Modul für Ecoflow-Komponenten (über HTTP-REST)
Begonnen von Neolux, 17 Februar 2025, 13:10:08
dergolem
hier estmal die Variablen:
"STREAM MAX" => {
"Adjustments" => {},
"Gets" => {
"relay2Onoff" => "",
"backupReverseSoc" => "",
"energyStrategyOperateMode.operateSelfPoweredOpen" => "",
"energyStrategyOperateMode.operateIntelligentScheduleModeOpen" => "",
"feedGridMode" => "",
"Sets" => {
"cfgRelay2Onoff" => ":true,false",
"cfgBackupReverseSoc"=> ":slider,3,1,95",
"cfgEnergyStrategyOperateMode.operateSelfPoweredOpen" => ":true",
"cfgEnergyStrategyOperateMode.operateIntelligentScheduleModeOpen" => ":true",
"cfgFeedGridMode" => ":1,2",
"SetCmdCodes" => {
    "cfgRelay2Onoff" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "needAck" => "true", "dest" => 2, "params.cfgRelay2Onoff" => "a[2]"},
"cfgBackupReverseSoc" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgBackupReverseSoc" => "a[2]" },
"cfgEnergyStrategyOperateMode.operateSelfPoweredOpen" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgEnergyStrategyOperateMode.operateSelfPoweredOpen" => "a[2]"},
"cfgEnergyStrategyOperateMode.operateIntelligentScheduleModeOpen" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgEnergyStrategyOperateMode.operateIntelligentScheduleModeOpen" => "a[2]"},
"cfgFeedGridMode" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgFeedGridMode" => "a[2]"},
klar, die Perl-Module sind installiert.
dergolem
#121
und hier nochmal ein Längerern Auszug aus der Logdatei:
2026.01.09 10:47:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirDest
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdId
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = needAck
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirSrc
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdFunc
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = params.cfgBackupReverseSoc
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $str_value = a[2]
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dest
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = PUT
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=713898 $timestamp=1767952080224
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKXXXXXXXXXXXXX", "params": {"cfgBackupReverseSoc": "34"}}
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true¶ms.cfgBackupReverseSoc=34&sn=BKXXXXXXXXXXXXX&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=713898×tamp=1767952080224
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"8524","message":"cfgBackupReverseSoc validator error","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:00 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"8524","message":"cfgBackupReverseSoc validator error","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:00 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = GET
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=84976 $timestamp=1767952085420
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/list $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=84976×tamp=1767952085420
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=88113 $timestamp=1767952085422
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=88113×tamp=1767952085422
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX
2026.01.09 10:48:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/list
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":[{"sn":"BKXXXXXXXXXXXXX","deviceName":"STREAM Max-7155gol","online":1}],"eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): code = 0
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_deviceName = STREAM Max-7155gol
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_online = 1
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn = BKXXXXXXXXXXXXX
2026.01.09 10:48:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn : Comparing SerialNo BKXXXXXXXXXXXXX
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $base = data_1
2026.01.09 10:48:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): STREAM Max-7155gol
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): eagleEyeTraceId =
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): message = Success
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): tid =
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dest
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = params.cfgRelay2Onoff
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $str_value = a[2]
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdFunc
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = needAck
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirSrc
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdId
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirDest
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = PUT
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=564982 $timestamp=1767952090441
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKXXXXXXXXXXXXX", "params": {"cfgRelay2Onoff": "false"}}
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true¶ms.cfgRelay2Onoff=false&sn=BKXXXXXXXXXXXXX&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=564982×tamp=1767952090441
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"8524","message":"Validation failed, Please check your param: cfgRelay2Onoff","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:10 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"8524","message":"Validation failed, Please check your param: cfgRelay2Onoff","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:10 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = params.cfgFeedGridMode
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $str_value = a[2]
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirDest
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdFunc
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdId
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = needAck
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dest
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirSrc
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = PUT
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=985369 $timestamp=1767952103448
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKXXXXXXXXXXXXX", "params": {"cfgFeedGridMode": "2"}}
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true¶ms.cfgFeedGridMode=2&sn=BKXXXXXXXXXXXXX&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=985369×tamp=1767952103448
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"8524","message":"Validation failed, Please check your param: cfgFeedGridMode","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:23 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"8524","message":"Validation failed, Please check your param: cfgFeedGridMode","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:23 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = GET
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=816752 $timestamp=1767952145429
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/list $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=816752×tamp=1767952145429
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=143763 $timestamp=1767952145431
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=143763×tamp=1767952145431
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/list
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":[{"sn":"BKXXXXXXXXXXXXX","deviceName":"STREAM Max-7155gol","online":1}],"eagleEyeTraceId":"","tid":""}
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): code = 0
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_deviceName = STREAM Max-7155gol
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_online = 1
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn = BKXXXXXXXXXXXXX
2026.01.09 10:49:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn : Comparing SerialNo BKXXXXXXXXXXXXX
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $base = data_1
2026.01.09 10:49:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): STREAM Max-7155gol
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): eagleEyeTraceId =
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): message = Success
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): tid =
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX
2026.01.09 10:49:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
KölnSolar
Erste Auffälligkeit: wo sind Deine GetCmdCodes ?
