(gelöst) nach Update keine Verbindung zu Repeater 450E
Begonnen von Nobbynews, 19 Januar 2024, 11:09:28
Nobbynews
ich habe heute ein Update des Moduls durchgeführt.
Danach steht im state:
Web connection could nt be established
Im Log steht folgende Warnung:
2024.01.19 11:01:44 3: [FritzKeller | 0000 | none | Set.2064] - BASIC:set FritzKeller update
2024.01.19 11:01:44 1: PERL WARNING: Use of uninitialized value $avmModel in pattern match (m//) at ./FHEM/72_FRITZBOX.pm line 8717.
2024.01.19 11:01:44 1: stacktrace:
2024.01.19 11:01:44 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8717)
2024.01.19 11:01:44 1:     main::FRITZBOX_open_Web_Connection  called by ./FHEM/72_FRITZBOX.pm (8753)
2024.01.19 11:01:44 1:     main::FRITZBOX_call_Lua_Query       called by ./FHEM/72_FRITZBOX.pm (2825)
2024.01.19 11:01:44 1:     main::FRITZBOX_Readout_Run_Web      called by FHEM/Blocking.pm (194)
2024.01.19 11:01:44 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2024.01.19 11:01:44 1:     main::BlockingCall                  called by ./FHEM/72_FRITZBOX.pm (2655)
2024.01.19 11:01:44 1:     main::FRITZBOX_Readout_Start        called by ./FHEM/72_FRITZBOX.pm (2066)
2024.01.19 11:01:44 1:     main::FRITZBOX_Set                  called by fhem.pl (3980)
2024.01.19 11:01:44 1:     main::CallFn                        called by fhem.pl (1970)
2024.01.19 11:01:44 1:     main::DoSet                         called by fhem.pl (2002)
2024.01.19 11:01:44 1:     main::CommandSet                    called by fhem.pl (1282)
2024.01.19 11:01:44 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2861)
2024.01.19 11:01:44 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (1025)
2024.01.19 11:01:44 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2024.01.19 11:01:44 1:     main::FW_Read                       called by fhem.pl (3985)
2024.01.19 11:01:44 1:     main::CallFn                        called by fhem.pl (786)
2024.01.19 11:01:45 2: [FritzKeller | 0000 | none | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.19 11:01:45 2: [FritzKeller | 0000 | none | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
Hier noch das list vom Repeater:
define FritzKeller FRITZBOX 192.168.2.164
attr FritzKeller userattr FritzBoxen FritzBoxen_map structexclude
attr FritzKeller boxUser fhem
#   APICHECKED 1
#   APICHECK_RET_CODES Ok
#   CFGFN
#   DEBUGLOG   OFF
#   DEF        192.168.2.164
#   FUUID      65aa4797-f33f-8873-7a6a-eb59ff35b449fb01
#   HOST       192.168.2.164
#   INTERVAL   300
#   LUADATA    -1
#   LUAQUERY   -1
#   NAME       FritzKeller
#   NR         2346
#   NTFY_ORDER 50-FritzKeller
#   SID_RENEW_CNT 0
#   SID_RENEW_ERR_CNT 2
#   STATE      Web connection could not be established
#   TIMEOUT    55
#   TR064      -1
#   TYPE       FRITZBOX
#   UPNP       -1
#   VERSION    07.57.02
#   _BETA      0
#   eventCount 4
#   READINGS:
#     2024-01-19 11:01:46   retStat_lastReadout Web connection could not be established
#     2024-01-19 11:01:46   state           Web connection could not be established
#   fhem:
#     LOCAL      0
#     definedHost 192.168.2.164
#     is_double_wlan -1
#     sidErrCount 3
#     sidNewCount 0
#     sidTime    0
#   helper:
#     FhemLog3Std 0
#     TimerCmd   FritzKeller.Cmd
#     TimerReadout FritzKeller.Readout
#     debugLog   FritzKeller_debugLog
#     logDebug
setstate FritzKeller Web connection could not be established
setstate FritzKeller 2024-01-19 11:01:46 retStat_lastReadout Web connection could not be established
setstate FritzKeller 2024-01-19 11:01:46 state Web connection could not be established
Das device habe ich bereits gelöscht und neu angelegt.
Box-User und Passwort habe ich auch neu angelegt.
Noch weitere Möglichkeiten von meiner Seite?
Norbert
JoWiemann
#1
Hallo Norbert,
welche FritzBox und welches Fritz!OS hast Du im Einsatz?
Grüße Jörg
PS: Hast Du Fhem neu gestartet? Und, bitte ein Log mit verbose 5 im FritzBox Device.
Jörg Wiemann
Nobbynews
#2
Hallo Joerg,
Fritzbox ist eine 7590 mit der Firmware 7.57. Die Fritzbox hat aber keine Probleme.
Der Repeater ist halt ein alter 450E mit der firmware 7.15.
Bin jetzt erst mal wieder auf die Version
Version   0.282260
Release Date   2023-11-29
des Moduls zurückgewechselt. Läuft damit.
Logfile mit verbose 5 werde ich spätestens am WE erstellen.
Danke für die schnelle Rückmeldung.
Norbert
Edit:
shutdown restart habe ich nach dem update gemacht
JoWiemann
Hallo Norbert,
dann schick mir doch bitte schonmal eine List vom Repeater von der funktionierenden Modul Version. Vielleicht kann ich da schon etwas sehen.
Grüße Jörg
Jörg Wiemann
Nobbynews
#4
Zitat von: JoWiemann am 19 Januar 2024, 14:12:26dann schick mir doch bitte schonmal eine List vom Repeater von der funktionierenden Modul Version.
attr FritzKeller verbose 5
#   APICHECKED 1
#   DEBUGLOG   <html><a href="/fhem/FileLog_logWrapper&amp;dev=FritzKeller_debugLog&amp;type=text&amp;file=FritzKeller_debugLog-2024-01.dlog">DEBUG Log kann hier eingesehen werden</a></html>
#   DEF        192.168.2.164
#   FVERSION   72_FRITZBOX.pm:0.283840/2024-01-15
#   INTERVAL   300
#   LUADATA    -1
#   LUAQUERY   -1
#   NAME       FritzKeller
#   NR         1158
#   SECPORT    49443
#   SID_RENEW_CNT 0
#   STATE      WLAN: on gWLAN: on
#   TIMEOUT    55
#   TR064      1
#   TYPE       FRITZBOX
#   UPNP       non-emu
#   VERSION    07.57.02
#   _BETA      0
#   eventCount 14
#   READINGS:
#     2024-01-19 14:13:44   box_cpuTemp     0
#     2024-01-19 14:13:44   box_fwVersion   128.07.15
#     2024-01-19 14:13:44   box_guestWlan   on
#     2024-01-19 14:13:44   box_guestWlanCount 0
#     2024-01-19 14:13:44   box_guestWlanRemain -1
#     2024-01-19 14:13:44   box_macFilter_active off
#     2024-01-19 14:13:44   box_powerRate   73
#     2024-01-19 14:13:44   box_tr064       on
#     2024-01-19 14:13:44   box_tr069       off
#     2024-01-19 14:13:44   box_upnp        non-emu
#     2024-01-19 14:13:44   box_upnp_control_activated non-emu
#     2024-01-19 14:13:44   box_uptime      11006760 sec = 127T 09:26:00
#     2024-01-19 14:13:44   box_wlan_2.4GHz on
#     2024-01-19 14:13:44   box_wlan_5GHz   off
#     2024-01-19 14:13:44   box_wlan_Count  3
#     2024-01-19 14:13:44   mac_00_11_05_FD_40_BA PC-192-168-2-199 [landevice9218]
#     2024-01-19 14:13:44   mac_30_F9_ED_8E_29_B5 PC-192-168-2-131 [landevice9262]
#     2024-01-19 14:13:44   mac_3C_61_05_EF_63_1B PC-192-168-2-243 [landevice9233]
#     2024-01-19 14:13:44   mac_3E_10_D5_96_7D_D0 PC-192-168-2-163 [landevice9232]
#     2024-01-19 14:13:44   mac_3E_10_D5_98_E2_1F PC-192-168-2-162 [landevice9228]
#     2024-01-19 14:13:44   mac_40_91_51_44_47_D3 PC-192-168-2-218 [landevice9219]
#     2024-01-19 14:13:44   mac_48_55_19_03_59_E3 PC-192-168-2-246 [landevice9231]
#     2024-01-19 14:13:44   mac_48_55_19_18_57_76 PC-192-168-2-51 [landevice9256]
#     2024-01-19 14:13:44   mac_50_02_91_4E_74_83 PC-192-168-2-224 [landevice9206] (WLAN: 53 / 53 Mbit/s, RSSI: -57)
#     2024-01-19 14:13:44   mac_5C_49_79_C9_6C_BE Repeater-Keller [landevice9217]
#     2024-01-19 14:13:44   mac_60_6D_3C_19_C9_90 PC-192-168-2-80 [landevice9224]
#     2024-01-19 14:13:44   mac_68_D7_9A_13_E7_3D PC-192-168-2-78 [landevice9294]
#     2024-01-19 14:13:44   mac_74_42_7F_33_5D_31 PC-192-168-2-1 [landevice9163] (208 