Aufruf DBrep über Notify
Begonnen von UvG, 26 Oktober 2023, 15:14:33
UvG
ich habe mir ein DBrep mit einem sqlcmd Statment angelegt.
   DATABASE   fhem
   DEF        logdb
   FUUID      60363f9c-f33f-d79e-0d59-4da7480aeed4f0dc
   FVERSION   93_DbRep.pm:v8.52.10-s27746/2023-07-10
   LASTCMD    sqlCmd SELECT MAX(TIMESTAMP), MAX(VALUE), MIN(TIMESTAMP), MIN(VALUE), round((MAX(VALUE)-MIN(VALUE)), 2) AS Diff, READING FROM history WHERE DEVICE = @device AND READING = @reading AND TIMESTAMP >= @begin_time and TIMESTAMP <= §timestamp_end§ GROUP BY DATE(`timestamp`) LIMIT 40;
   MODEL      Client
   NAME       myrepgas
   NOTIFYDEV  global,myrepgas
   NR         483
   NTFY_ORDER 50-myrepgas
   ROLE       Client
   STATE      done
   TYPE       DbRep
   UTF8       1
   eventCount 76
   HELPER:
     DBLOGDEVICE logdb
     GRANTS     UPDATE,SELECT,USAGE,DELETE,INSERT
     IDRETRIES  2
     MINTS      2020-02-29 00:00:02
     PACKAGE    main
     VERSION    8.52.10
     CV:
       aggregation no
       aggsec     1
       destr      2023-10-26
       dsstr      2023-09-01
       epoch_seconds_end 1698357599
       mestr      10
       msstr      09
       testr      23:59:59
       tsstr      00:00:00
       wdadd      259200
       yestr      2023
       ysstr      2023
     DBREPCOL:
       COLSET     1
       DEVICE     64
       EVENT      512
       READING    64
       TYPE       64
       UNIT       32
       VALUE      128
   OLDREADINGS:
     2023-10-26 09:26:12   SqlResult       {"01":"MAX(TIMESTAMP)|MAX(VALUE)|MIN(TIMESTAMP)|MIN(VALUE)|DIFF|READING","02":"2023-10-13 23:55:10|20714.56|2023-10-13 00:00:47|20714.56|0|total","03":"2023-10-14 23:59:35|20714.56|2023-10-14 00:00:11|20714.56|0|total","04":"2023-10-15 23:59:01|20714.56|2023-10-15 00:04:36|20714.56|0|total","05":"2023-10-16 23:58:28|20714.56|2023-10-16 00:04:02|20714.56|0|total","06":"2023-10-17 23:57:56|20715.92|2023-10-17 00:03:29|20714.56|1.36|total","07":"2023-10-18 23:57:23|20718.345|2023-10-18 00:02:56|20715.92|2.43|total","08":"2023-10-19 23:56:49|20719.785|2023-10-19 00:02:24|20718.345|1.44|total","09":"2023-10-20 23:56:15|20721.54|2023-10-20 00:01:50|20719.785|1.76|total","10":"2023-10-21 23:55:41|20722.99|2023-10-21 00:01:16|20721.54|1.45|total","11":"2023-10-22 23:55:06|20724.76|2023-10-22 00:00:42|20722.99|1.77|total","12":"2023-10-23 23:59:33|20726.685|2023-10-23 00:00:07|20724.76|1.93|total","13":"2023-10-24 23:58:58|20728.175|2023-10-24 00:04:34|20726.685|1.49|total","14":"2023-10-25 23:58:24|20730|2023-10-25 00:03:59|20728.175|1.83|total","15":"2023-10-26 09:25:08|20730.53|2023-10-26 00:03:25|20730|0.53|total"}
     2023-10-26 09:26:12   sqlCmd          SELECT MAX(TIMESTAMP), MAX(VALUE), MIN(TIMESTAMP), MIN(VALUE), round((MAX(VALUE)-MIN(VALUE)), 2) AS Diff, READING FROM history WHERE DEVICE = @device AND READING = @reading AND TIMESTAMP >= @begin_time and TIMESTAMP <= §timestamp_end§ GROUP BY DATE(`timestamp`) LIMIT 40;
     2023-10-26 09:26:12   sqlResultNumRows 14
     2023-10-26 09:26:12   state           done
   hmccu:
   DbLogExclude .*
   aggregation day
   allowDeletion 1
   device     CUL_EM_9
   diffAccept 10000
   limit      1000000
   reading    total
   room       DB,Unsorted
   sqlCmdHistoryLength 5
   sqlCmdVars SET @i:=1, @begin_time=CURDATE()- INTERVAL 13 DAY, @device='CUL_EM_9', @reading='total'
   sqlResultFormat json
   timestamp_begin previous_month_begin
   timestamp_end current_day_end
   userExitFn resfromjson
   verbose    3
Dies funktioniert auch so wie ich es wollte.
Nun wollte ich dieses DBrep über ein Notify aufrufen.
