shadeId":3,"type":1,"remoteAddress":374799,"name":"Markise WZ-rechts","direction":0,"position":0,"target":0,"mypos":-1,"myTiltPos":-1,"tiltType":2,"tiltDirection":0,"tiltTarget":0,"tiltPosition":0,"flipCommands":false,"flipPosition":false,"flags":1,"sunSensor":false,"light":false,"sortOrder":2}
tremichl
Zwar keine direkte Antwort auf die Frage aber vielleicht hilft das: Ich mache das mit MQTT. ESP-SOMFY-RTS mit einem Garagentor (eine Taste Stat/Stop), einer Markise, und einem Rollo. Zusätzlich schicke ich noch Befehle von einem ShellyI4 über Websocket an ESP-SOMFY-RTS. Wenn ein shade in Bewegung ist, kommt seit ESP-Somfy Version 2.19 pro % Bewegung eine MQTT-message für die Position und damit ein entsprechendes Reading in FHEM. Das können bei kurzen Rollos schon 10 und mehr Messages pro Sekunde sein und wenn mehrere Rollos gleichzeitig unterwegs sind es entsprechend mehr. FHEM mit MQTT2 auf einem Raspi3 kommt da schon an seine Grenzen (kurzzeitig 100% CPU Last). Aber im Prinzip funktioniert das gut so. Hier meine Konfiguration. Eine Aufteilung auf ein Device pro shade wäre sicher eleganter, aber für meine Zwecke reicht das so. LG
defmod ESP_Somfy_RTS MQTT2_DEVICE client_0000f4fcd21b5ae0
attr ESP_Somfy_RTS alexaName Markise;; Markise-gross;; grosse-Markise
attr ESP_Somfy_RTS autocreate 1
attr ESP_Somfy_RTS cmdIcon Markise_ausfahren:control_centr_arrow_down Markise_einfahren:control_centr_arrow_up Markise_stop:control_x my:fts_shutter_50
attr ESP_Somfy_RTS devStateIcon online:10px-kreis-gruen offline:10px-kreis-rot 0:fts_sunblind_0 100:fts_sunblind_100 9\d.*:fts_sunblind_90 8\d.*:fts_sunblind_80 7\d.*:fts_sunblind_70 6\d.*:fts_sunblind_60 5\d.*:fts_sunblind_50 4\d.*:fts_sunblind_60 3\d.*:fts_sunblind_30 2\d.*:fts_sunblind_20 1\d.*:fts_sunblind_10 0\d.*:fts_sunblind_0 set_.*:fts_sunblind_updown
attr ESP_Somfy_RTS genericDeviceType blind
attr ESP_Somfy_RTS icon fts_sunblind
attr ESP_Somfy_RTS readingList client_0000f4fcd21b5ae0:Somfy/status:.* status\
client_0000f4fcd21b5ae0:Somfy/shades/1/shadeId:.* shades_1_shadeId\
client_0000f4fcd21b5ae0:Somfy/shades/1/name:.* shades_1_name\
client_0000f4fcd21b5ae0:Somfy/shades/1/remoteAddress:.* shades_1_remoteAddress\
client_0000f4fcd21b5ae0:Somfy/shades/1/shadeType:.* shades_1_shadeType\
client_0000f4fcd21b5ae0:Somfy/shades/1/tiltType:.* shades_1_tiltType\
client_0000f4fcd21b5ae0:Somfy/shades/1/flipCommands:.* shades_1_flipCommands\
client_0000f4fcd21b5ae0:Somfy/shades/1/flipPosition:.* shades_1_flipPosition\
client_0000f4fcd21b5ae0:Somfy/shades/1/position:.* shades_1_position\
client_0000f4fcd21b5ae0:Somfy/shades/1/direction:.* shades_1_direction\
client_0000f4fcd21b5ae0:Somfy/shades/1/target:.* shades_1_target\
client_0000f4fcd21b5ae0:Somfy/shades/1/lastRollingCode:.* shades_1_lastRollingCode\
client_0000f4fcd21b5ae0:Somfy/shades/1/mypos:.* shades_1_mypos\
client_0000f4fcd21b5ae0:Somfy/shades/1/myTiltPos:.* shades_1_myTiltPos\
client_0000f4fcd21b5ae0:Somfy/shades/1/sunSensor:.* shades_1_sunSensor\
client_0000f4fcd21b5ae0:Somfy/shades/2/shadeId:.* shades_2_shadeId\
client_0000f4fcd21b5ae0:Somfy/shades/2/name:.* shades_2_name\
client_0000f4fcd21b5ae0:Somfy/shades/2/remoteAddress:.* shades_2_remoteAddress\