Mbit/s)
#     2024-01-19 14:13:44   mac_80_7D_3A_02_14_45 PC-192-168-2-236 [landevice9214] (WLAN: 72 / 49 Mbit/s, RSSI: -61)
#     2024-01-19 14:13:44   mac_98_CD_AC_2D_B7_87 PC-192-168-2-229 [landevice9238]
#     2024-01-19 14:13:44   mac_A4_E5_7C_02_AE_70 PC-192-168-2-219 [landevice9237]
#     2024-01-19 14:13:44   mac_B6_F2_08_84_DC_F5 PC-192-168-2-160 [landevice9236]
#     2024-01-19 14:13:44   mac_B8_27_EB_5E_3A_B0 PC-192-168-2-182 [landevice9229]
#     2024-01-19 14:13:44   mac_B8_27_EB_77_F5_16 PC-192-168-2-198 [landevice9235]
#     2024-01-19 14:13:44   mac_B8_27_EB_D8_F8_A9 PC-192-168-2-207 [landevice9204] (WLAN: 71 / 66 Mbit/s, RSSI: -60)
#     2024-01-19 14:13:44   mac_BC_FF_4D_5B_41_E8 PC-192-168-2-247 [landevice9240]
#     2024-01-19 14:13:44   mac_C2_39_6F_7F_D2_58 PC-192-168-2-161 [landevice9222]
#     2024-01-19 14:13:44   mac_C4_5B_BE_54_9D_B7 PC-192-168-2-91 [landevice9221]
#     2024-01-19 14:13:44   mac_C4_5B_BE_54_DB_16 PC-192-168-2-50 [landevice9230]
#     2024-01-19 14:13:44   mac_DC_A6_32_7C_DF_92 PC-192-168-2-250 [landevice9225]
#     2024-01-19 14:13:44   mac_E8_68_E7_C5_57_1B PC-192-168-2-238 [landevice9239]
#     2024-01-19 14:13:44   mac_E8_68_E7_C5_78_02 PC-192-168-2-241 [landevice9234]
#     2024-01-19 14:13:44   mac_E8_DB_84_D3_0D_FD PC-192-168-2-239 [landevice9227]
#     2024-01-19 14:13:44   mac_E8_DB_84_DC_CE_2B PC-192-168-2-71 [landevice9226]
#     2024-01-19 14:13:44   mac_E8_DB_84_DD_64_6A PC-192-168-2-75 [landevice9223]
#     2024-01-19 14:13:44   retStat_lastReadout 505 values captured in 3.84 s
#     2024-01-19 14:13:44   state           WLAN: on gWLAN: on
#   fhem:
#     LOCAL      0
#     is_double_wlan 0
#     radioCount 0
#     sid        77a5bd3802b67c71
#     sidErrCount 3
#     sidNewCount 0
#     sidTime    1705670023.93864
#     landevice:
#                  PC-F6-7C-E8-DF-94-01
#       00_11_05_FD_40_BA landevice9218
#       192.168.2.1 PC-192-168-2-1
#       192.168.2.10 PC-192-168-2-10
#       192.168.2.12 PC-192-168-2-12
#       192.168.2.122 PC-192-168-2-122
#       192.168.2.125 PC-192-168-2-125
#       192.168.2.13 PC-192-168-2-13
#       192.168.2.130 PC-192-168-2-130
#       192.168.2.131 PC-192-168-2-131
#       192.168.2.14 PC-192-168-2-14
#       192.168.2.15 PC-192-168-2-15
#       192.168.2.160 PC-192-168-2-160
#       192.168.2.161 PC-192-168-2-161
#       192.168.2.162 PC-192-168-2-162
#       192.168.2.163 PC-192-168-2-163
#       192.168.2.164 Repeater-Keller
#       192.168.2.17 PC-192-168-2-17
#       192.168.2.18 PC-192-168-2-18
#       192.168.2.181 PC-192-168-2-181
#       192.168.2.182 PC-192-168-2-182
#       192.168.2.190 PC-192-168-2-190
#       192.168.2.195 PC-192-168-2-195
#       192.168.2.198 PC-192-168-2-198
#       192.168.2.199 PC-192-168-2-199
#       192.168.2.205 PC-192-168-2-205
#       192.168.2.206 PC-192-168-2-206
#       192.168.2.207 PC-192-168-2-207
#       192.168.2.218 PC-192-168-2-218
#       192.168.2.219 PC-192-168-2-219
#       192.168.2.220 PC-192-168-2-220
#       192.168.2.221 PC-192-168-2-221
#       192.168.2.222 PC-192-168-2-222
#       192.168.2.223 PC-192-168-2-223
#       192.168.2.224 PC-192-168-2-224
#       192.168.2.225 PC-192-168-2-225
#       192.168.2.226 PC-192-168-2-226
#       192.168.2.227 PC-192-168-2-227
#       192.168.2.228 PC-192-168-2-228
#       192.168.2.229 PC-192-168-2-229
#       192.168.2.230 PC-192-168-2-230
#       192.168.2.231 PC-192-168-2-231
#       192.168.2.232 PC-192-168-2-232
#       192.168.2.233 PC-192-168-2-233
#       192.168.2.234 PC-192-168-2-234
#       192.168.2.235 PC-192-168-2-235
#       192.168.2.236 PC-192-168-2-236
#       192.168.2.237 PC-192-168-2-237
#       192.168.2.238 PC-192-168-2-238
#       192.168.2.239 PC-192-168-2-239
#       192.168.2.240 PC-192-168-2-240
#       192.168.2.241 PC-192-168-2-241
#       192.168.2.242 PC-192-168-2-242
#       192.168.2.243 PC-192-168-2-243
#       192.168.2.244 PC-192-168-2-244
#       192.168.2.245 PC-192-168-2-245
#       192.168.2.246 PC-192-168-2-246
#       192.168.2.247 PC-192-168-2-247
#       192.168.2.248 PC-192-168-2-248
#       192.168.2.250 PC-192-168-2-250
#       192.168.2.40 PC-192-168-2-40
#       192.168.2.41 PC-192-168-2-41
#       192.168.2.42 PC-192-168-2-42
#       192.168.2.44 PC-192-168-2-44
#       192.168.2.45 PC-192-168-2-45
#       192.168.2.46 PC-192-168-2-46
#       192.168.2.47 PC-192-168-2-47
#       192.168.2.48 PC-192-168-2-48
#       192.168.2.49 PC-192-168-2-49
#       192.168.2.50 PC-192-168-2-50
#       192.168.2.51 PC-192-168-2-51
#       192.168.2.52 PC-192-168-2-52
#       192.168.2.53 PC-192-168-2-53
#       192.168.2.54 PC-192-168-2-54
#       192.168.2.55 PC-192-168-2-55
#       192.168.2.56 PC-192-168-2-56
#       192.168.2.58 PC-192-168-2-58
#       192.168.2.59 PC-192-168-2-59
#       192.168.2.60 PC-192-168-2-60
#       192.168.2.62 PC-192-168-2-62
#       192.168.2.63 PC-192-168-2-63
#       192.168.2.65 PC-192-168-2-65
#       192.168.2.66 PC-192-168-2-66
#       192.168.2.67 PC-192-168-2-67
#       192.168.2.68 PC-192-168-2-68
#       192.168.2.69 PC-192-168-2-69
#       192.168.2.70 PC-192-168-2-70
#       192.168.2.71 PC-192-168-2-71
#       192.168.2.73 PC-192-168-2-73
#       192.168.2.75 PC-192-168-2-75
#       192.168.2.76 PC-192-168-2-76
#       192.168.2.77 PC-192-168-2-77
#       192.168.2.78 PC-192-168-2-78
#       192.168.2.79 PC-192-168-2-79
#       192.168.2.80 PC-192-168-2-80
#       192.168.2.81 PC-192-168-2-81
#       192.168.2.82 PC-192-168-2-82
#       192.168.2.83 PC-192-168-2-83
#       192.168.2.84 PC-192-168-2-84
#       192.168.2.85 PC-192-168-2-85
#       192.168.2.86 PC-192-168-2-86
#       192.168.2.89 PC-192-168-2-89
#       192.168.2.91 PC-192-168-2-91
#       192.168.2.93 PC-192-168-2-93
#       192.168.2.94 PC-192-168-2-94
#       192.168.2.95 PC-192-168-2-95
#       192.168.2.96 PC-192-168-2-96
#       192.168.2.97 PC-192-168-2-97
#       192.168.2.98 PC-192-168-2-98
#       192.168.2.99 PC-192-168-2-99
#       30_F9_ED_8E_29_B5 landevice9262
#       3C_61_05_EF_63_1B landevice9233
#       3E_10_D5_96_7D_D0 landevice9232
#       3E_10_D5_98_E2_1F landevice9228
#       40_91_51_44_47_D3 landevice9219
#       48_55_19_03_59_E3 landevice9231
#       48_55_19_18_57_76 landevice9256
#       50_02_91_4E_74_83 landevice9206
#       5C_49_79_C9_6C_BE landevice9217
#       60_6D_3C_19_C9_90 landevice9224
#       68_D7_9A_13_E7_3D landevice9294
#       74_42_7F_33_5D_31 landevice9163
#       80_7D_3A_02_14_45 landevice9214
#       98_CD_AC_2D_B7_87 landevice9238
#       A4_E5_7C_02_AE_70 landevice9237
#       B6_F2_08_84_DC_F5 landevice9236
#       B8_27_EB_5E_3A_B0 landevice9229
#       B8_27_EB_77_F5_16 landevice9235
#       B8_27_EB_D8_F8_A9 landevice9204
#       BC_FF_4D_5B_41_E8 landevice9240
#       C2_39_6F_7F_D2_58 landevice9222
#       C4_5B_BE_54_9D_B7 landevice9221
#       C4_5B_BE_54_DB_16 landevice9230
#       DC_A6_32_7C_DF_92 landevice9225
#       E8_68_E7_C5_57_1B landevice9239
#       E8_68_E7_C5_78_02 landevice9234
#       E8_DB_84_D3_0D_FD landevice9227
#       E8_DB_84_DC_CE_2B landevice9226
#       E8_DB_84_DD_64_6A landevice9223
#       landevice9163 PC-192-168-2-1
#       landevice9164 PC-192-168-2-67
#       landevice9165 PC-192-168-2-82
