Assigning a value to a dummy device
Begonnen von mgmino, 19 Dezember 2023, 04:01:48
mgmino
Why doesn't the following work as expected?
define count dummy
set count 1
set count {Value("count") +1}
The following works as expected but is less clear.
{ fhem "set count " .(Value("count") +1)}
Is there a better way to implement a counter?
binford6000
help set
has some examples for the set command like: {(perlExpression)} with the result of perlExpression.
Please note the round brackets around the PERL-code:
set count {(Value("count") +1)}
Cheers,
Sebastian
mgmino
Thank you for the prompt reply -- it works great. I scanned the help three times before I saw the documentation -- need better glasses  8)