   CFGFN
   DEF        heizeinl {
my @i;
my @begin_time;
my @device;
my @reading;
  fhem "SET @i:=1, @begin_time=CURDATE()- INTERVAL 13 DAY, @device='CUL_EM_9', @reading='total'; set myrepgas sqlCmd SELECT MAX(TIMESTAMP), MAX(VALUE), MIN(TIMESTAMP), MIN(VALUE), round((MAX(VALUE)-MIN(VALUE)), 2) AS Diff, READING FROM history WHERE DEVICE = @device AND READING = @reading AND TIMESTAMP >= @begin_time and TIMESTAMP <= §timestamp_end§ GROUP BY DATE(`timestamp`) LIMIT 40;" ;
   FUUID      6538d028-f33f-d79e-f435-eac4a131acf4e2ac
   NAME       Dayheiz
   NOTIFYDEV  heizeinl
   NR         600269
   NTFY_ORDER 50-Dayheiz
   REGEXP     heizeinl
   STATE      2023-10-25 17:50:59
   TRIGGERTIME 1698249059.45438
   TYPE       notify
   eventCount 9
   Helper:
     DBLOG:
       state:
         logdb:
           TIME       1698249022.83122
           VALUE      active
     2023-10-25 17:50:22   state           active
     2023-10-25 17:50:59   triggeredByDev  heizeinl
     2023-10-25 17:50:59   triggeredByEvent einlesen
   hmccu:
   room       ebus
Hierbei kommt es dann zu folgendem Fehler:
DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'AND READING = AND TIMESTAMP >= and TIMESTAMP <= '2023-10-26 23:59:59' GROUP BY D' at line 1 at ./FHEM/93_DbRep.pm line 11676.
2023-10-26 15:10
Ich habe schon mehrere Versuche gemacht, mit SET Variablen und ohne (setzen sqlCmdVars) ohne Erfolg.
Was mach ich falsch?
Gruß Ulrich
DS_Starter
#1
Die Variablen @i, @begin_time etc. sind hier SQL-Variablen, kein Perl.
Du wirst sie im Statement unterbringen und vermutlich die @ escapen müssen.
Versuche es mal so:
DEF        heizeinl {
  fhem "set myrepgas sqlCmd SET \@i:=1, \@begin_time=CURDATE()- INTERVAL 13 DAY, \@device='CUL_EM_9', \@reading='total'; SELECT MAX(TIMESTAMP), MAX(VALUE), MIN(TIMESTAMP), MIN(VALUE), round((MAX(VALUE)-MIN(VALUE)), 2) AS Diff, READING FROM history WHERE DEVICE = \@device AND READING = \@reading AND TIMESTAMP >= \@begin_time and TIMESTAMP <= §timestamp_end§ GROUP BY DATE(`timestamp`) LIMIT 40;" ;
UvG
Leider funktioniert die Lösung so nicht:
errortext DBD::mysql::st execute failed: Query was empty at ./FHEM/93_DbRep.pm line 11676.     2023-10-26 18:15:31
sqlCmd  SET @i:=1, @begin_time=CURDATE()- INTERVAL 13 DAY, @device='CUL_EM_9', @reading='total';
Ich habe aber eine Lösung gefunden.
Wenn ich die Variablen unter sqlcmdVars eintrage gehts.
Ulrich
DS_Starter
#3
Ja, so gehts auch.
Muß aber auch in dem Aufruf funktionieren. Kannst ja noch ein bisschen probieren, z.B. so:
DEF        heizeinl {
  fhem qw(set myrepgas sqlCmd set \@i:=1; set \@begin_time=CURDATE()- INTERVAL 13 DAY; set \@device="CUL_EM_9"; set \@reading="total"; SELECT MAX(TIMESTAMP), MAX(VALUE), MIN(TIMESTAMP), MIN(VALUE), round((MAX(VALUE)-MIN(VALUE)), 2) AS Diff, READING FROM history WHERE DEVICE = \@device AND READING = \@reading AND TIMESTAMP >= \@begin_time and TIMESTAMP <= §timestamp_end§ GROUP BY DATE(`timestamp`) LIMIT 40;)
UvG
Der Aufruf läuft fehlerfrei durch bringt aber nur
SqlResult {"1":"MAX(TIMESTAMP)|MAX(VALUE)|MIN(TIMESTAMP)|MIN(VALUE)|DIFF|READING"}
Wenn ich die sqlCmdVar setze dann funktioniert es.
Ulrich
DS_Starter
Es hat mir keine Ruhe gelassen und habe das Statement bei mir mit einem at Device probiert.
Es funktioniert einwandfrei mit:
+*01:00:00 set Rep.CPU sqlCmd set @i:=1, @begin_time=CURDATE()-INTERVAL 13 DAY, @device="SMA_Energymeter", @reading="Einspeisung_Wirkleistung_Zaehler";; SELECT MAX(TIMESTAMP), MAX(VALUE), MIN(TIMESTAMP), MIN(VALUE), round((MAX(VALUE)-MIN(VALUE)), 2) AS Diff, READING FROM history WHERE DEVICE = @device AND READING = @reading AND TIMESTAMP >= @begin_time and TIMESTAMP <= §timestamp_end§ GROUP BY DATE(`timestamp`) LIMIT 40;
Man kann ja ganz einfach das "set" als FHEM Kommando ausführen und braucht das Konstrukt "fhem ("")" nicht.
Außerdem muß man ";" als ";;" escapen.
Bei deinem notify sollte es so klappen:
heizeinl set myrepgas sqlCmd set @i:=1, @begin_time=CURDATE()- INTERVAL 13 DAY, set @device="CUL_EM_9", @reading="total";; SELECT MAX(TIMESTAMP), MAX(VALUE), MIN(TIMESTAMP), MIN(VALUE), round((MAX(VALUE)-MIN(VALUE)), 2) AS Diff, READING FROM history WHERE DEVICE = @device AND READING = @reading AND TIMESTAMP >= @begin_time and TIMESTAMP <= §timestamp_end§ GROUP BY DATE(`timestamp`) LIMIT 40;
UvG
Ja so scheint es zu gehen.
Einen Fehler habe ich noch entdeckt
set muß entfernt werden
vielen Dank so komm ich weiter
Ulrich
DS_Starter
Ja, das hatte ich noch vergessen zu entfernen.
Na dann viel Erfolg.