Du testet immer mit sets. Das ist komplizierter.
dergolem
sorry am WE ist immer schlecht mit antworten.
Die Get hab ich noch nicht gemacht, ich dachte erstmal die SetCmd zum laufen bringen und dann weitermachen. Ich werde die Montag fertig machen.
Gruß Denis
dergolem
So die Get sind drinn:
hier der Code für Stream MAX
"STREAM MAX" => {
"Gets" => {
"Sets" => {
"GetCmdCodes" => {
"relay2Onoff" =>                                           { "params.quotas" => {"relay2Onoff" => "",} },
"backupReverseSoc" =>                                       { "params.quotas" => {"backupReverseSoc" => ""},  },
"energyStrategyOperateMode.operateSelfPoweredOpen" =>       { "params.quotas" => {"energyStrategyOperateMode.operateSelfPoweredOpen" => ""} },
"energyStrategyOperateMode.operateIntelligentScheduleModeOpen" => { "params.quotas" => {"energyStrategyOperateMode.operateIntelligentScheduleModeOpen" => ""} },
"feedGridMode" =>                                       { "params.quotas" => {"feedGridMode" => ""} },
"SetCmdCodes" => {
Gurß Denis
hier der Auszug aus dem Log:
2026.01.12 07:07:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): cmd = relay2Onoff
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax has GetCmdCodes
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): $key = params.quotas
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): $str_value =
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = POST
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=553634 $timestamp=1768198064501
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"sn": "BKXXXXXXXXXXXXX", "params": {"quotas":["relay2Onoff"]}}
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = params.quotas[0]=relay2Onoff&sn=BKXXXXXXXXXXXXX&accessKey=XXXXXXXXXXXXXXXXXXXXXXXXXX&nonce=553634×tamp=1768198064501
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.12 07:07:44 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":{"relay2Onoff":true},"eagleEyeTraceId":"","tid":""}
2026.01.12 07:07:44 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = GET
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=376545 $timestamp=1768198072616
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/list $query_str = accessKey=XXXXXXXXXXXXXXXXXXXXXXXXXX&nonce=376545×tamp=1768198072616
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=754027 $timestamp=1768198072619
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX $query_str = accessKey=XXXXXXXXXXXXXXXXXXXXXXXXXX&nonce=754027×tamp=1768198072619
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/list
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":[{"sn":"BKXXXXXXXXXXXXX","deviceName":"STREAM Max-7155gol","online":1}],"eagleEyeTraceId":"","tid":""}
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): code = 0
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_deviceName = STREAM Max-7155gol
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_online = 1
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn = BKXXXXXXXXXXXXX
2026.01.12 07:07:52 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn : Comparing SerialNo BKXXXXXXXXXXXXX
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $base = data_1
2026.01.12 07:07:52 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): STREAM Max-7155gol
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): eagleEyeTraceId =
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): message = Success
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): tid =
2026.01.12 07:07:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX
2026.01.12 07:07:52 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): cmd = feedGridMode
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax has GetCmdCodes
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): $key = params.quotas
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): $str_value =
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = POST
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=981418 $timestamp=1768198080985
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"sn": "BKXXXXXXXXXXXXX", "params": {"quotas":["feedGridMode"]}}
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = params.quotas[0]=feedGridMode&sn=BKXXXXXXXXXXXXX&accessKey=XXXXXXXXXXXXXXXXXXXXXXXXXX&nonce=981418×tamp=1768198080985
