72_FRITZBOX.pm ab Version 08.00.00
Begonnen von elektron-bbs, 09 Oktober 2024, 17:28:16
Christian S.
  AGENTTMOUT 50
  APICHECKED 0
  DEBUGLOG  OFF
  DEF        192.168.178.1
  FUUID      675de32d-f33f-48a9-9370-4bfb69363ffd4313
  HOST      192.168.178.1
  INTERVAL  300
  LUADATA    -1
  LUAQUERY  -1
  NAME      FritzBox
  NR        66
  NTFY_ORDER 50-FritzBox
  SID_RENEW_CNT 0
  SID_RENEW_ERR_CNT 0
  STATE      Error: Timeout when reading Fritz!Box data. 144 | BlockingStart
  TIMEOUT    55
  TR064      -1
  TYPE      FRITZBOX
  UPNP      -1
  VERSION    08.00.04
  WEBCONNECT 0
  eventCount 4480
  LuaQueryCmd:
    GSM_AcT:
      AttrVal    1
      active    1
      cmd        gsm:settings/AcT
    GSM_NetworkState:
      AttrVal    1
      active    1
      cmd        gsm:settings/NetworkState
    GSM_RSSI:
      AttrVal    1
      active    1
      cmd        gsm:settings/RSSI
    TodayBytesReceivedHigh:
      AttrVal    1
      active    1
      cmd        inetstat:status/Today/BytesReceivedHigh
    TodayBytesReceivedLow:
      AttrVal    1
      active    1
      cmd        inetstat:status/Today/BytesReceivedLow
    TodayBytesSentHigh:
      AttrVal    1
      active    1
      cmd        inetstat:status/Today/BytesSentHigh
    TodayBytesSentLow:
      AttrVal    1
      active    1
      cmd        inetstat:status/Today/BytesSentLow
    UMTS_enabled:
      AttrVal    1
      active    1
      cmd        umts:settings/enabled
    alarmClock:
      AttrVal    1
      active    1
      cmd        telcfg:settings/AlarmClock/list(Name,Active,Time,Number,Weekdays)
    box_cpuTemp:
      AttrVal    1
      active    1
      cmd        power:status/act_temperature
    box_dect:
      AttrVal    1
      active    1
      cmd        dect:settings/enabled
    box_fwUpdate:
      AttrVal    1
      active    1
      cmd        updatecheck:status/update_available_hint
    box_fwVersion:
      AttrVal    1
      active    1
      cmd        logic:status/nspver
    box_fwVersion_neu:
      AttrVal    1
      active    1
      cmd        uimodlogic:status/nspver
    box_guestWlan:
      AttrVal    1
      active    1
      cmd        wlan:settings/guest_ap_enabled
    box_guestWlanRemain:
      AttrVal    1
      active    1
      cmd        wlan:settings/guest_time_remain
    box_is_double_wlan:
      AttrVal    1
      active    1
      cmd        wlan:settings/feature_flags/DBDC
    box_macFilter_active:
      AttrVal    1
      active    1
      cmd        wlan:settings/is_macfilter_active
    box_moh:
      AttrVal    1
      active    1
      cmd        telcfg:settings/MOHType
    box_powerRate:
      AttrVal    1
      active    1
      cmd        power:status/rate_sumact
    box_stdDialPort:
      AttrVal    1
      active    1
      cmd        telcfg:settings/DialPort
    box_tr064:
      AttrVal    1
      active    1
      cmd        tr064:settings/enabled
    box_tr069:
      AttrVal    1
      active    1
      cmd        tr069:settings/enabled
    box_upnp:
      AttrVal    1
      active    1
      cmd        box:settings/upnp_activated
    box_upnpCtrl:
      AttrVal    1
      active    1
      cmd        box:settings/upnp_control_activated
    box_uptimeHours:
      AttrVal    1
      active    1
      cmd        uimodlogic:status/uptime_hours
    box_uptimeMinutes:
      AttrVal    1
      active    1
      cmd        uimodlogic:status/uptime_minutes
    box_wlan_24GHz:
      AttrVal    1
      active    1
      cmd        wlan:settings/ap_enabled
    box_wlan_5GHz:
      AttrVal    1
      active    1
      cmd        wlan:settings/ap_enabled_scnd
    dectUser:
      AttrVal    1
      active    1
      cmd        telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName,NoRingTime,RingAllowed,NoRingTimeFlags,NoRingWithNightSetting)
    diversity:
      AttrVal    1
      active    1
      cmd        telcfg:settings/Diversity/list(MSN,Active,Destination)
    dslStatGlobalIn:
      AttrVal    1
      active    1
      cmd        dslstatglobal:status/in
    dslStatGlobalOut:
      AttrVal    1
      active    1
      cmd        dslstatglobal:status/out
    fonPort:
      AttrVal    1
      active    1
      cmd        telcfg:settings/MSN/Port/list(Name,MSN)
    handset:
      AttrVal    1
      active    1
      cmd        dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)