#       landevice9166 PC-192-168-2-73
#       landevice9167 PC-192-168-2-84
#       landevice9168 PC-192-168-2-94
#       landevice9169 PC-5E-FF-8B-D2-BC-29
#       landevice9170 PC-192-168-2-245
#       landevice9171 PC-192-168-2-70
#       landevice9172 PC-192-168-2-248
#       landevice9173 PC-192-168-2-244
#       landevice9174 PC-192-168-2-242
#       landevice9175 PC-192-168-2-59
#       landevice9176 PC-92-BE-B9-32-13-75
#       landevice9177 PC-192-168-2-40
#       landevice9178 PC-4E-43-38-7A-B8-3E
#       landevice9179 PC-192-168-2-47
#       landevice9180 PC-192-168-2-205
#       landevice9181 PC-0E-54-63-36-20-A9
#       landevice9182 PC-192-168-2-234
#       landevice9183 PC-2C-FD-AB-AC-0F-00
#       landevice9184 PC-B4-F7-A1-89-DF-A0
#       landevice9185 PC-192-168-2-235
#       landevice9186 PC-192-168-2-232
#       landevice9187 PC-192-168-2-233
#       landevice9188 PC-192-168-2-206
#       landevice9189 PC-192-168-2-79
#       landevice9190 PC-192-168-2-237
#       landevice9191 PC-62-D3-A0-E4-82-A3
#       landevice9192 PC-192-168-2-89
#       landevice9193 PC-F4-06-69-5A-AD-5C
#       landevice9194 PC-80-1F-02-6E-9B-69
#       landevice9195 PC-5A-10-D5-96-7D-D0
#       landevice9196 PC-5A-10-D5-96-7D-D1
#       landevice9197 PC-192-168-2-62
#       landevice9198 PC-192-168-2-230
#       landevice9199 PC-192-168-2-221
#       landevice9200 PC-192-168-2-231
#       landevice9201 PC-F6-7C-E8-DF-94-01
#       landevice9202 PC-192-168-2-93
#       landevice9203 PC-192-168-2-55
#       landevice9204 PC-192-168-2-207
#       landevice9205 PC-192-168-2-66
#       landevice9206 PC-192-168-2-224
#       landevice9207 PC-192-168-2-10
#       landevice9208 PC-192-168-2-240
#       landevice9209 PC-192-168-2-85
#       landevice9210 PC-192-168-2-68
#       landevice9211 PC-CC-21-19-59-C7-D6
#       landevice9212 PC-192-168-2-86
#       landevice9213 PC-192-168-2-228
#       landevice9214 PC-192-168-2-236
#       landevice9215 PC-192-168-2-60
#       landevice9216 PC-192-168-2-83
#       landevice9217 Repeater-Keller
#       landevice9218 PC-192-168-2-199
#       landevice9219 PC-192-168-2-218
#       landevice9220 PC-192-168-2-81
#       landevice9221 PC-192-168-2-91
#       landevice9222 PC-192-168-2-161
#       landevice9223 PC-192-168-2-75
#       landevice9224 PC-192-168-2-80
#       landevice9225 PC-192-168-2-250
#       landevice9226 PC-192-168-2-71
#       landevice9227 PC-192-168-2-239
#       landevice9228 PC-192-168-2-162
#       landevice9229 PC-192-168-2-182
#       landevice9230 PC-192-168-2-50
#       landevice9231 PC-192-168-2-246
#       landevice9232 PC-192-168-2-163
#       landevice9233 PC-192-168-2-243
#       landevice9234 PC-192-168-2-241
#       landevice9235 PC-192-168-2-198
#       landevice9236 PC-192-168-2-160
#       landevice9237 PC-192-168-2-219
#       landevice9238 PC-192-168-2-229
#       landevice9239 PC-192-168-2-238
#       landevice9240 PC-192-168-2-247
#       landevice9251 PC-192-168-2-96
#       landevice9252 PC-192-168-2-63
#       landevice9253 PC-192-168-2-46
#       landevice9256 PC-192-168-2-51
#       landevice9258 PC-192-168-2-58
#       landevice9260 PC-192-168-2-76
#       landevice9262 PC-192-168-2-131
#       landevice9264 PC-192-168-2-99
#       landevice9268 PC-192-168-2-95
#       landevice9272 PC-192-168-2-56
#       landevice9273 PC-192-168-2-125
#       landevice9274 PC-192-168-2-181
#       landevice9275 PC-192-168-2-190
#       landevice9279 PC-192-168-2-49
#       landevice9285 PC-192-168-2-69
#       landevice9294 PC-192-168-2-78
#       landevice9303 PC-192-168-2-222
#       landevice9334 PC-192-168-2-98
#       landevice9337 PC-192-168-2-54
#       landevice9342 PC-192-168-2-195
#       landevice9343 PC-192-168-2-227
#       landevice9344 PC-192-168-2-223
#       landevice9345 PC-192-168-2-226
#       landevice9346 PC-192-168-2-220
#       landevice9347 PC-192-168-2-225
#       landevice9348 PC-192-168-2-97
#       landevice9349 PC-192-168-2-77
#       landevice9350 PC-192-168-2-41
#       landevice9351 PC-192-168-2-48
#       landevice9352 PC-192-168-2-122
#       landevice9353 PC-192-168-2-53
#       landevice9355 PC-192-168-2-42
#       landevice9356 PC-192-168-2-45
#       landevice9371 PC-192-168-2-47
#       landevice9373 PC-192-168-2-130
#       landevice9374 PC-192-168-2-44
#       landevice9375 PC-192-168-2-52
#       landevice9376 PC-192-168-2-65
#       landevice9379 PC-192-168-2-12
#       landevice9380 PC-192-168-2-13
#       landevice9381 PC-192-168-2-14
#       landevice9382 PC-192-168-2-15
#       landevice9383 PC-192-168-2-17
#       landevice9384 PC-192-168-2-18
#     wlanDevice:
#       0C_EC_8D_38_BF_98:
#         rssi       0
#         speed      0
#         speed_rx   0
#       0E_54_63_36_20_A9:
#         rssi       0
#         speed      0
#         speed_rx   0
#       2C_FD_AB_AC_0F_00:
#         rssi       0
#         speed      0
#         speed_rx   0
#       2C_FD_AB_D7_EF_44:
#         rssi       0
#         speed      0
#         speed_rx   0
#       38_E3_9F_1C_DD_39:
#         rssi       0
#         speed      0
#         speed_rx   0
#       3C_61_05_EF_37_0B:
#         rssi       0
#         speed      0
#         speed_rx   0
#       44_EF_BF_34_C0_63:
#         rssi       0
#         speed      0
#         speed_rx   0
#       4C_75_25_3A_1D_FF:
#         rssi       0
#         speed      0
#         speed_rx   0
#       4E_43_38_7A_B8_3E:
#         rssi       0
#         speed      0
#         speed_rx   0
#       50_02_91_4E_74_83:
#         rssi       -57
#         speed      53
#         speed_rx   53
#       58_7A_62_3B_8A_BB:
#         rssi       0
#         speed      0
#         speed_rx   0
#       5A_10_D5_96_7D_D0:
#         rssi       0
#         speed      0
#         speed_rx   0
#       5A_10_D5_96_7D_D1:
#         rssi       0
#         speed      0
#         speed_rx   0
#       5E_FF_8B_D2_BC_29:
#         rssi       0
#         speed      0
#         speed_rx   0
#       60_B7_6E_4E_34_07:
#         rssi       0
#         speed      0
#         speed_rx   0
#       62_D3_A0_E4_82_A3:
#         rssi       0
#         speed      0
#         speed_rx   0
#       68_39_43_BD_B2_EB:
#         rssi       0
#         speed      0
#         speed_rx   0
#       68_39_43_D8_4E_5C:
#         rssi       0
#         speed      0
#         speed_rx   0
#       68_39_43_F8_67_FE:
#         rssi       0
#         speed      0
#         speed_rx   0
#       68_39_43_FB_3C_C1:
#         rssi       0
#         speed      0
#         speed_rx   0
#       70_BC_10_70_3E_EA:
#         rssi       0
#         speed      0
#         speed_rx   0
#       74_42_7F_33_5D_34:
#         rssi       -58
#         speed      211
#         speed_rx   1
#       74_74_46_B0_CD_88:
#         rssi       0
#         speed      0
#         speed_rx   0
#       7C_9E_BD_61_12_DC:
#         rssi       0
#         speed      0
#         speed_rx   0
#       80_1F_02_6E_9B_69:
#         rssi       0
#         speed      0
#         speed_rx   0
#       80_7D_3A_02_14_45:
#         rssi       -61
#         speed      72
#         speed_rx   49
#       84_F3_EB_DB_25_D6:
#         rssi       0
#         speed      0
#         speed_rx   0
#       84_F3_EB_DB_43_31:
