Javascript innerhalb von FHEM ausführen und das Ergebnis weitersenden?
Begonnen von andies, 25 Februar 2024, 19:10:38
andies
Ich habe eine Funktion, die ein Bild mit Javascript erzeugt. Der Code sieht in etwa so aus,
data <div id="eCharts_myChart" style="width: 800px;height:400px;"></div>
<script type="text/javascript">
var myChart_myChart = echarts.init(document.getElementById('eCharts_myChart'));
var option_myChart={"dataZoom":[{"end":"90","start":"30","type":"inside"},{"end":"90","start":"30"}],"toolbox":{"feature":{"saveAsImage":{}},"backgroundColor":"transparent","pixelRatio":2,"name":"Gartentor Raspberry Kerntemp"},"xAxis":{"name":"Zeit","type":"time"},"series":[{"markPoint":{"data":[{"type":"max","name":"Max"}],"itemStyle":{"color":"black"}},"name":"Kern","markLine":{"data":[{"type":"average","name":"Avg"}],"itemStyle":{"color":"black"}},"data":[["2024-02-24 20:03:50","44.5"],["2024-02-24 20:12:45","45.6"],["2024-02-24 20:13:18","47.2"],["2024-02-24 21:13:23","44.5"],["2024-02-24 22:13:25","43.5"],["2024-02-24 23:01:36","45.1"],["2024-02-24 23:58:30","45.6"],["2024-02-25 00:58:33","42.9"],["2024-02-25 01:58:36","42.4"],["2024-02-25 02:58:39","41.9"],["2024-02-25 03:58:42","40.8"],["2024-02-25 04:58:45","40.8"],["2024-02-25 05:58:49","40.8"],["2024-02-25 06:58:51","41.3"],["2024-02-25 07:58:54","40.8"],["2024-02-25 07:59:01","41.9"],["2024-02-25 08:29:29","45.1"],["2024-02-25 09:29:32","43.5"],["2024-02-25 10:29:50","47.8"],["2024-02-25 11:29:38","49.4"],["2024-02-25 11:49:14","52.6"],["2024-02-25 11:52:30","53.2"],["2024-02-25 12:42:57","53.2"],["2024-02-25 12:48:02","53.7"],["2024-02-25 12:51:29","57.5"],["2024-02-25 12:53:21","53.7"],["2024-02-25 13:53:24","52.6"],["2024-02-25 14:53:27","51.5"],["2024-02-25 15:10:22","53.7"],["2024-02-25 15:10:54","54.8"],["2024-02-25 16:10:57","49.4"],["2024-02-25 16:21:34","51.0"],["2024-02-25 16:22:59","54.2"],["2024-02-25 17:23:02","48.9"],["2024-02-25 18:23:05","46.2"]],"lineStyle":{"color":"black","width":2},"yAxisIndex":"0","symbol":"none","type":"line"}],"yAxis":[{"name":"rechts"},{"type":"value","axisLabel":{"formatter":"{value}"},"name":"Temperatur"}],"grid":{"show":"true"},"tooltip":{"axisPointer":{"type":"cross"},"trigger":"axis"},"title":{"text":"Gartentor Raspberry Kerntemp"}};myChart_myChart.setOption(option_myChart);
</script>
Sende ich den Code an FW_summaryFn (zum Beispiel), so wird ein Bild korrekt erzeugt. Ich möchte jetzt gern dieses Bild mit einem TelegramBot weitersenden. Mir ist nicht klar, wie ich diesen Code ausführen lassen kann und ihn damit zu einem png oder jpg transferiere und so in der Lage bin, ihn mit einem TelegramBot zu versenden.
Kann mir da jemand einen Tipp geben, wo ich weitersuchen kann?
FHEM 6.3 auf RaspPi4 (Raspbian:  6.6.28+; Perl: v5.36.0)
andies
Also ich sehe schon, meine Frage kapiert keiner. Noch ein Versuch.