client_0000f4fcd21b5ae0:Somfy/shades/2/shadeType:.* shades_2_shadeType\
client_0000f4fcd21b5ae0:Somfy/shades/2/tiltType:.* shades_2_tiltType\
client_0000f4fcd21b5ae0:Somfy/shades/2/flipCommands:.* shades_2_flipCommands\
client_0000f4fcd21b5ae0:Somfy/shades/2/flipPosition:.* shades_2_flipPosition\
client_0000f4fcd21b5ae0:Somfy/shades/2/position:.* shades_2_position\
client_0000f4fcd21b5ae0:Somfy/shades/2/direction:.* shades_2_direction\
client_0000f4fcd21b5ae0:Somfy/shades/2/target:.* shades_2_target\
client_0000f4fcd21b5ae0:Somfy/shades/2/lastRollingCode:.* shades_2_lastRollingCode\
client_0000f4fcd21b5ae0:Somfy/shades/2/mypos:.* shades_2_mypos\
client_0000f4fcd21b5ae0:Somfy/shades/2/myTiltPos:.* shades_2_myTiltPos\
client_0000f4fcd21b5ae0:Somfy/shades/2/sunSensor:.* shades_2_sunSensor\
client_0000f4fcd21b5ae0:Somfy/shades/3/shadeId:.* shades_3_shadeId\
client_0000f4fcd21b5ae0:Somfy/shades/3/name:.* shades_3_name\
client_0000f4fcd21b5ae0:Somfy/shades/3/remoteAddress:.* shades_3_remoteAddress\
client_0000f4fcd21b5ae0:Somfy/shades/3/shadeType:.* shades_3_shadeType\
client_0000f4fcd21b5ae0:Somfy/shades/3/tiltType:.* shades_3_tiltType\
client_0000f4fcd21b5ae0:Somfy/shades/3/flipCommands:.* shades_3_flipCommands\
client_0000f4fcd21b5ae0:Somfy/shades/3/flipPosition:.* shades_3_flipPosition\
client_0000f4fcd21b5ae0:Somfy/shades/3/position:.* shades_3_position\
client_0000f4fcd21b5ae0:Somfy/shades/3/direction:.* shades_3_direction\
client_0000f4fcd21b5ae0:Somfy/shades/3/target:.* shades_3_target\
client_0000f4fcd21b5ae0:Somfy/shades/3/lastRollingCode:.* shades_3_lastRollingCode\
client_0000f4fcd21b5ae0:Somfy/shades/3/mypos:.* shades_3_mypos\
client_0000f4fcd21b5ae0:Somfy/shades/3/myTiltPos:.* shades_3_myTiltPos\
client_0000f4fcd21b5ae0:Somfy/shades/3/sunSensor:.* shades_3_sunSensor\
client_0000f4fcd21b5ae0:Somfy/shades:.* { json2nameValue($EVENT, 'shades_', $JSONMAP) }\
client_0000f4fcd21b5ae0:Somfy/groups:.* groups\
client_0000f4fcd21b5ae0:Somfy/ipAddress:.* ipAddress\
client_0000f4fcd21b5ae0:Somfy/host:.* host\
client_0000f4fcd21b5ae0:Somfy/firmware:.* firmware\
client_0000f4fcd21b5ae0:Somfy/serverId:.* serverId\
client_0000f4fcd21b5ae0:Somfy/mac:.* mac
attr ESP_Somfy_RTS room Alexa,Garage,MQTT2_DEVICE,SOMFY
attr ESP_Somfy_RTS setList pct:slider,0,1,100 Somfy/shades/1/target/set\
Markise_target Somfy/shades/1/target/set\
Markise_my:noArg Somfy/shades/1/target/set 66\
Markise_einfahren:noArg Somfy/shades/1/direction/set -1\
Markise_ausfahren:noArg Somfy/shades/1/direction/set 1\
Markise_stop:noArg Somfy/shades/1/direction/set 0\
Garage:noArg Somfy/shades/3/direction/set 0ct
attr ESP_Somfy_RTS stateFormat Markise: shades_1_position %\
<br>\
RolloDG: shades_2_position %\
<br>\
Garage: shades_3_position %\
<br>\
<a href="http://ipAddress" target="_blank">ipAddress</a>\
status
attr ESP_Somfy_RTS webCmd Markise_ausfahren:Markise_stop:Markise_einfahren:::Garage
setstate ESP_Somfy_RTS Markise: 0 %\
<br>\
RolloDG: 0 %\
<br>\
Garage: 100 %\
<br>\
<a href="http://10.152.52.113" target="_blank">10.152.52.113</a>\
online
Wir haben keine Ahnung davon, was wir nicht wissen
#2
@buec65: Bitte verwende code-Tags um sowas einigermaßen lesbar darzustellen.