#         rssi       0
#         speed      0
#         speed_rx   0
#       84_F3_EB_DB_44_62:
#         rssi       0
#         speed      0
#         speed_rx   0
#       8C_AA_B5_C7_22_EB:
#         rssi       0
#         speed      0
#         speed_rx   0
#       92_BE_B9_32_13_75:
#         rssi       0
#         speed      0
#         speed_rx   0
#       94_45_60_3C_16_9F:
#         rssi       0
#         speed      0
#         speed_rx   0
#       94_53_30_25_1F_EF:
#         rssi       0
#         speed      0
#         speed_rx   0
#       9C_5F_B0_F1_41_C6:
#         rssi       0
#         speed      0
#         speed_rx   0
#       A4_B1_C1_9D_2B_73:
#         rssi       0
#         speed      0
#         speed_rx   0
#       A8_76_50_57_1B_A8:
#         rssi       0
#         speed      0
#         speed_rx   0
#       B4_0B_1D_5C_F0_E7:
#         rssi       0
#         speed      0
#         speed_rx   0
#       B4_E6_2D_79_E9_D8:
#         rssi       0
#         speed      0
#         speed_rx   0
#       B4_E6_2D_7A_E7_C8:
#         rssi       0
#         speed      0
#         speed_rx   0
#       B4_F7_A1_89_DF_A0:
#         rssi       0
#         speed      0
#         speed_rx   0
#       B8_27_EB_80_06_3E:
#         rssi       0
#         speed      0
#         speed_rx   0
#       B8_27_EB_8B_A2_2B:
#         rssi       0
#         speed      0
#         speed_rx   0
#       B8_27_EB_D8_F8_A9:
#         rssi       -60
#         speed      71
#         speed_rx   66
#       C4_5B_BE_57_6A_B9:
#         rssi       0
#         speed      0
#         speed_rx   0
#       C4_5B_BE_E4_22_27:
#         rssi       0
#         speed      0
#         speed_rx   0
#       C4_5B_BE_E4_43_E9:
#         rssi       0
#         speed      0
#         speed_rx   0
#       CC_21_19_59_C7_D6:
#         rssi       0
#         speed      0
#         speed_rx   0
#       CC_F9_E4_BC_DD_29:
#         rssi       0
#         speed      0
#         speed_rx   0
#       D8_BF_C0_1A_89_5A:
#         rssi       0
#         speed      0
#         speed_rx   0
#       D8_BF_C0_51_CB_C0:
#         rssi       0
#         speed      0
#         speed_rx   0
#       DE_3B_8A_E8_9B_06:
#         rssi       0
#         speed      0
#         speed_rx   0
#       E4_A8_DF_03_7D_E8:
#         rssi       0
#         speed      0
#         speed_rx   0
#       E4_A8_DF_04_C2_41:
#         rssi       0
#         speed      0
#         speed_rx   0
#       E8_DB_84_DD_64_97:
#         rssi       0
#         speed      0
#         speed_rx   0
#       EC_08_E5_32_08_4F:
#         rssi       0
#         speed      0
#         speed_rx   0
#       EC_FA_BC_2F_DA_3B:
#         rssi       0
#         speed      0
#         speed_rx   0
#       F4_06_69_5A_AD_5C:
#         rssi       0
#         speed      0
#         speed_rx   0
#       F4_CF_A2_6C_C2_AC:
#         rssi       0
#         speed      0
#         speed_rx   0
#       F6_7C_E8_DF_94_01:
#         rssi       0
#         speed      0
#         speed_rx   0
#   helper:
#     FhemLog3Std 0
#     logDebug   1
setstate FritzKeller WLAN: on gWLAN: on
setstate FritzKeller 2024-01-19 14:13:44 box_cpuTemp 0
setstate FritzKeller 2024-01-19 14:13:44 box_fwVersion 128.07.15
setstate FritzKeller 2024-01-19 14:13:44 box_guestWlan on
setstate FritzKeller 2024-01-19 14:13:44 box_guestWlanCount 0
setstate FritzKeller 2024-01-19 14:13:44 box_guestWlanRemain -1
setstate FritzKeller 2024-01-19 14:13:44 box_macFilter_active off
setstate FritzKeller 2024-01-19 14:13:44 box_powerRate 73
setstate FritzKeller 2024-01-19 14:13:44 box_tr064 on
setstate FritzKeller 2024-01-19 14:13:44 box_tr069 off
setstate FritzKeller 2024-01-19 14:13:44 box_upnp non-emu
setstate FritzKeller 2024-01-19 14:13:44 box_upnp_control_activated non-emu
setstate FritzKeller 2024-01-19 14:13:44 box_uptime 11006760 sec = 127T 09:26:00
setstate FritzKeller 2024-01-19 14:13:44 box_wlan_2.4GHz on
setstate FritzKeller 2024-01-19 14:13:44 box_wlan_5GHz off
setstate FritzKeller 2024-01-19 14:13:44 box_wlan_Count 3
setstate FritzKeller 2024-01-19 14:13:44 mac_00_11_05_FD_40_BA PC-192-168-2-199 [landevice9218]
setstate FritzKeller 2024-01-19 14:13:44 mac_30_F9_ED_8E_29_B5 PC-192-168-2-131 [landevice9262]
setstate FritzKeller 2024-01-19 14:13:44 mac_3C_61_05_EF_63_1B PC-192-168-2-243 [landevice9233]
setstate FritzKeller 2024-01-19 14:13:44 mac_3E_10_D5_96_7D_D0 PC-192-168-2-163 [landevice9232]
setstate FritzKeller 2024-01-19 14:13:44 mac_3E_10_D5_98_E2_1F PC-192-168-2-162 [landevice9228]
setstate FritzKeller 2024-01-19 14:13:44 mac_40_91_51_44_47_D3 PC-192-168-2-218 [landevice9219]
setstate FritzKeller 2024-01-19 14:13:44 mac_48_55_19_03_59_E3 PC-192-168-2-246 [landevice9231]
setstate FritzKeller 2024-01-19 14:13:44 mac_48_55_19_18_57_76 PC-192-168-2-51 [landevice9256]
setstate FritzKeller 2024-01-19 14:13:44 mac_50_02_91_4E_74_83 PC-192-168-2-224 [landevice9206] (WLAN: 53 / 53 Mbit/s, RSSI: -57)
setstate FritzKeller 2024-01-19 14:13:44 mac_5C_49_79_C9_6C_BE Repeater-Keller [landevice9217]
setstate FritzKeller 2024-01-19 14:13:44 mac_60_6D_3C_19_C9_90 PC-192-168-2-80 [landevice9224]
setstate FritzKeller 2024-01-19 14:13:44 mac_68_D7_9A_13_E7_3D PC-192-168-2-78 [landevice9294]
setstate FritzKeller 2024-01-19 14:13:44 mac_74_42_7F_33_5D_31 PC-192-168-2-1 [landevice9163] (208 Mbit/s)
setstate FritzKeller 2024-01-19 14:13:44 mac_80_7D_3A_02_14_45 PC-192-168-2-236 [landevice9214] (WLAN: 72 / 49 Mbit/s, RSSI: -61)
setstate FritzKeller 2024-01-19 14:13:44 mac_98_CD_AC_2D_B7_87 PC-192-168-2-229 [landevice9238]
setstate FritzKeller 2024-01-19 14:13:44 mac_A4_E5_7C_02_AE_70 PC-192-168-2-219 [landevice9237]
setstate FritzKeller 2024-01-19 14:13:44 mac_B6_F2_08_84_DC_F5 PC-192-168-2-160 [landevice9236]
setstate FritzKeller 2024-01-19 14:13:44 mac_B8_27_EB_5E_3A_B0 PC-192-168-2-182 [landevice9229]
setstate FritzKeller 2024-01-19 14:13:44 mac_B8_27_EB_77_F5_16 PC-192-168-2-198 [landevice9235]
setstate FritzKeller 2024-01-19 14:13:44 mac_B8_27_EB_D8_F8_A9 PC-192-168-2-207 [landevice9204] (WLAN: 71 / 66 Mbit/s, RSSI: -60)
setstate FritzKeller 2024-01-19 14:13:44 mac_BC_FF_4D_5B_41_E8 PC-192-168-2-247 [landevice9240]
setstate FritzKeller 2024-01-19 14:13:44 mac_C2_39_6F_7F_D2_58 PC-192-168-2-161 [landevice9222]
setstate FritzKeller 2024-01-19 14:13:44 mac_C4_5B_BE_54_9D_B7 PC-192-168-2-91 [landevice9221]
setstate FritzKeller 2024-01-19 14:13:44 mac_C4_5B_BE_54_DB_16 PC-192-168-2-50 [landevice9230]
setstate FritzKeller 2024-01-19 14:13:44 mac_DC_A6_32_7C_DF_92 PC-192-168-2-250 [landevice9225]
setstate FritzKeller 2024-01-19 14:13:44 mac_E8_68_E7_C5_57_1B PC-192-168-2-238 [landevice9239]
setstate FritzKeller 2024-01-19 14:13:44 mac_E8_68_E7_C5_78_02 PC-192-168-2-241 [landevice9234]
setstate FritzKeller 2024-01-19 14:13:44 mac_E8_DB_84_D3_0D_FD PC-192-168-2-239 [landevice9227]
setstate FritzKeller 2024-01-19 14:13:44 mac_E8_DB_84_DC_CE_2B PC-192-168-2-71 [landevice9226]
setstate FritzKeller 2024-01-19 14:13:44 mac_E8_DB_84_DD_64_6A PC-192-168-2-75 [landevice9223]
setstate FritzKeller 2024-01-19 14:13:44 retStat_lastReadout 505 values captured in 3.84 s
setstate FritzKeller 2024-01-19 14:13:44 state WLAN: on gWLAN: on
Kann es sein, dass im Modul noch ein anderer Fehler steckt?