FHEM hat einen eigenen Webserver. Wenn ich an den "Texte" sende, werden sie angezeigt. Das geschieht, wenn ich das richtig sehe, beispielsweise durch $<Modulname>_FwF und die Zuweisung my $data =. Sende ich beispielsweise ein Bild, das mit javascript erzeugt wird, zeigt der FHEM-Webserver es an.
Ich hoffe, ich habe das halbwegs richtig verstanden, dass das so abläuft.
Nun möchte ich gern diesen Webserver verwenden, um Bilder zu rendern. Dazu muss ich erstens wieder dieses javascript an den Server senden. Dann aber möchte ich, dass der Server nicht das Bild anzeigt, sondern es erzeugt und "an mich" (also eine Variable) zurücksendet, die ich dann weiterverarbeiten kann. ZB mit Telegram senden.
Leider stehe ich völlig auf dem Schlauch, wie das gehen könnte. Wäre nett, wenn mir hier jemand einen Tipp geben kann.
andies
Ich habe das mal hierhin verschoben, vielleicht ist das zu speziell für Anfänger?
#3
Zitat von: andies am 26 Februar 2024, 10:17:56Nun möchte ich gern diesen Webserver verwenden, um Bilder zu rendern. Dazu muss ich erstens wieder dieses javascript an den Server senden. Dann aber möchte ich, dass der Server nicht das Bild anzeigt, sondern es erzeugt und "an mich" (also eine Variable) zurücksendet
Sowas ist eigentlich nicht die Aufgabe des FHEM-internen Webservers.
Für solche Aufgaben gibt es eigene perl (und andere externe) libraries, die Du beispielsweise in Deiner 99_myUtils.pm verwenden kannst.
Ich geh mal Popcorn holen.
andies
Kannst du mir vorher einen Begriff geben, wo ich nachlesen kann?
(Ich zeige mich dann gern erkenntlich - salzig oder süß?)
Was Du tun möchtest, ist halt einfach kein FHEM-spezifisches Thema.
Du möchtest per JavaScript Code ein Bild erzeugen, das Ergebnis soll die Datenmenge sein, die das Bild repräsentiert. Du musst also eine Umgebung finden, die das tun kann.
Spontan fällt mir da beispielsweise Node.js ein.
Wikipedia sagt dazu:
ZitatNode.js ist eine plattformübergreifende Open-Source-JavaScript-Laufzeitumgebung, die JavaScript-Code außerhalb eines Webbrowsers ausführen kann.
Die erzeugte Datenmenge (das, was Du "in einer Variablen" nennst) kannst Du dann natürlich wieder in FHEM verwursten.
andies
OK, ich verstehe. Das wäre also unsystematisch und passt da nicht hinein.
Mein Problem ist jetzt, dass ich dann ein weiteres System installieren und auf dem aktuellen Stand halten müsste. Ich dachte mir, da der FHEM-Webserver die Grafiken sowieso rendert (sie werden ja angezeigt) und damit auch nicht überfordert ist, kann man den gleich fürs png-erstellen und weitersenden mit Telegram nehmen.
Aber ich sehe schon, da trifft mich die Wucht der Systematik und so werde ich nicht geholfen. Leider nachvollziehbar.
Zitat von: andies am 27 Februar 2024, 10:36:53Ich dachte mir, da der FHEM-Webserver die Grafiken sowieso rendert (sie werden ja angezeigt)
Genau hier liegt aber Dein grundsätzlicher Denkfehler.
Die Grafik wird nicht vom Webserver (egal welcher) gerendert, sondern erst in und von Deinem Browser, der den von der Webseite erhaltenen JavaScript-Code (!) ausführt.
andies
Ach so, der Browser rendert (ich dachte, FHEM macht server-side-Rendering). Ok, dann muss ich eine andere Lösung finden.
Danke, das wusste ich nicht. Wieder was gelernt.
Prof. Dr. Peter Henning
#9
Das muss nicht so sein. Zunächst einmal würde ich Grafiken niemals durch JavaScript erzeugen - das ist viel zu unflexibel.