    handsetCount:
      AttrVal    1
      active    1
      cmd        dect:settings/Handset/count
    init:
      AttrVal    1
      active    1
    lanDevice:
      AttrVal    1
      active    1
      cmd        landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID,static_dhcp)
    lanDeviceNew:
      AttrVal    1
      active    1
      cmd        landevice:settings/landevice/list(mac,ip,ethernet,guest,name,active,online,wlan,speed,UID)
    radio:
      AttrVal    1
      active    1
      cmd        configd:settings/WEBRADIO/list(Name)
    ringGender:
      AttrVal    1
      active    1
      cmd        telcfg:settings/VoiceRingtoneGender
    sip_info:
      AttrVal    1
      active    1
      cmd        sip:settings/sip/list(activated,displayname,connect)
    tam:
      AttrVal    1
      active    1
      cmd        tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)
    userProfil:
      AttrVal    1
      active    1
      cmd        user:settings/user/list(name,filter_profile_UID,this_month_time,today_time,type)
    userProfilNew:
      AttrVal    1
      active    1
      cmd        user:settings/user/list(name,type)
    userTicket:
      AttrVal    1
      active    1
      cmd        userticket:settings/ticket/list(id)
    vpn_info:
      AttrVal    1
      active    1
      cmd        vpn:settings/connection/list(remote_ip,activated,name,state,access_type,connected_since)
    wlanList:
      AttrVal    1
      active    1
      cmd        wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest,is_remote,is_repeater,is_ap)
    wlanListNew:
      AttrVal    1
      active    1
      cmd        wlan:settings/wlanlist/list(mac,speed,rssi)
    2024-12-14 21:23:16  box_fwVersion  154.08.00
    2024-12-14 21:23:16  box_model      FRITZ!Box 7590 (UI) [7590 - 1und1]
    2024-12-16 18:57:32  retStat_lastReadout Error: Timeout when reading Fritz!Box data. 144 | BlockingStart
    2024-12-14 21:23:16  retStat_processReadout 0.02 s
    2024-12-16 18:57:32  state          Error: Timeout when reading Fritz!Box data. 144 | BlockingStart
  fhem:
    LOCAL      0
    definedHost 192.168.178.1
    fwVersion  0
    fwVersionStr 0
    is_double_wlan -1
    sidErrCount 0
    sidNewCount 0
    sidTime    0
  helper:
    FhemLog3Std 0
    TimerCmd  FritzBox.Cmd
    TimerReadout FritzBox.Readout
    debugLog  FritzBox_debugLog
    logDebug
    timerInActive 0
  hmccu:
  boxUser    Home
  devStateIcon .*on.*off:WLAN_on_gWLAN_off .*on.*on.*:WLAN_on_gWLAN_on WLAN..off.*:WLAN_off
  fp_Erdgeschoss 294,958,0,FritzBox,
  group      FRITZBOX
  icon      it_router
  room      Telefon
  sortby    02
  verbose    2
FHEM auf NUC, CUL V3 868 MHz
DECT200 Steckdosen
MAX Heizungsthermostate, Wandthermostate, Fensterkontakte
Homematic
Netatmo
JoWiemann
Hallo Christian,
läuft Dein Fhem im Docker?
Grüße Jörg
Jörg Wiemann
JoWiemann
anbei ein neue Beta, in der lockLanDevice für Fritz!OS 8.xx wieder funktionieren sollte. Über Tests würde ich mich freuen.
Grüße Jörg
Jörg Wiemann
Christian S.
Hallo Jörg,
nein, Fhem läuft nicht im Docker.
Christian
DECT200 Steckdosen
Homematic
Netatmo
DonJuan
Moin Moin,
ich habe schon eine ganze Weile (über div. Updates hinweg) folgenden Fehler in meinem LOG:
set FB7590 guestWlan on: Process HASH(0x55cce661c8) is still running
Er tritt auf, wenn ich das Haus verlasse bzw. wenn ich nach Hause komme. Schuld ist wohl der eingebettet Code. Ich vermute, dass die beiden Set-Befehle zu schnell aufgerufen werden. Allerdings ist der Code schon sehr alt und hat so schonmal Fehlerfrei funktioniert.
Muss ich den Befehl ändern und dieses "wlanGuestParams" nutzen oder reicht es wenn ich eine Pause einfüge?
Sollte eine Pause ausreichen, bitte ich da um hilfe. Meine Versuche mit irgendwelchen sleep, wait und Zeitgeschichten hatten nicht den gewünschten Erfolg.
Gruss Dennis
([Bewohner] eq "absent" or [Bewohner] eq "gone")
(set FB7590 wlan off)
(set FB7590 guestWlan off)
(set dm800se shutdown)
DOELSE
(set FB7590 wlan on)
(set FB7590 guestWlan on)
juemuc
ich habe bei "set FB6690 guestWlan on" keine Einträge im Logfile.
Jürgen
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
juemuc
Hallo Jörg,
ich schalte meine DECT200 in der Nacht bei Geräuschen automatisch ein. Hierzu habe ich in der FB einen Zeitraum (s. Anhang) definiert. Siehst Du eine Möglichkeit diesen Zeitraum über FHEM zu beinflussen?