In global habe ich verbose=0 gesetzt im im device FritzKeller verbose=5.
Es kommen dann aber keine Log-Einträge.
Mit verbose=5 in global kommen verdammt viele in diesem Fall unnnütze Einträge.
Denkfehler meinerseits?
Norbert
JoWiemann
#   APICHECKED 1
#   DEF        192.168.2.164
#   INTERVAL   300
#   LUADATA    -1
#   LUAQUERY   -1
#   NAME       FritzKeller
#   NR         1158
#   SECPORT    49443
#   SID_RENEW_CNT 0
#   TIMEOUT    55
#   TR064      1
#   TYPE       FRITZBOX
#   UPNP       non-emu
#   VERSION    07.57.02
#   _BETA      0
#   eventCount 14
#   READINGS:
#   fhem:
#     LOCAL      0
#     is_double_wlan 0
#     radioCount 0
#     sidErrCount 3
#     sidNewCount 0
#     landevice:
#     wlanDevice:
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -57
#         speed      53
#         speed_rx   53
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -58
#         speed      211
#         speed_rx   1
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -61
#         speed      72
#         speed_rx   49
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -60
#         speed      71
#         speed_rx   66
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#   helper:
#     FhemLog3Std 0
#     logDebug   1
Norbert
Hallo Norbert,
bei der Modulversion 07.57.02 werden bei verbose 5 die Log-Einträge in eine eigene Datei geschrieben. Im Fhem Web siehst im Device FritzKeller das INTERNAL DEBUGLOG bei dem ein Link zur Log-Datei hinterlegt ist. Damit möchte ich das bereitstellen von verbos 5 Logs vereinfachen und das Fhem Log schonen.
Grüße Jörg
Ein List mit der funktionierenden Modulversion wäre schon wichtig. Aktuell wird für Deinen Repeater kein MODEL ermittelt.
Grüße Jörg
Jörg Wiemann
Nobbynews
#6
Hallo Jörg,
ich habe jetzt etwas länger auf dem Tablet mit der Log-Datei gekämpft.
Siehe Anhang...
Das list vom funktionierenden Modul siehe Beitrag #4
Norbert
JoWiemann
#7
Hallo Norbert,
lösch bitte einmal das Attribut boxUser. Repeater benötigen das nicht und es scheint, dass das das Problem sein könnte. Könnte aber auch ein Fehldenker sein. Ich muss da nochmal durch den Source wandern. Wie gesagt, ein List mit der funktionieren Modulversion würde mir echt weiter helfen.
Grüße Jörg
Jörg Wiemann
Nobbynews
Zitat von: JoWiemann am 19 Januar 2024, 18:48:13ein List mit der funktionieren Modulversion würde mir echt weiter helfen.
#   APICHECKED 1
#   DEBUGLOG   OFF
#   DEF        192.168.2.164
#   INTERVAL   300
#   LUADATA    -1
#   LUAQUERY   -1
#   NAME       FritzKeller
#   NR         1158
#   SECPORT    49443
#   SID_RENEW_CNT 0
#   SID_RENEW_ERR_CNT 5
#   TIMEOUT    55
#   TR064      1
#   TYPE       FRITZBOX
#   UPNP       non-emu
#   VERSION    07.57.02
#   _BETA      0
#   eventCount 54
#   READINGS:
#     2024-01-19 19:04:38   box_cpuTemp     0
#     2024-01-19 19:04:38   box_fwVersion   128.07.15
#     2024-01-19 19:04:38   box_guestWlan   on
#     2024-01-19 19:04:38   box_guestWlanCount 0
#     2024-01-19 19:04:38   box_guestWlanRemain -1
#     2024-01-19 19:04:38   box_macFilter_active off
#     2024-01-19 19:04:38   box_powerRate   73
#     2024-01-19 19:04:38   box_tr064       on
#     2024-01-19 19:04:38   box_tr069       off
#     2024-01-19 19:04:38   box_upnp        non-emu
#     2024-01-19 19:04:38   box_upnp_control_activated non-emu
#     2024-01-19 19:04:38   box_uptime      11024220 sec = 127T 14:17:00
#     2024-01-19 19:04:38   box_wlan_2.4GHz on
#     2024-01-19 19:04:38   box_wlan_5GHz   off
#     2024-01-19 19:04:38   box_wlan_Count  4
#     2024-01-19 19:04:38   mac_00_11_05_FD_40_BA PC-192-168-2-199 [landevice9218]
#     2024-01-19 19:04:38   mac_30_F9_ED_8E_29_B5 PC-192-168-2-131 [landevice9262]
#     2024-01-19 19:04:38   mac_3C_2A_F4_03_AE_68 inactive
#     2024-01-19 19:04:38   mac_3C_61_05_EF_63_1B PC-192-168-2-243 [landevice9233]
#     2024-01-19 19:04:38   mac_3E_10_D5_96_7D_D0 PC-192-168-2-163 [landevice9232]
#     2024-01-19 19:04:38   mac_3E_10_D5_98_E2_1F PC-192-168-2-162 [landevice9228]
#     2024-01-19 19:04:38   mac_40_91_51_44_47_D3 PC-192-168-2-218 [landevice9219]
#     2024-01-19 19:04:38   mac_48_55_19_03_59_E3 PC-192-168-2-246 [landevice9231]
#     2024-01-19 19:04:38   mac_48_55_19_17_95_D6 inactive
#     2024-01-19 19:04:38   mac_50_02_91_4E_74_83 PC-192-168-2-224 [landevice9206] (WLAN: 54 / 53 Mbit/s, RSSI: -57)
#     2024-01-19 19:04:38   mac_5C_49_79_C9_6C_BE Repeater-Keller [landevice9217]
#     2024-01-19 19:04:38   mac_60_6D_3C_19_C9_90 PC-192-168-2-80 [landevice9224]
#     2024-01-19 19:04:38   mac_68_D7_9A_13_E7_3D PC-192-168-2-78 [landevice9294]
#     2024-01-19 19:04:38   mac_74_42_7F_33_5D_31 PC-192-168-2-1 [landevice9163] (216 Mbit/s)
#     2024-01-19 19:04:38   mac_7C_9E_BD_61_12_DC PC-192-168-2-85 [landevice9209] (WLAN: 46 / 24 Mbit/s, RSSI: -55)
#     2024-01-19 19:04:38   mac_80_7D_3A_02_14_45 PC-192-168-2-236 [landevice9214] (WLAN: 0 / 1 Mbit/s, RSSI: -59)
#     2024-01-19 19:04:38   mac_94_DB_56_98_7F_A9 PC-192-168-2-81 [landevice9220]
#     2024-01-19 19:04:38   mac_98_CD_AC_2D_B7_87 PC-192-168-2-229 [landevice9238]
#     2024-01-19 19:04:38   mac_A4_E5_7C_02_AE_70 PC-192-168-2-219 [landevice9237]
#     2024-01-19 19:04:38   mac_B6_F2_08_84_DC_F5 PC-192-168-2-160 [landevice9236]
#     2024-01-19 19:04:38   mac_B8_27_EB_5E_3A_B0 PC-192-168-2-182 [landevice9229]
#     2024-01-19 19:04:38   mac_B8_27_EB_77_F5_16 PC-192-168-2-198 [landevice9235]
#     2024-01-19 19:04:38   mac_B8_27_EB_D2_95_7F inactive
#     2024-01-19 19:04:38   mac_B8_27_EB_D8_F8_A9 PC-192-168-2-207 [landevice9204] (WLAN: 72 / 67 Mbit/s, RSSI: -60)
#     2024-01-19 19:04:38   mac_BC_FF_4D_5B_41_E8 PC-192-168-2-247 [landevice9240]
#     2024-01-19 19:04:38   mac_C2_39_6F_7F_D2_58 PC-192-168-2-161 [landevice9222]
#     2024-01-19 19:04:38   mac_C4_5B_BE_54_9D_B7 PC-192-168-2-91 [landevice9221]
#     2024-01-19 19:04:38   mac_C4_5B_BE_54_DB_16 PC-192-168-2-50 [landevice9230]
#     2024-01-19 19:04:38   mac_DC_A6_32_7C_DF_92 PC-192-168-2-250 [landevice9225]
#     2024-01-19 19:04:38   mac_E8_68_E7_C5_57_1B PC-192-168-2-238 [landevice9239]
#     2024-01-19 19:04:38   mac_E8_68_E7_C5_78_02 PC-192-168-2-241 [landevice9234]
#     2024-01-19 19:04:38   mac_E8_DB_84_D3_0D_FD PC-192-168-2-239 [landevice9227]
#     2024-01-19 19:04:38   mac_E8_DB_84_DC_CE_2B PC-192-168-2-71 [landevice9226]
#     2024-01-19 19:04:38   mac_E8_DB_84_DD_64_6A PC-192-168-2-75 [landevice9223]
#     2024-01-19 19:04:38   retStat_lastReadout 511 values captured in 3.31 s
#     2024-01-19 19:04:38   state           WLAN: on gWLAN: on
#   fhem:
#     LOCAL      0
#     is_double_wlan 0
#     radioCount 0
#     sid        de2bcaf6db633e2e
#     sidErrCount 5
#     sidNewCount 0
#     sidTime    1705687477.96422
#     landevice:
#       192.168.2.20 PC-192-168-2-20
#       2C_F4_32_78_1B_2F landevice9251
#       3C_2A_F4_03_AE_68 landevice9273
#       48_3F_DA_7E_E0_79 landevice9252
#       48_55_19_17_95_D6 landevice9253
#       4C_EB_D6_DE_DC_3B landevice9380
#       4C_EB_D6_DE_DF_1B landevice9384
#       68_39_43_FB_50_67 landevice9385
#       7C_9E_BD_61_12_DC landevice9209
#       94_DB_56_98_7F_A9 landevice9220
#       B8_27_EB_D2_95_7F landevice9342
#       landevice9385 PC-192-168-2-20
#     wlanDevice:
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -57
