[GELÖST] Daikin Altherma 3 R - Verbindungsfehler
Begonnen von Burny4600, 13 April 2024, 08:45:32
Burny4600
Ich habe eine Daikin Altherma 3 R Wärmepumpe mit FHEM Anbindung. Leider kommt es immer wieder vor, dass ich manuell das tokenSet ausführen muss um die Verbingung zu starten.
list Daikin_Master
   FUUID      645e744c-f33f-f4d2-3baa-3d5d9ef10d9cc191
   INTERVAL   60
   NAME       Daikin_Master
   NR         4853
   NTFY_ORDER 50-Daikin_Master
   STATE      no access-token
   TYPE       DaikinCloud
   VERSION    v1.3.6 - 20.06.2023
   eventCount 2696
     2024-04-08 22:40:04   0c62e0bd-722f-4e03-84ac-6c02b2d2e18c 0c62e0bd-722f-4e03-84ac-6c02b2d2e18c
     2024-04-08 21:41:41   expires_in      3600
     2024-04-05 19:35:12   login_status    login successful
     2024-04-08 22:41:06   state           no access-token
     2024-04-08 22:41:06   token_status    timeout error
     2024-04-08 21:41:41   token_type      Bearer
     2024-04-08 22:40:04   update_response successful
   helper:
     REFRESH_TOKEN xxxxxxxx.................
   alias      Daikin Master
   autocreate 1
   consumptionData 1
   devStateStyle style="text-align:left;;font-weight:bold;;"
   group      Daikin Cloud
   icon       sani_heating_heatpump
   interval   60
   room       _Daikin
get Daikin_Master tokenSet
list Daikin_Master
   INTERVAL   60
   NAME       Daikin_Master
   NR         4853
   STATE      polling activ
   TYPE       DaikinCloud
   eventCount 2720
     2024-04-13 08:44:03   0c62e0bd-722f-4e03-84ac-6c02b2d2e18c 0c62e0bd-722f-4e03-84ac-6c02b2d2e18c
     2024-04-13 08:38:01   expires_in      3600
     2024-04-13 08:38:01   login_status    login successful
     2024-04-13 08:44:02   state           polling activ
     2024-04-13 08:38:01   token_status    tokenset successfully stored
     2024-04-13 08:38:01   token_type      Bearer
     2024-04-13 08:44:03   update_response successful
   helper:
     ACCESS_TOKEN xxxxxxxx.................
   alias      Daikin Master
   autocreate 1
   consumptionData 1
   group      Daikin Cloud
   interval   60
   room       _Daikin
Liegt das am Modul?
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
FrankL
Jein. Offensichtlich gab es ein Verbindungsproblem zur Daikin-Cloud (reading token_status = timeout error). Daher konnte kein neuer Access-Token abgeholt werden. Bei der Modulversion v1.3.6 wird noch die Verbindung zum "alten" Cloudzugang genutzt. Dieser funktioniert ggf. nicht mehr zuverlässig.
Die aktuelle Modulversion ist mittlerweile auf den neuen Cloudzugang/neue API umgestellt. Nähere Infos unter Github und in diesem Thread.
PS: Du solltest den ACCESS_TOKEN und den REFRESH_TOKEN nie im Klartext posten! Sie sind der Schlüssel zu deinem Cloudzugang!
MfG Frank
Burny4600
Werde ich mir ansehen. Danke für die Info.
LG Chris