Jürgen
JoWiemann
Hallo Jürgen,
wird ein bisschen dauern.
Grüße Jörg
Jörg Wiemann
juemuc
Hallo Jörg,
kein Problem und vorab schon einmal vielen Dank fürs schauen.
Jürgen
DonJuan
#24
Jürgen
Tatsächlich erhalte ich in meinem Log auch keinen Eintrag, wenn ich den Befehl so ausführe. Aber wenn das "Script" läuft, dann schon. Es wird ja auch noch die eine Dreambox ausgeschaltet. Aber da sehe ich keinen Zusammenhang.
2024.12.30 19:28:20 2: AutoWLAN: set FB7590 guestWlan off: Process HASH(0x55a75f7270) is still running
2024.12.30 19:28:21 3: ENIGMA2 set dm800se shutdown
2024.12.30 19:28:21 2: AutoWLAN: set dm800se shutdown: Device needs to be ON to be set to standby mode.
2024.12.30 20:02:22 2: AutoWLAN: set FB7590 guestWlan on: Process HASH(0x55a74c43b0) is still running
Gruss Dennis
JoWiemann
anbei eine neue Beta, in der set <name> macFilter <on|off> für FritzOS >= 8 wieder funktionieren sollte.
Grüße Jörg
Jörg Wiemann
bertl
Zitat von: JoWiemann am 02 Dezember 2024, 20:14:45lockFilterProfile: ist blockierend. Kann ich bei Gelegenheit mal umstellen.
lockLandevice: Könnte ein Problem der 8.00 sein. Muss ich mir dann auch einmal ansehen.
Update. Unter 8.00 funktioniert der Befehl nicht mehr. Da muss ich mich schlau machen, was ich alles ändern muss.
Hallo Jörg,
bei lockLandevice dürfte das Problem Status 'undefined situation' mit der Version '08.00.06a_Beta' behoben sein.
Soweit ich das beurteilen kann, hast du bei der Lösung das on und off vertauscht.
Aktuell: on = unlimited, off = blocked
Sollte aber genau umgekehrt sein.
Kosmetik: Bei der Beschreibung sollte es 'FritzOS >= 8.00' (falsch 'FritzOS <= 8.00') heissen.
Gruß Robert
bertl
Zitat von: JoWiemann am 02 Dezember 2024, 20:14:45lockLandevice: Könnte ein Problem der 8.00 sein. Muss ich mir dann auch einmal ansehen.
Hallo Jörg,
nach weiteren Tests habe ich festgestellt, dass neben dem inversen on/off auch das Zugangsprofil falsch auf 'Standard' gesetzt wird.
Egal welches Zugangsprofil vorhanden war, ist nach einem on/off immer das 'Standard' Zugangsprofil gesetzt.
Bitte um Behebung der Fehler.
Danke, Robert
JoWiemann
#28
anbei eine neue Beta zum Testen:
- set <name> lockLandevice <number|mac> <on|off|rt|rtoff> -> Fehler behoben
neue Parameter für
set <name> smartHome ...
da die Verwaltung von AVM SmartHome Devices in Fhem im FritzBox Modul "fast" unmöglich ist, habe ich jetzt die Möglichkeit geschaffen die Einstellungen eines Device, aktuell erst einmal Steckdosen, in Fhem zu speichern. Somit kann man für eine Steckdose die Einstellungen in der FritzBox Oberfläche vornehmen und in Fhem ablegen. Es können mehrere Einstellungen für ein Device in Fhem abgelegt werden und über Fhem geladen werden.
set <name> smartHome <deviceID> preDefSave:nameEinstellung speichert die Einstellungen für das Device unter dem angegeben Namen.
set <name> smartHome <deviceID> preDefLoad:[deviceID_load:]nameEinstellung -> lädt eine gespeicherte Einstellung in die Fritzbox. Wird [deviceID_load:] angegeben, so wird die gespeicherte Einstellung eines anderen funktional identischen Device in die Fritzbox geladen.
set <name> smartHome <deviceID> preDefShow:nameEinstellung -> zeigt den Inhalt der Einstellung
set <name> smartHome <deviceID> preDefShow -> zeigt alle für das Device gespeicherten Einstellungen
set <name> smartHome preDefShow -> zeigte alle vorhanden Einstellungen. Diese Auflistung wird auch bei get <name> luaInfo smartHome mit angezeigt.
Sofern das Feature auf Interesse stößt und ggf. Macken beseitigt sind würde ich das um die Heizkörperthermostate erweitern.
PS: Im Moment werden nur die Einstellungen des Reiters: Automatisch Schalten berücksichtigt.
Grüße Jörg
Jörg Wiemann
bertl
Zitat von: JoWiemann am 16 Januar 2025, 10:15:42- set <name> lockLandevice <number|mac> <on|off|rt|rtoff> -> Fehler behoben
Hallo Jörg,
aus meiner Sicht funktioniert die Funktion 'lockLandevice' jetzt wie sie soll.
Danke, Robert