#         speed      54
#         speed_rx   53
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -59
#         speed      215
#         speed_rx   1
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -55
#         speed      46
#         speed_rx   24
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -59
#         speed      0
#         speed_rx   1
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -60
#         speed      72
#         speed_rx   67
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#   helper:
#     FhemLog3Std 0
#     logDebug   0
setstate FritzKeller 2024-01-19 19:04:38 box_cpuTemp 0
setstate FritzKeller 2024-01-19 19:04:38 box_fwVersion 128.07.15
setstate FritzKeller 2024-01-19 19:04:38 box_guestWlan on
setstate FritzKeller 2024-01-19 19:04:38 box_guestWlanCount 0
setstate FritzKeller 2024-01-19 19:04:38 box_guestWlanRemain -1
setstate FritzKeller 2024-01-19 19:04:38 box_macFilter_active off
setstate FritzKeller 2024-01-19 19:04:38 box_powerRate 73
setstate FritzKeller 2024-01-19 19:04:38 box_tr064 on
setstate FritzKeller 2024-01-19 19:04:38 box_tr069 off
setstate FritzKeller 2024-01-19 19:04:38 box_upnp non-emu
setstate FritzKeller 2024-01-19 19:04:38 box_upnp_control_activated non-emu
setstate FritzKeller 2024-01-19 19:04:38 box_uptime 11024220 sec = 127T 14:17:00
setstate FritzKeller 2024-01-19 19:04:38 box_wlan_2.4GHz on
setstate FritzKeller 2024-01-19 19:04:38 box_wlan_5GHz off
setstate FritzKeller 2024-01-19 19:04:38 box_wlan_Count 4
setstate FritzKeller 2024-01-19 19:04:38 mac_00_11_05_FD_40_BA PC-192-168-2-199 [landevice9218]
setstate FritzKeller 2024-01-19 19:04:38 mac_30_F9_ED_8E_29_B5 PC-192-168-2-131 [landevice9262]
setstate FritzKeller 2024-01-19 19:04:38 mac_3C_2A_F4_03_AE_68 inactive
setstate FritzKeller 2024-01-19 19:04:38 mac_3C_61_05_EF_63_1B PC-192-168-2-243 [landevice9233]
setstate FritzKeller 2024-01-19 19:04:38 mac_3E_10_D5_96_7D_D0 PC-192-168-2-163 [landevice9232]
setstate FritzKeller 2024-01-19 19:04:38 mac_3E_10_D5_98_E2_1F PC-192-168-2-162 [landevice9228]
setstate FritzKeller 2024-01-19 19:04:38 mac_40_91_51_44_47_D3 PC-192-168-2-218 [landevice9219]
setstate FritzKeller 2024-01-19 19:04:38 mac_48_55_19_03_59_E3 PC-192-168-2-246 [landevice9231]
setstate FritzKeller 2024-01-19 19:04:38 mac_48_55_19_17_95_D6 inactive
setstate FritzKeller 2024-01-19 19:04:38 mac_50_02_91_4E_74_83 PC-192-168-2-224 [landevice9206] (WLAN: 54 / 53 Mbit/s, RSSI: -57)
setstate FritzKeller 2024-01-19 19:04:38 mac_5C_49_79_C9_6C_BE Repeater-Keller [landevice9217]
setstate FritzKeller 2024-01-19 19:04:38 mac_60_6D_3C_19_C9_90 PC-192-168-2-80 [landevice9224]
setstate FritzKeller 2024-01-19 19:04:38 mac_68_D7_9A_13_E7_3D PC-192-168-2-78 [landevice9294]
setstate FritzKeller 2024-01-19 19:04:38 mac_74_42_7F_33_5D_31 PC-192-168-2-1 [landevice9163] (216 Mbit/s)
setstate FritzKeller 2024-01-19 19:04:38 mac_7C_9E_BD_61_12_DC PC-192-168-2-85 [landevice9209] (WLAN: 46 / 24 Mbit/s, RSSI: -55)
setstate FritzKeller 2024-01-19 19:04:38 mac_80_7D_3A_02_14_45 PC-192-168-2-236 [landevice9214] (WLAN: 0 / 1 Mbit/s, RSSI: -59)
setstate FritzKeller 2024-01-19 19:04:38 mac_94_DB_56_98_7F_A9 PC-192-168-2-81 [landevice9220]
setstate FritzKeller 2024-01-19 19:04:38 mac_98_CD_AC_2D_B7_87 PC-192-168-2-229 [landevice9238]
setstate FritzKeller 2024-01-19 19:04:38 mac_A4_E5_7C_02_AE_70 PC-192-168-2-219 [landevice9237]
setstate FritzKeller 2024-01-19 19:04:38 mac_B6_F2_08_84_DC_F5 PC-192-168-2-160 [landevice9236]
setstate FritzKeller 2024-01-19 19:04:38 mac_B8_27_EB_5E_3A_B0 PC-192-168-2-182 [landevice9229]
setstate FritzKeller 2024-01-19 19:04:38 mac_B8_27_EB_77_F5_16 PC-192-168-2-198 [landevice9235]
setstate FritzKeller 2024-01-19 19:04:38 mac_B8_27_EB_D2_95_7F inactive
setstate FritzKeller 2024-01-19 19:04:38 mac_B8_27_EB_D8_F8_A9 PC-192-168-2-207 [landevice9204] (WLAN: 72 / 67 Mbit/s, RSSI: -60)
setstate FritzKeller 2024-01-19 19:04:38 mac_BC_FF_4D_5B_41_E8 PC-192-168-2-247 [landevice9240]
setstate FritzKeller 2024-01-19 19:04:38 mac_C2_39_6F_7F_D2_58 PC-192-168-2-161 [landevice9222]
setstate FritzKeller 2024-01-19 19:04:38 mac_C4_5B_BE_54_9D_B7 PC-192-168-2-91 [landevice9221]
setstate FritzKeller 2024-01-19 19:04:38 mac_C4_5B_BE_54_DB_16 PC-192-168-2-50 [landevice9230]
setstate FritzKeller 2024-01-19 19:04:38 mac_DC_A6_32_7C_DF_92 PC-192-168-2-250 [landevice9225]
setstate FritzKeller 2024-01-19 19:04:38 mac_E8_68_E7_C5_57_1B PC-192-168-2-238 [landevice9239]
setstate FritzKeller 2024-01-19 19:04:38 mac_E8_68_E7_C5_78_02 PC-192-168-2-241 [landevice9234]
setstate FritzKeller 2024-01-19 19:04:38 mac_E8_DB_84_D3_0D_FD PC-192-168-2-239 [landevice9227]
setstate FritzKeller 2024-01-19 19:04:38 mac_E8_DB_84_DC_CE_2B PC-192-168-2-71 [landevice9226]
setstate FritzKeller 2024-01-19 19:04:38 mac_E8_DB_84_DD_64_6A PC-192-168-2-75 [landevice9223]
setstate FritzKeller 2024-01-19 19:04:38 retStat_lastReadout 511 values captured in 3.31 s
setstate FritzKeller 2024-01-19 19:04:38 state WLAN: on gWLAN: on
JoWiemann
Hallo Norbert,
das ist immer noch die aktuelle, bei Dir fehlerhafte Version des Moduls:
VERSION    07.57.02
Grüße Jörg
Jörg Wiemann
Nobbynews
Zitat von: JoWiemann am 19 Januar 2024, 19:10:26das ist immer noch die aktuelle, bei Dir fehlerhafte Version des Moduls:
VERSION    07.57.02
Also version FRITZBOX liefert mir hier:
72_FRITZBOX.pm 28226 2023-11-29 08:36:23Z jowiemannWo das 7.57.02 her kommt, ist mir ein Rätsel.