Eigentlich musst Du doch nur Dein notify, das aktuell noch gar nix tut, um den passenden Ausführungsteil ergänzen. Im einfachsten Fall sollte ein json2reading($EVTPART1) schon ausreichen, um aus den json Daten readings mit Inhalten zu erzeugen.
defmod SomFy_RTS_02_notify_99 notify SomFy_RTS_02:UNKNOWNCODE:{.*} {json2reading("SomFy_RTS_02",$EVTPART1)}
buec65
@Tremichl
Bei mir funktioniert es mit Mqtt2 leider nicht zuverlässig.
@betateilchen
Werde ich versuchen, vielen Dank.
Ideal wäre natürlich ein eigenes Modul aber von Perl habe ich keine Ahnung und Websocket-Module habe ich auch nicht wirklich gefunden.
#4
Es ist doch egal, woher die Daten kommen, es geht doch im um deren Weiterverarbeitung.
buec65
#5
@betateilchen
danke für den Tip das funktioniert und es werden Readings angelegt, leider landet da immer der letzte Wert ich bräuchte aber für jede shadeId":1 - 6 jeweils die zugehörigen Werte
   DEF        SomFy_RTS_02:UNKNOWNCODE.{.*} {json2reading("SomFy_RTS_02_sh_1",$EVTPART1)}
   FUUID      6530dbf2-f33f-05ec-1ce4-a10463b9b6b5283e
   NAME       SomFy_RTS_02_notify_99
   NR         72
   NTFY_ORDER 50-SomFy_RTS_02_notify_99
   REGEXP     SomFy_RTS_02:UNKNOWNCODE.{.*}
   STATE      2023-10-19 13:28:29
   TYPE       notify
     2023-10-19 14:40:41   state           active
     2023-10-19 13:28:29   triggeredByDev  SomFy_RTS_02
     2023-10-19 13:28:29   triggeredByEvent UNKNOWNCODE {"shadeId":2,"remoteAddress":374798,"cmd":"Up","source":"internal","rcode":160,"sourceAddress":374798}
   room       SomFy
2023.10.19 08:46:17 5: UBUS (SomFy_RTS_02) - received: {"shadeId":4,"remoteAddress":374800,"cmd":"Up","source":"internal","rcode":175,"sourceAddress":374800}
2023.10.19 08:46:17 5: SomFy_RTS_02: dispatch {"shadeId":4,"remoteAddress":374800,"cmd":"Up","source":"internal","rcode":175,"sourceAddress":374800}
2023.10.19 08:46:17 3: SomFy_RTS_02: Unknown code {"shadeId":4,"remoteAddress":374800,"cmd":"Up","source":"internal","rcode":175,"sourceAddress":374800}, help me!
2023.10.19 08:47:27 5: UBUS (SomFy_RTS_02) - received: {"shadeId":1,"remoteAddress":374797,"cmd":"Up","source":"internal","rcode":208,"sourceAddress":374797}
2023.10.19 08:47:27 5: SomFy_RTS_02: dispatch {"shadeId":1,"remoteAddress":374797,"cmd":"Up","source":"internal","rcode":208,"sourceAddress":374797}
2023.10.19 08:47:27 3: SomFy_RTS_02: Unknown code {"shadeId":1,"remoteAddress":374797,"cmd":"Up","source":"internal","rcode":208,"sourceAddress":374797}, help me!