Sehr viel besser geht das, indem man die Kommandozeilensteuerung des ImageMagick-Paketes aufruft. Es gibt also auf dem Server ein Shell-Script, das (z.B. von FHEM) mit entsprechenden Parametern aufgerufen wird und dann, voilà, eine PNG_Datei ausspuckt. Das habe ich 2016 in Kapitel 7 der SmartHome Hacks ausführlich dokumentiert und erläutert, unten habe ich eine Beispieldatei für die Erzeugung einer Datumsanzeige als Bild, sowie ein Bild mit Datumsanzeige und Balkendiagramm angehängt. Vor etlichen Jahren habe ich das benutzt, um die Anzeige meiner Verbrauchsdaten auf einem (ziemlich dummen) digitalen Bilderrahmen zu realisieren.
Inzwischen sind meine Wanddisplays (einigermaßen intelligente) Tablets, die Bilder werden daher im jeweiligen Browser gerendert. Das bedeutet, dass man den Server entlasten kann - er sendet einfach nur noch SVG-Daten, die in der jeweiligen Webseite eingebettet sind. Auch damit kann man tolle Diagramme machen, die dann eben einfach als SVG-Widgets definiert sind. Wie Anleitung dazu habe ich 2020 im Buch SmartHome mit FHEM veröffentlicht, auch dazu unten ein Bild.
Und wie das dann aussehen kann, z.B. mit einem Schemabild des Hauses und live eingeblendeten Temperaturen etc. sieht man auf dem letzten angehängten Screenshot.
pah
(Edit: In dem Screenshot vom Tablet ist mein Stromverbrauch derzeit Null, weil meine neue "Moderne Messeinrichtung" noch nicht richtig ausgelesen wird ...)
#10
Zitat von: Prof. Dr. Peter Henning am 29 Februar 2024, 10:11:32Das muss nicht so sein. Zunächst einmal würde ich Grafiken niemals durch JavaScript erzeugen - das ist viel zu unflexibel.
Natürlich nicht. Und Deine Ausführungen sind grundsätzlich auch alle richtig.
Wenn man aber den Hintergrund kennt, in dem die gestellte Frage aufgetaucht war, hilft Deine Antwort nicht viel weiter, weil sie am Thema und der eigentlichen Fragestellung vorbeigeht.
Es geht um die Integration von eCharts in FHEM. Und da ist es halt doch so, dass die "Bilder" im Browser gerendert werden.
(offtopic:
Die "Werbung" für Deine Bücher an jeder passenden und unpassenden Stelle fängt an, störend zu wirken.
Aber das ist natürlich nur mein ganz persönliches Empfinden)
Haengt davon ab, mit welcher Methode das Bild erstellt wurde:
- wenn es Canvas ist, dann kann man den Inhalt der Canvas per JavaScript dumpen (z.Bsp. canvas.toDataURL("image/jpeg", 0.7)), und das Ergebnis zu FHEM schicken.
- wenn es SVG ist, dann kann man dieses SVG zu FHEM schicken, was wiederum per externe Bibliothek in was "Telegram-Kompatibles" umgewandelt werden kann (siehe plotAsPng in 98_SVG.pm).
andies
Zitat von: rudolfkoenig am 29 Februar 2024, 13:47:50Haengt davon ab, mit welcher Methode das Bild erstellt wurde:
Leider wurde es in Javascript erzeugt bzw der Browser erzeugt das, nicht FHEM. Das hat mir betateilchen beigebracht. Insofern muss ich da Umwege gehen.
Ok, dann mit mehr Text:
Haengt davon ab, mit welcher im Browser implementierten Methode das Bild von der JavaScript Bibliothek eCharts erstellt wurde.
Laut https://echarts.apache.org/v4/en/api.html#echarts:
ZitatOptional chart configurations; which may contain:
renderer
Supports 'canvas' or 'svg'. See Render by Canvas or SVG.
ZitatDie "Werbung" für Deine Bücher an jeder passenden und unpassenden Stelle fängt an, störend zu wirken.
Die Bücher sind in allen zitierten Teilen kostenfrei zugänglich, also mach mal langsam.
pah