Evtl. aus dem device der Fritzbox?
JoWiemann
Zitat von: Nobbynews am 19 Januar 2024, 19:16:19Wo das 7.57.02 her kommt, ist mir ein Rätsel.
Hallo Norbert,
kommt aus dem Sourcecode. Wird allerdings nur erneuert, wenn Fhem neu gestartet wird.
Grüße Jörg
Jörg Wiemann
Nobbynews
Grrrr, hatte nur ein reload gemacht. Sorry.
Jetzt:
#   APICHECKED 1
#   DEBUGLOG   OFF
#   DEF        192.168.2.164
#   FVERSION   72_FRITZBOX.pm:0.282260/2023-11-29
#   INTERVAL   300
#   LUADATA    1
#   LUAQUERY   1
#   MODEL      FRITZ!WLAN Repeater 450E
#   NAME       FritzKeller
#   NR         1158
#   SECPORT    49443
#   TIMEOUT    55
#   TR064      1
#   TYPE       FRITZBOX
#   UPNP       non-emu
#   VERSION    07.57.01
#   _BETA      0
#   eventCount 2
#   READINGS:
#     2024-01-19 19:22:22   box_cpuTemp     0
#     2024-01-19 19:22:22   box_fwVersion   128.07.15
#     2024-01-19 19:22:22   box_guestWlan   on
#     2024-01-19 19:22:22   box_guestWlanCount 0
#     2024-01-19 19:22:22   box_guestWlanRemain -1
#     2024-01-19 19:22:22   box_macFilter_active off
#     2024-01-19 19:21:18   box_model       FRITZ!WLAN Repeater 450E [avm]
#     2024-01-19 19:22:22   box_powerRate   73
#     2024-01-19 19:22:22   box_tr064       on
#     2024-01-19 19:22:22   box_tr069       off
#     2024-01-19 19:22:22   box_upnp        non-emu
#     2024-01-19 19:22:22   box_upnp_control_activated non-emu
#     2024-01-19 19:22:22   box_uptime      11025240 sec = 127T 14:34:00
#     2024-01-19 19:22:22   box_wlan_2.4GHz on
#     2024-01-19 19:22:22   box_wlan_5GHz   off
#     2024-01-19 19:22:22   box_wlan_Count  4
#     2024-01-19 19:22:22   mac_00_11_05_FD_40_BA PC-192-168-2-199 [landevice9218]
#     2024-01-19 19:22:22   mac_30_F9_ED_8E_29_B5 PC-192-168-2-131 [landevice9262]
#     2024-01-19 19:22:22   mac_3C_61_05_EF_63_1B PC-192-168-2-243 [landevice9233]
#     2024-01-19 19:22:22   mac_3E_10_D5_96_7D_D0 PC-192-168-2-163 [landevice9232]
#     2024-01-19 19:22:22   mac_3E_10_D5_98_E2_1F PC-192-168-2-162 [landevice9228]
#     2024-01-19 19:22:22   mac_40_91_51_44_47_D3 PC-192-168-2-218 [landevice9219]
#     2024-01-19 19:22:22   mac_48_3F_DA_0C_BA_81 PC-192-168-2-69 [landevice9285]
#     2024-01-19 19:22:22   mac_48_55_19_03_59_E3 PC-192-168-2-246 [landevice9231]
#     2024-01-19 19:22:22   mac_48_55_19_17_95_D6 inactive
#     2024-01-19 19:22:22   mac_48_55_19_18_57_76 PC-192-168-2-51 [landevice9256]
#     2024-01-19 19:22:22   mac_50_02_91_4E_74_83 PC-192-168-2-224 [landevice9206] (WLAN: 54 / 51 Mbit/s, RSSI: -57)
#     2024-01-19 19:22:22   mac_5C_49_79_C9_6C_BE Repeater-Keller [landevice9217]
#     2024-01-19 19:22:22   mac_60_6D_3C_19_C9_90 PC-192-168-2-80 [landevice9224]
#     2024-01-19 19:22:22   mac_68_D7_9A_13_E7_3D PC-192-168-2-78 [landevice9294]
#     2024-01-19 19:22:22   mac_74_42_7F_33_5D_31 PC-192-168-2-1 [landevice9163] (203 Mbit/s)
#     2024-01-19 19:22:22   mac_7C_9E_BD_61_12_DC PC-192-168-2-85 [landevice9209] (WLAN: 53 / 32 Mbit/s, RSSI: -56)
#     2024-01-19 19:22:22   mac_80_7D_3A_02_14_45 PC-192-168-2-236 [landevice9214] (WLAN: 71 / 52 Mbit/s, RSSI: -62)
#     2024-01-19 19:22:22   mac_94_DB_56_98_7F_A9 PC-192-168-2-81 [landevice9220]
#     2024-01-19 19:22:22   mac_98_CD_AC_2D_B7_87 PC-192-168-2-229 [landevice9238]
#     2024-01-19 19:22:22   mac_A4_E5_7C_02_AE_70 PC-192-168-2-219 [landevice9237]
#     2024-01-19 19:22:22   mac_B6_F2_08_84_DC_F5 PC-192-168-2-160 [landevice9236]
#     2024-01-19 19:22:22   mac_B8_27_EB_5E_3A_B0 PC-192-168-2-182 [landevice9229]
#     2024-01-19 19:22:22   mac_B8_27_EB_77_F5_16 PC-192-168-2-198 [landevice9235]
#     2024-01-19 19:22:22   mac_B8_27_EB_D8_F8_A9 PC-192-168-2-207 [landevice9204] (WLAN: 71 / 71 Mbit/s, RSSI: -60)
#     2024-01-19 19:22:22   mac_BC_FF_4D_5B_41_E8 PC-192-168-2-247 [landevice9240]
#     2024-01-19 19:22:22   mac_C2_39_6F_7F_D2_58 PC-192-168-2-161 [landevice9222]
#     2024-01-19 19:22:22   mac_C4_5B_BE_54_9D_B7 PC-192-168-2-91 [landevice9221]
#     2024-01-19 19:22:22   mac_C4_5B_BE_54_DB_16 PC-192-168-2-50 [landevice9230]
#     2024-01-19 19:22:22   mac_C6_37_94_90_5A_E0 PC-192-168-2-44 [landevice9374]
#     2024-01-19 19:22:22   mac_E8_68_E7_C5_57_1B PC-192-168-2-238 [landevice9239]
#     2024-01-19 19:22:22   mac_E8_68_E7_C5_78_02 PC-192-168-2-241 [landevice9234]
#     2024-01-19 19:22:22   mac_E8_DB_84_D3_0D_FD PC-192-168-2-239 [landevice9227]
#     2024-01-19 19:22:22   mac_E8_DB_84_DC_CE_2B PC-192-168-2-71 [landevice9226]
#     2024-01-19 19:22:22   mac_E8_DB_84_DD_64_6A PC-192-168-2-75 [landevice9223]
#     2024-01-19 19:22:22   retStat_lastReadout 511 values captured in 2.13 s
#     2024-01-19 19:22:22   state           WLAN: on gWLAN: on
#   fhem:
#     LOCAL      0
#     is_double_wlan 0
#     lastHour   0
#     modulVersion $Date: 2023-11-29 09:36:23 +0100 (Wed, 29 Nov 2023) $
#     radioCount 0
#     sid        3d5334b3bdf2ad28
#     sidTime    1705688494.4454
#     landevice:
#       48_3F_DA_0C_BA_81 landevice9285
#       C6_37_94_90_5A_E0 landevice9374
#     wlanDevice:
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -57
#         speed      54
#         speed_rx   51
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -57
#         speed      199
#         speed_rx   1
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -56
#         speed      53
#         speed_rx   32
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -62
#         speed      71
#         speed_rx   52
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       -60