2026.01.12 07:08:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2026.01.12 07:08:01 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.12 07:08:01 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":{"feedGridMode":2},"eagleEyeTraceId":"","tid":""}
2026.01.12 07:08:01 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): cmd = energyStrategyOperateMode.operateSelfPoweredOpen
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax has GetCmdCodes
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): $key = params.quotas
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): $str_value =
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = POST
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=763286 $timestamp=1768198087133
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"sn": "BKXXXXXXXXXXXXX", "params": {"quotas":["energyStrategyOperateMode.operateSelfPoweredOpen"]}}
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = params.quotas[0]=energyStrategyOperateMode.operateSelfPoweredOpen&sn=BKXXXXXXXXXXXXX&accessKey=XXXXXXXXXXXXXXXXXXXXXXXXXX&nonce=763286×tamp=1768198087133
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.12 07:08:07 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":{"energyStrategyOperateMode.operateSelfPoweredOpen":true},"eagleEyeTraceId":"","tid":""}
2026.01.12 07:08:07 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
KölnSolar
Na wer sagt es denn: Success  8)
Also klappt der generelle Zugriff.
Bleiben die sets. Guck als 1. mal nach dem xtamp. Evtl. versehentlich timestamp im Code überschrieben ?
dergolem
Nein das wort xtamp ist nicht im Code vorhanden. Da wo timestamp stehen soll ist es auch immer vorhanden.
Ich habe die Datei mal im jetzigen Zustand amgehängt.
KölnSolar
#127
Deine Version liefert bei mir kein xstamp. :o
Shutdown Restart gemacht ? wie hast Du URL::Encode installiert ? Bei welcher Hardware/OS Konstellation ?
Edit: nimm bitte mal meine Version, denn Deine verursachte bei mir andere Probleme.
Ich habe Deine Daten für Stream max übernommen. Nicht aber die "model detection". Knut hat das Attribut testmodel eingebaut. Wenn Du das mit STREAM MAX anlegst, sollte es auch funktionieren.
dergolem
die Hardware wird jetzt nicht mehr erkannt. Da er immernoch das Problem mit dem Xtamp hat werde ich die Perl Module alle noch mal mit einem Update versehen. Wenn ich noch die nötige Zeit habe werde ich das gesammte system updaten.
Ich habe einen Odroid HC2 mit DietPi v9.xy Shutdown Restart habe ich schon mehrfach gemacht.
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model =
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): cmd = devices
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = GET
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=124528 $timestamp=1768282049382
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/list $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&nonce=124528×tamp=1768282049382
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/list
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":[{"sn":"BKxxxxxxxxxxxxxx","deviceName":"STREAM Max-7155gol","online":1}],"eagleEyeTraceId":"","tid":""}
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): code = 0
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_deviceName = STREAM Max-7155gol
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_online = 1
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn = BKxxxxxxxxxxxxxx
2026.01.13 06:27:29 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn : Comparing SerialNo BKxxxxxxxxxxxxxx
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $base = data_1
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): eagleEyeTraceId =
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): message = Success
2026.01.13 06:27:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): tid =
KölnSolar
ZitatOdroid HC2 mit DietPi v9.xy
Da bin ich raus.
Attribut hattest Du gesetzt ? Was steht im Internal Model ?
dergolem
ich habe das mit dem attr testModel versucht, das Funktioniert. Ich habe aber noch keine Lösung für:
"&needAck=truems.cfgRelay2Onoff=false"
und "xtamp" gefunden. Ein Update des Moduls URL::Encode habe ich gemacht. Das hat nicht geholfen.
Gruß Denis
MasterRay
Zitat von: dergolem am 14 Januar 2026, 06:58:12... "xtamp" gefunden...
Gruß Denis
"xtamp" habe ich auch in der Antwort
...&nonce=61356×tamp=17... und es macht keine Probleme.
phantom
HI,
gibt es schon einen Fortschritt für Ecoflow STREAM Module? Insbesondere wie aktiviert man die Set-Funktionen?