#         speed      71
#         speed_rx   71
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#         rssi       0
#         speed      0
#         speed_rx   0
#   helper:
#     FhemLog3Std 0
#     logDebug
setstate FritzKeller 2024-01-19 19:22:22 box_cpuTemp 0
setstate FritzKeller 2024-01-19 19:22:22 box_fwVersion 128.07.15
setstate FritzKeller 2024-01-19 19:22:22 box_guestWlan on
setstate FritzKeller 2024-01-19 19:22:22 box_guestWlanCount 0
setstate FritzKeller 2024-01-19 19:22:22 box_guestWlanRemain -1
setstate FritzKeller 2024-01-19 19:22:22 box_macFilter_active off
setstate FritzKeller 2024-01-19 19:21:18 box_model FRITZ!WLAN Repeater 450E [avm]
setstate FritzKeller 2024-01-19 19:22:22 box_powerRate 73
setstate FritzKeller 2024-01-19 19:22:22 box_tr064 on
setstate FritzKeller 2024-01-19 19:22:22 box_tr069 off
setstate FritzKeller 2024-01-19 19:22:22 box_upnp non-emu
setstate FritzKeller 2024-01-19 19:22:22 box_upnp_control_activated non-emu
setstate FritzKeller 2024-01-19 19:22:22 box_uptime 11025240 sec = 127T 14:34:00
setstate FritzKeller 2024-01-19 19:22:22 box_wlan_2.4GHz on
setstate FritzKeller 2024-01-19 19:22:22 box_wlan_5GHz off
setstate FritzKeller 2024-01-19 19:22:22 box_wlan_Count 4
setstate FritzKeller 2024-01-19 19:22:22 mac_00_11_05_FD_40_BA PC-192-168-2-199 [landevice9218]
setstate FritzKeller 2024-01-19 19:22:22 mac_30_F9_ED_8E_29_B5 PC-192-168-2-131 [landevice9262]
setstate FritzKeller 2024-01-19 19:22:22 mac_3C_61_05_EF_63_1B PC-192-168-2-243 [landevice9233]
setstate FritzKeller 2024-01-19 19:22:22 mac_3E_10_D5_96_7D_D0 PC-192-168-2-163 [landevice9232]
setstate FritzKeller 2024-01-19 19:22:22 mac_3E_10_D5_98_E2_1F PC-192-168-2-162 [landevice9228]
setstate FritzKeller 2024-01-19 19:22:22 mac_40_91_51_44_47_D3 PC-192-168-2-218 [landevice9219]
setstate FritzKeller 2024-01-19 19:22:22 mac_48_3F_DA_0C_BA_81 PC-192-168-2-69 [landevice9285]
setstate FritzKeller 2024-01-19 19:22:22 mac_48_55_19_03_59_E3 PC-192-168-2-246 [landevice9231]
setstate FritzKeller 2024-01-19 19:22:22 mac_48_55_19_17_95_D6 inactive
setstate FritzKeller 2024-01-19 19:22:22 mac_48_55_19_18_57_76 PC-192-168-2-51 [landevice9256]
setstate FritzKeller 2024-01-19 19:22:22 mac_50_02_91_4E_74_83 PC-192-168-2-224 [landevice9206] (WLAN: 54 / 51 Mbit/s, RSSI: -57)
setstate FritzKeller 2024-01-19 19:22:22 mac_5C_49_79_C9_6C_BE Repeater-Keller [landevice9217]
setstate FritzKeller 2024-01-19 19:22:22 mac_60_6D_3C_19_C9_90 PC-192-168-2-80 [landevice9224]
setstate FritzKeller 2024-01-19 19:22:22 mac_68_D7_9A_13_E7_3D PC-192-168-2-78 [landevice9294]
setstate FritzKeller 2024-01-19 19:22:22 mac_74_42_7F_33_5D_31 PC-192-168-2-1 [landevice9163] (203 Mbit/s)
setstate FritzKeller 2024-01-19 19:22:22 mac_7C_9E_BD_61_12_DC PC-192-168-2-85 [landevice9209] (WLAN: 53 / 32 Mbit/s, RSSI: -56)
setstate FritzKeller 2024-01-19 19:22:22 mac_80_7D_3A_02_14_45 PC-192-168-2-236 [landevice9214] (WLAN: 71 / 52 Mbit/s, RSSI: -62)
setstate FritzKeller 2024-01-19 19:22:22 mac_94_DB_56_98_7F_A9 PC-192-168-2-81 [landevice9220]
setstate FritzKeller 2024-01-19 19:22:22 mac_98_CD_AC_2D_B7_87 PC-192-168-2-229 [landevice9238]
setstate FritzKeller 2024-01-19 19:22:22 mac_A4_E5_7C_02_AE_70 PC-192-168-2-219 [landevice9237]
setstate FritzKeller 2024-01-19 19:22:22 mac_B6_F2_08_84_DC_F5 PC-192-168-2-160 [landevice9236]
setstate FritzKeller 2024-01-19 19:22:22 mac_B8_27_EB_5E_3A_B0 PC-192-168-2-182 [landevice9229]
setstate FritzKeller 2024-01-19 19:22:22 mac_B8_27_EB_77_F5_16 PC-192-168-2-198 [landevice9235]
setstate FritzKeller 2024-01-19 19:22:22 mac_B8_27_EB_D8_F8_A9 PC-192-168-2-207 [landevice9204] (WLAN: 71 / 71 Mbit/s, RSSI: -60)
setstate FritzKeller 2024-01-19 19:22:22 mac_BC_FF_4D_5B_41_E8 PC-192-168-2-247 [landevice9240]
setstate FritzKeller 2024-01-19 19:22:22 mac_C2_39_6F_7F_D2_58 PC-192-168-2-161 [landevice9222]
setstate FritzKeller 2024-01-19 19:22:22 mac_C4_5B_BE_54_9D_B7 PC-192-168-2-91 [landevice9221]
setstate FritzKeller 2024-01-19 19:22:22 mac_C4_5B_BE_54_DB_16 PC-192-168-2-50 [landevice9230]
setstate FritzKeller 2024-01-19 19:22:22 mac_C6_37_94_90_5A_E0 PC-192-168-2-44 [landevice9374]
setstate FritzKeller 2024-01-19 19:22:22 mac_E8_68_E7_C5_57_1B PC-192-168-2-238 [landevice9239]
setstate FritzKeller 2024-01-19 19:22:22 mac_E8_68_E7_C5_78_02 PC-192-168-2-241 [landevice9234]
setstate FritzKeller 2024-01-19 19:22:22 mac_E8_DB_84_D3_0D_FD PC-192-168-2-239 [landevice9227]
setstate FritzKeller 2024-01-19 19:22:22 mac_E8_DB_84_DC_CE_2B PC-192-168-2-71 [landevice9226]
setstate FritzKeller 2024-01-19 19:22:22 mac_E8_DB_84_DD_64_6A PC-192-168-2-75 [landevice9223]
setstate FritzKeller 2024-01-19 19:22:22 retStat_lastReadout 511 values captured in 2.13 s
setstate FritzKeller 2024-01-19 19:22:22 state WLAN: on gWLAN: on
JoWiemann
Hallo Norbert,
benutzt Du beim Repeater User / Passwort zur Anmeldung? Wenn ja, dann versuch bitte einmal die angehängte Version.
Grüße Jörg
Jörg Wiemann
Nobbynews
Hallo Jörg,
Zitat von: JoWiemann am 19 Januar 2024, 19:31:04benutzt Du beim Repeater User / Passwort zur Anmeldung? Wenn ja, dann versuch bitte einmal die angehängte Version
funktioniert leider nicht.
im STATE steht "NO attr boxUser set".
Das Attribut ist aber gesetzt, auch ein erneutes setzen des Attributs bringt keine Veränderung.
Bei der Fritzbox selbst scheint es zu funktionieren.
Aber auch bei den 2400er oder 1750er wird das angeblich fehlende Attribut angezeigt.
Norbert
